37 #ifndef _RTEMS_SCORE_CPU_H    38 #define _RTEMS_SCORE_CPU_H    41 #if defined(RTEMS_PARAVIRT)    42 #include <rtems/score/paravirt.h>    65 #define CPU_STACK_GROWS_UP               FALSE    67 #define CPU_CACHE_LINE_BYTES PPC_STRUCTURE_ALIGNMENT    69 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )    87 #if ( PPC_HAS_FPU == 1 )    88 #define CPU_HARDWARE_FP     TRUE    89 #define CPU_SOFTWARE_FP     FALSE    91 #define CPU_HARDWARE_FP     FALSE    92 #define CPU_SOFTWARE_FP     FALSE   108 #define CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP   122 #define CPU_IDLE_TASK_IS_FP      FALSE   124 #define CPU_MAXIMUM_PROCESSORS 32   166   #define PPC_GPR_TYPE uintptr_t   167   #if defined(__powerpc64__)   168     #define PPC_GPR_SIZE 8   169     #define PPC_GPR_LOAD ld   170     #define PPC_GPR_STORE std   172     #define PPC_GPR_SIZE 4   173     #define PPC_GPR_LOAD lwz   174     #define PPC_GPR_STORE stw   177   #define PPC_GPR_TYPE uint64_t   178   #define PPC_GPR_SIZE 8   179   #define PPC_GPR_LOAD evldd   180   #define PPC_GPR_STORE evstdd   183 #if defined(__powerpc64__)   184   #define PPC_REG_SIZE 8   185   #define PPC_REG_LOAD ld   186   #define PPC_REG_STORE std   187   #define PPC_REG_STORE_UPDATE stdu   188   #define PPC_REG_CMP cmpd   190   #define PPC_REG_SIZE 4   191   #define PPC_REG_LOAD lwz   192   #define PPC_REG_STORE stw   193   #define PPC_REG_STORE_UPDATE stwu   194   #define PPC_REG_CMP cmpw   227   uint32_t isr_dispatch_disable;
   228   uint32_t reserved_for_alignment;
   229   #if defined(PPC_MULTILIB_ALTIVEC)   243   #elif defined(__ALTIVEC__)   253     uint8_t altivec[16*12 + 32 + PPC_DEFAULT_CACHE_LINE_SIZE];
   255   #if defined(PPC_MULTILIB_FPU)   281   #if defined(RTEMS_SMP)   282     volatile uint32_t is_executing;
   288     PPC_DEFAULT_CACHE_LINE_SIZE
   290       + (
sizeof(
ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE == 0
   292           : PPC_DEFAULT_CACHE_LINE_SIZE
   293             -
sizeof(
ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE)
   299   uintptr_t clsz = PPC_DEFAULT_CACHE_LINE_SIZE;
   300   uintptr_t mask = clsz - 1;
   301   uintptr_t addr = (uintptr_t)
context;
   306 #define _CPU_Context_Get_SP( _context ) \   307   ppc_get_context(_context)->gpr1   310   static inline bool _CPU_Context_Get_is_executing(
   314     return ppc_get_context(
context)->is_executing;
   317   static inline void _CPU_Context_Set_is_executing(
   322     ppc_get_context(
context)->is_executing = is_executing;
   327 #define PPC_CONTEXT_OFFSET_MSR (PPC_DEFAULT_CACHE_LINE_SIZE)   328 #define PPC_CONTEXT_OFFSET_CR (PPC_DEFAULT_CACHE_LINE_SIZE + 4)   329 #define PPC_CONTEXT_OFFSET_GPR1 (PPC_DEFAULT_CACHE_LINE_SIZE + 8)   330 #define PPC_CONTEXT_OFFSET_LR (PPC_DEFAULT_CACHE_LINE_SIZE + PPC_REG_SIZE + 8)   332 #define PPC_CONTEXT_GPR_OFFSET( gpr ) \   333   (((gpr) - 14) * PPC_GPR_SIZE + \   334     PPC_DEFAULT_CACHE_LINE_SIZE + 8 + 2 * PPC_REG_SIZE)   336 #define PPC_CONTEXT_OFFSET_GPR14 PPC_CONTEXT_GPR_OFFSET( 14 )   337 #define PPC_CONTEXT_OFFSET_GPR15 PPC_CONTEXT_GPR_OFFSET( 15 )   338 #define PPC_CONTEXT_OFFSET_GPR16 PPC_CONTEXT_GPR_OFFSET( 