RTEMS  5.1
Functions | Variables
legacy-console.h File Reference
Extension of the generic libchip console driver shell. More...
#include <libchip/serial.h>
int vt_ioctl (unsigned int cmd, unsigned long arg)
 This function is the ioctl() support for a VGA buffer driver. More...
console_tbl * console_find_console_entry (const char *match, size_t length, rtems_device_minor_number *match_minor)
 console_find_console_entry More...
void console_initialize_data (void)
 console_initialize_data More...
void console_register_devices (console_tbl *new_ports, size_t number_of_ports)
 console_register_devices More...
rtems_device_minor_number BSPPrintkPort
◆ console_find_console_entry()
console_tbl* console_find_console_entry ( const char *  match,
size_t  length,
rtems_device_minor_number *  match_minor
This method is used to search the console entries for a specific device entry and return it. If match is NULL the minor number provided is matched.
◆ console_initialize_data()
void console_initialize_data ( void  )
This must be called before dynamic registration of devices can occur. It is normally called as a side-effect of console_initialize() but if a probe and dynamic registration occurs before that, then this method should be explicitly invoked.
◆ console_register_devices()
void console_register_devices ( console_tbl *  new_ports,
This function expands the console table to include previous ports and the array of new ports specified.
Parameters
[in]new_portsspecifies an array of new ports to register
[in]number_of_portsspecifies the number of elements in the new_ports array
◆ vt_ioctl()
int vt_ioctl ( unsigned int  cmd,
unsigned long  arg
Returns
This method returns 0 on success.
