36 #define GRLIB_IO_AREA 0xfff00000    39 #define GRLIB_CONF_AREA 0xff000    40 #define GRLIB_AHB_SLAVE_CONF_AREA (1 << 11)    42 #define GRLIB_AHB_CONF_WORDS 8    43 #define GRLIB_APB_CONF_WORDS 2    44 #define GRLIB_AHB_MASTERS 64    45 #define GRLIB_AHB_SLAVES 64    46 #define GRLIB_APB_SLAVES 16    48 #if defined(RTEMS_MULTIPROCESSING)    49   #define GRLIB_CLOCK_INDEX \    50    (rtems_configuration_get_user_multiprocessing_table() ? GRLIB_Cpu_Index : 0)    52   #define GRLIB_CLOCK_INDEX 0    55 #if defined(RTEMS_SMP)    56 #define GRLIB_COUNTER_GPTIMER_INDEX (GRLIB_CLOCK_INDEX + 1)    58 #define GRLIB_COUNTER_GPTIMER_INDEX GRLIB_CLOCK_INDEX    61 #define GRLIB_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000    63 #define GRLIB_IRQMPSTATUS_CPUNR     28    75 extern uint32_t GRLIB_Cpu_Index;
    76 extern const unsigned char GRLIB_mp_irq;
    78 extern volatile struct irqmp_regs *GRLIB_IrqCtrl_Regs;
    80 extern int GRLIB_IrqCtrl_EIrq;
    83 void gptimer_initialize(
void);
    84 void irqmp_initialize(
void);
    86 static inline uint32_t grlib_up_counter_frequency(
void)
    92   return ambapp_freq_get(&ambapp_plb, GRLIB_IrqCtrl_Adev);
    98 static inline uint32_t grlib_get_cpu_count(
   102   uint32_t mpstat = irqmp->mpstat;
   104   return ((mpstat >> GRLIB_IRQMPSTATUS_CPUNR) & 0xf)  + 1;
   107 #define GRLIB_IRQCTRL_ACQUIRE( _lock_context ) \   108   rtems_interrupt_lock_acquire( &GRLIB_IrqCtrl_Lock, _lock_context )   110 #define GRLIB_IRQCTRL_RELEASE( _lock_context ) \   111   rtems_interrupt_lock_release( &GRLIB_IrqCtrl_Lock, _lock_context )   113 #define GRLIB_Cpu_Unmask_interrupt( _source, _cpu ) \   115     rtems_interrupt_lock_context _lock_context; \   116     GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \   117     GRLIB_IrqCtrl_Regs->mask[_cpu]  |= (1U << (_source)); \   118     GRLIB_IRQCTRL_RELEASE( &_lock_context ); \   121 #define GRLIB_Cpu_Mask_interrupt( _source, _cpu ) \   123     rtems_interrupt_lock_context _lock_context; \   124     GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \   125      GRLIB_IrqCtrl_Regs->mask[_cpu]  &= ~(1U << (_source)); \   126     GRLIB_IRQCTRL_RELEASE( &_lock_context ); \   129 #define GRLIB_Enable_interrupt_broadcast( _source ) \   131     rtems_interrupt_lock_context _lock_context; \   132     uint32_t _mask = 1U << ( _source ); \   133     GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \   134     GRLIB_IrqCtrl_Regs->bcast |= _mask; \   135     GRLIB_IRQCTRL_RELEASE( &_lock_context ); \   138 #define GRLIB_Disable_interrupt_broadcast( _source ) \   140     rtems_interrupt_lock_context _lock_context; \   141     uint32_t _mask = 1U << ( _source ); \   142     GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \   143     GRLIB_IrqCtrl_Regs->bcast &= ~_mask; \   144     GRLIB_IRQCTRL_RELEASE( &_lock_context ); \   147 #define BSP_Cpu_Is_interrupt_masked( _source, _cpu ) \   148      (!(GRLIB_IrqCtrl_Regs->mask[_cpu] & (1U << (_source))))
ISR lock control.
Definition: isrlock.h:56
Common GRLIB AMBA Core Register definitions.
