#define | GMACSA_NUMBER 4 |
| | Gmac hardware registers.
#define | GMACST2COMPARE_NUMBER 24 |
#define | GMAC_NCR_LBL (0x1u << 1) |
| | (GMAC_NCR) Loop Back Local
#define | GMAC_NCR_RXEN (0x1u << 2) |
| | (GMAC_NCR) Receive Enable
#define | GMAC_NCR_TXEN (0x1u << 3) |
| | (GMAC_NCR) Transmit Enable
#define | GMAC_NCR_MPE (0x1u << 4) |
| | (GMAC_NCR) Management Port Enable
#define | GMAC_NCR_CLRSTAT (0x1u << 5) |
| | (GMAC_NCR) Clear Statistics Registers
#define | GMAC_NCR_INCSTAT (0x1u << 6) |
| | (GMAC_NCR) Increment Statistics Registers
#define | GMAC_NCR_WESTAT (0x1u << 7) |
| | (GMAC_NCR) Write Enable for Statistics Registers
#define | GMAC_NCR_BP (0x1u << 8) |
| | (GMAC_NCR) Back pressure
#define | GMAC_NCR_TSTART (0x1u << 9) |
| | (GMAC_NCR) Start Transmission
#define | GMAC_NCR_THALT (0x1u << 10) |
| | (GMAC_NCR) Transmit Halt
#define | GMAC_NCR_TXPF (0x1u << 11) |
| | (GMAC_NCR) Transmit Pause Frame
#define | GMAC_NCR_TXZQPF (0x1u << 12) |
| | (GMAC_NCR) Transmit Zero Quantum Pause Frame
#define | GMAC_NCR_SRTSM (0x1u << 15) |
| | (GMAC_NCR) Store Receive Time Stamp to Memory
#define | GMAC_NCR_ENPBPR (0x1u << 16) |
| | (GMAC_NCR) Enable PFC Priority-based Pause Reception
#define | GMAC_NCR_TXPBPF (0x1u << 17) |
| | (GMAC_NCR) Transmit PFC Priority-based Pause Frame
#define | GMAC_NCR_FNP (0x1u << 18) |
| | (GMAC_NCR) Flush Next Packet
#define | GMAC_NCFGR_SPD (0x1u << 0) |
| | (GMAC_NCFGR) Speed
#define | GMAC_NCFGR_FD (0x1u << 1) |
| | (GMAC_NCFGR) Full Duplex
#define | GMAC_NCFGR_DNVLAN (0x1u << 2) |
| | (GMAC_NCFGR) Discard Non-VLAN FRAMES
#define | GMAC_NCFGR_JFRAME (0x1u << 3) |
| | (GMAC_NCFGR) Jumbo Frame Size
#define | GMAC_NCFGR_CAF (0x1u << 4) |
| | (GMAC_NCFGR) Copy All Frames
#define | GMAC_NCFGR_NBC (0x1u << 5) |
| | (GMAC_NCFGR) No Broadcast
#define | GMAC_NCFGR_MTIHEN (0x1u << 6) |
| | (GMAC_NCFGR) Multicast Hash Enable
#define | GMAC_NCFGR_UNIHEN (0x1u << 7) |
| | (GMAC_NCFGR) Unicast Hash Enable
#define | GMAC_NCFGR_MAXFS (0x1u << 8) |
| | (GMAC_NCFGR) 1536 Maximum Frame Size
#define | GMAC_NCFGR_RTY (0x1u << 12) |
| | (GMAC_NCFGR) Retry Test
#define | GMAC_NCFGR_PEN (0x1u << 13) |
| | (GMAC_NCFGR) Pause Enable
#define | GMAC_NCFGR_RXBUFO_Pos 14 |
#define | GMAC_NCFGR_RXBUFO_Msk (0x3u << GMAC_NCFGR_RXBUFO_Pos) |
| | (GMAC_NCFGR) Receive Buffer Offset
#define | GMAC_NCFGR_RXBUFO(value) ((GMAC_NCFGR_RXBUFO_Msk & ((value) << GMAC_NCFGR_RXBUFO_Pos))) |
#define | GMAC_NCFGR_LFERD (0x1u << 16) |
| | (GMAC_NCFGR) Length Field Error Frame Discard
#define | GMAC_NCFGR_RFCS (0x1u << 17) |
