#define  | MSDOS_NAME_NOT_FOUND_ERR   0x7D01 |
#define  | MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE   32 /* 32 bytes */ |
#define  | MSDOS_DIR_NAME(x)   (char     *)((x) + 0) |
#define  | MSDOS_DIR_ENTRY_TYPE(x)   (uint8_t  *)((x) + 0) |
#define  | MSDOS_DIR_ATTR(x)   (uint8_t  *)((x) + 11) |
#define  | MSDOS_DIR_NT_RES(x)   (uint8_t  *)((x) + 12) |
#define  | MSDOS_DIR_LFN_CHECKSUM(x)   (uint8_t  *)((x) + 13) |
#define  | MSDOS_DIR_CRT_TIME_TENTH(x)   (uint8_t  *)((x) + 13) |
#define  | MSDOS_DIR_CRT_TIME(x)   (uint16_t *)((x) + 14) |
#define  | MSDOS_DIR_CRT_DATE(x)   (uint16_t *)((x) + 16) |
#define  | MSDOS_DIR_LAST_ACCESS_DATE(x)   (uint16_t *)((x) + 18) |
#define  | MSDOS_DIR_FIRST_CLUSTER_HI(x)   (uint16_t *)((x) + 20) |
#define  | MSDOS_DIR_WRITE_TIME(x)   (uint16_t *)((x) + 22) |
#define  | MSDOS_DIR_WRITE_DATE(x)   (uint16_t *)((x) + 24) |
#define  | MSDOS_DIR_FIRST_CLUSTER_LOW(x)   (uint16_t *)((x) + 26) |
#define  | MSDOS_DIR_FILE_SIZE(x)   (uint32_t *)((x) + 28) |
| #define  | MSDOS_EXTRACT_CLUSTER_NUM(p) |
#define  | MSDOS_FILE_SIZE_OFFSET   28 |
#define  | MSDOS_FILE_NAME_OFFSET   0 |
#define  | MSDOS_FIRST_CLUSTER_HI_OFFSET   20 |
#define  | MSDOS_FIRST_CLUSTER_LOW_OFFSET   26 |
#define  | MSDOS_FILE_WDATE_OFFSET   24 |
#define  | MSDOS_FILE_WTIME_OFFSET   22 |
#define  | MSDOS_FILE_ADATE_OFFSET   18 |
#define  | MSDOS_FILE_CDATE_OFFSET   16 |
#define  | MSDOS_FILE_CTIME_OFFSET   14 |
#define  | MSDOS_ATTR_READ_ONLY   0x01 |
#define  | MSDOS_ATTR_HIDDEN   0x02 |
#define  | MSDOS_ATTR_SYSTEM   0x04 |
#define  | MSDOS_ATTR_VOLUME_ID   0x08 |
#define  | MSDOS_ATTR_DIRECTORY   0x10 |
#define  | MSDOS_ATTR_ARCHIVE   0x20 |
| #define  | MSDOS_ATTR_LFN |
| #define  | MSDOS_ATTR_LFN_MASK |
#define  | MSDOS_LAST_LONG_ENTRY   0x40 |
#define  | MSDOS_LAST_LONG_ENTRY_MASK   0x3F |
#define  | MSDOS_DT_2SECONDS_MASK   0x1F    /* seconds divided by 2 */ |
#define  | MSDOS_DT_2SECONDS_SHIFT   0 |
#define  | MSDOS_DT_MINUTES_MASK   0x7E0   /* minutes */ |
#define  | MSDOS_DT_MINUTES_SHIFT   5 |
#define  | MSDOS_DT_HOURS_MASK   0xF800  /* hours */ |
#define  | MSDOS_DT_HOURS_SHIFT   11 |
#define  | MSDOS_DD_DAY_MASK   0x1F    /* day of month */ |
#define  | MSDOS_DD_DAY_SHIFT   0 |
#define  | MSDOS_DD_MONTH_MASK   0x1E0   /* month */ |
#define  | MSDOS_DD_MONTH_SHIFT   5 |
#define  | MSDOS_DD_YEAR_MASK   0xFE00  /* year - 1980 */ |
#define  | MSDOS_DD_YEAR_SHIFT   9 |
#define  | MSDOS_THIS_DIR_ENTRY_EMPTY   0xE5 |
#define  | MSDOS_THIS_DIR_ENTRY_AND_REST_EMPTY   0x00 |
#define  | MSDOS_LFN_LEN_PER_ENTRY   (13) |
#define  | MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR   4 |
#define  | MSDOS_NAME_MIN_UTF8_BYTES_PER_CHAR   1 |
#define  | MSDOS_SHORT_BASE_LEN   8  /* 8 characters */ |
