RTEMS  5.1
cpu.h
1
10 /*
11  * COPYRIGHT (c) 1989-2011.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_CPU_H
20 #define _RTEMS_SCORE_CPU_H
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 #include <rtems/score/basedefs.h>
27 #include <rtems/score/sparc.h>
28
29 /* conditional compilation parameters */
30
31 /*
32  * The SPARC ABI is a bit special with respect to the floating point context.
33  * The complete floating point context is volatile. Thus, from an ABI point
34  * of view nothing needs to be saved and restored during a context switch.
35  * Instead the floating point context must be saved and restored during
36  * interrupt processing. Historically, the deferred floating point switch was
37  * used for SPARC and the complete floating point context is saved and
38  * restored during a context switch to the new floating point unit owner.
39  * This is a bit dangerous since post-switch actions (e.g. signal handlers)
40  * and context switch extensions may silently corrupt the floating point
41  * context.
42  *
43  * The floating point unit is disabled for interrupt handlers. Thus, in case
44  * an interrupt handler uses the floating point unit then this will result in a
45  * trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
46  *
47  * In uniprocessor configurations, a lazy floating point context switch is
48  * used. In case an active floating point thread is interrupted (PSR[EF] == 1)
49  * and a thread dispatch is carried out, then this thread is registered as the
50  * floating point owner. When a floating point owner is present during a
51  * context switch, the floating point unit is disabled for the heir thread
52  * (PSR[EF] == 0). The floating point disabled trap checks that the use of the
53  * floating point unit is allowed and saves/restores the floating point context
54  * on demand.
55  *
56  * In SMP configurations, the deferred floating point switch is not supported
57  * in principle. So, use here a synchronous floating point switching.
58  * Synchronous means that the volatile floating point context is saved and
59  * restored around a thread dispatch issued during interrupt processing. Thus
60  * post-switch actions and context switch extensions may safely use the
61  * floating point unit.
62  */
63 #if SPARC_HAS_FPU == 1
64  #if defined(RTEMS_SMP)
65  #define SPARC_USE_SYNCHRONOUS_FP_SWITCH
66  #else
67  #define SPARC_USE_LAZY_FP_SWITCH
68  #endif
69 #endif
70
81 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
82
91 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
92
101 #if ( SPARC_HAS_FPU == 1 ) && !defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
102  #define CPU_HARDWARE_FP TRUE
103 #else
104  #define CPU_HARDWARE_FP FALSE
105 #endif
106
111 #define CPU_SOFTWARE_FP FALSE
112
121 #define CPU_ALL_TASKS_ARE_FP FALSE
122
132 #define CPU_IDLE_TASK_IS_FP FALSE
133
134 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
135
136 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
137
147 #define CPU_STACK_GROWS_UP FALSE
148
149 /* LEON3 systems may use a cache line size of 64 */
150 #define CPU_CACHE_LINE_BYTES 64
151
152 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
153
161 #define CPU_MODES_INTERRUPT_MASK 0x0000000F
162
163 #ifndef ASM
164
170 typedef struct {
172  uint32_t l0;
174  uint32_t l1;
176  uint32_t l2;
178  uint32_t l3;
180  uint32_t l4;
182  uint32_t l5;
184  uint32_t l6;
186  uint32_t l7;
188  uint32_t i0;
190  uint32_t i1;
192  uint32_t i2;
194  uint32_t i3;
196  uint32_t i4;
198  uint32_t i5;
200  uint32_t i6_fp;
202  uint32_t i7;
205
206  /*
207  * The following are for the callee to save the register arguments in
208  * should this be necessary.
