#define | MLB_MLBC0_MLBEN (0x1u << 0) |
| | (MLB_MLBC0) MediaLB Enable
#define | MLB_MLBC0_MLBCLK_Pos 2 |
#define | MLB_MLBC0_MLBCLK_Msk (0x7u << MLB_MLBC0_MLBCLK_Pos) |
| | (MLB_MLBC0) MLBCLK (MediaLB clock) speed select
#define | MLB_MLBC0_MLBCLK(value) ((MLB_MLBC0_MLBCLK_Msk & ((value) << MLB_MLBC0_MLBCLK_Pos))) |
#define | MLB_MLBC0_MLBCLK_256_FS (0x0u << 2) |
| | (MLB_MLBC0) 256xFs (for MLBPEN = 0)
#define | MLB_MLBC0_MLBCLK_512_FS (0x1u << 2) |
| | (MLB_MLBC0) 512xFs (for MLBPEN = 0)
#define | MLB_MLBC0_MLBCLK_1024_FS (0x2u << 2) |
| | (MLB_MLBC0) 1024xFs (for MLBPEN = 0)
#define | MLB_MLBC0_ZERO (0x1u << 5) |
| | (MLB_MLBC0) Must be Written to 0
#define | MLB_MLBC0_MLBLK (0x1u << 7) |
| | (MLB_MLBC0) MediaLB Lock Status (read-only)
#define | MLB_MLBC0_ASYRETRY (0x1u << 12) |
| | (MLB_MLBC0) Asynchronous Tx Packet Retry
#define | MLB_MLBC0_CTLRETRY (0x1u << 14) |
| | (MLB_MLBC0) Control Tx Packet Retry
#define | MLB_MLBC0_FCNT_Pos 15 |
#define | MLB_MLBC0_FCNT_Msk (0x7u << MLB_MLBC0_FCNT_Pos) |
| | (MLB_MLBC0) The number of frames per sub-buffer for synchronous channels
#define | MLB_MLBC0_FCNT(value) ((MLB_MLBC0_FCNT_Msk & ((value) << MLB_MLBC0_FCNT_Pos))) |
#define | MLB_MLBC0_FCNT_1_FRAME (0x0u << 15) |
| | (MLB_MLBC0) 1 frame per sub-buffer (Operation is the same as Standard mode.)
#define | MLB_MLBC0_FCNT_2_FRAMES (0x1u << 15) |
| | (MLB_MLBC0) 2 frames per sub-buffer
#define | MLB_MLBC0_FCNT_4_FRAMES (0x2u << 15) |
| | (MLB_MLBC0) 4 frames per sub-buffer
#define | MLB_MLBC0_FCNT_8_FRAMES (0x3u << 15) |
| | (MLB_MLBC0) 8 frames per sub-buffer
#define | MLB_MLBC0_FCNT_16_FRAMES (0x4u << 15) |
| | (MLB_MLBC0) 16 frames per sub-buffer
#define | MLB_MLBC0_FCNT_32_FRAMES (0x5u << 15) |
| | (MLB_MLBC0) 32 frames per sub-buffer
#define | MLB_MLBC0_FCNT_64_FRAMES (0x6u << 15) |
| | (MLB_MLBC0) 64 frames per sub-buffer
#define | MLB_MS0_MCS_Pos 0 |
#define | MLB_MS0_MCS_Msk (0xffffffffu << MLB_MS0_MCS_Pos) |
| | (MLB_MS0) MediaLB Channel Status [31:0] (cleared by writing a 0)
#define | MLB_MS0_MCS(value) ((MLB_MS0_MCS_Msk & ((value) << MLB_MS0_MCS_Pos))) |
#define | MLB_MS1_MCS_Pos 0 |
#define | MLB_MS1_MCS_Msk (0xffffffffu << MLB_MS1_MCS_Pos) |
| | (MLB_MS1) MediaLB Channel Status [63:32] (cleared by writing a 0)
#define | MLB_MS1_MCS(value) ((MLB_MS1_MCS_Msk & ((value) << MLB_MS1_MCS_Pos))) |
#define | MLB_MSS_RSTSYSCMD (0x1u << 0) |
| | (MLB_MSS) Reset System Command Detected in the System Quadlet (cleared by writing a 0)
#define | MLB_MSS_LKSYSCMD (0x1u << 1) |
| | (MLB_MSS) Network Lock System Command Detected in the System Quadlet (cleared by writing a 0)
#define | MLB_MSS_ULKSYSCMD (0x1u << 2) |
| | (MLB_MSS) Network Unlock System Command Detected in the System Quadlet (cleared by writing a 0)