#define  | MSDOS_SHORT_EXT_LEN   3  /* 3 characters */ |
| #define  | MSDOS_SHORT_NAME_LEN |
#define  | MSDOS_NAME_MAX_LNF_LEN   (255) |
#define  | MSDOS_NAME_MAX   MSDOS_SHORT_NAME_LEN |
| #define  | MSDOS_NAME_MAX_UTF8_SFN_BYTES |
#define  | MSDOS_NAME_MAX_WITH_DOT   (MSDOS_NAME_MAX + 1) |
| #define  | MSDOS_SFN_MAX_WITH_DOT_UTF8_BYTES |
#define  | MSDOS_NAME_MAX_LFN_WITH_DOT   (260) |
#define  | MSDOS_NAME_LFN_BYTES_PER_CHAR   (2) |
| #define  | MSDOS_NAME_MAX_LFN_BYTES |
| #define  | MSDOS_NAME_MAX_UTF8_LFN_BYTES |
| #define  | MSDOS_ENTRY_LFN_UTF8_BYTES |
#define  | MSDOS_RES_NT_VALUE   0x00 |
#define  | MSDOS_INIT_DIR_SIZE   0x00 |
#define  | MSDOS_DOT_DIR_ENTRY_OFFSET   0x00 /* first entry in directory */ |
#define  | MSDOS_DOTDOT_DIR_ENTRY_OFFSET   0x20 /* second entry in directory */ |
#define  | DOT_NODE_P(p)   ((char *)(p)) |
#define  | DOTDOT_NODE_P(p)   ((char *)((p) + MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE)) |
#define  | MSDOS_MAX_DIR_LENGTH   0x200000   /* 2,097,152 bytes */ |
#define  | MSDOS_MAX_FILE_SIZE   0xFFFFFFFF /* 4 Gb */ |
#define  | MSDOS_DPS512_NUM   16 |
RTEMS_INLINE_ROUTINE void  | msdos_fs_lock (msdos_fs_info_t *fs_info) |
RTEMS_INLINE_ROUTINE void  | msdos_fs_unlock (msdos_fs_info_t *fs_info) |
| void  | msdos_shut_down (rtems_filesystem_mount_table_entry_t *temp_mt_entry) |
|   | Shut down the MSDOS filesystem.  More...
void  | msdos_eval_path (rtems_filesystem_eval_path_context_t *ctx) |
| void  | msdos_free_node_info (const rtems_filesystem_location_info_t *pathloc) |
|   | Call the Fat-File close routine.  More...
| int  | msdos_mknod (const rtems_filesystem_location_info_t *loc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
|   | Routine for node creation in a MSDOS filesystem.  More...
| int  | msdos_rmnod (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc) |
|   | Remove node from MSDOS directory.  More...
| int  | msdos_rename (const rtems_filesystem_location_info_t *old_parent_loc, const rtems_filesystem_location_info_t *old_loc, const rtems_filesystem_location_info_t *new_parent_loc, const char *new_name, size_t new_namelen) |
|   | Rename a MSDOS filesystem node.  More...
int  | msdos_statvfs (const rtems_filesystem_location_info_t *root_loc, struct statvfs *sb) |
void  | msdos_lock (const rtems_filesystem_mount_table_entry_t *mt_entry) |
void  | msdos_unlock (const rtems_filesystem_mount_table_entry_t *mt_entry) |
| int  | msdos_initialize_support (rtems_filesystem_mount_table_entry_t *temp_mt_entry, const rtems_filesystem_operations_table *op_table, const rtems_filesystem_file_handlers_r *file_handlers, const rtems_filesystem_file_handlers_r *directory_handlers, rtems_dosfs_convert_control *converter) |
|   | MSDOS filesystem initialization routine.  More...