209  */
211  uint32_t saved_arg0;
213  uint32_t saved_arg1;
215  uint32_t saved_arg2;
217  uint32_t saved_arg3;
219  uint32_t saved_arg4;
221  uint32_t saved_arg5;
223  uint32_t pad0;
225
226 #endif /* ASM */
227
229 #define CPU_STACK_FRAME_L0_OFFSET 0x00
230
231 #define CPU_STACK_FRAME_L1_OFFSET 0x04
232
233 #define CPU_STACK_FRAME_L2_OFFSET 0x08
234
235 #define CPU_STACK_FRAME_L3_OFFSET 0x0c
236
237 #define CPU_STACK_FRAME_L4_OFFSET 0x10
238
239 #define CPU_STACK_FRAME_L5_OFFSET 0x14
240
241 #define CPU_STACK_FRAME_L6_OFFSET 0x18
242
243 #define CPU_STACK_FRAME_L7_OFFSET 0x1c
244
245 #define CPU_STACK_FRAME_I0_OFFSET 0x20
246
247 #define CPU_STACK_FRAME_I1_OFFSET 0x24
248
249 #define CPU_STACK_FRAME_I2_OFFSET 0x28
250
251 #define CPU_STACK_FRAME_I3_OFFSET 0x2c
252
253 #define CPU_STACK_FRAME_I4_OFFSET 0x30
254
255 #define CPU_STACK_FRAME_I5_OFFSET 0x34
256
257 #define CPU_STACK_FRAME_I6_FP_OFFSET 0x38
258
259 #define CPU_STACK_FRAME_I7_OFFSET 0x3c
260
261 #define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET 0x40
262
263 #define CPU_STACK_FRAME_SAVED_ARG0_OFFSET 0x44
264
265 #define CPU_STACK_FRAME_SAVED_ARG1_OFFSET 0x48
266
267 #define CPU_STACK_FRAME_SAVED_ARG2_OFFSET 0x4c
268
269 #define CPU_STACK_FRAME_SAVED_ARG3_OFFSET 0x50
270
271 #define CPU_STACK_FRAME_SAVED_ARG4_OFFSET 0x54
272
273 #define CPU_STACK_FRAME_SAVED_ARG5_OFFSET 0x58
274
275 #define CPU_STACK_FRAME_PAD0_OFFSET 0x5c
276
277 #define CPU_MAXIMUM_PROCESSORS 32
278
300 #ifndef ASM
302
318 typedef struct {
320  uint32_t g5;
322  uint32_t g7;
323
331  double l0_and_l1;
333  uint32_t l2;
335  uint32_t l3;
337  uint32_t l4;
339  uint32_t l5;
341  uint32_t l6;
343  uint32_t l7;
344
346  uint32_t i0;
348  uint32_t i1;
350  uint32_t i2;
352  uint32_t i3;
354  uint32_t i4;
356  uint32_t i5;
358  uint32_t i6_fp;
360  uint32_t i7;
361
363  uint32_t o6_sp;
368  uint32_t o7;
369
371  uint32_t psr;
377  uint32_t isr_dispatch_disable;
378
379 #if defined(SPARC_USE_LAZY_FP_SWITCH)
380  Context_Control_fp *fp_context;
381 #endif
382
383 #if defined(RTEMS_SMP)
384  volatile uint32_t is_executing;
385 #endif
387
393 #define _CPU_Context_Get_SP( _context ) \
394  (_context)->o6_sp
395
396 #ifdef RTEMS_SMP
397  static inline bool _CPU_Context_Get_is_executing(
398  const Context_Control *context
399  )
400  {
401  return context->is_executing;
402  }
403
404  static inline void _CPU_Context_Set_is_executing(
406  bool is_executing
407  )
408  {
409  context->is_executing = is_executing;
410  }
411 #endif
412
413 #endif /* ASM */
414
415 /*
416  * Offsets of fields with Context_Control for assembly routines.
