#define | PWMCMP_NUMBER 8 |
| | Pwm hardware registers.
#define | PWMCH_NUM_NUMBER 4 |
#define | PWM_CLK_DIVA_Pos 0 |
#define | PWM_CLK_DIVA_Msk (0xffu << PWM_CLK_DIVA_Pos) |
| | (PWM_CLK) CLKA Divide Factor
#define | PWM_CLK_DIVA(value) ((PWM_CLK_DIVA_Msk & ((value) << PWM_CLK_DIVA_Pos))) |
#define | PWM_CLK_DIVA_CLKA_POFF (0x0u << 0) |
| | (PWM_CLK) CLKA clock is turned off
#define | PWM_CLK_DIVA_PREA (0x1u << 0) |
| | (PWM_CLK) CLKA clock is clock selected by PREA
#define | PWM_CLK_PREA_Pos 8 |
#define | PWM_CLK_PREA_Msk (0xfu << PWM_CLK_PREA_Pos) |
| | (PWM_CLK) CLKA Source Clock Selection
#define | PWM_CLK_PREA(value) ((PWM_CLK_PREA_Msk & ((value) << PWM_CLK_PREA_Pos))) |
#define | PWM_CLK_PREA_CLK (0x0u << 8) |
| | (PWM_CLK) Peripheral clock
#define | PWM_CLK_PREA_CLK_DIV2 (0x1u << 8) |
| | (PWM_CLK) Peripheral clock/2
#define | PWM_CLK_PREA_CLK_DIV4 (0x2u << 8) |
| | (PWM_CLK) Peripheral clock/4
#define | PWM_CLK_PREA_CLK_DIV8 (0x3u << 8) |
| | (PWM_CLK) Peripheral clock/8
#define | PWM_CLK_PREA_CLK_DIV16 (0x4u << 8) |
| | (PWM_CLK) Peripheral clock/16
#define | PWM_CLK_PREA_CLK_DIV32 (0x5u << 8) |
| | (PWM_CLK) Peripheral clock/32
#define | PWM_CLK_PREA_CLK_DIV64 (0x6u << 8) |
| | (PWM_CLK) Peripheral clock/64
#define | PWM_CLK_PREA_CLK_DIV128 (0x7u << 8) |
| | (PWM_CLK) Peripheral clock/128
#define | PWM_CLK_PREA_CLK_DIV256 (0x8u << 8) |
| | (PWM_CLK) Peripheral clock/256
#define | PWM_CLK_PREA_CLK_DIV512 (0x9u << 8) |
| | (PWM_CLK) Peripheral clock/512
#define | PWM_CLK_PREA_CLK_DIV1024 (0xAu << 8) |
| | (PWM_CLK) Peripheral clock/1024
#define | PWM_CLK_DIVB_Pos 16 |
#define | PWM_CLK_DIVB_Msk (0xffu << PWM_CLK_DIVB_Pos) |
| | (PWM_CLK) CLKB Divide Factor
#define | PWM_CLK_DIVB(value) ((PWM_CLK_DIVB_Msk & ((value) << PWM_CLK_DIVB_Pos))) |
#define | PWM_CLK_DIVB_CLKB_POFF (0x0u << 16) |
| | (PWM_CLK) CLKB clock is turned off
#define | PWM_CLK_DIVB_PREB (0x1u << 16) |
| | (PWM_CLK) CLKB clock is clock selected by PREB
#define | PWM_CLK_PREB_Pos 24 |
#define | PWM_CLK_PREB_Msk (0xfu << PWM_CLK_PREB_Pos) |
| | (PWM_CLK) CLKB Source Clock Selection
#define | PWM_CLK_PREB(value) ((PWM_CLK_PREB_Msk & ((value) << PWM_CLK_PREB_Pos))) |
#define | PWM_CLK_PREB_CLK (0x0u << 24) |
#define | PWM_CLK_PREB_CLK_DIV2 (0x1u << 24) |
#define | PWM_CLK_PREB_CLK_DIV4 (0x2u << 24) |
#define | PWM_CLK_PREB_CLK_DIV8 (0x3u << 24) |
#define | PWM_CLK_PREB_CLK_DIV16 (0x4u << 24) |
#define | PWM_CLK_PREB_CLK_DIV32 (0x5u << 24) |
#define | PWM_CLK_PREB_CLK_DIV64 (0x6u << 24) |
#define | PWM_CLK_PREB_CLK_DIV128 (0x7u << 24) |
#define | PWM_CLK_PREB_CLK_DIV256 (0x8u << 24) |
#define | PWM_CLK_PREB_CLK_DIV512 (0x9u << 24) |
#define | PWM_CLK_PREB_CLK_DIV1024 (0xAu << 24) |
#define | PWM_ENA_CHID0 (0x1u << 0) |
| | (PWM_ENA) Channel ID
#define | PWM_ENA_CHID1 (0x1u << 1) |
#define | PWM_ENA_CHID2 (0x1u << 2) |
#define | PWM_ENA_CHID3 (0x1u << 3) |
#define | PWM_DIS_CHID0 (0x1u << 0) |
| | (PWM_DIS) Channel ID
#define | PWM_DIS_CHID1 (0x1u << 1) |
#define | PWM_DIS_CHID2 (0x1u << 2) |
#define | PWM_DIS_CHID3 (0x1u << 3) |
#define | PWM_SR_CHID0 (0x1u << 0) |
| | (PWM_SR) Channel ID
#define | PWM_SR_CHID1 (0x1u << 1) |
| | (PWM_SR) Channel ID
#define | PWM_SR_CHID2 (0x1u << 2) |
| | (PWM_SR) Channel ID
#define | PWM_SR_CHID3 (0x1u << 3) |
| | (PWM_SR) Channel ID
#define | PWM_IER1_CHID0 (0x1u << 0) |
| | (PWM_IER1) Counter Event on Channel 0 Interrupt Enable
#define | PWM_IER1_CHID1 (0x1u << 1) |
| | (PWM_IER1) Counter Event on Channel 1 Interrupt Enable
#define | PWM_IER1_CHID2 (0x1u << 2) |
| | (PWM_IER1) Counter Event on Channel 2 Interrupt Enable
#define | PWM_IER1_CHID3 (0x1u << 3) |
| | (PWM_IER1) Counter Event on Channel 3 Interrupt Enable
#define | PWM_IER1_FCHID0 (0x1u << 16) |
| | (PWM_IER1) Fault Protection Trigger on Channel 0 Interrupt Enable
#define | PWM_IER1_FCHID1 (0x1u << 17) |
| | (PWM_IER1) Fault Protection Trigger on Channel 1 Interrupt Enable
#define | PWM_IER1_FCHID2 (0x1u << 18) |
| | (PWM_IER1) Fault Protection Trigger on Channel 2 Interrupt Enable
#define | PWM_IER1_FCHID3 (0x1u << 19) |
| | (PWM_IER1) Fault Protection Trigger on Channel 3 Interrupt Enable
#define | PWM_IDR1_CHID0 (0x1u << 0) |
| | (PWM_IDR1) Counter Event on Channel 0 Interrupt Disable
#define | PWM_IDR1_CHID1 (0x1u << 1) |
| | (PWM_IDR1) Counter Event on Channel 1 Interrupt Disable
#define | PWM_IDR1_CHID2 (0x1u << 2) |
| | (PWM_IDR1) Counter Event on Channel 2 Interrupt Disable
#define | PWM_IDR1_CHID3 (0x1u << 3) |
| | (PWM_IDR1) Counter Event on Channel 3 Interrupt Disable
#define | PWM_IDR1_FCHID0 (0x1u << 16) |
| | (PWM_IDR1) Fault Protection Trigger on Channel 0 Interrupt Disable
#define | PWM_IDR1_FCHID1 (0x1u << 17) |
| | (PWM_IDR1) Fault Protection Trigger on Channel 1 Interrupt Disable
#define | PWM_IDR1_FCHID2 (0x1u << 18) |
| | (PWM_IDR1) Fault Protection Trigger on Channel 2 Interrupt Disable
#define | PWM_IDR1_FCHID3 (0x1u << 19) |
| | (PWM_IDR1) Fault Protection Trigger on Channel 3 Interrupt Disable
#define | PWM_IMR1_CHID0 (0x1u << 0) |
| | (PWM_IMR1) Counter Event on Channel 0 Interrupt Mask
#define | PWM_IMR1_CHID1 (0x1u << 1) |
| | (PWM_IMR1) Counter Event on Channel 1 Interrupt Mask
#define | PWM_IMR1_CHID2 (0x1u << 2) |