#define | MLB_MSS_CSSYSCMD (0x1u << 3) |
| | (MLB_MSS) Channel Scan System Command Detected in the System Quadlet (cleared by writing a 0)
#define | MLB_MSS_SWSYSCMD (0x1u << 4) |
| | (MLB_MSS) Software System Command Detected in the System Quadlet (cleared by writing a 0)
#define | MLB_MSS_SERVREQ (0x1u << 5) |
| | (MLB_MSS) Service Request Enabled
#define | MLB_MSD_SD0_Pos 0 |
#define | MLB_MSD_SD0_Msk (0xffu << MLB_MSD_SD0_Pos) |
| | (MLB_MSD) System Data (Byte 0)
#define | MLB_MSD_SD1_Pos 8 |
#define | MLB_MSD_SD1_Msk (0xffu << MLB_MSD_SD1_Pos) |
| | (MLB_MSD) System Data (Byte 1)
#define | MLB_MSD_SD2_Pos 16 |
#define | MLB_MSD_SD2_Msk (0xffu << MLB_MSD_SD2_Pos) |
| | (MLB_MSD) System Data (Byte 2)
#define | MLB_MSD_SD3_Pos 24 |
#define | MLB_MSD_SD3_Msk (0xffu << MLB_MSD_SD3_Pos) |
| | (MLB_MSD) System Data (Byte 3)
#define | MLB_MIEN_ISOC_PE (0x1u << 0) |
| | (MLB_MIEN) Isochronous Rx Protocol Error Enable
#define | MLB_MIEN_ISOC_BUFO (0x1u << 1) |
| | (MLB_MIEN) Isochronous Rx Buffer Overflow Enable
#define | MLB_MIEN_SYNC_PE (0x1u << 16) |
| | (MLB_MIEN) Synchronous Protocol Error Enable
#define | MLB_MIEN_ARX_DONE (0x1u << 17) |
| | (MLB_MIEN) Asynchronous Rx Done Enable
#define | MLB_MIEN_ARX_PE (0x1u << 18) |
| | (MLB_MIEN) Asynchronous Rx Protocol Error Enable
#define | MLB_MIEN_ARX_BREAK (0x1u << 19) |
| | (MLB_MIEN) Asynchronous Rx Break Enable
#define | MLB_MIEN_ATX_DONE (0x1u << 20) |
| | (MLB_MIEN) Asynchronous Tx Packet Done Enable
#define | MLB_MIEN_ATX_PE (0x1u << 21) |
| | (MLB_MIEN) Asynchronous Tx Protocol Error Enable
#define | MLB_MIEN_ATX_BREAK (0x1u << 22) |
| | (MLB_MIEN) Asynchronous Tx Break Enable
#define | MLB_MIEN_CRX_DONE (0x1u << 24) |
| | (MLB_MIEN) Control Rx Packet Done Enable
#define | MLB_MIEN_CRX_PE (0x1u << 25) |
| | (MLB_MIEN) Control Rx Protocol Error Enable
#define | MLB_MIEN_CRX_BREAK (0x1u << 26) |
| | (MLB_MIEN) Control Rx Break Enable
#define | MLB_MIEN_CTX_DONE (0x1u << 27) |
| | (MLB_MIEN) Control Tx Packet Done Enable
#define | MLB_MIEN_CTX_PE (0x1u << 28) |
| | (MLB_MIEN) Control Tx Protocol Error Enable
#define | MLB_MIEN_CTX_BREAK (0x1u << 29) |
| | (MLB_MIEN) Control Tx Break Enable
#define | MLB_MLBC1_LOCK (0x1u << 6) |
| | (MLB_MLBC1) MediaLB Lock Error Status (cleared by writing a 0)
#define | MLB_MLBC1_CLKM (0x1u << 7) |
| | (MLB_MLBC1) MediaLB Clock Missing Status (cleared by writing a 0)
#define | MLB_MLBC1_NDA_Pos 8 |
#define | MLB_MLBC1_NDA_Msk (0xffu << MLB_MLBC1_NDA_Pos) |
| | (MLB_MLBC1) Node Device Address
#define | MLB_MLBC1_NDA(value) ((MLB_MLBC1_NDA_Msk & ((value) << MLB_MLBC1_NDA_Pos))) |
#define | MLB_HCTL_RST0 (0x1u << 0) |
| | (MLB_HCTL) Address Generation Unit 0 Software Reset