417  */
418
420 #define G5_OFFSET 0x00
421
422 #define G7_OFFSET 0x04
423
425 #define L0_OFFSET 0x08
426
427 #define L1_OFFSET 0x0C
428
429 #define L2_OFFSET 0x10
430
431 #define L3_OFFSET 0x14
432
433 #define L4_OFFSET 0x18
434
435 #define L5_OFFSET 0x1C
436
437 #define L6_OFFSET 0x20
438
439 #define L7_OFFSET 0x24
440
442 #define I0_OFFSET 0x28
443
444 #define I1_OFFSET 0x2C
445
446 #define I2_OFFSET 0x30
447
448 #define I3_OFFSET 0x34
449
450 #define I4_OFFSET 0x38
451
452 #define I5_OFFSET 0x3C
453
454 #define I6_FP_OFFSET 0x40
455
456 #define I7_OFFSET 0x44
457
459 #define O6_SP_OFFSET 0x48
460
461 #define O7_OFFSET 0x4C
462
464 #define PSR_OFFSET 0x50
465
466 #define ISR_DISPATCH_DISABLE_STACK_OFFSET 0x54
467
468 #if defined(RTEMS_SMP)
469  #define SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x58
470 #endif
471
472 #ifndef ASM
473
478 struct Context_Control_fp {
480  double f0_f1;
482  double f2_f3;
484  double f4_f5;
486  double f6_f7;
488  double f8_f9;
490  double f10_f11;
492  double f12_f13;
494  double f14_f15;
496  double f16_f17;
498  double f18_f19;
500  double f20_f21;
502  double f22_f23;
504  double f24_f25;
506  double f26_f27;
508  double f28_f29;
510  double f30_f31;
512  uint32_t fsr;
513 };
514
515 #endif /* ASM */
516
517 /*
518  * Offsets of fields with Context_Control_fp for assembly routines.
519  */
520
522 #define FO_F1_OFFSET 0x00
523
524 #define F2_F3_OFFSET 0x08
525
526 #define F4_F5_OFFSET 0x10
527
528 #define F6_F7_OFFSET 0x18
529
530 #define F8_F9_OFFSET 0x20
531
532 #define F1O_F11_OFFSET 0x28
533
534 #define F12_F13_OFFSET 0x30
535
536 #define F14_F15_OFFSET 0x38
537
538 #define F16_F17_OFFSET 0x40
539
540 #define F18_F19_OFFSET 0x48
541
542 #define F2O_F21_OFFSET 0x50
543
544 #define F22_F23_OFFSET 0x58
545
546 #define F24_F25_OFFSET 0x60
547
548 #define F26_F27_OFFSET 0x68
549
550 #define F28_F29_OFFSET 0x70
551
552 #define F3O_F31_OFFSET 0x78
553
554 #define FSR_OFFSET 0x80
555
557 #define CONTEXT_CONTROL_FP_SIZE 0x84
558
559 #ifndef ASM
560
571 typedef struct {
575  uint32_t psr;
577  uint32_t pc;
579  uint32_t npc;
581  uint32_t g1;
583  uint32_t g2;
585  uint32_t g3;
587  uint32_t g4;
589  uint32_t g5;
593  uint32_t g7;
595  uint32_t i0;
597  uint32_t i1;
599  uint32_t i2;
601  uint32_t i3;
603  uint32_t i4;
605  uint32_t i5;
607  uint32_t i6_fp;
609  uint32_t i7;
611  uint32_t y;
613  uint32_t tpc;
615
616 #endif /* ASM */
617
618 #ifndef ASM
619
627 typedef struct {
629  uint32_t mov_psr_l0;
635  uint32_t mov_vector_l3;
637
648
652 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
653
654 #endif
655
661 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
662
686 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
687
692 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 511
693
698 #define SPARC_SYNCHRONOUS_TRAP_BIT_MASK 0x100
699
703 #define SPARC_ASYNCHRONOUS_TRAP( _trap ) (_trap)
704
708 #define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 256 )
709
713 #define SPARC_REAL_TRAP_NUMBER( _trap ) ((_trap) % 256)
714
719 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
720
729 #define CPU_STACK_MINIMUM_SIZE (1024*4)
730
734 #define CPU_SIZEOF_POINTER 4
735
742 #define CPU_ALIGNMENT 8
743
