RTEMS  5.1
Macros | Functions
irq-legacy.c File Reference
Generic BSP interrupt support legacy implementation. More...
#include <rtems/irq.h>
#include <bsp/irq-generic.h>
int BSP_get_current_rtems_irq_handler (rtems_irq_connect_data *cd)
int BSP_install_rtems_irq_handler (const rtems_irq_connect_data *cd)
int BSP_install_rtems_shared_irq_handler (const rtems_irq_connect_data *cd)
int BSP_remove_rtems_irq_handler (const rtems_irq_connect_data *cd)
int BSP_rtems_irq_mngt_set (rtems_irq_global_settings *config)
int BSP_rtems_irq_mngt_get (rtems_irq_global_settings **config)
◆ BSP_get_current_rtems_irq_handler()
int BSP_get_current_rtems_irq_handler ( rtems_irq_connect_data *  cd)
Deprecated:
Obsolete.
◆ BSP_install_rtems_irq_handler()
int BSP_install_rtems_irq_handler ( const rtems_irq_connect_data *  cd)
◆ BSP_install_rtems_shared_irq_handler()
int BSP_install_rtems_shared_irq_handler ( const rtems_irq_connect_data *  cd)
◆ BSP_remove_rtems_irq_handler()
int BSP_remove_rtems_irq_handler ( const rtems_irq_connect_data *  cd)
◆ BSP_rtems_irq_mngt_get()
int BSP_rtems_irq_mngt_get ( rtems_irq_global_settings **  config)
Deprecated:
Obsolete.
◆ BSP_rtems_irq_mngt_set()
int BSP_rtems_irq_mngt_set ( rtems_irq_global_settings *  config)
