RTEMS  5.1
Typedefs | Functions
rtl-chain-iterator.h File Reference
RTEMS Run-Time Linker Chain Iterator. More...
#include <rtems/chain.h>
typedef bool(* rtems_chain_iterator) (rtems_chain_node *node, void *data)
bool rtems_rtl_chain_iterate (rtems_chain_control *chain, rtems_chain_iterator iterator, void *data)
int rtems_rtl_chain_count (rtems_chain_control *chain)
Typedef Documentation
◆ rtems_chain_iterator
Chain iterator handler.
◆ rtems_rtl_chain_count()
int rtems_rtl_chain_count ( rtems_chain_control *  chain)
Count the number of nodes on the chain.
Parameters
chainThe chain to count the nodes of.
Returns
int The number of nodes.
◆ rtems_rtl_chain_iterate()
bool rtems_rtl_chain_iterate ( rtems_chain_control *  chain,
void *  data
Iterate a chain of nodes invoking the iterator handler. Supply a data pointer the iterator moves data between the invoker and the iterator.
The iterator allows removal of the node from the chain.
Parameters
chainThe chain of nodes to iterator over.
iteratorThe iterator handler called once for each node.
dataPointer to the data used by the iterator.
Return values
trueThe whole chain was iterated over.
falseThe iterator returned false.