755 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
756
761 #define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
762
763 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
764
765 #ifndef ASM
766
767 /*
768  * ISR handler macros
769  */
770
774 #define _CPU_Initialize_vectors()
775
780 #define _CPU_ISR_Disable( _level ) \
781  (_level) = sparc_disable_interrupts()
782
788 #define _CPU_ISR_Enable( _level ) \
789  sparc_enable_interrupts( _level )
790
797 #define _CPU_ISR_Flash( _level ) \
798  sparc_flash_interrupts( _level )
799
800 #define _CPU_ISR_Is_enabled( _isr_cookie ) \
801  sparc_interrupt_is_enabled( _isr_cookie )
802
804 {
805  return ( level & SPARC_PSR_PIL_MASK ) == 0;
806 }
807
813 #define _CPU_ISR_Set_level( _newlevel ) \
814  sparc_enable_interrupts( _newlevel << 8)
815
823 uint32_t _CPU_ISR_Get_level( void );
824
825 /* end of ISR handler macros */
826
827 /* Context handler macros */
828
851  Context_Control *the_context,
852  uint32_t *stack_base,
853  uint32_t size,
854  uint32_t new_level,
855  void *entry_point,
856  bool is_fp,
857  void *tls_area
858 );
859
873 #define _CPU_Context_Initialization_at_thread_begin() \
874  do { \
875  __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
876  } while (0)
877
886 #define _CPU_Context_Restart_self( _the_context ) \
887  _CPU_Context_restore( (_the_context) );
888
892 #define _CPU_Context_Initialize_fp( _destination ) \
893  do { } while ( 0 )
894
898 #define _CPU_Context_save_fp( _fp_context_ptr ) \
899  do { } while ( 0 )
900
904 #define _CPU_Context_restore_fp( _fp_context_ptr ) \
905  do { } while ( 0 )
906 /* end of Context handler macros */
907
908 /* Fatal Error manager macros */
909
915 extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
917
918 /* end of Fatal Error manager macros */
919
920 /* Bitfield handler macros */
921
922 #if ( SPARC_HAS_BITSCAN == 0 )
923
927  #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
928 #else
929  #error "scan instruction not currently supported by RTEMS!!"
930 #endif
931
932 /* end of Bitfield handler macros */
933
934 /* functions */
935
941 void _CPU_Initialize(void);
942
943 typedef void ( *CPU_ISR_raw_handler )( void );
944
956  uint32_t vector,
957  CPU_ISR_raw_handler new_handler,
958  CPU_ISR_raw_handler *old_handler
959 );
960
961 typedef void ( *CPU_ISR_handler )( uint32_t );
962
974  uint32_t vector,
975  CPU_ISR_handler new_handler,
976  CPU_ISR_handler *old_handler
977 );
978
979 void *_CPU_Thread_Idle_body( uintptr_t ignored );
980
990  Context_Control *run,
991  Context_Control *heir
992 );
993
1003  Context_Control *new_context
1004 ) RTEMS_NO_RETURN;
1005
1006 #if defined(RTEMS_SMP)
1007  uint32_t _CPU_SMP_Initialize( void );
1008
1009  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
1010
1011  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
1012
1013  void _CPU_SMP_Prepare_start_multitasking( void );
1014
1015  #if defined(__leon__) && !defined(RTEMS_PARAVIRT)
1016  static inline uint32_t _CPU_SMP_Get_current_processor( void )
1017  {
1018  return _LEON3_Get_current_processor();
1019  }
1020  #else
1021  uint32_t _CPU_SMP_Get_current_processor( void );
1022  #endif
1023
1024  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
