DP8390 Ethernet Controller Support.
More...
| file   | wd80x3.h |
|   | DP8390 Ethernet Controller Support.
#define  | DATAPORT   0x10 |
|   | Port Window.
#define  | RESET   0x1f |
|   | Issue a read for reset.
#define  | W83CREG   0x00 |
|   | I/O port definition.
#define  | ADDROM   0x08 |
#define  | CMDR   0x00+RO |
#define  | CLDA0   0x01+RO |
|   | current local dma addr 0 for read
#define  | CLDA1   0x02+RO |
|   | current local dma addr 1 for read
#define  | BNRY   0x03+RO |
|   | boundary reg for rd and wr
#define  | TSR   0x04+RO |
|   | tx status reg for rd
#define  | NCR   0x05+RO |
|   | number of collision reg for rd
| #define  | FIFO   0x06+RO |
#define  | ISR   0x07+RO |
|   | interrupt status reg for rd and wr
#define  | CRDA0   0x08+RO |
|   | current remote dma address 0 for rd
#define  | CRDA1   0x09+RO |
|   | current remote dma address 1 for rd
#define  | RSR   0x0C+RO |
|   | rx status reg for rd
#define  | CNTR0   0x0D+RO |
|   | tally cnt 0 for frm alg err for rd
#define  | CNTR1   RO+0x0E |
|   | tally cnt 1 for crc err for rd
#define  | CNTR2   0x0F+RO |
|   | tally cnt 2 for missed pkt for rd
#define  | PSTART   0x01+RO |
|   | page start register
#define  | PSTOP   0x02+RO |
|   | page stop register
| #define  | TPSR   0x04+RO |
#define  | TBCR0   0x05+RO |
|   | tx byte count 0 reg
#define  | TBCR1   0x06+RO |
|   | tx byte count 1 reg
#define  | RSAR0   0x08+RO |
|   | remote start address reg 0
#define  | RSAR1   0x09+RO |
|   | remote start address reg 1
#define  | RBCR0   0x0A+RO |
|   | remote byte count reg 0
#define  | RBCR1   0x0B+RO |
|   | remote byte count reg 1
#define  | RCR   0x0C+RO |
|   | rx configuration reg
#define  | TCR   0x0D+RO |
|   | tx configuration reg
#define  | DCR   RO+0x0E |
|   | data configuration reg
#define  | IMR   0x0F+RO |
|   | interrupt mask reg
#define  | PAR   0x01+RO |
|   | physical addr reg base for rd and wr
#define  | CURR   0x07+RO |
|   | current page reg for rd and wr
#define  | MAR   0x08+RO |
|   | multicast addr reg base fro rd and WR
#define  | MARsize   8 |
|   | size of multicast addr space
#define  | MSK_RESET   0x80 |
|   | W83CREG masks.
#define  | MSK_ENASH   0x40 |
#define  | MSK_DECOD   0x3F |
|   | memory decode bits, corresponding
#define  | MSK_STP   0x01 |
|   | stop the chip
#define  | MSK_STA   0x02 |
|   | start the chip
#define  | MSK_TXP   0x04 |
|   | initial txing of a frm
#define  | MSK_RRE   0x08 |
|   | remote read
#define  | MSK_RWR   0x10 |
|   | remote write
#define  | MSK_RD2   0x20 |
|   | no DMA used
#define  | MSK_PG0   0x00 |
|   | select register page 0
#define  | MSK_PG1   0x40 |
|   | select register page 1
#define  | MSK_PG2   0x80 |
|   | select register page 2
#define  | MSK_PRX   0x01 |
#define  | MSK_PTX   0x02 |
#define  | MSK_RXE   0x04 |
#define  | MSK_TXE   0x08 |
#define  | MSK_OVW   0x10 |
#define  | MSK_CNT   0x20 |
#define  | MSK_RDC   0x40 |
#define  | MSK_RST   0x80 |
#define  | MSK_WTS   0x01 |
|   | word transfer mode selection
#define  | MSK_BOS   0x02 |
|   | byte order selection
#define  | MSK_LAS   0x04 |
|   | long addr selection
#define  | MSK_BMS   0x08 |
|   | burst mode selection
#define  | MSK_ARM   0x10 |
|   | autoinitialize remote
#define  | MSK_FT00   0x00 |
|   | burst lrngth selection
#define  | MSK_FT01   0x20 |
#define  | MSK_FT10   0x40 |
#define  | MSK_FT11   0x60 |
#define  | MSK_SEP   0x01 |
|   | save error pkts
#define  | MSK_AR   0x02 |
|   | accept runt pkt
#define  | MSK_AB   0x04 |
|   | 8390 RCR
#define  | MSK_AM   0x08 |
|   | accept multicast
#define  | MSK_PRO   0x10 |
|   | accept all pkt with physical adr
#define  | MSK_MON   0x20 |
|   | monitor mode
#define  | MSK_CRC   0x01 |
|   | inhibit CRC, do not append crc
#define  | MSK_LOOP   0x02 |
|   | set loopback mode
#define  | MSK_BCST   0x04 |
|   | Accept broadcasts.
#define  | MSK_LB01   0x06 |
|   | encoded loopback control
#define  | MSK_ATD   0x08 |
|   | auto tx disable
#define  | MSK_OFST   0x10 |
|   | collision offset enable
#define  | SMK_PRX   0x01 |
|   | rx without error
#define  | SMK_CRC   0x02 |
|   | CRC error.
#define  | SMK_FAE   0x04 |
|   | frame alignment error
#define  | SMK_FO   0x08 |
|   | FIFO overrun.
#define  | SMK_MPA   0x10 |
|   | missed pkt
#define  | SMK_PHY   0x20 |
|   | physical/multicase address
#define  | SMK_DIS   0x40 |
|   | receiver disable. set in monitor mode
#define  | SMK_DEF   0x80 |
|   | deferring
#define  | SMK_PTX   0x01 |
|   | tx without error
#define  | SMK_DFR   0x02 |
|   | non deferred tx
#define  | SMK_COL   0x04 |
|   | tx collided
#define  | SMK_ABT   0x08 |
|   | tx abort because of excessive collisions
#define  | SMK_CRS   0x10 |
|   | carrier sense lost
#define  | SMK_FU   0x20 |
|   | FIFO underrun.
#define  | SMK_CDH   0x40 |
|   | collision detect heartbeat
#define  | SMK_OWC   0x80 |
|   | out of window collision
◆ FIFO
◆ TPSR
@breif tx start page start reg