| | (PWM_IMR1) Counter Event on Channel 2 Interrupt Mask
#define | PWM_IMR1_CHID3 (0x1u << 3) |
| | (PWM_IMR1) Counter Event on Channel 3 Interrupt Mask
#define | PWM_IMR1_FCHID0 (0x1u << 16) |
| | (PWM_IMR1) Fault Protection Trigger on Channel 0 Interrupt Mask
#define | PWM_IMR1_FCHID1 (0x1u << 17) |
| | (PWM_IMR1) Fault Protection Trigger on Channel 1 Interrupt Mask
#define | PWM_IMR1_FCHID2 (0x1u << 18) |
| | (PWM_IMR1) Fault Protection Trigger on Channel 2 Interrupt Mask
#define | PWM_IMR1_FCHID3 (0x1u << 19) |
| | (PWM_IMR1) Fault Protection Trigger on Channel 3 Interrupt Mask
#define | PWM_ISR1_CHID0 (0x1u << 0) |
| | (PWM_ISR1) Counter Event on Channel 0
#define | PWM_ISR1_CHID1 (0x1u << 1) |
| | (PWM_ISR1) Counter Event on Channel 1
#define | PWM_ISR1_CHID2 (0x1u << 2) |
| | (PWM_ISR1) Counter Event on Channel 2
#define | PWM_ISR1_CHID3 (0x1u << 3) |
| | (PWM_ISR1) Counter Event on Channel 3
#define | PWM_ISR1_FCHID0 (0x1u << 16) |
| | (PWM_ISR1) Fault Protection Trigger on Channel 0
#define | PWM_ISR1_FCHID1 (0x1u << 17) |
| | (PWM_ISR1) Fault Protection Trigger on Channel 1
#define | PWM_ISR1_FCHID2 (0x1u << 18) |
| | (PWM_ISR1) Fault Protection Trigger on Channel 2
#define | PWM_ISR1_FCHID3 (0x1u << 19) |
| | (PWM_ISR1) Fault Protection Trigger on Channel 3
#define | PWM_SCM_SYNC0 (0x1u << 0) |
| | (PWM_SCM) Synchronous Channel 0
#define | PWM_SCM_SYNC1 (0x1u << 1) |
| | (PWM_SCM) Synchronous Channel 1
#define | PWM_SCM_SYNC2 (0x1u << 2) |
| | (PWM_SCM) Synchronous Channel 2
#define | PWM_SCM_SYNC3 (0x1u << 3) |
| | (PWM_SCM) Synchronous Channel 3
#define | PWM_SCM_UPDM_Pos 16 |
#define | PWM_SCM_UPDM_Msk (0x3u << PWM_SCM_UPDM_Pos) |
| | (PWM_SCM) Synchronous Channels Update Mode
#define | PWM_SCM_UPDM(value) ((PWM_SCM_UPDM_Msk & ((value) << PWM_SCM_UPDM_Pos))) |
#define | PWM_SCM_UPDM_MODE0 (0x0u << 16) |
| | (PWM_SCM) Manual write of double buffer registers and manual update of synchronous channels
#define | PWM_SCM_UPDM_MODE1 (0x1u << 16) |
| | (PWM_SCM) Manual write of double buffer registers and automatic update of synchronous channels
#define | PWM_SCM_UPDM_MODE2 (0x2u << 16) |
| | (PWM_SCM) Automatic write of duty-cycle update registers by the DMA Controller and automatic update of synchronous channels
#define | PWM_SCM_PTRM (0x1u << 20) |
| | (PWM_SCM) DMA Controller Transfer Request Mode
#define | PWM_SCM_PTRCS_Pos 21 |
#define | PWM_SCM_PTRCS_Msk (0x7u << PWM_SCM_PTRCS_Pos) |
| | (PWM_SCM) DMA Controller Transfer Request Comparison Selection
#define | PWM_SCM_PTRCS(value) ((PWM_SCM_PTRCS_Msk & ((value) << PWM_SCM_PTRCS_Pos))) |
#define | PWM_DMAR_DMADUTY_Pos 0 |
#define | PWM_DMAR_DMADUTY_Msk (0xffffffu << PWM_DMAR_DMADUTY_Pos) |
| | (PWM_DMAR) Duty-Cycle Holding Register for DMA Access
#define | PWM_DMAR_DMADUTY(value) ((PWM_DMAR_DMADUTY_Msk & ((value) << PWM_DMAR_DMADUTY_Pos))) |
#define | PWM_SCUC_UPDULOCK (0x1u << 0) |
| | (PWM_SCUC) Synchronous Channels Update Unlock
#define | PWM_SCUP_UPR_Pos 0 |
#define | PWM_SCUP_UPR_Msk (0xfu << PWM_SCUP_UPR_Pos) |
| | (PWM_SCUP) Update Period
#define | PWM_SCUP_UPR(value) ((PWM_SCUP_UPR_Msk & ((value) << PWM_SCUP_UPR_Pos))) |
#define | PWM_SCUP_UPRCNT_Pos 4 |
#define | PWM_SCUP_UPRCNT_Msk (0xfu << PWM_SCUP_UPRCNT_Pos) |
| | (PWM_SCUP) Update Period Counter
#define | PWM_SCUP_UPRCNT(value) ((PWM_SCUP_UPRCNT_Msk & ((value) << PWM_SCUP_UPRCNT_Pos))) |
#define | PWM_SCUPUPD_UPRUPD_Pos 0 |
#define | PWM_SCUPUPD_UPRUPD_Msk (0xfu << PWM_SCUPUPD_UPRUPD_Pos) |
| | (PWM_SCUPUPD) Update Period Update
#define | PWM_SCUPUPD_UPRUPD(value) ((PWM_SCUPUPD_UPRUPD_Msk & ((value) << PWM_SCUPUPD_UPRUPD_Pos))) |
#define | PWM_IER2_WRDY (0x1u << 0) |
| | (PWM_IER2) Write Ready for Synchronous Channels Update Interrupt Enable
#define | PWM_IER2_UNRE (0x1u << 3) |
| | (PWM_IER2) Synchronous Channels Update Underrun Error Interrupt Enable
#define | PWM_IER2_CMPM0 (0x1u << 8) |
| | (PWM_IER2) Comparison 0 Match Interrupt Enable
#define | PWM_IER2_CMPM1 (0x1u << 9) |
| | (PWM_IER2) Comparison 1 Match Interrupt Enable
#define | PWM_IER2_CMPM2 (0x1u << 10) |
| | (PWM_IER2) Comparison 2 Match Interrupt Enable
#define | PWM_IER2_CMPM3 (0x1u << 11) |
| | (PWM_IER2) Comparison 3 Match Interrupt Enable
#define | PWM_IER2_CMPM4 (0x1u << 12) |
| | (PWM_IER2) Comparison 4 Match Interrupt Enable
#define | PWM_IER2_CMPM5 (0x1u << 13) |
| | (PWM_IER2) Comparison 5 Match Interrupt Enable
#define | PWM_IER2_CMPM6 (0x1u << 14) |
| | (PWM_IER2) Comparison 6 Match Interrupt Enable
#define | PWM_IER2_CMPM7 (0x1u << 15) |
| | (PWM_IER2) Comparison 7 Match Interrupt Enable
#define | PWM_IER2_CMPU0 (0x1u << 16) |
| | (PWM_IER2) Comparison 0 Update Interrupt Enable
#define | PWM_IER2_CMPU1 (0x1u << 17) |
| | (PWM_IER2) Comparison 1 Update Interrupt Enable
#define | PWM_IER2_CMPU2 (0x1u << 18) |
| | (PWM_IER2) Comparison 2 Update Interrupt Enable
#define | PWM_IER2_CMPU3 (0x1u << 19) |
| | (PWM_IER2) Comparison 3 Update Interrupt Enable
#define | PWM_IER2_CMPU4 (0x1u << 20) |
| | (PWM_IER2) Comparison 4 Update Interrupt Enable
#define | PWM_IER2_CMPU5 (0x1u << 21) |
| | (PWM_IER2) Comparison 5 Update Interrupt Enable
#define | PWM_IER2_CMPU6 (0x1u << 22) |
