23 #define MAX_DEVICES 256                     24 #define AVE_PNP_SIZE 32                     25 #define MAX_MEM_SEGS 64                     33 typedef enum _L1CACHE_TYPE {
    39 typedef enum _TLB_TYPE {
    45 typedef enum _FIRMWARE_SUPPORT {
    55   SCSI_InitiatorID_Override = 0x0200,
    60 typedef enum _FIRMWARE_SUPPLIERS {
    65   QEMU = (
'q'<<24) | (
'e'<<16) | (
'm'<<8) | (
'u'<<0),
    68 typedef enum _ENDIAN_SWITCH_METHODS {
    70   UsePCIConfigA8 = 0x02,
    72   } ENDIAN_SWITCH_METHODS;
    74 typedef enum _SPREAD_IO_METHODS {
    82   unsigned char PrintableModel[32];
    87   unsigned char Serial[16];
    92   unsigned char Reserved[48];
    93   unsigned long FirmwareSupplier;
    94   unsigned long FirmwareSupports;
    95   unsigned long NvramSize;
    96   unsigned long NumSIMMSlots;
    97   unsigned short EndianSwitchMethod;
    98   unsigned short SpreadIOMethod;
   100   unsigned long RAMErrLogOffset;
   101   unsigned long Reserved5;
   102   unsigned long Reserved6;
   103   unsigned long ProcessorHz;
   104   unsigned long ProcessorBusHz;
   105   unsigned long Reserved7;
   106   unsigned long TimeBaseDivisor;
   107   unsigned long WordWidth;
   108   unsigned long PageSize;
   109   unsigned long CoherenceBlockSize;
   112   unsigned long GranuleSize;
   116   unsigned long CacheSize;
   119   unsigned long CacheAttrib;
   120   unsigned long CacheAssoc;
   123   unsigned long CacheLineSize;
   127   unsigned long I_CacheSize;
   128   unsigned long I_CacheAssoc;
   129   unsigned long I_CacheLineSize;
   130   unsigned long D_CacheSize;
   131   unsigned long D_CacheAssoc;
   132   unsigned long D_CacheLineSize;
   135   unsigned long TLBSize;
   136   unsigned long TLBAttrib;
   137   unsigned long TLBAssoc;
   141   unsigned long I_TLBSize;
   142   unsigned long I_TLBAssoc;
   143   unsigned long D_TLBSize;
   144   unsigned long D_TLBAssoc;
   146   unsigned long ExtendedVPD;
   150 typedef enum _DEVICE_FLAGS {
   160   Configurable = 0x0100,
   171 typedef enum _BUS_ID {
   179   PROCESSORDEVICE = 0x80,
   186   unsigned long SerialNum;
   189   unsigned char BaseType;
   190   unsigned char SubType;
   191   unsigned char Interface;
   198     unsigned char LogicalDevNumber;
   199     unsigned short ReadDataPort;
   202     unsigned char SlotNumber;
   204     unsigned char LogicalDevNumber;
   205     unsigned short ISAReserved;
   208     unsigned char SlotNumber;
   209     unsigned char LogicalDevNumber;
   210     unsigned short MCAReserved;
   213     unsigned char SlotNumber;
   214     unsigned char LogicalDevNumber;
   215     unsigned short PCMCIAReserved;
   218     unsigned char SlotNumber;
   219     unsigned char FunctionNumber;
   220     unsigned short EISAReserved;
   223     unsigned char BusNumber;
   224     unsigned char DevFuncNumber;
   225     unsigned short PCIReserved;
   228     unsigned char BusNumber;
   230     unsigned short ProcBusReserved;
   241   unsigned long AllocatedOffset;
   242   unsigned long PossibleOffset;
   243   unsigned long CompatibleOffset;
   246 typedef enum _CPU_STATE {
   251   CPU_NOT_PRESENT = 255
   255   unsigned long CpuType;
   259   unsigned char CpuNumber;
   260   unsigned char CpuState;
   261   unsigned short Reserved;
   265   unsigned long SIMMSize;
   269 typedef enum _MEM_USAGE {
   271   ResumeBlock = 0x4000,
   273   UnPopSystemROM = 0x1000,
   290   unsigned long BasePage;
   291   unsigned long PageCount;
   295   unsigned long ResidualLength;
   296   unsigned char Version;
   297   unsigned char Revision;
   300   VPD VitalProductData;
   302   unsigned short MaxNumCpus;
   303   unsigned short ActualNumCpus;
   308   unsigned long TotalMemory;
   309   unsigned long GoodMemory;
   310   unsigned long ActualNumMemSegs;
   312   unsigned long ActualNumMemories;
   315   unsigned long ActualNumDevices;
   317   unsigned char DevicePnPHeap[2*MAX_DEVICES*AVE_PNP_SIZE];
   327     return QEMU == r->VitalProductData.FirmwareSupplier;
   332 extern void print_residual_device_info(
void);
   335                     unsigned char * DevID,
int BaseType,
   336                     int SubType,
int Interface,
int n);
   338 extern PPC_DEVICE *residual_find_device(
unsigned long BusMask,
   339                     unsigned char * DevID,
int BaseType,
   340                     int SubType,
int Interface,
int n);
   342 extern PnP_TAG_PACKET *PnP_find_packet(
unsigned char *
p,
unsigned packet_tag,
   345                             unsigned packet_type,
   348                             unsigned packet_type,
   353 uint32_t res_copy(
void);
 Definition: residual.h:79
Definition: residual.h:264
Definition: residual.h:195
Definition: residual.h:212
Definition: residual.h:288
unsigned p
Definition: tte.h:90
Definition: residual.h:207
Definition: residual.h:201
Definition: residual.h:254
Definition: residual.h:217
Definition: residual.h:235
Definition: residual.h:196
Definition: residual.h:294
Definition: residual.h:227
Definition: residual.h:183
Definition: residual.h:222
