RTEMS
5.1
#include <messagedata.h>
Data Fields | |
| Objects_Control | Object |
| CORE_message_queue_Control | message_queue |
| rtems_attribute | attribute_set |
The following records define the control block used to manage each message queue.
| rtems_attribute Message_queue_Control::attribute_set |
This field is the attribute set as defined by the API.
| CORE_message_queue_Control Message_queue_Control::message_queue |
This field is the instance of the SuperCore Message Queue.
| Objects_Control Message_queue_Control::Object |
This field is the inherited object characteristics.
1.8.15