| | (PWM_IER2) Comparison 6 Update Interrupt Enable
#define | PWM_IER2_CMPU7 (0x1u << 23) |
| | (PWM_IER2) Comparison 7 Update Interrupt Enable
#define | PWM_IDR2_WRDY (0x1u << 0) |
| | (PWM_IDR2) Write Ready for Synchronous Channels Update Interrupt Disable
#define | PWM_IDR2_UNRE (0x1u << 3) |
| | (PWM_IDR2) Synchronous Channels Update Underrun Error Interrupt Disable
#define | PWM_IDR2_CMPM0 (0x1u << 8) |
| | (PWM_IDR2) Comparison 0 Match Interrupt Disable
#define | PWM_IDR2_CMPM1 (0x1u << 9) |
| | (PWM_IDR2) Comparison 1 Match Interrupt Disable
#define | PWM_IDR2_CMPM2 (0x1u << 10) |
| | (PWM_IDR2) Comparison 2 Match Interrupt Disable
#define | PWM_IDR2_CMPM3 (0x1u << 11) |
| | (PWM_IDR2) Comparison 3 Match Interrupt Disable
#define | PWM_IDR2_CMPM4 (0x1u << 12) |
| | (PWM_IDR2) Comparison 4 Match Interrupt Disable
#define | PWM_IDR2_CMPM5 (0x1u << 13) |
| | (PWM_IDR2) Comparison 5 Match Interrupt Disable
#define | PWM_IDR2_CMPM6 (0x1u << 14) |
| | (PWM_IDR2) Comparison 6 Match Interrupt Disable
#define | PWM_IDR2_CMPM7 (0x1u << 15) |
| | (PWM_IDR2) Comparison 7 Match Interrupt Disable
#define | PWM_IDR2_CMPU0 (0x1u << 16) |
| | (PWM_IDR2) Comparison 0 Update Interrupt Disable
#define | PWM_IDR2_CMPU1 (0x1u << 17) |
| | (PWM_IDR2) Comparison 1 Update Interrupt Disable
#define | PWM_IDR2_CMPU2 (0x1u << 18) |
| | (PWM_IDR2) Comparison 2 Update Interrupt Disable
#define | PWM_IDR2_CMPU3 (0x1u << 19) |
| | (PWM_IDR2) Comparison 3 Update Interrupt Disable
#define | PWM_IDR2_CMPU4 (0x1u << 20) |
| | (PWM_IDR2) Comparison 4 Update Interrupt Disable
#define | PWM_IDR2_CMPU5 (0x1u << 21) |
| | (PWM_IDR2) Comparison 5 Update Interrupt Disable
#define | PWM_IDR2_CMPU6 (0x1u << 22) |
| | (PWM_IDR2) Comparison 6 Update Interrupt Disable
#define | PWM_IDR2_CMPU7 (0x1u << 23) |
| | (PWM_IDR2) Comparison 7 Update Interrupt Disable
#define | PWM_IMR2_WRDY (0x1u << 0) |
| | (PWM_IMR2) Write Ready for Synchronous Channels Update Interrupt Mask
#define | PWM_IMR2_UNRE (0x1u << 3) |
| | (PWM_IMR2) Synchronous Channels Update Underrun Error Interrupt Mask
#define | PWM_IMR2_CMPM0 (0x1u << 8) |
| | (PWM_IMR2) Comparison 0 Match Interrupt Mask
#define | PWM_IMR2_CMPM1 (0x1u << 9) |
| | (PWM_IMR2) Comparison 1 Match Interrupt Mask
#define | PWM_IMR2_CMPM2 (0x1u << 10) |
| | (PWM_IMR2) Comparison 2 Match Interrupt Mask
#define | PWM_IMR2_CMPM3 (0x1u << 11) |
| | (PWM_IMR2) Comparison 3 Match Interrupt Mask
#define | PWM_IMR2_CMPM4 (0x1u << 12) |
| | (PWM_IMR2) Comparison 4 Match Interrupt Mask
#define | PWM_IMR2_CMPM5 (0x1u << 13) |
| | (PWM_IMR2) Comparison 5 Match Interrupt Mask
#define | PWM_IMR2_CMPM6 (0x1u << 14) |
| | (PWM_IMR2) Comparison 6 Match Interrupt Mask
#define | PWM_IMR2_CMPM7 (0x1u << 15) |
| | (PWM_IMR2) Comparison 7 Match Interrupt Mask
#define | PWM_IMR2_CMPU0 (0x1u << 16) |
| | (PWM_IMR2) Comparison 0 Update Interrupt Mask
#define | PWM_IMR2_CMPU1 (0x1u << 17) |
| | (PWM_IMR2) Comparison 1 Update Interrupt Mask
#define | PWM_IMR2_CMPU2 (0x1u << 18) |
| | (PWM_IMR2) Comparison 2 Update Interrupt Mask
#define | PWM_IMR2_CMPU3 (0x1u << 19) |
| | (PWM_IMR2) Comparison 3 Update Interrupt Mask
#define | PWM_IMR2_CMPU4 (0x1u << 20) |
| | (PWM_IMR2) Comparison 4 Update Interrupt Mask
#define | PWM_IMR2_CMPU5 (0x1u << 21) |
| | (PWM_IMR2) Comparison 5 Update Interrupt Mask
#define | PWM_IMR2_CMPU6 (0x1u << 22) |
| | (PWM_IMR2) Comparison 6 Update Interrupt Mask
#define | PWM_IMR2_CMPU7 (0x1u << 23) |
| | (PWM_IMR2) Comparison 7 Update Interrupt Mask
#define | PWM_ISR2_WRDY (0x1u << 0) |
| | (PWM_ISR2) Write Ready for Synchronous Channels Update
#define | PWM_ISR2_UNRE (0x1u << 3) |
| | (PWM_ISR2) Synchronous Channels Update Underrun Error
#define | PWM_ISR2_CMPM0 (0x1u << 8) |
| | (PWM_ISR2) Comparison 0 Match
#define | PWM_ISR2_CMPM1 (0x1u << 9) |
| | (PWM_ISR2) Comparison 1 Match
#define | PWM_ISR2_CMPM2 (0x1u << 10) |
| | (PWM_ISR2) Comparison 2 Match
#define | PWM_ISR2_CMPM3 (0x1u << 11) |
| | (PWM_ISR2) Comparison 3 Match
#define | PWM_ISR2_CMPM4 (0x1u << 12) |
| | (PWM_ISR2) Comparison 4 Match
#define | PWM_ISR2_CMPM5 (0x1u << 13) |
| | (PWM_ISR2) Comparison 5 Match
#define | PWM_ISR2_CMPM6 (0x1u << 14) |
| | (PWM_ISR2) Comparison 6 Match
#define | PWM_ISR2_CMPM7 (0x1u << 15) |
| | (PWM_ISR2) Comparison 7 Match
#define | PWM_ISR2_CMPU0 (0x1u << 16) |
| | (PWM_ISR2) Comparison 0 Update
#define | PWM_ISR2_CMPU1 (0x1u << 17) |
| | (PWM_ISR2) Comparison 1 Update
#define | PWM_ISR2_CMPU2 (0x1u << 18) |
| | (PWM_ISR2) Comparison 2 Update
#define | PWM_ISR2_CMPU3 (0x1u << 19) |
| | (PWM_ISR2) Comparison 3 Update
#define | PWM_ISR2_CMPU4 (0x1u << 20) |
| | (PWM_ISR2) Comparison 4 Update
#define | PWM_ISR2_CMPU5 (0x1u << 21) |
| | (PWM_ISR2) Comparison 5 Update
#define | PWM_ISR2_CMPU6 (0x1u << 22) |
| | (PWM_ISR2) Comparison 6 Update
#define | PWM_ISR2_CMPU7 (0x1u << 23) |
| | (PWM_ISR2) Comparison 7 Update
#define | PWM_OOV_OOVH0 (0x1u << 0) |
| | (PWM_OOV) Output Override Value for PWMH output of the channel 0
#define | PWM_OOV_OOVH1 (0x1u << 1) |
| | (PWM_OOV) Output Override Value for PWMH output of the channel 1
#define | PWM_OOV_OOVH2 (0x1u << 2) |
| | (PWM_OOV) Output Override Value for PWMH output of the channel 2
