RTEMS  5.1
cpuimpl.h
1
7 /*
8  * Copyright (c) 1989, 2007 On-Line Applications Research Corporation (OAR)
9  * Copyright (c) 2013, 2016 embedded brains GmbH
10  *
11  * The license and distribution terms for this file may be
12  * found in the file LICENSE in this distribution or at
13  * http://www.rtems.org/license/LICENSE.
14  */
15
16 #ifndef _RTEMS_SCORE_CPUIMPL_H
17 #define _RTEMS_SCORE_CPUIMPL_H
18
19 #include <rtems/score/cpu.h>
20
32 #define SPARC_MINIMUM_STACK_FRAME_SIZE 0x60
33
34 /*
35  * Offsets of fields with CPU_Interrupt_frame for assembly routines.
36  */
37
39 #define ISF_PSR_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x00
40
41 #define ISF_PC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x04
42
43 #define ISF_NPC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x08
44
45 #define ISF_G1_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x0c
46
47 #define ISF_G2_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x10
48
49 #define ISF_G3_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x14
50
51 #define ISF_G4_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x18
52
53 #define ISF_G5_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x1c
54
55 #define ISF_G7_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x24
56
57 #define ISF_I0_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x28
58
59 #define ISF_I1_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x2c
60
61 #define ISF_I2_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x30
62
63 #define ISF_I3_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x34
64
65 #define ISF_I4_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x38
66
67 #define ISF_I5_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x3c
68
69 #define ISF_I6_FP_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x40
70
71 #define ISF_I7_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x44
72
73 #define ISF_Y_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x48
74
75 #define ISF_TPC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x4c
76
78 #define CPU_INTERRUPT_FRAME_SIZE SPARC_MINIMUM_STACK_FRAME_SIZE + 0x50
79
80 #define SPARC_FP_CONTEXT_OFFSET_F0_F1 0
81 #define SPARC_FP_CONTEXT_OFFSET_F2_F3 8
82 #define SPARC_FP_CONTEXT_OFFSET_F4_F5 16
83 #define SPARC_FP_CONTEXT_OFFSET_F6_F7 24
84 #define SPARC_FP_CONTEXT_OFFSET_F8_F9 32
85 #define SPARC_FP_CONTEXT_OFFSET_F10_F11 40
86 #define SPARC_FP_CONTEXT_OFFSET_F12_F13 48
87 #define SPARC_FP_CONTEXT_OFFSET_F14_F15 56
88 #define SPARC_FP_CONTEXT_OFFSET_F16_F17 64
89 #define SPARC_FP_CONTEXT_OFFSET_F18_F19 72
90 #define SPARC_FP_CONTEXT_OFFSET_F20_F21 80
91 #define SPARC_FP_CONTEXT_OFFSET_F22_F23 88
92 #define SPARC_FP_CONTEXT_OFFSET_F24_F25 96
93 #define SPARC_FP_CONTEXT_OFFSET_F26_F27 104
94 #define SPARC_FP_CONTEXT_OFFSET_F28_F29 112
95 #define SPARC_FP_CONTEXT_OFFSET_F30_F31 120
96 #define SPARC_FP_CONTEXT_OFFSET_FSR 128
97
98 #if ( SPARC_HAS_FPU == 1 )
99  #define CPU_PER_CPU_CONTROL_SIZE 8
100 #else
101  #define CPU_PER_CPU_CONTROL_SIZE 0
102 #endif
103
104 #if ( SPARC_HAS_FPU == 1 )
105
109  #define SPARC_PER_CPU_FSR_OFFSET 0
110
111  #if defined(SPARC_USE_LAZY_FP_SWITCH)
112
116  #define SPARC_PER_CPU_FP_OWNER_OFFSET 4
117  #endif
118 #endif
119
120 #ifndef ASM
121
122 #ifdef __cplusplus
123 extern "C" {
124 #endif
125
126 typedef struct {
127 #if ( SPARC_HAS_FPU == 1 )
128
135  uint32_t fsr;
136
137 #if defined(SPARC_USE_LAZY_FP_SWITCH)
138
141  struct _Thread_Control *fp_owner;
142 #else
143  /* See Per_CPU_Control::Interrupt_frame */
144  uint32_t reserved_for_alignment_of_interrupt_frame;
145 #endif
146 #endif
148
153 register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
154
155 #define _CPU_Get_current_per_CPU_control() _SPARC_Per_CPU_current
156
157 #define _CPU_Get_thread_executing() ( _SPARC_Per_CPU_current->executing )
158
159 void _CPU_Context_volatile_clobber( uintptr_t pattern );
160
161 void _CPU_Context_validate( uintptr_t pattern );
162
164 {
165  __asm__ volatile ( "unimp 0" );
166 }
167
169 {
170  __asm__ volatile ( "nop" );
171 }
172
173 #ifdef __cplusplus
174 }
175 #endif
176
177 #endif /* ASM */
178
181 #endif /* _RTEMS_SCORE_CPUIMPL_H */
The CPU specific per-CPU control.
Definition: cpuimpl.h:54
Definition: thread.h:732
Per CPU Core Structure.
Definition: percpu.h:347
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation(void)
Emits a no operation instruction (nop).
Definition: cpuimpl.h:132
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal(void)
Emits an illegal instruction.
Definition: cpuimpl.h:122
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
