RTEMS
5.1
Public Member Functions | |
| SPIN_DECLARE (devlock) | |
Data Fields | |
| struct drvmgr_dev * | dev |
| char | prefix [20] |
| pci_dev_t | pcidev |
| struct pci_dev_info * | devinfo |
| uint32_t | ahbmst2pci_map |
| int | eirq |
| genirq_t | genirq |
| unsigned int | amba_freq_hz |
| unsigned int | cg_en_mask |
| struct irqmp_regs * | irq |
| struct l4n2x_grcg_regs * | cg |
| struct grpci2_regs * | grpci2 |
| struct drvmgr_map_entry | bus_maps_up [2] |
| struct drvmgr_map_entry | bus_maps_down [4] |
| struct ambapp_bus | abus |
| struct ambapp_mmap | amba_maps [5] |
| struct ambapp_config | config |
1.8.15