| | (GMAC_NCFGR) Remove FCS
#define | GMAC_NCFGR_CLK_Pos 18 |
#define | GMAC_NCFGR_CLK_Msk (0x7u << GMAC_NCFGR_CLK_Pos) |
| | (GMAC_NCFGR) MDC CLock Division
#define | GMAC_NCFGR_CLK(value) ((GMAC_NCFGR_CLK_Msk & ((value) << GMAC_NCFGR_CLK_Pos))) |
#define | GMAC_NCFGR_CLK_MCK_8 (0x0u << 18) |
| | (GMAC_NCFGR) MCK divided by 8 (MCK up to 20 MHz)
#define | GMAC_NCFGR_CLK_MCK_16 (0x1u << 18) |
| | (GMAC_NCFGR) MCK divided by 16 (MCK up to 40 MHz)
#define | GMAC_NCFGR_CLK_MCK_32 (0x2u << 18) |
| | (GMAC_NCFGR) MCK divided by 32 (MCK up to 80 MHz)
#define | GMAC_NCFGR_CLK_MCK_48 (0x3u << 18) |
| | (GMAC_NCFGR) MCK divided by 48 (MCK up to 120 MHz)
#define | GMAC_NCFGR_CLK_MCK_64 (0x4u << 18) |
| | (GMAC_NCFGR) MCK divided by 64 (MCK up to 160 MHz)
#define | GMAC_NCFGR_CLK_MCK_96 (0x5u << 18) |
| | (GMAC_NCFGR) MCK divided by 96 (MCK up to 240 MHz)
#define | GMAC_NCFGR_DBW_Pos 21 |
#define | GMAC_NCFGR_DBW_Msk (0x3u << GMAC_NCFGR_DBW_Pos) |
| | (GMAC_NCFGR) Data Bus Width
#define | GMAC_NCFGR_DBW(value) ((GMAC_NCFGR_DBW_Msk & ((value) << GMAC_NCFGR_DBW_Pos))) |
#define | GMAC_NCFGR_DCPF (0x1u << 23) |
| | (GMAC_NCFGR) Disable Copy of Pause Frames
#define | GMAC_NCFGR_RXCOEN (0x1u << 24) |
| | (GMAC_NCFGR) Receive Checksum Offload Enable
#define | GMAC_NCFGR_EFRHD (0x1u << 25) |
| | (GMAC_NCFGR) Enable Frames Received in Half Duplex
#define | GMAC_NCFGR_IRXFCS (0x1u << 26) |
| | (GMAC_NCFGR) Ignore RX FCS
#define | GMAC_NCFGR_IPGSEN (0x1u << 28) |
| | (GMAC_NCFGR) IP Stretch Enable
#define | GMAC_NCFGR_RXBP (0x1u << 29) |
| | (GMAC_NCFGR) Receive Bad Preamble
#define | GMAC_NCFGR_IRXER (0x1u << 30) |
| | (GMAC_NCFGR) Ignore IPG GRXER
#define | GMAC_NSR_MDIO (0x1u << 1) |
| | (GMAC_NSR) MDIO Input Status
#define | GMAC_NSR_IDLE (0x1u << 2) |
| | (GMAC_NSR) PHY Management Logic Idle
#define | GMAC_UR_RMII (0x1u << 0) |
| | (GMAC_UR) Reduced MII Mode
#define | GMAC_DCFGR_FBLDO_Pos 0 |
#define | GMAC_DCFGR_FBLDO_Msk (0x1fu << GMAC_DCFGR_FBLDO_Pos) |
| | (GMAC_DCFGR) Fixed Burst Length for DMA Data Operations:
#define | GMAC_DCFGR_FBLDO(value) ((GMAC_DCFGR_FBLDO_Msk & ((value) << GMAC_DCFGR_FBLDO_Pos))) |
#define | GMAC_DCFGR_FBLDO_SINGLE (0x1u << 0) |
| | (GMAC_DCFGR) 00001: Always use SINGLE AHB bursts
#define | GMAC_DCFGR_FBLDO_INCR4 (0x4u << 0) |
| | (GMAC_DCFGR) 001xx: Attempt to use INCR4 AHB bursts (Default)
#define | GMAC_DCFGR_FBLDO_INCR8 (0x8u << 0) |
| | (GMAC_DCFGR) 01xxx: Attempt to use INCR8 AHB bursts
#define | GMAC_DCFGR_FBLDO_INCR16 (0x10u << 0) |
| | (GMAC_DCFGR) 1xxxx: Attempt to use INCR16 AHB bursts
