RTEMS  5.1
cpu.h
1
10 /*
11  * This include file contains information pertaining to the XXX
12  * processor.
13  *
14  * @note This file is part of a porting template that is intended
15  * to be used as the starting point when porting RTEMS to a new
16  * CPU family. The following needs to be done when using this as
17  * the starting point for a new port:
18  *
19  * + Anywhere there is an XXX, it should be replaced
20  * with information about the CPU family being ported to.
21  *
22  * + At the end of each comment section, there is a heading which
23  * says "Port Specific Information:". When porting to RTEMS,
24  * add CPU family specific information in this section
25  */
26
27 /*
28  * COPYRIGHT (c) 1989-2008.
29  * On-Line Applications Research Corporation (OAR).
30  *
31  * The license and distribution terms for this file may be
32  * found in the file LICENSE in this distribution or at
33  * http://www.rtems.org/license/LICENSE.
34  */
35
36 #ifndef _RTEMS_SCORE_CPU_H
37 #define _RTEMS_SCORE_CPU_H
38
39 #ifdef __cplusplus
40 extern "C" {
41 #endif
42
43 #include <rtems/score/basedefs.h>
44 #include <rtems/score/no_cpu.h>
45
46 /* conditional compilation parameters */
47
59 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
60
70 #define CPU_ISR_PASSES_FRAME_POINTER FALSE
71
107 #if ( NO_CPU_HAS_FPU == 1 )
108 #define CPU_HARDWARE_FP TRUE
109 #else
110 #define CPU_HARDWARE_FP FALSE
111 #endif
112 #define CPU_SOFTWARE_FP FALSE
113
138 #define CPU_ALL_TASKS_ARE_FP TRUE
139
155 #define CPU_IDLE_TASK_IS_FP FALSE
156
186 #define CPU_USE_DEFERRED_FP_SWITCH TRUE
187
198 #define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
199
211 #define CPU_STACK_GROWS_UP TRUE
212
218 #define CPU_CACHE_LINE_BYTES 32
219
231 #define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
232
244 #define CPU_MODES_INTERRUPT_MASK 0x00000001
245
250 #define CPU_MAXIMUM_PROCESSORS 32
251
252 /*
253  * Processor defined structures required for cpukit/score.
254  *
255  * Port Specific Information:
256  *
257  * XXX document implementation including references if appropriate
258  */
259
260 /* may need to put some structures here. */
261
323 typedef struct {
334
339  uint32_t stack_pointer;
340
341 #ifdef RTEMS_SMP
342
386  volatile bool is_executing;
387 #endif
389
399 #define _CPU_Context_Get_SP( _context ) \
400  (_context)->stack_pointer
401
408 typedef struct {
412
420 typedef struct {
426  uint32_t special_interrupt_register;
428
440
459 /*
460  * Nothing prevents the porter from declaring more CPU specific variables.
461  *
462  * Port Specific Information:
463  *
464  * XXX document implementation including references if appropriate
465  */
466
467 /* XXX: if needed, put more variables here */
468
481 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
482
492 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
493
504 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
505
516 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
517
524 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
525
536 #define CPU_STACK_MINIMUM_SIZE (1024*4)
537
545 #define CPU_SIZEOF_POINTER 4
546
558 #define CPU_ALIGNMENT 8
559
582 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
583
597 #define CPU_STACK_ALIGNMENT 0
598
605 #define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
606
607 /*
608  * ISR handler macros
609  */
610
620 #define _CPU_Initialize_vectors()
621
634 #define _CPU_ISR_Disable( _isr_cookie ) \
635  { \
636  (_isr_cookie) = 0; /* do something to prevent warnings */ \
637  }
638
652 #define _CPU_ISR_Enable( _isr_cookie ) \
653  { \
654  }
655
670 #define _CPU_ISR_Flash( _isr_cookie ) \
671  { \
672  }
673
684 {
685  return false;
686 }
687
705 #define _CPU_ISR_Set_level( new_level ) \
706  { \
707  }
708
721 uint32_t _CPU_ISR_Get_level( void );
722
723 /* end of ISR handler macros */
724
725 /* Context handler macros */
726
742 #define _CPU_Context_Destroy( _the_thread, _the_context ) \
743  { \
744  }
745
783 #define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
784  _isr, _entry_point, _is_fp, _tls_area ) \
785  { \
786  }
787
803 #define _CPU_Context_Restart_self( _the_context ) \
804  _CPU_Context_restore( (_the_context) );
805
824 #define _CPU_Context_Initialize_fp( _destination ) \
825  { \
826  *(*(_destination)) = _CPU_Null_fp_context; \
827  }
828
829 /* end of Context handler macros */
830
831 /* Fatal Error manager macros */
832
842 #define _CPU_Fatal_halt( _source, _error ) \
843  { \
844  }
845