ssize_t  | msdos_file_read (rtems_libio_t *iop, void *buffer, size_t count) |
ssize_t  | msdos_file_write (rtems_libio_t *iop, const void *buffer, size_t count) |
int  | msdos_file_stat (const rtems_filesystem_location_info_t *loc, struct stat *buf) |
int  | msdos_file_ftruncate (rtems_libio_t *iop, off_t length) |
int  | msdos_file_sync (rtems_libio_t *iop) |
ssize_t  | msdos_dir_read (rtems_libio_t *iop, void *buffer, size_t count) |
int  | msdos_dir_sync (rtems_libio_t *iop) |
int  | msdos_dir_stat (const rtems_filesystem_location_info_t *loc, struct stat *buf) |
| int  | msdos_creat_node (const rtems_filesystem_location_info_t *parent_loc, fat_file_type_t type, const char *name, int name_len, mode_t mode, const fat_file_fd_t *link_fd) |
|   | Implements wake up version of the "signal" operation.  More...
int  | msdos_find_name (rtems_filesystem_location_info_t *parent_loc, const char *name, int name_len) |
int  | msdos_get_name_node (const rtems_filesystem_location_info_t *parent_loc, bool create_node, const char *name, int name_len, msdos_name_type_t name_type, fat_dir_pos_t *dir_pos, char *name_dir_entry) |
int  | msdos_dir_info_remove (rtems_filesystem_location_info_t *pathloc) |
ssize_t  | msdos_format_dirent_with_dot (char *dst, const char *src) |
msdos_name_type_t  | msdos_long_to_short (rtems_dosfs_convert_control *converter, const char *lfn, int lfn_len, char *sfn, int sfn_len) |
ssize_t  | msdos_filename_utf8_to_short_name_for_compare (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, void *short_name, const size_t short_name_size) |
ssize_t  | msdos_filename_utf8_to_short_name_for_save (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, void *short_name, const size_t short_name_size) |
ssize_t  | msdos_filename_utf8_to_long_name_for_compare (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, uint8_t *long_name, const size_t long_name_size) |
ssize_t  | msdos_filename_utf8_to_long_name_for_save (rtems_dosfs_convert_control *converter, const uint8_t *utf8_name, const size_t utf8_name_size, uint16_t *long_name, const size_t long_name_size) |
ssize_t  | msdos_get_utf16_string_from_long_entry (const char *entry, uint16_t *entry_string_buf, const size_t buf_size, bool is_first_entry) |
void  | msdos_date_unix2dos (unsigned int tsp, uint16_t *ddp, uint16_t *dtp) |
unsigned int  | msdos_date_dos2unix (unsigned int dd, unsigned int dt) |
int  | msdos_set_first_char4file_name (rtems_filesystem_mount_table_entry_t *mt_entry, fat_dir_pos_t *dir_pos, unsigned char first_char) |
int  | msdos_dir_is_empty (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, bool *ret_val) |
int  | msdos_find_name_in_fat_file (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, bool create_node, const uint8_t *name_utf8, int name_len, msdos_name_type_t name_type, fat_dir_pos_t *dir_pos, char *name_dir_entry) |
int  | msdos_find_node_by_cluster_num_in_fat_file (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, uint32_t cl4find, fat_dir_pos_t *dir_pos, char *dir_entry) |
int  | msdos_get_dotdot_dir_info_cluster_num_and_offset (rtems_filesystem_mount_table_entry_t *mt_entry, uint32_t cln, fat_dir_pos_t *dir_pos, char *dir_entry) |
int  | msdos_sync (rtems_libio_t *iop) |
uint8_t  | msdos_lfn_checksum (const void *entry) |
The MSDOS Filesystem Constants/Data Structures/Prototypes.
