49 #define FXP_CXINT_THRESH 120    54 #define FXP_TXCB_MASK   (FXP_NTXCB - 1)    61 #define FXP_NRFABUFS    64    63 #define FXP_NRFABUFS    16    71 #define FXP_MAX_RX_IDLE 15    73 #if __FreeBSD_version < 500000    75 #define FXP_UNLOCK(_sc)    76 #define mtx_init(a, b, c)    77 #define mtx_destroy(a)    78 struct mtx {
int dummy; };
    80 #define FXP_LOCK(_sc)       mtx_lock(&(_sc)->sc_mtx)    81 #define FXP_UNLOCK(_sc)     mtx_unlock(&(_sc)->sc_mtx)    86 #define vtophys(va) alpha_XXX_dmamap((vm_offset_t)(va))   104     bus_space_tag_t sc_st;
   105     bus_space_handle_t sc_sh;
   109     unsigned char pci_fun;
   110     bool pci_regs_are_io;
   111     u_int32_t pci_regs_base;
   116     struct mbuf *rfa_headm;
   117     struct mbuf *rfa_tailm;
   124         enum {fxp_timeout_stopped,fxp_timeout_running,fxp_timeout_stop_rq}
   129     struct ifmedia sc_media;
   138     u_int32_t saved_maps[5];
   139     u_int32_t saved_biosaddr;
   140     u_int8_t saved_intline;
   141     u_int8_t saved_cachelnsz;
   142     u_int8_t saved_lattimer;
   145 #define FXP_CHIP_82557      1      147 #define FXP_FLAG_MWI_ENABLE 0x0001     148 #define FXP_FLAG_READ_ALIGN 0x0002     149 #define FXP_FLAG_WRITE_ALIGN    0x0004     150 #define FXP_FLAG_EXT_TXCB   0x0008     151 #define FXP_FLAG_SERIAL_MEDIA   0x0010     152 #define FXP_FLAG_LONG_PKT_EN    0x0020     153 #define FXP_FLAG_ALL_MCAST  0x0040     154 #define FXP_FLAG_CU_RESUME_BUG  0x0080     158 #define CSR_READ_1(sc, reg)                     \   159     bus_space_read_1((sc)->sc_st, (sc)->sc_sh, (reg))   160 #define CSR_READ_2(sc, reg)                     \   161     bus_space_read_2((sc)->sc_st, (sc)->sc_sh, (reg))   162 #define CSR_READ_4(sc, reg)                     \   163     bus_space_read_4((sc)->sc_st, (sc)->sc_sh, (reg))   164 #define CSR_WRITE_1(sc, reg, val)                   \   165     bus_space_write_1((sc)->sc_st, (sc)->sc_sh, (reg), (val))   166 #define CSR_WRITE_2(sc, reg, val)                   \   167     bus_space_write_2((sc)->sc_st, (sc)->sc_sh, (reg), (val))   168 #define CSR_WRITE_4(sc, reg, val)                   \   169     bus_space_write_4((sc)->sc_st, (sc)->sc_sh, (reg), (val))   171 #define CSR_READ_1(sc, reg) fxp_csr_read_1(sc,reg)   172 #define CSR_READ_2(sc, reg) fxp_csr_read_2(sc,reg)   173 #define CSR_READ_4(sc, reg) fxp_csr_read_4(sc,reg)   175 #define CSR_WRITE_1(sc, reg, val)                   \   177      if ((sc)->pci_regs_are_io)                                         \   178        outport_byte((sc)->pci_regs_base+(reg),val);                     \   180        *((volatile u_int8_t*)((sc)->pci_regs_base)+(reg)) = val;                \   183 #define CSR_WRITE_2(sc, reg, val)                   \   185      if ((sc)->pci_regs_are_io)                                         \   186        outport_word((sc)->pci_regs_base+(reg),val);                     \   188        *((volatile u_int16_t*)((u_int8_t*)((sc)->pci_regs_base)+(reg))) = val; \   191 #define CSR_WRITE_4(sc, reg, val)                   \   193      if ((sc)->pci_regs_are_io)                                         \   194        outport_long((sc)->pci_regs_base+(reg),val);                     \   196        *((volatile u_int32_t*)((u_int8_t*)((sc)->pci_regs_base)+(reg))) = val; \   201 #define sc_if           arpcom.ac_if   203 #define FXP_UNIT(_sc)       (_sc)->arpcom.ac_if.if_unit Definition: if_fxpreg.h:214
Definition: if_fxpreg.h:313
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: rtemscompat1.h:15
Definition: if_fxpvar.h:93
Definition: if_fxpvar.h:78
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: if_fxpreg.h:241