1025
1026  static inline void _CPU_SMP_Processor_event_broadcast( void )
1027  {
1028  __asm__ volatile ( "" : : : "memory" );
1029  }
1030
1031  static inline void _CPU_SMP_Processor_event_receive( void )
1032  {
1033  __asm__ volatile ( "" : : : "memory" );
1034  }
1035 #endif
1036
1037 #if defined(SPARC_USE_LAZY_FP_SWITCH)
1038 #define _CPU_Context_Destroy( _the_thread, _the_context ) \
1039  do { \
1040  Per_CPU_Control *cpu_self = _Per_CPU_Get(); \
1041  Thread_Control *_fp_owner = cpu_self->cpu_per_cpu.fp_owner; \
1042  if ( _fp_owner == _the_thread ) { \
1043  cpu_self->cpu_per_cpu.fp_owner = NULL; \
1044  } \
1045  } while ( 0 )
1046 #endif
1047
1048 typedef struct {
1049  uint32_t trap;
1050  CPU_Interrupt_frame *isf;
1052
1053 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
1054
1075 static inline uint32_t CPU_swap_u32(
1076  uint32_t value
1077 )
1078 {
1079  uint32_t byte1, byte2, byte3, byte4, swapped;
1080
1081  byte4 = (value >> 24) & 0xff;
1082  byte3 = (value >> 16) & 0xff;
1083  byte2 = (value >> 8) & 0xff;
1084  byte1 = value & 0xff;
1085
1086  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1087  return( swapped );
1088 }
1089
1097 #define CPU_swap_u16( value ) \
1098  (((value&0xff) << 8) | ((value >> 8)&0xff))
1099
1100 typedef uint32_t CPU_Counter_ticks;
1101
1102 uint32_t _CPU_Counter_frequency( void );
1103
1104 typedef CPU_Counter_ticks ( *SPARC_Counter_read )( void );
1105
1106 /*
1107  * The SPARC processors supported by RTEMS have no built-in CPU counter
1108  * support. We have to use some hardware counter module for this purpose, for
1109  * example the GPTIMER instance used by the clock driver. The BSP must provide
1110  * an implementation of the CPU counter read function. This allows the use of
1111  * dynamic hardware enumeration.
1112  */
1113 typedef struct {
1114  SPARC_Counter_read read_isr_disabled;
1115  SPARC_Counter_read read;
1116  volatile const CPU_Counter_ticks *counter_register;
1117  volatile const uint32_t *pending_register;
1118  uint32_t pending_mask;
1119  CPU_Counter_ticks accumulated;
1120  CPU_Counter_ticks interval;
1121 } SPARC_Counter;
1122
1123 extern const SPARC_Counter _SPARC_Counter;
1124
1125 static inline CPU_Counter_ticks _CPU_Counter_read( void )
1126 {
1127  return ( *_SPARC_Counter.read )();
1128 }
1129
1130 static inline CPU_Counter_ticks _CPU_Counter_difference(
1131  CPU_Counter_ticks second,
1132  CPU_Counter_ticks first
1133 )
1134 {
1135  return second - first;
1136 }
1137
1139 typedef uintptr_t CPU_Uint32ptr;
1140
1141 #endif /* ASM */
1142
1143 #ifdef __cplusplus
1144 }
1145 #endif
1146
1147 #endif
uint32_t l2
Definition: cpu.h:176
uint32_t g5
Definition: cpu.h:320
uint32_t g7
Definition: cpu.h:593
double f0_f1
Definition: cpu.h:480
uint32_t fsr
Definition: cpu.h:512
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
Definition: cpu.h:627
uint32_t i0
Definition: cpu.h:346
uint32_t l3
Definition: cpu.h:335
Definition: cpu.h:1113
Definition: cpu.h:635
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
uint32_t i6_fp
Definition: cpu.h:200
uint32_t i5
Definition: cpu.h:605
uint32_t i4
Definition: cpu.h:196
void * structure_return_address
Definition: cpu.h:204
Thread register context.