#define | GMAC_DCFGR_ESMA (0x1u << 6) |
| | (GMAC_DCFGR) Endian Swap Mode Enable for Management Descriptor Accesses
#define | GMAC_DCFGR_ESPA (0x1u << 7) |
| | (GMAC_DCFGR) Endian Swap Mode Enable for Packet Data Accesses
#define | GMAC_DCFGR_RXBMS_Pos 8 |
#define | GMAC_DCFGR_RXBMS_Msk (0x3u << GMAC_DCFGR_RXBMS_Pos) |
| | (GMAC_DCFGR) Receiver Packet Buffer Memory Size Select
#define | GMAC_DCFGR_RXBMS(value) ((GMAC_DCFGR_RXBMS_Msk & ((value) << GMAC_DCFGR_RXBMS_Pos))) |
#define | GMAC_DCFGR_RXBMS_EIGHTH (0x0u << 8) |
| | (GMAC_DCFGR) 4/8 Kbyte Memory Size
#define | GMAC_DCFGR_RXBMS_QUARTER (0x1u << 8) |
| | (GMAC_DCFGR) 4/4 Kbytes Memory Size
#define | GMAC_DCFGR_RXBMS_HALF (0x2u << 8) |
| | (GMAC_DCFGR) 4/2 Kbytes Memory Size
#define | GMAC_DCFGR_RXBMS_FULL (0x3u << 8) |
| | (GMAC_DCFGR) 4 Kbytes Memory Size
#define | GMAC_DCFGR_TXPBMS (0x1u << 10) |
| | (GMAC_DCFGR) Transmitter Packet Buffer Memory Size Select
#define | GMAC_DCFGR_TXCOEN (0x1u << 11) |
| | (GMAC_DCFGR) Transmitter Checksum Generation Offload Enable
#define | GMAC_DCFGR_DRBS_Pos 16 |
#define | GMAC_DCFGR_DRBS_Msk (0xffu << GMAC_DCFGR_DRBS_Pos) |
| | (GMAC_DCFGR) DMA Receive Buffer Size
#define | GMAC_DCFGR_DRBS(value) ((GMAC_DCFGR_DRBS_Msk & ((value) << GMAC_DCFGR_DRBS_Pos))) |
#define | GMAC_DCFGR_DDRP (0x1u << 24) |
| | (GMAC_DCFGR) DMA Discard Receive Packets
#define | GMAC_TSR_UBR (0x1u << 0) |
| | (GMAC_TSR) Used Bit Read
#define | GMAC_TSR_COL (0x1u << 1) |
| | (GMAC_TSR) Collision Occurred
#define | GMAC_TSR_RLE (0x1u << 2) |
| | (GMAC_TSR) Retry Limit Exceeded
#define | GMAC_TSR_TXGO (0x1u << 3) |
| | (GMAC_TSR) Transmit Go
#define | GMAC_TSR_TFC (0x1u << 4) |
| | (GMAC_TSR) Transmit Frame Corruption Due to AHB Error
#define | GMAC_TSR_TXCOMP (0x1u << 5) |
| | (GMAC_TSR) Transmit Complete
#define | GMAC_TSR_HRESP (0x1u << 8) |
| | (GMAC_TSR) HRESP Not OK
#define | GMAC_RBQB_ADDR_Pos 2 |
#define | GMAC_RBQB_ADDR_Msk (0x3fffffffu << GMAC_RBQB_ADDR_Pos) |
| | (GMAC_RBQB) Receive Buffer Queue Base Address
#define | GMAC_RBQB_ADDR(value) ((GMAC_RBQB_ADDR_Msk & ((value) << GMAC_RBQB_ADDR_Pos))) |
#define | GMAC_TBQB_ADDR_Pos 2 |
#define | GMAC_TBQB_ADDR_Msk (0x3fffffffu << GMAC_TBQB_ADDR_Pos) |
| | (GMAC_TBQB) Transmit Buffer Queue Base Address
#define | GMAC_TBQB_ADDR(value) ((GMAC_TBQB_ADDR_Msk & ((value) << GMAC_TBQB_ADDR_Pos))) |
#define | GMAC_RSR_BNA (0x1u << 0) |
| | (GMAC_RSR) Buffer Not Available
#define | GMAC_RSR_REC (0x1u << 1) |
| | (GMAC_RSR) Frame Received
#define | GMAC_RSR_RXOVR (0x1u << 2) |
| | (GMAC_RSR) Receive Overrun
#define | GMAC_RSR_HNO (0x1u << 3) |
