RTEMS  5.1
Files | Data Structures | Macros | Functions
GDB Interface. More...
file  gdb_if.h
 Definition of the interface between stub and gdb.
struct  rtems_gdb_stub_thread_info
#define QM_MAX_THREADS   (20)
 Max number of threads in qM response.
#define MEMOPT_READABLE   1
#define MEMOPT_WRITEABLE   2
#define NUM_MEMSEGS   10
void mips_gdb_stub_install (int enableThreads)
int gdbstub_add_memsegment (unsigned, unsigned, int)
Prototypes
int parse_zbreak (const char *in, int *type, unsigned char **addr, int *len)
char * mem2hstr (char *buf, const unsigned char *mem, int count)
int hstr2mem (unsigned char *mem, const char *buf, int count)
void set_mem_err (void)
unsigned char get_byte (const unsigned char *ptr)
void set_byte (unsigned char *ptr, int val)
char * thread2vhstr (char *buf, int thread)
char * thread2fhstr (char *buf, int thread)
const char * fhstr2thread (const char *buf, int *thread)
const char * vhstr2thread (const char *buf, int *thread)
char * int2fhstr (char *buf, int val)
char * int2vhstr (char *buf, int vali)
const char * fhstr2int (const char *buf, int *ival)
const char * vhstr2int (const char *buf, int *ival)
int hstr2byte (const char *buf, int *bval)
int hstr2nibble (const char *buf, int *nibble)
Thread_Control * rtems_gdb_index_to_stub_id (int)
int rtems_gdb_stub_thread_support_ok (void)
int rtems_gdb_stub_get_current_thread (void)
int rtems_gdb_stub_get_next_thread (int)
int rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr)
int rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers)
int rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers)
void rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread)
MIPS registers
Numbered in the order in which gdb expects to see them.
#define ZERO   0
#define AT   1
#define V0   2
#define V1   3
#define A0   4
#define A1   5
#define A2   6
#define A3   7
#define T0   8
#define T1   9
#define T2   10
#define T3   11
#define T4   12
#define T5   13
#define T6   14
#define T7   15
#define S0   16
#define S1   17
#define S2   18
#define S3   19
#define S4   20
#define S5   21
#define S6   22
#define S7   23
#define T8   24
#define T9   25
#define K0   26
#define K1   27
#define GP   28
#define SP   29
#define S8   30
#define RA   31
#define SR   32
#define LO   33
#define HI   34
#define BAD_VA   35
#define CAUSE   36
#define PC   37
#define F0   38
#define F1   39
#define F2   40
#define F3   41
#define F4   42
#define F5   43
#define F6   44
#define F7   45
#define F8   46
#define F9   47
#define F10   48
#define F11   49
#define F12   50
#define F13   51
#define F14   52
#define F15   53
#define F16   54
#define F17   55
#define F18   56
#define F19   57
#define F20   58
#define F21   59
#define F22   60
#define F23   61
#define F24   62
#define F25   63
#define F26   64
#define F27   65
#define F28   66
#define F29   67
#define F30   68
#define F31   69
#define FCSR   70
#define FIRR   71
#define NUM_REGS   72
GDB Interface.
