RTEMS  5.1
spi_dma.h File Reference
#include "chip.h"
struct  _SpidCmd
 Spi Transfer Request prepared by the application upper layer. More...
struct  _Spid
#define SPID_ERROR   1
#define SPID_ERROR_LOCK   2
#define SPID_CSR_SCBR(mck, spck)   SPI_CSR_SCBR((mck) / (spck))
#define SPID_CSR_DLYBS(mck, delay)
#define SPID_CSR_DLYBCT(mck, delay)
typedef void(* SpidCallback) (uint8_t, void *)
typedef struct _SpidCmd SpidCmd
typedef struct _Spid Spid
uint32_t SPID_Configure (Spid *pSpid, Spi *pSpiHw, uint8_t spiId, uint32_t SpiMode, sXdmad *pXdmad)
 Initializes the Spid structure and the corresponding SPI & DMA hardware. select value. The driver will uses DMA channel 0 for RX and DMA channel 1 for TX. The DMA channels are freed automatically when no SPI command processing. More...
void SPID_ConfigureCS (Spid *pSpid, uint32_t dwCS, uint32_t dwCsr)
 Configures the parameters for the device corresponding to the cs value. More...
uint32_t SPID_SendCommand (Spid *pSpid, SpidCmd *pCommand)
 Starts a SPI master transfer. This is a non blocking function. It will return as soon as the transfer is started. More...
void SPID_Handler (Spid *pSpid)
void SPID_DmaHandler (Spid *pSpid)
uint32_t SPID_IsBusy (const Spid *pSpid)
 Check if the SPI driver is busy. More...
Implementation of SPI driver, transfer data through DMA.
◆ SPID_CSR_DLYBCT
#define SPID_CSR_DLYBCT (   mck,
  delay
Value:
SPI_CSR_DLYBCT((((delay) / 32 * \
((mck) / 1000000)) / 1000) + 1)
Calculates the value of the DLYBCT field of the Chip Select Register given delay in ns and MCK.
◆ SPID_CSR_DLYBS
#define SPID_CSR_DLYBS (   mck,
  delay
Value:
SPI_CSR_DLYBS((((delay) * \
Calculates the value of the DLYBS field of the Chip Select Register given delay in ns and MCK.
◆ SPID_CSR_SCBR
#define SPID_CSR_SCBR (   mck,
  spck
Calculates the value of the SCBR field of the Chip Select Register given MCK and SPCK.
◆ SPID_ERROR
An unspecified error has occurred.
◆ SPID_ERROR_LOCK
SPI driver is currently in use.
Typedef Documentation
◆ Spid
Constant structure associated with SPI port. This structure prevents client applications to have access in the same time.
◆ SpidCallback
SPI transfer complete callback.
◆ SpidCmd
This structure is sent to the SPI_SendCommand function to start the transfer. At the end of the transfer, the callback is invoked by the interrupt handler.
◆ SPID_Configure()
uint32_t SPID_Configure ( Spid *  pSpid,
Spi *  pSpiHw,
uint8_t  spiId,
uint32_t  spiMode,
sXdmad *  pXdmad
Parameters
pSpidPointer to a Spid instance.
pSpiHwAssociated SPI peripheral.
spiIdSPI peripheral identifier.
pDmadPointer to a Dmad instance.
◆ SPID_ConfigureCS()
void SPID_ConfigureCS ( Spid *  pSpid,
uint32_t  dwCS,
uint32_t  dwCsr
Parameters
csnumber corresponding to the SPI chip select.
csrSPI_CSR value to setup.
◆ SPID_IsBusy()
uint32_t SPID_IsBusy ( const Spid *  pSpid)
Parameters
Returns
1 if the SPI driver is currently busy executing a command; otherwise
◆ SPID_SendCommand()
uint32_t SPID_SendCommand ( Spid *  pSpid,
SpidCmd *  pCommand
Parameters
pCommandPointer to the SPI command to execute.
Returns
0 if the transfer has been started successfully; otherwise returns SPID_ERROR_LOCK is the driver is in use, or SPID_ERROR if the command is not valid.