| | (GMAC_RSR) HRESP Not OK
#define | GMAC_ISR_MFS (0x1u << 0) |
| | (GMAC_ISR) Management Frame Sent
#define | GMAC_ISR_RCOMP (0x1u << 1) |
| | (GMAC_ISR) Receive Complete
#define | GMAC_ISR_RXUBR (0x1u << 2) |
| | (GMAC_ISR) RX Used Bit Read
#define | GMAC_ISR_TXUBR (0x1u << 3) |
| | (GMAC_ISR) TX Used Bit Read
#define | GMAC_ISR_TUR (0x1u << 4) |
| | (GMAC_ISR) Transmit Underrun
#define | GMAC_ISR_RLEX (0x1u << 5) |
| | (GMAC_ISR) Retry Limit Exceeded
#define | GMAC_ISR_TFC (0x1u << 6) |
| | (GMAC_ISR) Transmit Frame Corruption Due to AHB Error
#define | GMAC_ISR_TCOMP (0x1u << 7) |
| | (GMAC_ISR) Transmit Complete
#define | GMAC_ISR_ROVR (0x1u << 10) |
| | (GMAC_ISR) Receive Overrun
#define | GMAC_ISR_HRESP (0x1u << 11) |
| | (GMAC_ISR) HRESP Not OK
#define | GMAC_ISR_PFNZ (0x1u << 12) |
| | (GMAC_ISR) Pause Frame with Non-zero Pause Quantum Received
#define | GMAC_ISR_PTZ (0x1u << 13) |
| | (GMAC_ISR) Pause Time Zero
#define | GMAC_ISR_PFTR (0x1u << 14) |
| | (GMAC_ISR) Pause Frame Transmitted
#define | GMAC_ISR_DRQFR (0x1u << 18) |
| | (GMAC_ISR) PTP Delay Request Frame Received
#define | GMAC_ISR_SFR (0x1u << 19) |
| | (GMAC_ISR) PTP Sync Frame Received
#define | GMAC_ISR_DRQFT (0x1u << 20) |
| | (GMAC_ISR) PTP Delay Request Frame Transmitted
#define | GMAC_ISR_SFT (0x1u << 21) |
| | (GMAC_ISR) PTP Sync Frame Transmitted
#define | GMAC_ISR_PDRQFR (0x1u << 22) |
| | (GMAC_ISR) PDelay Request Frame Received
#define | GMAC_ISR_PDRSFR (0x1u << 23) |
| | (GMAC_ISR) PDelay Response Frame Received
#define | GMAC_ISR_PDRQFT (0x1u << 24) |
| | (GMAC_ISR) PDelay Request Frame Transmitted
#define | GMAC_ISR_PDRSFT (0x1u << 25) |
| | (GMAC_ISR) PDelay Response Frame Transmitted
#define | GMAC_ISR_SRI (0x1u << 26) |
| | (GMAC_ISR) TSU Seconds Register Increment
#define | GMAC_ISR_WOL (0x1u << 28) |
| | (GMAC_ISR) Wake On LAN
#define | GMAC_ISR_TSU (0x1u << 29) |
| | (GMAC_ISR) TSU timer comparison interrupt
#define | GMAC_IER_MFS (0x1u << 0) |
| | (GMAC_IER) Management Frame Sent
#define | GMAC_IER_RCOMP (0x1u << 1) |
| | (GMAC_IER) Receive Complete
#define | GMAC_IER_RXUBR (0x1u << 2) |
| | (GMAC_IER) RX Used Bit Read
#define | GMAC_IER_TXUBR (0x1u << 3) |
| | (GMAC_IER) TX Used Bit Read
#define | GMAC_IER_TUR (0x1u << 4) |
| | (GMAC_IER) Transmit Underrun
#define | GMAC_IER_RLEX (0x1u << 5) |
| | (GMAC_IER) Retry Limit Exceeded or Late Collision
#define | GMAC_IER_TFC (0x1u << 6) |
| | (GMAC_IER) Transmit Frame Corruption Due to AHB Error
#define | GMAC_IER_TCOMP (0x1u << 7) |
| | (GMAC_IER) Transmit Complete