#define | PWM_OOV_OOVH3 (0x1u << 3) |
| | (PWM_OOV) Output Override Value for PWMH output of the channel 3
#define | PWM_OOV_OOVL0 (0x1u << 16) |
| | (PWM_OOV) Output Override Value for PWML output of the channel 0
#define | PWM_OOV_OOVL1 (0x1u << 17) |
| | (PWM_OOV) Output Override Value for PWML output of the channel 1
#define | PWM_OOV_OOVL2 (0x1u << 18) |
| | (PWM_OOV) Output Override Value for PWML output of the channel 2
#define | PWM_OOV_OOVL3 (0x1u << 19) |
| | (PWM_OOV) Output Override Value for PWML output of the channel 3
#define | PWM_OS_OSH0 (0x1u << 0) |
| | (PWM_OS) Output Selection for PWMH output of the channel 0
#define | PWM_OS_OSH1 (0x1u << 1) |
| | (PWM_OS) Output Selection for PWMH output of the channel 1
#define | PWM_OS_OSH2 (0x1u << 2) |
| | (PWM_OS) Output Selection for PWMH output of the channel 2
#define | PWM_OS_OSH3 (0x1u << 3) |
| | (PWM_OS) Output Selection for PWMH output of the channel 3
#define | PWM_OS_OSL0 (0x1u << 16) |
| | (PWM_OS) Output Selection for PWML output of the channel 0
#define | PWM_OS_OSL1 (0x1u << 17) |
| | (PWM_OS) Output Selection for PWML output of the channel 1
#define | PWM_OS_OSL2 (0x1u << 18) |
| | (PWM_OS) Output Selection for PWML output of the channel 2
#define | PWM_OS_OSL3 (0x1u << 19) |
| | (PWM_OS) Output Selection for PWML output of the channel 3
#define | PWM_OSS_OSSH0 (0x1u << 0) |
| | (PWM_OSS) Output Selection Set for PWMH output of the channel 0
#define | PWM_OSS_OSSH1 (0x1u << 1) |
| | (PWM_OSS) Output Selection Set for PWMH output of the channel 1
#define | PWM_OSS_OSSH2 (0x1u << 2) |
| | (PWM_OSS) Output Selection Set for PWMH output of the channel 2
#define | PWM_OSS_OSSH3 (0x1u << 3) |
| | (PWM_OSS) Output Selection Set for PWMH output of the channel 3
#define | PWM_OSS_OSSL0 (0x1u << 16) |
| | (PWM_OSS) Output Selection Set for PWML output of the channel 0
#define | PWM_OSS_OSSL1 (0x1u << 17) |
| | (PWM_OSS) Output Selection Set for PWML output of the channel 1
#define | PWM_OSS_OSSL2 (0x1u << 18) |
| | (PWM_OSS) Output Selection Set for PWML output of the channel 2
#define | PWM_OSS_OSSL3 (0x1u << 19) |
| | (PWM_OSS) Output Selection Set for PWML output of the channel 3
#define | PWM_OSC_OSCH0 (0x1u << 0) |
| | (PWM_OSC) Output Selection Clear for PWMH output of the channel 0
#define | PWM_OSC_OSCH1 (0x1u << 1) |
| | (PWM_OSC) Output Selection Clear for PWMH output of the channel 1
#define | PWM_OSC_OSCH2 (0x1u << 2) |
| | (PWM_OSC) Output Selection Clear for PWMH output of the channel 2
#define | PWM_OSC_OSCH3 (0x1u << 3) |
| | (PWM_OSC) Output Selection Clear for PWMH output of the channel 3
#define | PWM_OSC_OSCL0 (0x1u << 16) |
| | (PWM_OSC) Output Selection Clear for PWML output of the channel 0
#define | PWM_OSC_OSCL1 (0x1u << 17) |
| | (PWM_OSC) Output Selection Clear for PWML output of the channel 1
#define | PWM_OSC_OSCL2 (0x1u << 18) |
| | (PWM_OSC) Output Selection Clear for PWML output of the channel 2
#define | PWM_OSC_OSCL3 (0x1u << 19) |
| | (PWM_OSC) Output Selection Clear for PWML output of the channel 3
#define | PWM_OSSUPD_OSSUPH0 (0x1u << 0) |
| | (PWM_OSSUPD) Output Selection Set for PWMH output of the channel 0
#define | PWM_OSSUPD_OSSUPH1 (0x1u << 1) |
| | (PWM_OSSUPD) Output Selection Set for PWMH output of the channel 1
#define | PWM_OSSUPD_OSSUPH2 (0x1u << 2) |
| | (PWM_OSSUPD) Output Selection Set for PWMH output of the channel 2
#define | PWM_OSSUPD_OSSUPH3 (0x1u << 3) |
| | (PWM_OSSUPD) Output Selection Set for PWMH output of the channel 3
#define | PWM_OSSUPD_OSSUPL0 (0x1u << 16) |
| | (PWM_OSSUPD) Output Selection Set for PWML output of the channel 0
#define | PWM_OSSUPD_OSSUPL1 (0x1u << 17) |
| | (PWM_OSSUPD) Output Selection Set for PWML output of the channel 1
#define | PWM_OSSUPD_OSSUPL2 (0x1u << 18) |
| | (PWM_OSSUPD) Output Selection Set for PWML output of the channel 2
#define | PWM_OSSUPD_OSSUPL3 (0x1u << 19) |
| | (PWM_OSSUPD) Output Selection Set for PWML output of the channel 3
#define | PWM_OSCUPD_OSCUPH0 (0x1u << 0) |
| | (PWM_OSCUPD) Output Selection Clear for PWMH output of the channel 0
#define | PWM_OSCUPD_OSCUPH1 (0x1u << 1) |
| | (PWM_OSCUPD) Output Selection Clear for PWMH output of the channel 1
#define | PWM_OSCUPD_OSCUPH2 (0x1u << 2) |
| | (PWM_OSCUPD) Output Selection Clear for PWMH output of the channel 2
#define | PWM_OSCUPD_OSCUPH3 (0x1u << 3) |
| | (PWM_OSCUPD) Output Selection Clear for PWMH output of the channel 3
#define | PWM_OSCUPD_OSCUPL0 (0x1u << 16) |
| | (PWM_OSCUPD) Output Selection Clear for PWML output of the channel 0
#define | PWM_OSCUPD_OSCUPL1 (0x1u << 17) |
| | (PWM_OSCUPD) Output Selection Clear for PWML output of the channel 1
#define | PWM_OSCUPD_OSCUPL2 (0x1u << 18) |
| | (PWM_OSCUPD) Output Selection Clear for PWML output of the channel 2
#define | PWM_OSCUPD_OSCUPL3 (0x1u << 19) |
| | (PWM_OSCUPD) Output Selection Clear for PWML output of the channel 3
#define | PWM_FMR_FPOL_Pos 0 |
#define | PWM_FMR_FPOL_Msk (0xffu << PWM_FMR_FPOL_Pos) |
| | (PWM_FMR) Fault Polarity
#define | PWM_FMR_FPOL(value) ((PWM_FMR_FPOL_Msk & ((value) << PWM_FMR_FPOL_Pos))) |
#define | PWM_FMR_FMOD_Pos 8 |
#define | PWM_FMR_FMOD_Msk (0xffu << PWM_FMR_FMOD_Pos) |
