RTEMS  5.1
mqueueimpl.h File Reference
Private Inlined Routines for POSIX Message Queue. More...
#include <rtems/posix/mqueue.h>
#include <rtems/posix/posixapi.h>
#include <rtems/seterr.h>
void _POSIX_Message_queue_Delete (POSIX_Message_queue_Control *the_mq, Thread_queue_Context *queue_context)
 Delete a POSIX Message Queue. More...
ssize_t _POSIX_Message_queue_Receive_support (mqd_t mqdes, char *msg_ptr, size_t msg_len, unsigned int *msg_prio, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout)
int _POSIX_Message_queue_Send_support (mqd_t mqdes, const char *msg_ptr, size_t msg_len, unsigned int msg_prio, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout)
 POSIX Message Queue Send Support. More...
RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * _POSIX_Message_queue_Allocate_unprotected (void)
RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free (POSIX_Message_queue_Control *the_mq)
 POSIX Message Queue Free. More...
RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * _POSIX_Message_queue_Get (Objects_Id id, Thread_queue_Context *queue_context)
RTEMS_INLINE_ROUTINE CORE_message_queue_Submit_types _POSIX_Message_queue_Priority_to_core (unsigned int priority)
RTEMS_INLINE_ROUTINE unsigned int _POSIX_Message_queue_Priority_from_core (CORE_message_queue_Submit_types priority)
RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Namespace_remove (POSIX_Message_queue_Control *the_mq)
 POSIX Message Queue Remove from Namespace.
RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * _POSIX_Message_queue_Get_by_name (const char *name, size_t *name_length_p, Objects_Get_by_name_error *error)
This include file contains the static inline implementation of the private inlined routines for POSIX Message Queue.
◆ _POSIX_Message_queue_Delete()
void _POSIX_Message_queue_Delete ( POSIX_Message_queue_Control *  the_mq,
Thread_queue_Context *  queue_context
This routine supports the mq_unlink and mq_close routines by doing most of the work involved with removing a message queue.
◆ _POSIX_Message_queue_Free()
RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free ( POSIX_Message_queue_Control *  the_mq)
This routine frees a message queue control block to the inactive chain of free message queue control blocks.
◆ _POSIX_Message_queue_Send_support()
int _POSIX_Message_queue_Send_support ( mqd_t  mqdes,
const char *  msg_ptr,
size_t  msg_len,
const struct timespec *  abstime,
This routine posts a message to a specified message queue.
