RTEMS  5.1
Files | Macros | Functions
Stack Checker Mechanism
file  stackchk.h
 Stack Checker Information.
file  check.c
 Stack Overflow Check User Extension Set.
#define RTEMS_STACK_CHECKER_EXTENSION
 Stack Checker Extension Set Definition. More...
bool rtems_stack_checker_is_blown (void)
 Checks if current task is blown its stack. More...
void rtems_stack_checker_report_usage (void)
 Print the stack usage report using printk. More...
void rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer)
 Print the stack usage report using caller's routine. More...
bool rtems_stack_checker_create_extension (Thread_Control *running, Thread_Control *the_thread)
 Stack Checker Task Create Extension. More...
void rtems_stack_checker_begin_extension (Thread_Control *executing)
void rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir)
 Stack Checker Task Context Switch Extension. More...
◆ RTEMS_STACK_CHECKER_EXTENSION
Value:
rtems_stack_checker_create_extension, /* rtems_task_create */ \
0, /* rtems_task_start */ \
0, /* rtems_task_restart */ \
0, /* rtems_task_delete */ \
rtems_stack_checker_switch_extension, /* task_switch */ \
rtems_stack_checker_begin_extension, /* task_begin */ \
0, /* task_exitted */ \
0, /* fatal */ \
0 /* terminate */ \
This macro defines the user extension handler set for the stack checker. This macro is normally only used by confdefs.h.
◆ rtems_stack_checker_create_extension()
bool rtems_stack_checker_create_extension ( Thread_Control *  running,
Thread_Control *  the_thread
This method is the task create extension for the stack checker.
Parameters
[in]runningpoints to the currently executing task
[in]the_threadpoints to the newly created task
Note
If this this the first task created, the stack checker will automatically intialize itself.
◆ rtems_stack_checker_is_blown()
bool rtems_stack_checker_is_blown ( void  )
This method is used to determine if the current stack pointer of the currently executing task is within bounds.
Return values
Thismethod returns true if the currently executing task has blown its stack.
◆ rtems_stack_checker_report_usage()
void rtems_stack_checker_report_usage ( void  )
This method prints a stack usage report for the curently executing task.
Note
It uses printk to print the report.
◆ rtems_stack_checker_report_usage_with_plugin()
void rtems_stack_checker_report_usage_with_plugin ( const rtems_printer *  printer)
Parameters
[in]contextis the context to pass to the print handler
[in]printis the print handler
Note
It uses the caller's routine to print the report.
◆ rtems_stack_checker_switch_extension()
void rtems_stack_checker_switch_extension ( Thread_Control *  running,
Thread_Control *  heir
This method is the task context switch extension for the stack checker.
Parameters
[in]runningpoints to the currently executing task which is being context switched out
[in]runningpoints to the heir task which we are switching to
Note
This is called from the internal method _Thread_Dispatch.