16 )   339 #define PPC_CONTEXT_OFFSET_GPR17 PPC_CONTEXT_GPR_OFFSET( 17 )   340 #define PPC_CONTEXT_OFFSET_GPR18 PPC_CONTEXT_GPR_OFFSET( 18 )   341 #define PPC_CONTEXT_OFFSET_GPR19 PPC_CONTEXT_GPR_OFFSET( 19 )   342 #define PPC_CONTEXT_OFFSET_GPR20 PPC_CONTEXT_GPR_OFFSET( 20 )   343 #define PPC_CONTEXT_OFFSET_GPR21 PPC_CONTEXT_GPR_OFFSET( 21 )   344 #define PPC_CONTEXT_OFFSET_GPR22 PPC_CONTEXT_GPR_OFFSET( 22 )   345 #define PPC_CONTEXT_OFFSET_GPR23 PPC_CONTEXT_GPR_OFFSET( 23 )   346 #define PPC_CONTEXT_OFFSET_GPR24 PPC_CONTEXT_GPR_OFFSET( 24 )   347 #define PPC_CONTEXT_OFFSET_GPR25 PPC_CONTEXT_GPR_OFFSET( 25 )   348 #define PPC_CONTEXT_OFFSET_GPR26 PPC_CONTEXT_GPR_OFFSET( 26 )   349 #define PPC_CONTEXT_OFFSET_GPR27 PPC_CONTEXT_GPR_OFFSET( 27 )   350 #define PPC_CONTEXT_OFFSET_GPR28 PPC_CONTEXT_GPR_OFFSET( 28 )   351 #define PPC_CONTEXT_OFFSET_GPR29 PPC_CONTEXT_GPR_OFFSET( 29 )   352 #define PPC_CONTEXT_OFFSET_GPR30 PPC_CONTEXT_GPR_OFFSET( 30 )   353 #define PPC_CONTEXT_OFFSET_GPR31 PPC_CONTEXT_GPR_OFFSET( 31 )   354 #define PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE PPC_CONTEXT_GPR_OFFSET( 32 )   356 #ifdef PPC_MULTILIB_ALTIVEC   357   #define PPC_CONTEXT_OFFSET_V( v ) \   358     ( ( ( v ) - 20 ) * 16 + PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE + 8)   359   #define PPC_CONTEXT_OFFSET_V20 PPC_CONTEXT_OFFSET_V( 20 )   360   #define PPC_CONTEXT_OFFSET_V21 PPC_CONTEXT_OFFSET_V( 21 )   361   #define PPC_CONTEXT_OFFSET_V22 PPC_CONTEXT_OFFSET_V( 22 )   362   #define PPC_CONTEXT_OFFSET_V23 PPC_CONTEXT_OFFSET_V( 23 )   363   #define PPC_CONTEXT_OFFSET_V24 PPC_CONTEXT_OFFSET_V( 24 )   364   #define PPC_CONTEXT_OFFSET_V25 PPC_CONTEXT_OFFSET_V( 25 )   365   #define PPC_CONTEXT_OFFSET_V26 PPC_CONTEXT_OFFSET_V( 26 )   366   #define PPC_CONTEXT_OFFSET_V27 PPC_CONTEXT_OFFSET_V( 27 )   367   #define PPC_CONTEXT_OFFSET_V28 PPC_CONTEXT_OFFSET_V( 28 )   368   #define PPC_CONTEXT_OFFSET_V29 PPC_CONTEXT_OFFSET_V( 29 )   369   #define PPC_CONTEXT_OFFSET_V30 PPC_CONTEXT_OFFSET_V( 30 )   370   #define PPC_CONTEXT_OFFSET_V31 PPC_CONTEXT_OFFSET_V( 31 )   371   #define PPC_CONTEXT_OFFSET_VRSAVE PPC_CONTEXT_OFFSET_V( 32 )   372   #define PPC_CONTEXT_OFFSET_F( f ) \   373     ( ( ( f ) - 14 ) * 8 + PPC_CONTEXT_OFFSET_VRSAVE + 8 )   375   #define PPC_CONTEXT_OFFSET_F( f ) \   376     ( ( ( f ) - 14 ) * 8 + PPC_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE + 8 )   379 #ifdef PPC_MULTILIB_FPU   380   #define PPC_CONTEXT_OFFSET_F14 PPC_CONTEXT_OFFSET_F( 14 )   381   #define PPC_CONTEXT_OFFSET_F15 PPC_CONTEXT_OFFSET_F( 15 )   382   #define PPC_CONTEXT_OFFSET_F16 PPC_CONTEXT_OFFSET_F( 16 )   383   #define PPC_CONTEXT_OFFSET_F17 PPC_CONTEXT_OFFSET_F( 17 )   384   #define PPC_CONTEXT_OFFSET_F18 PPC_CONTEXT_OFFSET_F( 18 )   385   #define PPC_CONTEXT_OFFSET_F19 PPC_CONTEXT_OFFSET_F( 19 )   386   #define PPC_CONTEXT_OFFSET_F20 PPC_CONTEXT_OFFSET_F( 20 )   387   #define PPC_CONTEXT_OFFSET_F21 PPC_CONTEXT_OFFSET_F( 21 )   388   #define PPC_CONTEXT_OFFSET_F22 PPC_CONTEXT_OFFSET_F( 22 )   389   #define PPC_CONTEXT_OFFSET_F23 PPC_CONTEXT_OFFSET_F( 23 )   390   #define PPC_CONTEXT_OFFSET_F24 PPC_CONTEXT_OFFSET_F( 