RTEMS  5.1
_rtems_rfs_file_handle Struct Reference
#include <rtems-rfs-file.h>
int flags
rtems_rfs_buffer_handle buffer
rtems_rfs_block_pos bpos
rtems_rfs_file_shared * shared
File data used to managed an open file.
Field Documentation
◆ bpos
rtems_rfs_block_pos _rtems_rfs_file_handle::bpos
The block position of this file handle.
◆ buffer
rtems_rfs_buffer_handle _rtems_rfs_file_handle::buffer
The buffer of data at the file's position.
◆ flags
int _rtems_rfs_file_handle::flags
Special flags that can be controlled by the fctrl call.
◆ shared
rtems_rfs_file_shared* _rtems_rfs_file_handle::shared
Pointer to the shared file data.