| | (PWM_FMR) Fault Activation Mode
#define | PWM_FMR_FMOD(value) ((PWM_FMR_FMOD_Msk & ((value) << PWM_FMR_FMOD_Pos))) |
#define | PWM_FMR_FFIL_Pos 16 |
#define | PWM_FMR_FFIL_Msk (0xffu << PWM_FMR_FFIL_Pos) |
| | (PWM_FMR) Fault Filtering
#define | PWM_FMR_FFIL(value) ((PWM_FMR_FFIL_Msk & ((value) << PWM_FMR_FFIL_Pos))) |
#define | PWM_FSR_FIV_Pos 0 |
#define | PWM_FSR_FIV_Msk (0xffu << PWM_FSR_FIV_Pos) |
| | (PWM_FSR) Fault Input Value
#define | PWM_FSR_FS_Pos 8 |
#define | PWM_FSR_FS_Msk (0xffu << PWM_FSR_FS_Pos) |
| | (PWM_FSR) Fault Status
#define | PWM_FCR_FCLR_Pos 0 |
#define | PWM_FCR_FCLR_Msk (0xffu << PWM_FCR_FCLR_Pos) |
| | (PWM_FCR) Fault Clear
#define | PWM_FCR_FCLR(value) ((PWM_FCR_FCLR_Msk & ((value) << PWM_FCR_FCLR_Pos))) |
#define | PWM_FPV1_FPVH0 (0x1u << 0) |
| | (PWM_FPV1) Fault Protection Value for PWMH output on channel 0
#define | PWM_FPV1_FPVH1 (0x1u << 1) |
| | (PWM_FPV1) Fault Protection Value for PWMH output on channel 1
#define | PWM_FPV1_FPVH2 (0x1u << 2) |
| | (PWM_FPV1) Fault Protection Value for PWMH output on channel 2
#define | PWM_FPV1_FPVH3 (0x1u << 3) |
| | (PWM_FPV1) Fault Protection Value for PWMH output on channel 3
#define | PWM_FPV1_FPVL0 (0x1u << 16) |
| | (PWM_FPV1) Fault Protection Value for PWML output on channel 0
#define | PWM_FPV1_FPVL1 (0x1u << 17) |
| | (PWM_FPV1) Fault Protection Value for PWML output on channel 1
#define | PWM_FPV1_FPVL2 (0x1u << 18) |
| | (PWM_FPV1) Fault Protection Value for PWML output on channel 2
#define | PWM_FPV1_FPVL3 (0x1u << 19) |
| | (PWM_FPV1) Fault Protection Value for PWML output on channel 3
#define | PWM_FPE_FPE0_Pos 0 |
#define | PWM_FPE_FPE0_Msk (0xffu << PWM_FPE_FPE0_Pos) |
| | (PWM_FPE) Fault Protection Enable for channel 0
#define | PWM_FPE_FPE0(value) ((PWM_FPE_FPE0_Msk & ((value) << PWM_FPE_FPE0_Pos))) |
#define | PWM_FPE_FPE1_Pos 8 |
#define | PWM_FPE_FPE1_Msk (0xffu << PWM_FPE_FPE1_Pos) |
| | (PWM_FPE) Fault Protection Enable for channel 1
#define | PWM_FPE_FPE1(value) ((PWM_FPE_FPE1_Msk & ((value) << PWM_FPE_FPE1_Pos))) |
#define | PWM_FPE_FPE2_Pos 16 |
#define | PWM_FPE_FPE2_Msk (0xffu << PWM_FPE_FPE2_Pos) |
| | (PWM_FPE) Fault Protection Enable for channel 2
#define | PWM_FPE_FPE2(value) ((PWM_FPE_FPE2_Msk & ((value) << PWM_FPE_FPE2_Pos))) |
#define | PWM_FPE_FPE3_Pos 24 |
#define | PWM_FPE_FPE3_Msk (0xffu << PWM_FPE_FPE3_Pos) |
| | (PWM_FPE) Fault Protection Enable for channel 3
#define | PWM_FPE_FPE3(value) ((PWM_FPE_FPE3_Msk & ((value) << PWM_FPE_FPE3_Pos))) |
#define | PWM_ELMR_CSEL0 (0x1u << 0) |
| | (PWM_ELMR[2]) Comparison 0 Selection
#define | PWM_ELMR_CSEL1 (0x1u << 1) |
| | (PWM_ELMR[2]) Comparison 1 Selection
#define | PWM_ELMR_CSEL2 (0x1u << 2) |
| | (PWM_ELMR[2]) Comparison 2 Selection
#define | PWM_ELMR_CSEL3 (0x1u << 3) |
| | (PWM_ELMR[2]) Comparison 3 Selection
#define | PWM_ELMR_CSEL4 (0x1u << 4) |
| | (PWM_ELMR[2]) Comparison 4 Selection
#define | PWM_ELMR_CSEL5 (0x1u << 5) |
| | (PWM_ELMR[2]) Comparison 5 Selection
#define | PWM_ELMR_CSEL6 (0x1u << 6) |
| | (PWM_ELMR[2]) Comparison 6 Selection
#define | PWM_ELMR_CSEL7 (0x1u << 7) |
| | (PWM_ELMR[2]) Comparison 7 Selection
#define | PWM_SSPR_SPRD_Pos 0 |
#define | PWM_SSPR_SPRD_Msk (0xffffffu << PWM_SSPR_SPRD_Pos) |
| | (PWM_SSPR) Spread Spectrum Limit Value
#define | PWM_SSPR_SPRD(value) ((PWM_SSPR_SPRD_Msk & ((value) << PWM_SSPR_SPRD_Pos))) |
#define | PWM_SSPR_SPRDM (0x1u << 24) |
| | (PWM_SSPR) Spread Spectrum Counter Mode
#define | PWM_SSPUP_SPRDUP_Pos 0 |
#define | PWM_SSPUP_SPRDUP_Msk (0xffffffu << PWM_SSPUP_SPRDUP_Pos) |
| | (PWM_SSPUP) Spread Spectrum Limit Value Update
#define | PWM_SSPUP_SPRDUP(value) ((PWM_SSPUP_SPRDUP_Msk & ((value) << PWM_SSPUP_SPRDUP_Pos))) |
#define | PWM_SMMR_GCEN0 (0x1u << 0) |
| | (PWM_SMMR) Gray Count ENable
#define | PWM_SMMR_GCEN1 (0x1u << 1) |
#define | PWM_SMMR_DOWN0 (0x1u << 16) |
| | (PWM_SMMR) DOWN Count
#define | PWM_SMMR_DOWN1 (0x1u << 17) |
#define | PWM_FPV2_FPZH0 (0x1u << 0) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWMH output on channel 0
#define | PWM_FPV2_FPZH1 (0x1u << 1) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWMH output on channel 1
#define | PWM_FPV2_FPZH2 (0x1u << 2) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWMH output on channel 2
#define | PWM_FPV2_FPZH3 (0x1u << 3) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWMH output on channel 3
#define | PWM_FPV2_FPZL0 (0x1u << 16) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWML output on channel 0
#define | PWM_FPV2_FPZL1 (0x1u << 17) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWML output on channel 1
#define | PWM_FPV2_FPZL2 (0x1u << 18) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWML output on channel 2
#define | PWM_FPV2_FPZL3 (0x1u << 19) |
| | (PWM_FPV2) Fault Protection to Hi-Z for PWML output on channel 3
#define | PWM_WPCR_WPCMD_Pos 0 |
#define | PWM_WPCR_WPCMD_Msk (0x3u << PWM_WPCR_WPCMD_Pos) |
| | (PWM_WPCR) Write Protection Command
#define | PWM_WPCR_WPCMD(value) ((PWM_WPCR_WPCMD_Msk & ((value) << PWM_WPCR_WPCMD_Pos))) |
#define | PWM_WPCR_WPCMD_DISABLE_SW_PROT (0x0u << 0) |
| | (PWM_WPCR) Disables the software write protection of the register groups of which the bit WPRGx is at '1'.
