RTEMS  5.1
cpuimpl.h File Reference
CPU Port Implementation API. More...
#include <rtems/score/cpu.h>
struct  CPU_Per_CPU_control
 The CPU specific per-CPU control. More...
#define SPARC_MINIMUM_STACK_FRAME_SIZE   0x60
#define ISF_PSR_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x00
#define ISF_PC_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x04
#define ISF_NPC_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x08
#define ISF_G1_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x0c
#define ISF_G2_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x10
#define ISF_G3_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x14
#define ISF_G4_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x18
#define ISF_G5_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x1c
#define ISF_G7_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x24
#define ISF_I0_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x28
#define ISF_I1_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x2c
#define ISF_I2_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x30
#define ISF_I3_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x34
#define ISF_I4_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x38
#define ISF_I5_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x3c
#define ISF_I6_FP_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x40
#define ISF_I7_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x44
#define ISF_Y_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x48
#define ISF_TPC_OFFSET   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x4c
#define CPU_INTERRUPT_FRAME_SIZE   SPARC_MINIMUM_STACK_FRAME_SIZE + 0x50
#define SPARC_FP_CONTEXT_OFFSET_F0_F1   0
#define SPARC_FP_CONTEXT_OFFSET_F2_F3   8
#define SPARC_FP_CONTEXT_OFFSET_F4_F5   16
#define SPARC_FP_CONTEXT_OFFSET_F6_F7   24
#define SPARC_FP_CONTEXT_OFFSET_F8_F9   32
#define SPARC_FP_CONTEXT_OFFSET_F10_F11   40
#define SPARC_FP_CONTEXT_OFFSET_F12_F13   48
#define SPARC_FP_CONTEXT_OFFSET_F14_F15   56
#define SPARC_FP_CONTEXT_OFFSET_F16_F17   64
#define SPARC_FP_CONTEXT_OFFSET_F18_F19   72
#define SPARC_FP_CONTEXT_OFFSET_F20_F21   80
#define SPARC_FP_CONTEXT_OFFSET_F22_F23   88
#define SPARC_FP_CONTEXT_OFFSET_F24_F25   96
#define SPARC_FP_CONTEXT_OFFSET_F26_F27   104
#define SPARC_FP_CONTEXT_OFFSET_F28_F29   112
#define SPARC_FP_CONTEXT_OFFSET_F30_F31   120
#define SPARC_FP_CONTEXT_OFFSET_FSR   128
#define CPU_PER_CPU_CONTROL_SIZE   0
#define _CPU_Get_current_per_CPU_control()   _SPARC_Per_CPU_current
#define _CPU_Get_thread_executing()   ( _SPARC_Per_CPU_current->executing )
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__ ("g6")
 The pointer to the current per-CPU control is available via register g6.
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