24 )   391   #define PPC_CONTEXT_OFFSET_F25 PPC_CONTEXT_OFFSET_F( 25 )   392   #define PPC_CONTEXT_OFFSET_F26 PPC_CONTEXT_OFFSET_F( 26 )   393   #define PPC_CONTEXT_OFFSET_F27 PPC_CONTEXT_OFFSET_F( 27 )   394   #define PPC_CONTEXT_OFFSET_F28 PPC_CONTEXT_OFFSET_F( 28 )   395   #define PPC_CONTEXT_OFFSET_F29 PPC_CONTEXT_OFFSET_F( 29 )   396   #define PPC_CONTEXT_OFFSET_F30 PPC_CONTEXT_OFFSET_F( 30 )   397   #define PPC_CONTEXT_OFFSET_F31 PPC_CONTEXT_OFFSET_F( 31 )   400 #if defined(PPC_MULTILIB_FPU)   401   #define PPC_CONTEXT_VOLATILE_SIZE PPC_CONTEXT_OFFSET_F( 32 )   402 #elif defined(PPC_MULTILIB_ALTIVEC)   403   #define PPC_CONTEXT_VOLATILE_SIZE (PPC_CONTEXT_OFFSET_VRSAVE + 4)   404 #elif defined(__ALTIVEC__)   405   #define PPC_CONTEXT_VOLATILE_SIZE \   406     (PPC_CONTEXT_GPR_OFFSET( 32 ) + 8 \   407       + 16 * 12 + 32 + PPC_DEFAULT_CACHE_LINE_SIZE)   409   #define PPC_CONTEXT_VOLATILE_SIZE (PPC_CONTEXT_GPR_OFFSET( 32 ) + 8)   412 #define PPC_CONTEXT_OFFSET_TP PPC_CONTEXT_VOLATILE_SIZE   415   #define PPC_CONTEXT_OFFSET_IS_EXECUTING \   416     (PPC_CONTEXT_OFFSET_TP + PPC_REG_SIZE)   421 #if (PPC_HAS_FPU == 1)   428 #if (PPC_HAS_DOUBLE == 1)   452 #define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE   460 #define CPU_ISR_PASSES_FRAME_POINTER FALSE   498 #define CPU_USE_DEFERRED_FP_SWITCH       FALSE   500 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE   524 #define CPU_MODES_INTERRUPT_MASK   0x00000001    533 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )   541 #define CPU_STACK_CHECK_PATTERN_INITIALIZER \   542   { 0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   543     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   544     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   545     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   546     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   547     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   548     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06, \   549     0xFEEDF00D, 0x0BAD0D06, 0xDEADF00D, 0x600D0D06 }   557 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0   566 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE   581   return ( level & MSR_EE ) != 0;
   584 #if !defined(PPC_DISABLE_INLINE_ISR_DISABLE_ENABLE)   590   if (msr & MSR_EE)
return 0;
   599     msr |= ppc_interrupt_get_disable_mask();
   602     msr &= ~ppc_interrupt_get_disable_mask();
   608 uint32_t ppc_get_interrupt_level(
void );
   609 void ppc_set_interrupt_level( uint32_t level );
   610 #define _CPU_ISR_Get_level( _new_level ) ppc_get_interrupt_level()   611 #define _CPU_ISR_Set_level( _new_level ) ppc_set_interrupt_level(_new_level)   616 #define _CPU_Fatal_halt( _source, _error ) \   618     ppc_interrupt_disable(); \   625       : "r" (_source), "r" (_error) \   635 #define CPU_STACK_MINIMUM_SIZE          (1024*8)   637 #if defined(__powerpc64__)   638 #define CPU_SIZEOF_POINTER 8   640 #define CPU_SIZEOF_POINTER 4   648 #define CPU_ALIGNMENT              (PPC_ALIGNMENT)   662 #define CPU_HEAP_ALIGNMENT         (PPC_ALIGNMENT)   673 #define CPU_STACK_ALIGNMENT        (PPC_STACK_ALIGNMENT)   675 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES   698 static inline uint32_t CPU_swap_u32(
