RTEMS  5.1
ambapp.h File Reference
#include "ambapp_ids.h"
struct  ambapp_dev
struct  ambapp_common_info
struct  ambapp_apb_info
struct  ambapp_ahb_info
struct  ambapp_core
struct  ambapp_ahb_bus
struct  ambapp_mmap
struct  ambapp_bus
struct  ambapp_pnp_ahb
struct  ambapp_pnp_apb
#define AHB_BUS_MAX   6
#define AMBAPP_FLAG_FFACT_DIR   0x100 /* Frequency factor direction, 0=down, 1=up */
#define AMBAPP_FLAG_FFACT   0x0f0 /* Frequency factor against top bus */
#define AMBAPP_FLAG_MBUS   0x00c
#define AMBAPP_FLAG_SBUS   0x003
#define DEV_TO_APB(adev)   ((struct ambapp_apb_info *)((adev)->devinfo))
#define DEV_TO_AHB(adev)   ((struct ambapp_ahb_info *)((adev)->devinfo))
#define DEV_TO_COMMON(adev)   ((struct ambapp_common_info *)((adev)->devinfo))
#define APB_TO_DEV(apb_info)
#define AHB_TO_DEV(ahb_info)
#define DEV_IS_FREE(dev)   (dev->owner == NULL)
#define DEV_IS_ALLOCATED(dev)   (dev->owner != NULL)
#define OPTIONS_AHB_MSTS   0x00000001
#define OPTIONS_AHB_SLVS   0x00000002
#define OPTIONS_APB_SLVS   0x00000004
#define OPTIONS_ALL_DEVS   (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)
#define OPTIONS_FREE   0x00000010
#define OPTIONS_ALLOCATED   0x00000020
#define OPTIONS_ALL   (OPTIONS_FREE|OPTIONS_ALLOCATED)
#define OPTIONS_DEPTH_FIRST   0x00000100
#define DEV_AHB_NONE   0
#define DEV_AHB_MST   1
#define DEV_AHB_SLV   2
#define DEV_APB_SLV   3
#define ambapp_pnp_vendor(id)   (((id) >> 24) & 0xff)
#define ambapp_pnp_device(id)   (((id) >> 12) & 0xfff)
#define ambapp_pnp_ver(id)   (((id)>>5) & 0x1f)
#define ambapp_pnp_irq(id)   ((id) & 0x1f)
#define ambapp_pnp_start(mbar)   (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))
#define ambapp_pnp_mbar_mask(mbar)   (((mbar)>>4) & 0xfff)
#define ambapp_pnp_mbar_type(mbar)   ((mbar) & 0xf)
#define ambapp_pnp_apb_start(iobar, base)   ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )
#define ambapp_pnp_apb_mask(iobar)   ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)
#define AMBA_TYPE_AHBIO_ADDR(addr, base_ioarea)   ((unsigned int)(base_ioarea) | ((addr) >> 12))
#define AMBA_TYPE_APBIO   0x1
#define AMBA_TYPE_MEM   0x2
#define AMBA_TYPE_AHBIO   0x3
typedef int(* ambapp_func_t) (struct ambapp_dev *dev, int index, void *arg)
typedef void *(* ambapp_memcpy_t) (void *dest, const void *src, int n, struct ambapp_bus *abus)
int ambapp_scan (struct ambapp_bus *abus, unsigned int ioarea, ambapp_memcpy_t memfunc, struct ambapp_mmap *mmaps)
void ambapp_freq_init (struct ambapp_bus *abus, struct ambapp_dev *dev, unsigned int freq)
unsigned int ambapp_freq_get (struct ambapp_bus *abus, struct ambapp_dev *dev)
int ambapp_for_each (struct ambapp_bus *abus, unsigned int options, int vendor, int device, ambapp_func_t func, void *arg)
int ambapp_find_by_idx (struct ambapp_dev *dev, int index, void *pcount)
int ambapp_dev_count (struct ambapp_bus *abus, unsigned int options, int vendor, int device)
void ambapp_print (struct ambapp_bus *abus, int show_depth)
int ambapp_alloc_dev (struct ambapp_dev *dev, void *owner)
void ambapp_free_dev (struct ambapp_dev *dev)
struct ambapp_dev * ambapp_find_parent (struct ambapp_dev *dev)
int ambapp_depth (struct ambapp_dev *dev)
char * ambapp_device_id2str (int vendor, int id)
char * ambapp_vendor_id2str (int vendor)
int ambapp_vendev_id2str (int vendor, int id, char *buf)
int ambapp_find_apbslv (struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev)
int ambapp_find_apbslv_next (struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index)
int ambapp_find_apbslvs_next (struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int index, int maxno)
int ambapp_find_apbslvs (struct ambapp_bus *abus, int vendor, int device, struct ambapp_apb_info *dev, int maxno)
int ambapp_find_ahbslv (struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev)
int ambapp_find_ahbslv_next (struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index)
int ambapp_find_ahbslvs_next (struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int index, int maxno)
int ambapp_find_ahbslvs (struct ambapp_bus *abus, int vendor, int device, struct ambapp_ahb_info *dev, int maxno)
int ambapp_get_number_ahbslv_devices (struct ambapp_bus *abus, int vendor, int device)
int ambapp_get_number_apbslv_devices (struct ambapp_bus *abus, int vendor, int device)
