volatile unsigned int | ctrl |
volatile unsigned int | statcap |
volatile unsigned int | pcimstprefetch |
volatile unsigned int | ahbtopciiomap |
volatile unsigned int | dmactrl |
volatile unsigned int | dmadesc |
volatile unsigned int | dmachanact |
volatile unsigned int | reserved |
volatile unsigned int | pcibartoahb [6] |
volatile unsigned int | reserved2 [2] |
volatile unsigned int | ahbtopcimemmap [16] |
volatile unsigned int | trcctrl |
volatile unsigned int | trccntmode |
volatile unsigned int | trcadpat |
volatile unsigned int | trcadmask |
volatile unsigned int | trcctrlsigpat |
volatile unsigned int | trcctrlsigmask |
volatile unsigned int | trcadstate |
volatile unsigned int | trcctrlsigstate |
volatile unsigned int | sts_cap |
volatile unsigned int | ppref |
volatile unsigned int | io_map |
volatile unsigned int | dma_ctrl |
volatile unsigned int | dma_bdbase |
volatile unsigned int | dma_chact |
int | res1 |
volatile unsigned int | bars [6] |
int | res2 [2] |
volatile unsigned int | ahbmst_map [16] |
The documentation for this struct was generated from the following files:
- bsps/shared/grlib/pci/gr_rasta_io.c
- bsps/shared/grlib/pci/gr_rasta_spw_router.c
- bsps/shared/grlib/pci/gr_rasta_tmtc.c
- bsps/shared/grlib/pci/grpci2.c
- bsps/sparc/shared/pci/gr_cpci_gr740.c
- bsps/sparc/shared/pci/gr_leon4_n2x.c
