#define  | LPC_ETH_CONFIG_TX_BUF_SIZE   1518U |
#define  | DEFAULT_PHY   0 |
#define  | WATCHDOG_TIMEOUT   5 |
#define  | ETH_RX_CTRL_SIZE_MASK   0x000007ffU |
#define  | ETH_RX_CTRL_INTERRUPT   0x80000000U |
#define  | ETH_RX_STAT_RXSIZE_MASK   0x000007ffU |
#define  | ETH_RX_STAT_BYTES   0x00000100U |
#define  | ETH_RX_STAT_CONTROL_FRAME   0x00040000U |
#define  | ETH_RX_STAT_VLAN   0x00080000U |
#define  | ETH_RX_STAT_FAIL_FILTER   0x00100000U |
#define  | ETH_RX_STAT_MULTICAST   0x00200000U |
#define  | ETH_RX_STAT_BROADCAST   0x00400000U |
#define  | ETH_RX_STAT_CRC_ERROR   0x00800000U |
#define  | ETH_RX_STAT_SYMBOL_ERROR   0x01000000U |
#define  | ETH_RX_STAT_LENGTH_ERROR   0x02000000U |
#define  | ETH_RX_STAT_RANGE_ERROR   0x04000000U |
#define  | ETH_RX_STAT_ALIGNMENT_ERROR   0x08000000U |
#define  | ETH_RX_STAT_OVERRUN   0x10000000U |
#define  | ETH_RX_STAT_NO_DESCRIPTOR   0x20000000U |
#define  | ETH_RX_STAT_LAST_FLAG   0x40000000U |
#define  | ETH_RX_STAT_ERROR   0x80000000U |
#define  | ETH_TX_CTRL_SIZE_MASK   0x7ffU |
#define  | ETH_TX_CTRL_SIZE_SHIFT   0 |
#define  | ETH_TX_CTRL_OVERRIDE   0x04000000U |
#define  | ETH_TX_CTRL_HUGE   0x08000000U |
#define  | ETH_TX_CTRL_PAD   0x10000000U |
#define  | ETH_TX_CTRL_CRC   0x20000000U |
#define  | ETH_TX_CTRL_LAST   0x40000000U |
#define  | ETH_TX_CTRL_INTERRUPT   0x80000000U |
#define  | ETH_TX_STAT_COLLISION_COUNT_MASK   0x01e00000U |
#define  | ETH_TX_STAT_DEFER   0x02000000U |
#define  | ETH_TX_STAT_EXCESSIVE_DEFER   0x04000000U |
#define  | ETH_TX_STAT_EXCESSIVE_COLLISION   0x08000000U |
#define  | ETH_TX_STAT_LATE_COLLISION   0x10000000U |
#define  | ETH_TX_STAT_UNDERRUN   0x20000000U |
#define  | ETH_TX_STAT_NO_DESCRIPTOR   0x40000000U |
#define  | ETH_TX_STAT_ERROR   0x80000000U |
#define  | ETH_INT_RX_OVERRUN   0x00000001U |
#define  | ETH_INT_RX_ERROR   0x00000002U |
#define  | ETH_INT_RX_FINISHED   0x00000004U |
#define  | ETH_INT_RX_DONE   0x00000008U |
#define  | ETH_INT_TX_UNDERRUN   0x00000010U |
#define  | ETH_INT_TX_ERROR   0x00000020U |
#define  | ETH_INT_TX_FINISHED   0x00000040U |
#define  | ETH_INT_TX_DONE   0x00000080U |
#define  | ETH_INT_SOFT   0x00001000U |
#define  | ETH_INT_WAKEUP   0x00002000U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_UNICAST   0x00000001U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_BROADCAST   0x00000002U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_MULTICAST   0x00000004U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_UNICAST_HASH   0x00000008U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_MULTICAST_HASH   0x00000010U |
#define  | ETH_RX_FIL_CTRL_ACCEPT_PERFECT   0x00000020U |
#define  | ETH_RX_FIL_CTRL_MAGIC_PACKET_WOL   0x00001000U |
#define  | ETH_RX_FIL_CTRL_RX_FILTER_WOL   0x00002000U |
#define  | ETH_CMD_RX_ENABLE   0x00000001U |
#define  | ETH_CMD_TX_ENABLE   0x00000002U |
#define  | ETH_CMD_REG_RESET   0x00000008U |
#define  | ETH_CMD_TX_RESET   0x00000010U |
#define  | ETH_CMD_RX_RESET   0x00000020U |
#define  | ETH_CMD_PASS_RUNT_FRAME   0x00000040U |
#define  | ETH_CMD_PASS_RX_FILTER   0X00000080U |
#define  | ETH_CMD_TX_FLOW_CONTROL   0x00000100U |
#define  | ETH_CMD_RMII   0x00000200U |
#define  | ETH_CMD_FULL_DUPLEX   0x00000400U |
#define  | ETH_STAT_RX_ACTIVE   0x00000001U |
#define  | ETH_STAT_TX_ACTIVE   0x00000002U |
#define  | ETH_MAC2_FULL_DUPLEX   BSP_BIT32(8) |
#define  | ETH_SUPP_SPEED   BSP_BIT32(8) |
#define  | ETH_MCFG_CLOCK_SELECT(val)   BSP_FLD32(val, 2, 4) |
#define  | ETH_MCFG_RESETMIIMGMT   BSP_BIT32(15) |
#define  | ETH_MCMD_READ   BSP_BIT32(0) |
#define  | ETH_MCMD_SCAN   BSP_BIT32(1) |
#define  | ETH_MADR_REG(val)   BSP_FLD32(val, 0, 4) |
#define  | ETH_MADR_PHY(val)   BSP_FLD32(val, 8, 12) |
#define  | ETH_MIND_BUSY   BSP_BIT32(0) |
#define  | ETH_MIND_SCANNING   BSP_BIT32(1) |
#define  | ETH_MIND_NOT_VALID   BSP_BIT32(2) |
#define  | ETH_MIND_MII_LINK_FAIL   BSP_BIT32(3) |
#define  | LPC_ETH_EVENT_INITIALIZE   RTEMS_EVENT_1 |
#define  | LPC_ETH_EVENT_TXSTART   RTEMS_EVENT_2 |
#define  | LPC_ETH_EVENT_INTERRUPT   RTEMS_EVENT_3 |
#define  | LPC_ETH_EVENT_STOP   RTEMS_EVENT_4 |
#define  | LPC_ETH_INTERRUPT_RECEIVE   (ETH_INT_RX_ERROR | ETH_INT_RX_FINISHED | ETH_INT_RX_DONE) |
#define  | LPC_ETH_INTERRUPT_TRANSMIT   (ETH_INT_TX_DONE | ETH_INT_TX_FINISHED | ETH_INT_TX_ERROR) |
| #define  | LPC_ETH_RX_STAT_ERRORS |
| #define  | LPC_ETH_LAST_FRAGMENT_FLAGS |
#define  | LPC_ETH_PRINTF(...) |
#define  | LPC_ETH_PRINTK(...) |
#define  | LPC_ETH_RX_DATA_OFFSET   2 |
#define  | PHY_KSZ80X1RNL   0x221550 |
#define  | PHY_DP83848   0x20005c90 |
