#define  | DMA_CFG_E   BSP_BIT32(0) |
#define  | DMA_CFG_M_0   BSP_BIT32(1) |
#define  | DMA_CFG_M_1   BSP_BIT32(2) |
#define  | DMA_CH_CTRL_TSZ(val)   BSP_FLD32(val, 0, 11) |
#define  | DMA_CH_CTRL_TSZ_MAX   DMA_CH_CTRL_TSZ(0xfff) |
#define  | DMA_CH_CTRL_SB(val)   BSP_FLD32(val, 12, 14) |
#define  | DMA_CH_CTRL_SB_1   DMA_CH_CTRL_SB(0) |
#define  | DMA_CH_CTRL_SB_4   DMA_CH_CTRL_SB(1) |
#define  | DMA_CH_CTRL_SB_8   DMA_CH_CTRL_SB(2) |
#define  | DMA_CH_CTRL_SB_16   DMA_CH_CTRL_SB(3) |
#define  | DMA_CH_CTRL_SB_32   DMA_CH_CTRL_SB(4) |
#define  | DMA_CH_CTRL_SB_64   DMA_CH_CTRL_SB(5) |
#define  | DMA_CH_CTRL_SB_128   DMA_CH_CTRL_SB(6) |
#define  | DMA_CH_CTRL_SB_256   DMA_CH_CTRL_SB(7) |
#define  | DMA_CH_CTRL_DB(val)   BSP_FLD32(val, 15, 17) |
#define  | DMA_CH_CTRL_DB_1   DMA_CH_CTRL_DB(0) |
#define  | DMA_CH_CTRL_DB_4   DMA_CH_CTRL_DB(1) |
#define  | DMA_CH_CTRL_DB_8   DMA_CH_CTRL_DB(2) |
#define  | DMA_CH_CTRL_DB_16   DMA_CH_CTRL_DB(3) |
#define  | DMA_CH_CTRL_DB_32   DMA_CH_CTRL_DB(4) |
#define  | DMA_CH_CTRL_DB_64   DMA_CH_CTRL_DB(5) |
#define  | DMA_CH_CTRL_DB_128   DMA_CH_CTRL_DB(6) |
#define  | DMA_CH_CTRL_DB_256   DMA_CH_CTRL_DB(7) |
#define  | DMA_CH_CTRL_SW(val)   BSP_FLD32(val, 18, 20) |
#define  | DMA_CH_CTRL_SW_8   DMA_CH_CTRL_SW(0) |
#define  | DMA_CH_CTRL_SW_16   DMA_CH_CTRL_SW(1) |
#define  | DMA_CH_CTRL_SW_32   DMA_CH_CTRL_SW(2) |
#define  | DMA_CH_CTRL_DW(val)   BSP_FLD32(val, 21, 23) |
#define  | DMA_CH_CTRL_DW_8   DMA_CH_CTRL_DW(0) |
#define  | DMA_CH_CTRL_DW_16   DMA_CH_CTRL_DW(1) |
#define  | DMA_CH_CTRL_DW_32   DMA_CH_CTRL_DW(2) |
#define  | DMA_CH_CTRL_S   BSP_BIT32(24) |
#define  | DMA_CH_CTRL_D   BSP_BIT32(25) |
#define  | DMA_CH_CTRL_SI   BSP_BIT32(26) |
#define  | DMA_CH_CTRL_DI   BSP_BIT32(27) |
#define  | DMA_CH_CTRL_PROT(val)   BSP_FLD32(val, 28, 30) |
#define  | DMA_CH_CTRL_I   BSP_BIT32(31) |
#define  | DMA_CH_CFG_E   BSP_BIT32(0) |
#define  | DMA_CH_CFG_SPER(val)   BSP_FLD32(val, 1, 5) |
#define  | DMA_CH_CFG_DPER(val)   BSP_FLD32(val, 6, 10) |
#define  | DMA_CH_CFG_FLOW(val)   BSP_FLD32(val, 11, 13) |
#define  | DMA_CH_CFG_FLOW_MEM_TO_MEM_DMA   DMA_CH_CFG_FLOW(0) |
#define  | DMA_CH_CFG_FLOW_MEM_TO_PER_DMA   DMA_CH_CFG_FLOW(1) |
#define  | DMA_CH_CFG_FLOW_PER_TO_MEM_DMA   DMA_CH_CFG_FLOW(2) |
#define  | DMA_CH_CFG_FLOW_PER_TO_PER_DMA   DMA_CH_CFG_FLOW(3) |
#define  | DMA_CH_CFG_FLOW_PER_TO_PER_DEST   DMA_CH_CFG_FLOW(4) |
#define  | DMA_CH_CFG_FLOW_MEM_TO_PER_PER   DMA_CH_CFG_FLOW(5) |
#define  | DMA_CH_CFG_FLOW_PER_TO_MEM_PER   DMA_CH_CFG_FLOW(6) |
#define  | DMA_CH_CFG_FLOW_PER_TO_PER_SRC   DMA_CH_CFG_FLOW(7) |
#define  | DMA_CH_CFG_IE   BSP_BIT32(14) |
#define  | DMA_CH_CFG_ITC   BSP_BIT32(15) |
#define  | DMA_CH_CFG_L   BSP_BIT32(16) |
#define  | DMA_CH_CFG_A   BSP_BIT32(17) |
#define  | DMA_CH_CFG_H   BSP_BIT32(18) |
#define  | LPC24XX_DMA_PER_SSP_0_TX   0 |
#define  | LPC24XX_DMA_PER_SSP_0_RX   1 |
#define  | LPC24XX_DMA_PER_SSP_1_TX   2 |
#define  | LPC24XX_DMA_PER_SSP_1_RX   3 |
#define  | LPC24XX_DMA_PER_SD_MMC   4 |
#define  | LPC24XX_DMA_PER_I2S_CH_0   5 |
#define  | LPC24XX_DMA_PER_I2S_CH_1   6 |
#define  | LPC32XX_DMA_PER_I2S_0_CH_0   0 |
#define  | LPC32XX_DMA_PER_I2S_0_CH_1   13 |
#define  | LPC32XX_DMA_PER_I2S_1_CH_0   2 |
#define  | LPC32XX_DMA_PER_I2S_1_CH_1   10 |
#define  | LPC32XX_DMA_PER_NAND_0   1 |
#define  | LPC32XX_DMA_PER_NAND_1   12 |
#define  | LPC32XX_DMA_PER_SD_MMC   4 |
#define  | LPC32XX_DMA_PER_SSP_0_RX   14 |
#define  | LPC32XX_DMA_PER_SSP_0_TX   15 |
#define  | LPC32XX_DMA_PER_SSP_1_RX   3 |
#define  | LPC32XX_DMA_PER_SSP_1_TX   11 |
#define  | LPC32XX_DMA_PER_UART_1_RX   6 |
#define  | LPC32XX_DMA_PER_UART_1_TX   5 |
#define  | LPC32XX_DMA_PER_UART_2_RX   8 |
#define  | LPC32XX_DMA_PER_UART_2_TX   7 |
#define  | LPC32XX_DMA_PER_UART_7_RX   10 |
#define  | LPC32XX_DMA_PER_UART_7_TX   9 |