#define | PWM_WPCR_WPCMD_ENABLE_SW_PROT (0x1u << 0) |
| | (PWM_WPCR) Enables the software write protection of the register groups of which the bit WPRGx is at '1'.
#define | PWM_WPCR_WPCMD_ENABLE_HW_PROT (0x2u << 0) |
| | (PWM_WPCR) Enables the hardware write protection of the register groups of which the bit WPRGx is at '1'. Only a hardware reset of the PWM controller can disable the hardware write protection. Moreover, to meet security requirements, the PIO lines associated with the PWM can not be configured through the PIO interface.
#define | PWM_WPCR_WPRG0 (0x1u << 2) |
| | (PWM_WPCR) Write Protection Register Group 0
#define | PWM_WPCR_WPRG1 (0x1u << 3) |
| | (PWM_WPCR) Write Protection Register Group 1
#define | PWM_WPCR_WPRG2 (0x1u << 4) |
| | (PWM_WPCR) Write Protection Register Group 2
#define | PWM_WPCR_WPRG3 (0x1u << 5) |
| | (PWM_WPCR) Write Protection Register Group 3
#define | PWM_WPCR_WPRG4 (0x1u << 6) |
| | (PWM_WPCR) Write Protection Register Group 4
#define | PWM_WPCR_WPRG5 (0x1u << 7) |
| | (PWM_WPCR) Write Protection Register Group 5
#define | PWM_WPCR_WPKEY_Pos 8 |
#define | PWM_WPCR_WPKEY_Msk (0xffffffu << PWM_WPCR_WPKEY_Pos) |
| | (PWM_WPCR) Write Protection Key
#define | PWM_WPCR_WPKEY(value) ((PWM_WPCR_WPKEY_Msk & ((value) << PWM_WPCR_WPKEY_Pos))) |
#define | PWM_WPCR_WPKEY_PASSWD (0x50574Du << 8) |
| | (PWM_WPCR) Writing any other value in this field aborts the write operation of the WPCMD field.Always reads as 0
#define | PWM_WPSR_WPSWS0 (0x1u << 0) |
| | (PWM_WPSR) Write Protect SW Status
#define | PWM_WPSR_WPSWS1 (0x1u << 1) |
#define | PWM_WPSR_WPSWS2 (0x1u << 2) |
#define | PWM_WPSR_WPSWS3 (0x1u << 3) |
#define | PWM_WPSR_WPSWS4 (0x1u << 4) |
#define | PWM_WPSR_WPSWS5 (0x1u << 5) |
#define | PWM_WPSR_WPVS (0x1u << 7) |
| | (PWM_WPSR) Write Protect Violation Status
#define | PWM_WPSR_WPHWS0 (0x1u << 8) |
| | (PWM_WPSR) Write Protect HW Status
#define | PWM_WPSR_WPHWS1 (0x1u << 9) |
#define | PWM_WPSR_WPHWS2 (0x1u << 10) |
#define | PWM_WPSR_WPHWS3 (0x1u << 11) |
#define | PWM_WPSR_WPHWS4 (0x1u << 12) |
#define | PWM_WPSR_WPHWS5 (0x1u << 13) |
#define | PWM_WPSR_WPVSRC_Pos 16 |
#define | PWM_WPSR_WPVSRC_Msk (0xffffu << PWM_WPSR_WPVSRC_Pos) |
| | (PWM_WPSR) Write Protect Violation Source
#define | PWM_VERSION_VERSION_Pos 0 |
#define | PWM_VERSION_VERSION_Msk (0xfffu << PWM_VERSION_VERSION_Pos) |
| | (PWM_VERSION) Version of the Hardware Module
#define | PWM_VERSION_MFN_Pos 16 |
#define | PWM_VERSION_MFN_Msk (0x7u << PWM_VERSION_MFN_Pos) |
| | (PWM_VERSION) Metal Fix Number
#define | PWM_CMPV_CV_Pos 0 |
#define | PWM_CMPV_CV_Msk (0xffffffu << PWM_CMPV_CV_Pos) |
| | (PWM_CMPV) Comparison x Value
#define | PWM_CMPV_CV(value) ((PWM_CMPV_CV_Msk & ((value) << PWM_CMPV_CV_Pos))) |
#define | PWM_CMPV_CVM (0x1u << 24) |
| | (PWM_CMPV) Comparison x Value Mode
#define | PWM_CMPVUPD_CVUPD_Pos 0 |
#define | PWM_CMPVUPD_CVUPD_Msk (0xffffffu << PWM_CMPVUPD_CVUPD_Pos) |
| | (PWM_CMPVUPD) Comparison x Value Update
#define | PWM_CMPVUPD_CVUPD(value) ((PWM_CMPVUPD_CVUPD_Msk & ((value) << PWM_CMPVUPD_CVUPD_Pos))) |
#define | PWM_CMPVUPD_CVMUPD (0x1u << 24) |
| | (PWM_CMPVUPD) Comparison x Value Mode Update
#define | PWM_CMPM_CEN (0x1u << 0) |
| | (PWM_CMPM) Comparison x Enable
#define | PWM_CMPM_CTR_Pos 4 |
#define | PWM_CMPM_CTR_Msk (0xfu << PWM_CMPM_CTR_Pos) |
| | (PWM_CMPM) Comparison x Trigger
#define | PWM_CMPM_CTR(value) ((PWM_CMPM_CTR_Msk & ((value) << PWM_CMPM_CTR_Pos))) |
#define | PWM_CMPM_CPR_Pos 8 |
#define | PWM_CMPM_CPR_Msk (0xfu << PWM_CMPM_CPR_Pos) |
| | (PWM_CMPM) Comparison x Period
#define | PWM_CMPM_CPR(value) ((PWM_CMPM_CPR_Msk & ((value) << PWM_CMPM_CPR_Pos))) |
#define | PWM_CMPM_CPRCNT_Pos 12 |
#define | PWM_CMPM_CPRCNT_Msk (0xfu << PWM_CMPM_CPRCNT_Pos) |
| | (PWM_CMPM) Comparison x Period Counter
#define | PWM_CMPM_CPRCNT(value) ((PWM_CMPM_CPRCNT_Msk & ((value) << PWM_CMPM_CPRCNT_Pos))) |
#define | PWM_CMPM_CUPR_Pos 16 |
#define | PWM_CMPM_CUPR_Msk (0xfu << PWM_CMPM_CUPR_Pos) |
| | (PWM_CMPM) Comparison x Update Period
#define | PWM_CMPM_CUPR(value) ((PWM_CMPM_CUPR_Msk & ((value) << PWM_CMPM_CUPR_Pos))) |
#define | PWM_CMPM_CUPRCNT_Pos 20 |
#define | PWM_CMPM_CUPRCNT_Msk (0xfu << PWM_CMPM_CUPRCNT_Pos) |
| | (PWM_CMPM) Comparison x Update Period Counter
#define | PWM_CMPM_CUPRCNT(value) ((PWM_CMPM_CUPRCNT_Msk & ((value) << PWM_CMPM_CUPRCNT_Pos))) |
#define | PWM_CMPMUPD_CENUPD (0x1u << 0) |
| | (PWM_CMPMUPD) Comparison x Enable Update
#define | PWM_CMPMUPD_CTRUPD_Pos 4 |
#define | PWM_CMPMUPD_CTRUPD_Msk (0xfu << PWM_CMPMUPD_CTRUPD_Pos) |
| | (PWM_CMPMUPD) Comparison x Trigger Update
#define | PWM_CMPMUPD_CTRUPD(value) ((PWM_CMPMUPD_CTRUPD_Msk & ((value) << PWM_CMPMUPD_CTRUPD_Pos))) |
#define | PWM_CMPMUPD_CPRUPD_Pos 8 |
#define | PWM_CMPMUPD_CPRUPD_Msk (0xfu << PWM_CMPMUPD_CPRUPD_Pos) |
| | (PWM_CMPMUPD) Comparison x Period Update
#define | PWM_CMPMUPD_CPRUPD(value) ((PWM_CMPMUPD_CPRUPD_Msk & ((value) << PWM_CMPMUPD_CPRUPD_Pos))) |
#define | PWM_CMPMUPD_CUPRUPD_Pos 16 |
#define | PWM_CMPMUPD_CUPRUPD_Msk (0xfu << PWM_CMPMUPD_CUPRUPD_Pos) |
