RTEMS  5.1
rtems-fdt-shell.h File Reference
RTEMS Flattened Device Tree Shell Command. More...
#include <rtems/rtems-fdt.h>
void rtems_fdt_add_shell_command (void)
rtems_fdt_handle * rtems_fdt_get_shell_handle (void)
Support for loading, managing and accessing FDT blobs in RTEMS.
◆ rtems_fdt_add_shell_command()
void rtems_fdt_add_shell_command ( void  )
Add a shell command to access memory and registers associated with the DTF.
◆ rtems_fdt_get_shell_handle()
rtems_fdt_handle* rtems_fdt_get_shell_handle ( void  )
Get a pointer to the handle. You can use this to load files or register blobs and have the shell command access them.
