RTEMS
5.1
#include <uart.h>
Data Fields | |
| const char * | name |
| uint32_t | uart_baseAddress |
| uint32_t | uart_rxDmaBaseAddress |
| uint32_t | uart_txDmaBaseAddress |
| bool | uart_useInterrupts |
| bool | uart_useDma |
| int | uart_baud |
| void * | termios |
| uint8_t volatile | flags |
| uint16_t | length |
bfin_uart_channel object
| uint8_t volatile bfin_uart_channel_t::flags |
termios associated
| uint16_t bfin_uart_channel_t::length |
flags for internal use
| void* bfin_uart_channel_t::termios |
baud rate, 0 for default
| uint32_t bfin_uart_channel_t::uart_baseAddress |
Holds name of the device
| int bfin_uart_channel_t::uart_baud |
is dma used
| uint32_t bfin_uart_channel_t::uart_rxDmaBaseAddress |
UART base address
| uint32_t bfin_uart_channel_t::uart_txDmaBaseAddress |
RX DMA base address
| bool bfin_uart_channel_t::uart_useDma |
are interrupts used
| bool bfin_uart_channel_t::uart_useInterrupts |
TX DMA base address
1.8.15