| | (PWM_CMPMUPD) Comparison x Update Period Update
#define | PWM_CMPMUPD_CUPRUPD(value) ((PWM_CMPMUPD_CUPRUPD_Msk & ((value) << PWM_CMPMUPD_CUPRUPD_Pos))) |
#define | PWM_CMR_CPRE_Pos 0 |
#define | PWM_CMR_CPRE_Msk (0xfu << PWM_CMR_CPRE_Pos) |
| | (PWM_CMR) Channel Pre-scaler
#define | PWM_CMR_CPRE(value) ((PWM_CMR_CPRE_Msk & ((value) << PWM_CMR_CPRE_Pos))) |
#define | PWM_CMR_CPRE_MCK (0x0u << 0) |
| | (PWM_CMR) Peripheral clock
#define | PWM_CMR_CPRE_MCK_DIV_2 (0x1u << 0) |
| | (PWM_CMR) Peripheral clock/2
#define | PWM_CMR_CPRE_MCK_DIV_4 (0x2u << 0) |
| | (PWM_CMR) Peripheral clock/4
#define | PWM_CMR_CPRE_MCK_DIV_8 (0x3u << 0) |
| | (PWM_CMR) Peripheral clock/8
#define | PWM_CMR_CPRE_MCK_DIV_16 (0x4u << 0) |
| | (PWM_CMR) Peripheral clock/16
#define | PWM_CMR_CPRE_MCK_DIV_32 (0x5u << 0) |
| | (PWM_CMR) Peripheral clock/32
#define | PWM_CMR_CPRE_MCK_DIV_64 (0x6u << 0) |
| | (PWM_CMR) Peripheral clock/64
#define | PWM_CMR_CPRE_MCK_DIV_128 (0x7u << 0) |
| | (PWM_CMR) Peripheral clock/128
#define | PWM_CMR_CPRE_MCK_DIV_256 (0x8u << 0) |
| | (PWM_CMR) Peripheral clock/256
#define | PWM_CMR_CPRE_MCK_DIV_512 (0x9u << 0) |
| | (PWM_CMR) Peripheral clock/512
#define | PWM_CMR_CPRE_MCK_DIV_1024 (0xAu << 0) |
| | (PWM_CMR) Peripheral clock/1024
#define | PWM_CMR_CPRE_CLKA (0xBu << 0) |
| | (PWM_CMR) Clock A
#define | PWM_CMR_CPRE_CLKB (0xCu << 0) |
| | (PWM_CMR) Clock B
#define | PWM_CMR_CALG (0x1u << 8) |
| | (PWM_CMR) Channel Alignment
#define | PWM_CMR_CPOL (0x1u << 9) |
| | (PWM_CMR) Channel Polarity
#define | PWM_CMR_CES (0x1u << 10) |
| | (PWM_CMR) Counter Event Selection
#define | PWM_CMR_UPDS (0x1u << 11) |
| | (PWM_CMR) Update Selection
#define | PWM_CMR_DPOLI (0x1u << 12) |
| | (PWM_CMR) Disabled Polarity Inverted
#define | PWM_CMR_TCTS (0x1u << 13) |
| | (PWM_CMR) Timer Counter Trigger Selection
#define | PWM_CMR_DTE (0x1u << 16) |
| | (PWM_CMR) Dead-Time Generator Enable
#define | PWM_CMR_DTHI (0x1u << 17) |
| | (PWM_CMR) Dead-Time PWMHx Output Inverted
#define | PWM_CMR_DTLI (0x1u << 18) |
| | (PWM_CMR) Dead-Time PWMLx Output Inverted
#define | PWM_CMR_PPM (0x1u << 19) |
| | (PWM_CMR) Push-Pull Mode
#define | PWM_CDTY_CDTY_Pos 0 |
#define | PWM_CDTY_CDTY_Msk (0xffffffu << PWM_CDTY_CDTY_Pos) |
| | (PWM_CDTY) Channel Duty-Cycle
#define | PWM_CDTY_CDTY(value) ((PWM_CDTY_CDTY_Msk & ((value) << PWM_CDTY_CDTY_Pos))) |
#define | PWM_CDTYUPD_CDTYUPD_Pos 0 |
#define | PWM_CDTYUPD_CDTYUPD_Msk (0xffffffu << PWM_CDTYUPD_CDTYUPD_Pos) |
| | (PWM_CDTYUPD) Channel Duty-Cycle Update
#define | PWM_CDTYUPD_CDTYUPD(value) ((PWM_CDTYUPD_CDTYUPD_Msk & ((value) << PWM_CDTYUPD_CDTYUPD_Pos))) |
#define | PWM_CPRD_CPRD_Pos 0 |
#define | PWM_CPRD_CPRD_Msk (0xffffffu << PWM_CPRD_CPRD_Pos) |
| | (PWM_CPRD) Channel Period
#define | PWM_CPRD_CPRD(value) ((PWM_CPRD_CPRD_Msk & ((value) << PWM_CPRD_CPRD_Pos))) |
#define | PWM_CPRDUPD_CPRDUPD_Pos 0 |
#define | PWM_CPRDUPD_CPRDUPD_Msk (0xffffffu << PWM_CPRDUPD_CPRDUPD_Pos) |
| | (PWM_CPRDUPD) Channel Period Update
#define | PWM_CPRDUPD_CPRDUPD(value) ((PWM_CPRDUPD_CPRDUPD_Msk & ((value) << PWM_CPRDUPD_CPRDUPD_Pos))) |
#define | PWM_CCNT_CNT_Pos 0 |
#define | PWM_CCNT_CNT_Msk (0xffffffu << PWM_CCNT_CNT_Pos) |
| | (PWM_CCNT) Channel Counter Register
#define | PWM_DT_DTH_Pos 0 |
#define | PWM_DT_DTH_Msk (0xffffu << PWM_DT_DTH_Pos) |
| | (PWM_DT) Dead-Time Value for PWMHx Output
#define | PWM_DT_DTH(value) ((PWM_DT_DTH_Msk & ((value) << PWM_DT_DTH_Pos))) |
#define | PWM_DT_DTL_Pos 16 |
#define | PWM_DT_DTL_Msk (0xffffu << PWM_DT_DTL_Pos) |
| | (PWM_DT) Dead-Time Value for PWMLx Output
#define | PWM_DT_DTL(value) ((PWM_DT_DTL_Msk & ((value) << PWM_DT_DTL_Pos))) |
#define | PWM_DTUPD_DTHUPD_Pos 0 |
#define | PWM_DTUPD_DTHUPD_Msk (0xffffu << PWM_DTUPD_DTHUPD_Pos) |
| | (PWM_DTUPD) Dead-Time Value Update for PWMHx Output
#define | PWM_DTUPD_DTHUPD(value) ((PWM_DTUPD_DTHUPD_Msk & ((value) << PWM_DTUPD_DTHUPD_Pos))) |
#define | PWM_DTUPD_DTLUPD_Pos 16 |
#define | PWM_DTUPD_DTLUPD_Msk (0xffffu << PWM_DTUPD_DTLUPD_Pos) |
| | (PWM_DTUPD) Dead-Time Value Update for PWMLx Output
#define | PWM_DTUPD_DTLUPD(value) ((PWM_DTUPD_DTLUPD_Msk & ((value) << PWM_DTUPD_DTLUPD_Pos))) |
#define | PWM_CMUPD0_CPOLUP (0x1u << 9) |
| | (PWM_CMUPD0) Channel Polarity Update
#define | PWM_CMUPD0_CPOLINVUP (0x1u << 13) |
| | (PWM_CMUPD0) Channel Polarity Inversion Update
#define | PWM_CMUPD1_CPOLUP (0x1u << 9) |
| | (PWM_CMUPD1) Channel Polarity Update
#define | PWM_CMUPD1_CPOLINVUP (0x1u << 13) |
| | (PWM_CMUPD1) Channel Polarity Inversion Update
#define | PWM_ETRG1_MAXCNT_Pos 0 |
#define | PWM_ETRG1_MAXCNT_Msk (0xffffffu << PWM_ETRG1_MAXCNT_Pos) |
| | (PWM_ETRG1) Maximum Counter value
#define | PWM_ETRG1_MAXCNT(value) ((PWM_ETRG1_MAXCNT_Msk & ((value) << PWM_ETRG1_MAXCNT_Pos))) |
#define | PWM_ETRG1_TRGMODE_Pos 24 |
#define | PWM_ETRG1_TRGMODE_Msk (0x3u << PWM_ETRG1_TRGMODE_Pos) |
| | (PWM_ETRG1) External Trigger Mode
#define | PWM_ETRG1_TRGMODE(value) ((PWM_ETRG1_TRGMODE_Msk & ((value) << PWM_ETRG1_TRGMODE_Pos))) |
#define | PWM_ETRG1_TRGMODE_OFF (0x0u << 24) |
| | (PWM_ETRG1) External trigger is not enabled.
