19 #ifndef __DOSFS_FAT_FILE_H__    20 #define __DOSFS_FAT_FILE_H__    85     fat_file_type_t  fat_file_type;
    87     uint32_t         fat_file_size;
    97 #define FAT_FILE_REMOVED 0x01    99 #define FAT_FILE_META_DATA_CHANGED 0x02   101 static inline bool FAT_FILE_IS_REMOVED(
const fat_file_fd_t *fat_fd)
   103      return (fat_fd->flags & FAT_FILE_REMOVED) != 0;
   106 static inline bool FAT_FILE_HAS_META_DATA_CHANGED(
   108      return (fat_fd->flags & FAT_FILE_META_DATA_CHANGED) != 0;
   112 #define F_CLU_NUM  0x01   123 #define FAT_ROOTDIR_CLUSTER_NUM 0x01   125 #define FAT_FD_OF_ROOT_DIR(fat_fd)  \   126   ((fat_fd->dir_pos.sname.cln == FAT_ROOTDIR_CLUSTER_NUM) && \   127   (fat_fd->dir_pos.sname.ofs == 0))   143 static inline uint32_t
   148     return ( ((fat_cluster_num_to_sector512_num(fs_info, pos->cln) +
   149               (pos->ofs >> FAT_SECTOR512_BITS)) << 4)              +
   150               ((pos->ofs >> 5) & (FAT_DIRENTRIES_PER_SEC512 - 1)) );
   154 fat_file_set_first_cluster_num(
fat_file_fd_t *fat_fd, uint32_t cln)
   157     fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
   160 static inline void fat_file_set_file_size(
fat_file_fd_t *fat_fd, uint32_t s)
   162     fat_fd->fat_file_size = s;
   163     fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
   166 static inline void fat_file_set_ctime(
fat_file_fd_t *fat_fd, time_t t)
   169     fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
   172 static inline void fat_file_set_mtime(
   175     fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
   178 static inline void fat_file_set_ctime_mtime(
   182     fat_fd->flags |= FAT_FILE_META_DATA_CHANGED;
   222                   uint32_t                              new_length);
The "fat-file" representation.
Definition: fat_file.h:61
struct fat_file_map_s fat_file_map_t
Descriptor of a fat-file.
Definition: fat_file.h:73
LibIO Internal Interface.
struct fat_file_fd_s fat_file_fd_t
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
