49     unsigned char dev_type;
    55 #define AMBAPP_FLAG_FFACT_DIR   0x100       56 #define AMBAPP_FLAG_FFACT   0x0f0       57 #define AMBAPP_FLAG_MBUS    0x00c    58 #define AMBAPP_FLAG_SBUS    0x003    61 #define DEV_TO_APB(adev) ((struct ambapp_apb_info *)((adev)->devinfo))    62 #define DEV_TO_AHB(adev) ((struct ambapp_ahb_info *)((adev)->devinfo))    63 #define DEV_TO_COMMON(adev) ((struct ambapp_common_info *)((adev)->devinfo))    65 #define APB_TO_DEV(apb_info) ((struct ambapp_dev *)(unsigned int(apb_info) - \    66                 offsetof(struct ambapp_dev, devinfo)))    67 #define AHB_TO_DEV(ahb_info) ((struct ambapp_dev *)(unsigned int(ahb_info) - \    68                 offsetof(struct ambapp_dev, devinfo)))    94     unsigned int start[4];
    98     unsigned int custom[3];
   104     unsigned char       vendor;
   114     unsigned int freq_hz;
   121     unsigned int        local_adr;
   122     unsigned int        remote_adr;
   137 typedef int (*ambapp_func_t)(
struct ambapp_dev *dev,
int index,
void *arg);
   139 #define DEV_IS_FREE(dev) (dev->owner == NULL)   140 #define DEV_IS_ALLOCATED(dev) (dev->owner != NULL)   143 #define OPTIONS_AHB_MSTS    0x00000001   144 #define OPTIONS_AHB_SLVS    0x00000002   145 #define OPTIONS_APB_SLVS    0x00000004   146 #define OPTIONS_ALL_DEVS    (OPTIONS_AHB_MSTS|OPTIONS_AHB_SLVS|OPTIONS_APB_SLVS)   148 #define OPTIONS_FREE        0x00000010   149 #define OPTIONS_ALLOCATED   0x00000020   150 #define OPTIONS_ALL     (OPTIONS_FREE|OPTIONS_ALLOCATED)   153 #define OPTIONS_DEPTH_FIRST 0x00000100   155 #define DEV_AHB_NONE 0   156 #define DEV_AHB_MST  1   157 #define DEV_AHB_SLV  2   158 #define DEV_APB_SLV 3   162     const unsigned int  id;
   163     const unsigned int  custom[3];
   164     const unsigned int  mbar[4];
   168     const unsigned int  id;
   169     const unsigned int  iobar;
   172 #define ambapp_pnp_vendor(id) (((id) >> 24) & 0xff)   173 #define ambapp_pnp_device(id) (((id) >> 12) & 0xfff)   174 #define ambapp_pnp_ver(id) (((id)>>5) & 0x1f)   175 #define ambapp_pnp_irq(id) ((id) & 0x1f)   177 #define ambapp_pnp_start(mbar)  (((mbar) & 0xfff00000) & (((mbar) & 0xfff0) << 16))    178 #define ambapp_pnp_mbar_mask(mbar) (((mbar)>>4) & 0xfff)   179 #define ambapp_pnp_mbar_type(mbar) ((mbar) & 0xf)   181 #define ambapp_pnp_apb_start(iobar, base) ((base) | ((((iobar) & 0xfff00000)>>12) & (((iobar) & 0xfff0)<<4)) )   182 #define ambapp_pnp_apb_mask(iobar) ((~(ambapp_pnp_mbar_mask(iobar)<<8) & 0x000fffff) + 1)   184 #define AMBA_TYPE_AHBIO_ADDR(addr,base_ioarea) ((unsigned int)(base_ioarea) | ((addr) >> 12))   186 #define AMBA_TYPE_APBIO 0x1   187 #define AMBA_TYPE_MEM   0x2   188 #define AMBA_TYPE_AHBIO 0x3   191 typedef void *(*ambapp_memcpy_t)(
   211 extern int ambapp_scan(
   214     ambapp_memcpy_t memfunc,
   221 extern void ambapp_freq_init(
   227 extern unsigned int ambapp_freq_get(
   257 extern int ambapp_for_each(
   259     unsigned int options,
   274 extern int ambapp_find_by_idx(
int index,
void *pcount);
   279 extern int ambapp_dev_count(
struct ambapp_bus *abus,
   283 extern void ambapp_print(
int show_depth);
   288 extern int ambapp_alloc_dev(
void *owner);
   291 extern void ambapp_free_dev(
struct ambapp_dev *dev);
   297 extern int ambapp_depth(
   300 extern char *ambapp_device_id2str(
int vendor,
int id);
   303 extern char *ambapp_vendor_id2str(
int vendor);
   308 extern int ambapp_vendev_id2str(
int vendor,
int id,
char *buf);
   312 extern int ambapp_find_apbslv(
   318 extern int ambapp_find_apbslv_next(
   325 extern int ambapp_find_apbslvs_next(
   333 extern int ambapp_find_apbslvs(
   340 extern int ambapp_find_ahbslv(
   346 extern int ambapp_find_ahbslv_next(
   353 extern int ambapp_find_ahbslvs_next(
   361 extern int ambapp_find_ahbslvs(
   369 extern int ambapp_get_number_ahbslv_devices(
   374 extern int ambapp_get_number_apbslv_devices(
Definition: rtemscompat1.h:15
AMBA Plug & Play Bus Vendor and Device IDs.
