RTEMS
5.1
#include <rtems-rfs-format.h>
Data Fields | |
| size_t | block_size |
| size_t | group_blocks |
| size_t | group_inodes |
| int | inode_overhead |
| size_t | max_name_length |
| bool | initialise_inodes |
| bool | verbose |
RFS File System Configuration data used to format the file system. For default values leave the field set to 0.
| size_t _rtems_rfs_format_config::block_size |
The size of a block.
| size_t _rtems_rfs_format_config::group_blocks |
The number of blocks in a group.
| size_t _rtems_rfs_format_config::group_inodes |
The number of inodes in a group.
| bool _rtems_rfs_format_config::initialise_inodes |
Initialise the inode tables to all ones.
| int _rtems_rfs_format_config::inode_overhead |
The percentage overhead allocated to inodes.
| size_t _rtems_rfs_format_config::max_name_length |
The maximum length of a name.
| bool _rtems_rfs_format_config::verbose |
Is the format verbose.
1.8.15
