    RTEMS
    5.1
Operations on POSIX Shared Memory Objects. More...
#include <shm.h>
Data Fields | |
| int(* | object_create )(POSIX_Shm_Object *shm_obj, size_t size) |
| Allocates a new shm_obj with initial size.  More... | |
| int(* | object_resize )(POSIX_Shm_Object *shm_obj, size_t size) |
| Changes the shm_obj size to size.  More... | |
| int(* | object_delete )(POSIX_Shm_Object *shm_obj) |
| Deletes the shm_obj.  More... | |
| int(* | object_read )(POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
| Copies up to @count bytes of the shm_obj data into buf.  More... | |
| void *(* | object_mmap )(POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
| Maps a shared memory object.  More... | |
| int( * POSIX_Shm_Object_operations::object_create) (POSIX_Shm_Object *shm_obj, size_t size) |
New shared memory is initialized to zeroes.
Returns 0 for success.
| int( * POSIX_Shm_Object_operations::object_delete) (POSIX_Shm_Object *shm_obj) |
Zeroes out the memory.
| void*( * POSIX_Shm_Object_operations::object_mmap) (POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off) |
Establishes a memory mapping between the shared memory object and the caller.
Returns the mapped address of the object.
| int( * POSIX_Shm_Object_operations::object_read) (POSIX_Shm_Object *shm_obj, void *buf, size_t count) |
Returns the number of bytes read (copied) into buf.
| int( * POSIX_Shm_Object_operations::object_resize) (POSIX_Shm_Object *shm_obj, size_t size) |
Zeroes out the portion of the shared memory object that shrinks or grows.
 1.8.15