#define | MLB_HCTL_RST1 (0x1u << 1) |
| | (MLB_HCTL) Address Generation Unit 1 Software Reset
#define | MLB_HCTL_EN (0x1u << 15) |
| | (MLB_HCTL) HBI Enable
#define | MLB_HCMR_CHM_Pos 0 |
#define | MLB_HCMR_CHM_Msk (0xffffffffu << MLB_HCMR_CHM_Pos) |
| | (MLB_HCMR[2]) Bitwise Channel Mask Bit [31:0]
#define | MLB_HCMR_CHM(value) ((MLB_HCMR_CHM_Msk & ((value) << MLB_HCMR_CHM_Pos))) |
#define | MLB_HCER_CERR_Pos 0 |
#define | MLB_HCER_CERR_Msk (0xffffffffu << MLB_HCER_CERR_Pos) |
| | (MLB_HCER[2]) Bitwise Channel Error Bit [31:0]
#define | MLB_HCBR_CHB_Pos 0 |
#define | MLB_HCBR_CHB_Msk (0xffffffffu << MLB_HCBR_CHB_Pos) |
| | (MLB_HCBR[2]) Bitwise Channel Busy Bit [31:0]
#define | MLB_MDAT_DATA_Pos 0 |
#define | MLB_MDAT_DATA_Msk (0xffffffffu << MLB_MDAT_DATA_Pos) |
| | (MLB_MDAT[4]) CRT or DBR Data
#define | MLB_MDAT_DATA(value) ((MLB_MDAT_DATA_Msk & ((value) << MLB_MDAT_DATA_Pos))) |
#define | MLB_MDWE_MASK_Pos 0 |
#define | MLB_MDWE_MASK_Msk (0xffffffffu << MLB_MDWE_MASK_Pos) |
| | (MLB_MDWE[4]) Bitwise write enable for CTR data - bits[31:0]
#define | MLB_MDWE_MASK(value) ((MLB_MDWE_MASK_Msk & ((value) << MLB_MDWE_MASK_Pos))) |
#define | MLB_MCTL_XCMP (0x1u << 0) |
| | (MLB_MCTL) Transfer Complete (Write 0 to Clear)
#define | MLB_MADR_ADDR_Pos 0 |
#define | MLB_MADR_ADDR_Msk (0x3fffu << MLB_MADR_ADDR_Pos) |
| | (MLB_MADR) CTR or DBR Address
#define | MLB_MADR_ADDR(value) ((MLB_MADR_ADDR_Msk & ((value) << MLB_MADR_ADDR_Pos))) |
#define | MLB_MADR_TB (0x1u << 30) |
| | (MLB_MADR) Target Location Bit
#define | MLB_MADR_TB_CTR (0x0u << 30) |
| | (MLB_MADR) Selects CTR
#define | MLB_MADR_TB_DBR (0x1u << 30) |
| | (MLB_MADR) Selects DBR
#define | MLB_MADR_WNR (0x1u << 31) |
| | (MLB_MADR) Write-Not-Read Selection
#define | MLB_ACTL_SCE (0x1u << 0) |
| | (MLB_ACTL) Software Clear Enable
#define | MLB_ACTL_SMX (0x1u << 1) |
| | (MLB_ACTL) AHB Interrupt Mux Enable
#define | MLB_ACTL_DMA_MODE (0x1u << 2) |
| | (MLB_ACTL) DMA Mode
#define | MLB_ACTL_MPB (0x1u << 4) |
| | (MLB_ACTL) DMA Packet Buffering Mode
#define | MLB_ACTL_MPB_SINGLE_PACKET (0x0u << 4) |
| | (MLB_ACTL) Single-packet mode
#define | MLB_ACTL_MPB_MULTIPLE_PACKET (0x1u << 4) |
| | (MLB_ACTL) Multiple-packet mode
#define | MLB_ACSR_CHS_Pos 0 |
#define | MLB_ACSR_CHS_Msk (0xffffffffu << MLB_ACSR_CHS_Pos) |
| | (MLB_ACSR[2]) Interrupt Status for Logical Channels [31:0] (cleared by writing a 1)
#define | MLB_ACSR_CHS(value) ((MLB_ACSR_CHS_Msk & ((value) << MLB_ACSR_CHS_Pos))) |
#define | MLB_ACMR_CHM_Pos 0 |
#define | MLB_ACMR_CHM_Msk (0xffffffffu << MLB_ACMR_CHM_Pos) |
| | (MLB_ACMR[2]) Bitwise Channel Mask Bits 31 to 0
#define | MLB_ACMR_CHM(value) ((MLB_ACMR_CHM_Msk & ((value) << MLB_ACMR_CHM_Pos))) |