Definition: cpu.h:194
uint32_t saved_arg4
Definition: cpu.h:219
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
uint32_t l2
Definition: cpu.h:333
uint32_t reserved_for_alignment
Definition: cpu.h:591
uint32_t mov_psr_l0
Definition: cpu.h:629
double f8_f9
Definition: cpu.h:488
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
uint32_t saved_arg0
Definition: cpu.h:211
uint32_t pad0
Definition: cpu.h:223
uint32_t i1
Definition: cpu.h:190
uint32_t g7
Definition: cpu.h:322
uint32_t i6_fp
Definition: cpu.h:358
uint32_t g3
Definition: cpu.h:585
uint32_t sethi_of_handler_to_l4
Definition: cpu.h:631
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
uint32_t saved_arg5
Definition: cpu.h:221
double f10_f11
Definition: cpu.h:490
double l0_and_l1
Definition: cpu.h:331
uint32_t i3
uint32_t l6
Definition: cpu.h:341
uint32_t i5
Definition: cpu.h:356
uint32_t i7
Definition: cpu.h:202
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
double f22_f23
Definition: cpu.h:502
uint32_t l5
Definition: cpu.h:182
uint32_t i7
Definition: cpu.h:609
uint32_t tpc
Definition: cpu.h:613
uint32_t i0
Definition: cpu.h:595
uint32_t i2
Definition: cpu.h:599
double f4_f5
Definition: cpu.h:484
uint32_t i4
Definition: cpu.h:354
uint32_t g2
Definition: cpu.h:583
uint32_t i2
Definition: cpu.h:350
uint32_t l7
Definition: cpu.h:186
uint32_t psr
Definition: cpu.h:371
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
SPARC_Minimum_stack_frame Stack_frame
Definition: cpu.h:573
double f2_f3
Definition: cpu.h:482
uint32_t l3
Definition: cpu.h:178
double f26_f27
Definition: cpu.h:506
CPU initialization.
Definition: cpu.c:45
uint32_t l5
Definition: cpu.h:339
uint32_t npc
Definition: cpu.h:579
SPARC basic context.
const CPU_Trap_table_entry _CPU_Trap_slot_template
Definition: cpu.c:156
uint32_t jmp_to_low_of_handler_plus_l4
Definition: cpu.h:633
double f12_f13
Definition: cpu.h:492
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
double f18_f19
Definition: cpu.h:498
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t l6
Definition: cpu.h:184
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
double f28_f29
Definition: cpu.h:508
uint32_t i0
Definition: cpu.h:188
uint32_t l4
Definition: cpu.h:337
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
double f30_f31
Definition: cpu.h:510
uint32_t i5
Definition: cpu.h:198
uint32_t l1
Definition: cpu.h:174
unsigned context
Definition: tlb.h:108
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
double f6_f7
Definition: cpu.h:486
uint32_t g1
Definition: cpu.h:581
uint32_t saved_arg3
Definition: cpu.h:217
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
uint32_t i1
Definition: cpu.h:597
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:170
uint32_t o6_sp
Definition: cpu.h:363
uint32_t psr
Definition: cpu.h:575
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
uint32_t i3
Definition: cpu.h:352
Basic Definitions.
double f20_f21
Definition: cpu.h:500
#define SPARC_PSR_PIL_MASK
Definition: sparc.h:127
double f24_f25
Definition: cpu.h:504
uint32_t g4
Definition: cpu.h:587
uint32_t g5
Definition: cpu.h:589
uint32_t l4
Definition: cpu.h:180
double f16_f17
Definition: cpu.h:496
uint32_t i2
Definition: cpu.h:192
unsigned size
Definition: tte.h:74
double f14_f15
Definition: cpu.h:494
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
uint32_t i6_fp
Definition: cpu.h:607
uint32_t i4
Definition: cpu.h:603
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
uint32_t pc
Definition: cpu.h:577
uint32_t l0
Definition: cpu.h:172
uint32_t y
Definition: cpu.h:611
uint32_t i3
Definition: cpu.h:601
uint32_t saved_arg2
Definition: cpu.h:215
uint32_t l7
Definition: cpu.h:343
uint32_t o7
Definition: cpu.h:368
uint32_t saved_arg1
Definition: cpu.h:213
uint32_t i7
Definition: cpu.h:360
uint32_t i1
Definition: cpu.h:348
