RTEMS  5.1
rtems_bdbuf_cache Struct Reference
rtems_id swapout
bool swapout_enabled
rtems_chain_control swapout_free_workers
rtems_bdbuf_buffer * bds
void * buffers
size_t buffer_min_count
size_t max_bds_per_group
uint32_t flags
rtems_mutex lock
rtems_mutex sync_lock
bool sync_active
rtems_id sync_requester
rtems_disk_device * sync_device
rtems_bdbuf_buffer * tree
rtems_chain_control lru
rtems_chain_control modified
rtems_chain_control sync
rtems_bdbuf_waiters access_waiters
rtems_bdbuf_waiters transfer_waiters
rtems_bdbuf_waiters buffer_waiters
rtems_bdbuf_swapout_transfer * swapout_transfer
rtems_bdbuf_swapout_worker * swapout_workers
size_t group_count
rtems_bdbuf_group * groups
rtems_id read_ahead_task
rtems_chain_control read_ahead_chain
bool read_ahead_enabled
rtems_status_code init_status
pthread_once_t once
The BD buffer cache.
Field Documentation
◆ access_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::access_waiters
Wait for a buffer in ACCESS_CACHED, ACCESS_MODIFIED or ACCESS_EMPTY state.
◆ bds
rtems_bdbuf_buffer* rtems_bdbuf_cache::bds
Pointer to table of buffer descriptors.
◆ buffer_min_count
size_t rtems_bdbuf_cache::buffer_min_count
Number of minimum size buffers that fit the buffer memory.
◆ buffer_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::buffer_waiters
Wait for a buffer and no one is available.
◆ buffers
void* rtems_bdbuf_cache::buffers
The buffer's memory.
◆ flags
uint32_t rtems_bdbuf_cache::flags
Configuration flags.
◆ group_count
size_t rtems_bdbuf_cache::group_count
The number of groups.
◆ groups
rtems_bdbuf_group* rtems_bdbuf_cache::groups
The groups.
◆ init_status
rtems_status_code rtems_bdbuf_cache::init_status
The initialization status
◆ lock
rtems_mutex rtems_bdbuf_cache::lock
The cache lock. It locks all cache data, BD and lists.
◆ lru
rtems_chain_control rtems_bdbuf_cache::lru
Least recently used list
◆ max_bds_per_group
size_t rtems_bdbuf_cache::max_bds_per_group
The number of BDs of minimum buffer size that fit in a group.
◆ modified
rtems_chain_control rtems_bdbuf_cache::modified
Modified buffers list
◆ read_ahead_chain
rtems_chain_control rtems_bdbuf_cache::read_ahead_chain
Read-ahead request chain
◆ read_ahead_enabled
bool rtems_bdbuf_cache::read_ahead_enabled
Read-ahead enabled
◆ read_ahead_task
rtems_id rtems_bdbuf_cache::read_ahead_task
Read-ahead task
◆ swapout
rtems_id rtems_bdbuf_cache::swapout
Swapout task ID
◆ swapout_enabled
bool rtems_bdbuf_cache::swapout_enabled
Swapout is only running if enabled. Set to false to kill the swap out task. It deletes itself.
◆ swapout_free_workers
rtems_chain_control rtems_bdbuf_cache::swapout_free_workers
The work threads for the swapout task.
◆ sync
rtems_chain_control rtems_bdbuf_cache::sync
Buffers to sync list
◆ sync_active
bool rtems_bdbuf_cache::sync_active
True if a sync is active.
◆ sync_device
rtems_disk_device* rtems_bdbuf_cache::sync_device
The device to sync and BDBUF_INVALID_DEV not a device sync.
◆ sync_lock
rtems_mutex rtems_bdbuf_cache::sync_lock
Sync calls block writes.
◆ sync_requester
rtems_id rtems_bdbuf_cache::sync_requester
The sync requester.
◆ transfer_waiters
rtems_bdbuf_waiters rtems_bdbuf_cache::transfer_waiters
Wait for a buffer in TRANSFER state.
◆ tree
rtems_bdbuf_buffer* rtems_bdbuf_cache::tree
Buffer descriptor lookup AVL tree root. There is only one.
