RTEMS
5.1
Generic console driver implementation. More...
#include <sys/cdefs.h>#include <bsp.h>#include <bsp/console-generic.h>#include <bsp/fatal.h>#include <rtems/bspIo.h>#include <rtems/console.h>Functions | |
| rtems_device_driver | console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console initialization entry point. More... | |
| rtems_device_driver | console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console open entry point. More... | |
| rtems_device_driver | console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console close entry point. More... | |
| rtems_device_driver | console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console read entry point. More... | |
| rtems_device_driver | console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console write entry point. More... | |
| rtems_device_driver | console_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Console IO control entry point. More... | |
| BSP_output_char_function_type | BSP_output_char = console_generic_char_out_init |
| BSP_polling_getchar_function_type | BSP_poll_char = console_generic_char_in |
| rtems_device_driver console_close | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arg | ||
This method closes a specific device supported by the console device driver.
| [in] | major | is the device driver major number |
| [in] | minor | is the device driver minor number |
| [in] | arg | is the parameters to this call |
| RTEMS_SUCCESSFUL | The device driver is successfully closed. |
| rtems_device_driver console_control | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method performs an IO Control operation on a specific device supported by the console device driver.
| RTEMS_SUCCESSFUL | the device driver IO control operation is successfully performed. |
| rtems_device_driver console_initialize | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method initializes the console device driver.
| [in] | major | is the device driver major number. |
| [in] | minor | is the device driver minor number. |
| [in] | arg | is the parameters to this call. |
| RTEMS_SUCCESSFUL | The device driver is successfully initialized. |
Initialize all serial drivers specified in driver_context_table
| [in] | major | |
| [in] | minor | |
| [in] | arg |
| RTEMS_SUCCESSFUL | Initialization completed |
This routine initializes the console IO driver.
Parameters
| major | major number |
| minor | minor number |
Output parameters: NONE
| rtems_device_driver console_open | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method opens a specific device supported by the console device driver.
| RTEMS_SUCCESSFUL | The device driver is successfully opened. |
| rtems_device_driver console_read | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method reads from a specific device supported by the console device driver.
| RTEMS_SUCCESSFUL | The device is successfully read from. |
| rtems_device_driver console_write | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method writes to a specific device supported by the console device driver.
| RTEMS_SUCCESSFUL | The device is successfully written. |
| BSP_output_char_function_type BSP_output_char = console_generic_char_out_init |
This variable points to the BSP provided method to output a character for the purposes of debug output.
It must output only the specific character. It must not perform character translations, e.g. "\n" to "\r\n".
| BSP_polling_getchar_function_type BSP_poll_char = console_generic_char_in |
This variable points to the BSP provided method to input a character for the purposes of debug input.
1.8.15
