#define  | RISCV_MSTATUS_MIE   0x8 |
#define  | CPU_ISR_PASSES_FRAME_POINTER   FALSE |
#define  | CPU_HARDWARE_FP   FALSE |
#define  | CPU_SOFTWARE_FP   FALSE |
#define  | CPU_ALL_TASKS_ARE_FP   FALSE |
#define  | CPU_IDLE_TASK_IS_FP   FALSE |
#define  | CPU_USE_DEFERRED_FP_SWITCH   FALSE |
#define  | CPU_ENABLE_ROBUST_THREAD_DISPATCH   TRUE |
#define  | CPU_STACK_GROWS_UP   FALSE |
#define  | CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned (64))) |
#define  | CPU_BIG_ENDIAN   FALSE |
#define  | CPU_LITTLE_ENDIAN   TRUE |
#define  | CPU_MODES_INTERRUPT_MASK   0x0000000000000001 |
#define  | CPU_CACHE_LINE_BYTES   64 |
#define  | CPU_ALIGNMENT   16 |
#define  | CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT |
#define  | CPU_STACK_ALIGNMENT   16 |
#define  | CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES |
#define  | _CPU_Context_Get_SP(_context)   (_context)->sp |
#define  | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0 |
#define  | CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE |
#define  | _CPU_Initialize_vectors() |
#define  | _CPU_ISR_Disable(_level)   _level = riscv_interrupt_disable() |
#define  | _CPU_ISR_Enable(_level)   riscv_interrupt_enable( _level ) |
| #define  | _CPU_ISR_Flash(_level) |
#define  | _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) ) |
#define  | CPU_USE_GENERIC_BITFIELD_CODE   TRUE |
#define  | CPU_USE_GENERIC_BITFIELD_DATA   TRUE |
#define  | CPU_MAXIMUM_PROCESSORS   32 |
#define  | CPU_swap_u16(value)   (((value&0xff) << 8) | ((value >> 8)&0xff)) |
typedef uint16_t  | Priority_bit_map_Word |
typedef uint32_t  | CPU_Counter_ticks |
| typedef uintptr_t  | CPU_Uint32ptr |
| enum   | RISCV_Interrupt_code {
  RISCV_INTERRUPT_SOFTWARE_USER = 0,
RISCV_INTERRUPT_SOFTWARE_SUPERVISOR = 1,
RISCV_INTERRUPT_SOFTWARE_MACHINE = 3,
RISCV_INTERRUPT_TIMER_USER = 4,
  RISCV_INTERRUPT_TIMER_SUPERVISOR = 5,
RISCV_INTERRUPT_TIMER_MACHINE = 7,
RISCV_INTERRUPT_EXTERNAL_USER = 8,
RISCV_INTERRUPT_EXTERNAL_SUPERVISOR = 9,
  RISCV_INTERRUPT_EXTERNAL_MACHINE = 11
| enum   | RISCV_Exception_code {
  RISCV_EXCEPTION_INSTRUCTION_ADDRESS_MISALIGNED = 0,
RISCV_EXCEPTION_INSTRUCTION_ACCESS_FAULT = 1,
RISCV_EXCEPTION_ILLEGAL_INSTRUCTION = 2,
RISCV_EXCEPTION_BREAKPOINT = 3,
  RISCV_EXCEPTION_LOAD_ADDRESS_MISALIGNED = 4,
RISCV_EXCEPTION_LOAD_ACCESS_FAULT = 5,
RISCV_EXCEPTION_STORE_OR_AMO_ADDRESS_MISALIGNED = 6,
RISCV_EXCEPTION_STORE_OR_AMO_ACCESS_FAULT = 7,
  RISCV_EXCEPTION_ENVIRONMENT_CALL_FROM_U_MODE = 8,
RISCV_EXCEPTION_ENVIRONMENT_CALL_FROM_S_MODE = 9,
RISCV_EXCEPTION_ENVIRONMENT_CALL_FROM_M_MODE = 11,
RISCV_EXCEPTION_INSTRUCTION_PAGE_FAULT = 12,
  RISCV_EXCEPTION_LOAD_PAGE_FAULT = 13,
RISCV_EXCEPTION_STORE_OR_AMO_PAGE_FAULT = 15
volatile uint32_t *const  | _RISCV_Counter |
◆ _CPU_ISR_Flash
          | #define _CPU_ISR_Flash |
          _level | ) |
Value:do{ \
      _CPU_ISR_Enable( _level ); \
      riscv_interrupt_disable(); \
    } while(0)
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