   704   __asm__ volatile(
"rlwimi %0,%1,8,24,31;"   705            "rlwimi %0,%1,24,16,23;"   706            "rlwimi %0,%1,8,8,15;"   707            "rlwimi %0,%1,24,0,7;" :
   708            "=&r" ((swapped)) :
"r" ((value)));
   713 #define CPU_swap_u16( value ) \   714   (((value&0xff) << 8) | ((value >> 8)&0xff))   722   CPU_Counter_ticks value;
   724 #if defined(__PPC_CPU_E6500__)   726   __asm__ volatile(
"mfspr %0, 526" :
"=r" (value) );
   727 #elif defined(mpc860)   728   __asm__ volatile(
"mftb %0" :
"=r" (value) );
   730   __asm__ volatile(
"mfspr %0, 268" :
"=r" (value) );
   736 static inline CPU_Counter_ticks _CPU_Counter_difference(
   737   CPU_Counter_ticks second,
   738   CPU_Counter_ticks first
   741   return second - first;
   786 #define _CPU_Context_Restart_self( _the_context ) \   787    _CPU_Context_restore( (_the_context) );   801 #define _CPU_Context_Initialize_fp( _destination ) \   802   memset( *(_destination), 0, sizeof( **(_destination) ) )   810 #define CPU_USE_GENERIC_BITFIELD_CODE FALSE   867 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \   869     __asm__ volatile ("cntlzw %0, %1" : "=r" ((_output)), "=r" ((_value)) : \   871     (_output) = (_output) - 16; \   882 #define _CPU_Priority_Mask( _bit_number ) \   883   ( 0x8000u >> (_bit_number) )   892 #define _CPU_Priority_bits_index( _priority ) \   957   uint32_t _CPU_SMP_Initialize(
void );
   959   bool _CPU_SMP_Start_processor( uint32_t cpu_index );
   961   void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
   963   void _CPU_SMP_Prepare_start_multitasking(
void );
   965   static inline uint32_t _CPU_SMP_Get_current_processor(
void )
   978   void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
   980   static inline void _CPU_SMP_Processor_event_broadcast(
void )
   982     __asm__ volatile (
"memory" );
   985   static inline void _CPU_SMP_Processor_event_receive(
void )
   987     __asm__ volatile (
"memory" );
   994   uint32_t _EXC_number;
   995   uint32_t RESERVED_FOR_ALIGNMENT_0;
  1000   uintptr_t RESERVED_FOR_ALIGNMENT_1;
  1002     uint32_t EXC_SPEFSCR;
  1037   uintptr_t RESERVED_FOR_ALIGNMENT_2;
  1038   #ifdef PPC_MULTILIB_ALTIVEC  1040     uint32_t RESERVED_FOR_ALIGNMENT_3[3];
  1043     uint32_t RESERVED_FOR_ALIGNMENT_4[3];
  1079   #ifdef PPC_MULTILIB_FPU  1113     uint64_t RESERVED_FOR_ALIGNMENT_5;
  1125 _CPU_Initialize_altivec(
void);
  1134 _CPU_Context_switch_altivec(
  1146 _CPU_Context_restore_altivec(
  1157 _CPU_Context_initialize_altivec(
  1161 void _CPU_Fatal_error(
 #define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
IBM/Motorola PowerPC Definitions.
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
SPARC basic context.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
unsigned context
Definition: tlb.h:108
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
unsigned size
Definition: tte.h:74
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Definition: cpu.h:161
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