#define | PWM_ETRG1_TRGMODE_MODE1 (0x1u << 24) |
| | (PWM_ETRG1) External PWM Reset Mode
#define | PWM_ETRG1_TRGMODE_MODE2 (0x2u << 24) |
| | (PWM_ETRG1) External PWM Start Mode
#define | PWM_ETRG1_TRGMODE_MODE3 (0x3u << 24) |
| | (PWM_ETRG1) Cycle-by-cycle Duty Mode
#define | PWM_ETRG1_TRGEDGE (0x1u << 28) |
| | (PWM_ETRG1) Edge Selection
#define | PWM_ETRG1_TRGEDGE_FALLING_ZERO (0x0u << 28) |
| | (PWM_ETRG1) TRGMODE = 1: TRGINx event detection on falling edge.TRGMODE = 2, 3: TRGINx active level is 0
#define | PWM_ETRG1_TRGEDGE_RISING_ONE (0x1u << 28) |
| | (PWM_ETRG1) TRGMODE = 1: TRGINx event detection on rising edge.TRGMODE = 2, 3: TRGINx active level is 1
#define | PWM_ETRG1_TRGFILT (0x1u << 29) |
| | (PWM_ETRG1) Filtered input
#define | PWM_ETRG1_TRGSRC (0x1u << 30) |
| | (PWM_ETRG1) Trigger Source
#define | PWM_ETRG1_RFEN (0x1u << 31) |
| | (PWM_ETRG1) Recoverable Fault Enable
#define | PWM_LEBR1_LEBDELAY_Pos 0 |
#define | PWM_LEBR1_LEBDELAY_Msk (0x7fu << PWM_LEBR1_LEBDELAY_Pos) |
| | (PWM_LEBR1) Leading-Edge Blanking Delay for TRGINx
#define | PWM_LEBR1_LEBDELAY(value) ((PWM_LEBR1_LEBDELAY_Msk & ((value) << PWM_LEBR1_LEBDELAY_Pos))) |
#define | PWM_LEBR1_PWMLFEN (0x1u << 16) |
| | (PWM_LEBR1) PWML Falling Edge Enable
#define | PWM_LEBR1_PWMLREN (0x1u << 17) |
| | (PWM_LEBR1) PWML Rising Edge Enable
#define | PWM_LEBR1_PWMHFEN (0x1u << 18) |
| | (PWM_LEBR1) PWMH Falling Edge Enable
#define | PWM_LEBR1_PWMHREN (0x1u << 19) |
| | (PWM_LEBR1) PWMH Rising Edge Enable
#define | PWM_CMUPD2_CPOLUP (0x1u << 9) |
| | (PWM_CMUPD2) Channel Polarity Update
#define | PWM_CMUPD2_CPOLINVUP (0x1u << 13) |
| | (PWM_CMUPD2) Channel Polarity Inversion Update
#define | PWM_ETRG2_MAXCNT_Pos 0 |
#define | PWM_ETRG2_MAXCNT_Msk (0xffffffu << PWM_ETRG2_MAXCNT_Pos) |
| | (PWM_ETRG2) Maximum Counter value
#define | PWM_ETRG2_MAXCNT(value) ((PWM_ETRG2_MAXCNT_Msk & ((value) << PWM_ETRG2_MAXCNT_Pos))) |
#define | PWM_ETRG2_TRGMODE_Pos 24 |
#define | PWM_ETRG2_TRGMODE_Msk (0x3u << PWM_ETRG2_TRGMODE_Pos) |
| | (PWM_ETRG2) External Trigger Mode
#define | PWM_ETRG2_TRGMODE(value) ((PWM_ETRG2_TRGMODE_Msk & ((value) << PWM_ETRG2_TRGMODE_Pos))) |
#define | PWM_ETRG2_TRGMODE_OFF (0x0u << 24) |
| | (PWM_ETRG2) External trigger is not enabled.
#define | PWM_ETRG2_TRGMODE_MODE1 (0x1u << 24) |
| | (PWM_ETRG2) External PWM Reset Mode
#define | PWM_ETRG2_TRGMODE_MODE2 (0x2u << 24) |
| | (PWM_ETRG2) External PWM Start Mode
#define | PWM_ETRG2_TRGMODE_MODE3 (0x3u << 24) |
| | (PWM_ETRG2) Cycle-by-cycle Duty Mode
#define | PWM_ETRG2_TRGEDGE (0x1u << 28) |
| | (PWM_ETRG2) Edge Selection
#define | PWM_ETRG2_TRGEDGE_FALLING_ZERO (0x0u << 28) |
| | (PWM_ETRG2) TRGMODE = 1: TRGINx event detection on falling edge.TRGMODE = 2, 3: TRGINx active level is 0
#define | PWM_ETRG2_TRGEDGE_RISING_ONE (0x1u << 28) |
| | (PWM_ETRG2) TRGMODE = 1: TRGINx event detection on rising edge.TRGMODE = 2, 3: TRGINx active level is 1
#define | PWM_ETRG2_TRGFILT (0x1u << 29) |
| | (PWM_ETRG2) Filtered input
#define | PWM_ETRG2_TRGSRC (0x1u << 30) |
| | (PWM_ETRG2) Trigger Source
#define | PWM_ETRG2_RFEN (0x1u << 31) |
| | (PWM_ETRG2) Recoverable Fault Enable
#define | PWM_LEBR2_LEBDELAY_Pos 0 |
#define | PWM_LEBR2_LEBDELAY_Msk (0x7fu << PWM_LEBR2_LEBDELAY_Pos) |
| | (PWM_LEBR2) Leading-Edge Blanking Delay for TRGINx
#define | PWM_LEBR2_LEBDELAY(value) ((PWM_LEBR2_LEBDELAY_Msk & ((value) << PWM_LEBR2_LEBDELAY_Pos))) |
#define | PWM_LEBR2_PWMLFEN (0x1u << 16) |
| | (PWM_LEBR2) PWML Falling Edge Enable
#define | PWM_LEBR2_PWMLREN (0x1u << 17) |
| | (PWM_LEBR2) PWML Rising Edge Enable
#define | PWM_LEBR2_PWMHFEN (0x1u << 18) |
| | (PWM_LEBR2) PWMH Falling Edge Enable
#define | PWM_LEBR2_PWMHREN (0x1u << 19) |
| | (PWM_LEBR2) PWMH Rising Edge Enable
#define | PWM_CMUPD3_CPOLUP (0x1u << 9) |
| | (PWM_CMUPD3) Channel Polarity Update
#define | PWM_CMUPD3_CPOLINVUP (0x1u << 13) |
| | (PWM_CMUPD3) Channel Polarity Inversion Update