846 /* end of Fatal Error manager macros */
847
848 /* Bitfield handler macros */
849
865 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
866
931 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
932 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
933  { \
934  (_output) = 0; /* do something to prevent warnings */ \
935  }
936 #endif
937
940 /* end of Bitfield handler macros */
941
951 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
952
953 #define _CPU_Priority_Mask( _bit_number ) \
954  ( 1 << (_bit_number) )
955
956 #endif
957
972 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
973
974 #define _CPU_Priority_bits_index( _priority ) \
975  (_priority)
976
977 #endif
978
979 /* end of Priority handler macros */
980
981 /* functions */
982
990 void _CPU_Initialize(void);
991
992 typedef void ( *CPU_ISR_raw_handler )( void );
993
1011  uint32_t vector,
1012  CPU_ISR_raw_handler new_handler,
1013  CPU_ISR_raw_handler *old_handler
1014 );
1015
1016 typedef void ( *CPU_ISR_handler )( uint32_t );
1017
1035  uint32_t vector,
1036  CPU_ISR_handler new_handler,
1037  CPU_ISR_handler *old_handler
1038 );
1039
1047 void *_CPU_Thread_Idle_body( uintptr_t ignored );
1048
1061 void _CPU_Context_switch(
1062  Context_Control *run,
1063  Context_Control *heir
1064 );
1065
1081  Context_Control *new_context
1082 ) RTEMS_NO_RETURN;
1083
1100  Context_Control_fp **fp_context_ptr
1101 );
1102
1119  Context_Control_fp **fp_context_ptr
1120 );
1121
1131 typedef struct {
1132  uint32_t processor_state_register;
1133  uint32_t integer_registers [1];
1134  double float_registers [1];
1136
1142 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
1143
1181 static inline uint32_t CPU_swap_u32(
1182  uint32_t value
1183 )
1184 {
1185  uint32_t byte1, byte2, byte3, byte4, swapped;
1186
1187  byte4 = (value >> 24) & 0xff;
1188  byte3 = (value >> 16) & 0xff;
1189  byte2 = (value >> 8) & 0xff;
1190  byte1 = value & 0xff;
1191
1192  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1193  return swapped;
1194 }
1195
1202 #define CPU_swap_u16( value ) \
1203  (((value&0xff) << 8) | ((value >> 8)&0xff))
1204
1210 typedef uint32_t CPU_Counter_ticks;
1211
1217 uint32_t _CPU_Counter_frequency( void );
1218
1229 CPU_Counter_ticks _CPU_Counter_read( void );
1230
1243 static inline CPU_Counter_ticks _CPU_Counter_difference(
1244  CPU_Counter_ticks second,
1245  CPU_Counter_ticks first
1246 )
1247 {
1248  return second - first;
1249 }
1250
1251 #ifdef RTEMS_SMP
1252
1265  uint32_t _CPU_SMP_Initialize( void );
1266
1280  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
1281
1296  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
1297
1308  void _CPU_SMP_Prepare_start_multitasking( void );
1309
1317  static inline uint32_t _CPU_SMP_Get_current_processor( void )
1318  {
1319  return 123;
1320  }
1321
1330  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
1331
1343  static inline void _CPU_SMP_Processor_event_broadcast( void )
1344  {
1345  __asm__ volatile ( "" : : : "memory" );
1346  }
1347
1356  static inline void _CPU_SMP_Processor_event_receive( void )
1357  {
1358  __asm__ volatile ( "" : : : "memory" );
1359  }
1360
1366  static inline bool _CPU_Context_Get_is_executing(
1367  const Context_Control *context
1368  )
1369  {
1370  return context->is_executing;
1371  }
1372
1379  static inline void _CPU_Context_Set_is_executing(
1381  bool is_executing
1382  )
1383  {
1384  context->is_executing = is_executing;
1385  }
1386
1388 typedef uintptr_t CPU_Uint32ptr;
1389
1390 #endif
1391
1392 #ifdef __cplusplus
1393 }
1394 #endif
1395
1396 #endif
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
uint32_t some_integer_register
Definition: cpu.h:328
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
Thread register context.
Definition: cpu.h:194
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
Interrupt stack frame (ISF).
Definition: cpu.h:191
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
Definition: cpu.h:339
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
double some_float_register
Definition: cpu.h:410
CPU initialization.
Definition: cpu.c:45
SPARC basic context.
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
unsigned context
Definition: tlb.h:108
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
Context_Control_fp _CPU_Null_fp_context
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
Basic Definitions.
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
uint32_t some_system_register
Definition: cpu.h:333