#define | GMAC_IER_ROVR (0x1u << 10) |
| | (GMAC_IER) Receive Overrun
#define | GMAC_IER_HRESP (0x1u << 11) |
| | (GMAC_IER) HRESP Not OK
#define | GMAC_IER_PFNZ (0x1u << 12) |
| | (GMAC_IER) Pause Frame with Non-zero Pause Quantum Received
#define | GMAC_IER_PTZ (0x1u << 13) |
| | (GMAC_IER) Pause Time Zero
#define | GMAC_IER_PFTR (0x1u << 14) |
| | (GMAC_IER) Pause Frame Transmitted
#define | GMAC_IER_EXINT (0x1u << 15) |
| | (GMAC_IER) External Interrupt
#define | GMAC_IER_DRQFR (0x1u << 18) |
| | (GMAC_IER) PTP Delay Request Frame Received
#define | GMAC_IER_SFR (0x1u << 19) |
| | (GMAC_IER) PTP Sync Frame Received
#define | GMAC_IER_DRQFT (0x1u << 20) |
| | (GMAC_IER) PTP Delay Request Frame Transmitted
#define | GMAC_IER_SFT (0x1u << 21) |
| | (GMAC_IER) PTP Sync Frame Transmitted
#define | GMAC_IER_PDRQFR (0x1u << 22) |
| | (GMAC_IER) PDelay Request Frame Received
#define | GMAC_IER_PDRSFR (0x1u << 23) |
| | (GMAC_IER) PDelay Response Frame Received
#define | GMAC_IER_PDRQFT (0x1u << 24) |
| | (GMAC_IER) PDelay Request Frame Transmitted
#define | GMAC_IER_PDRSFT (0x1u << 25) |
| | (GMAC_IER) PDelay Response Frame Transmitted
#define | GMAC_IER_SRI (0x1u << 26) |
| | (GMAC_IER) TSU Seconds Register Increment
#define | GMAC_IER_WOL (0x1u << 28) |
| | (GMAC_IER) Wake On LAN
#define | GMAC_IDR_MFS (0x1u << 0) |
| | (GMAC_IDR) Management Frame Sent
#define | GMAC_IDR_RCOMP (0x1u << 1) |
| | (GMAC_IDR) Receive Complete
#define | GMAC_IDR_RXUBR (0x1u << 2) |
| | (GMAC_IDR) RX Used Bit Read
#define | GMAC_IDR_TXUBR (0x1u << 3) |
| | (GMAC_IDR) TX Used Bit Read
#define | GMAC_IDR_TUR (0x1u << 4) |
| | (GMAC_IDR) Transmit Underrun
#define | GMAC_IDR_RLEX (0x1u << 5) |
| | (GMAC_IDR) Retry Limit Exceeded or Late Collision
#define | GMAC_IDR_TFC (0x1u << 6) |
| | (GMAC_IDR) Transmit Frame Corruption Due to AHB Error
#define | GMAC_IDR_TCOMP (0x1u << 7) |
| | (GMAC_IDR) Transmit Complete
#define | GMAC_IDR_ROVR (0x1u << 10) |
| | (GMAC_IDR) Receive Overrun
#define | GMAC_IDR_HRESP (0x1u << 11) |
| | (GMAC_IDR) HRESP Not OK
#define | GMAC_IDR_PFNZ (0x1u << 12) |
| | (GMAC_IDR) Pause Frame with Non-zero Pause Quantum Received
#define | GMAC_IDR_PTZ (0x1u << 13) |
| | (GMAC_IDR) Pause Time Zero
#define | GMAC_IDR_PFTR (0x1u << 14) |
| | (GMAC_IDR) Pause Frame Transmitted
#define | GMAC_IDR_EXINT (0x1u << 15) |
| | (GMAC_IDR) External Interrupt
#define | GMAC_IDR_DRQFR (0x1u << 18) |
| | (GMAC_IDR) PTP Delay Request Frame Received
#define | GMAC_IDR_SFR (0x1u << 19) |
| | (GMAC_IDR) PTP Sync Frame Received
#define | GMAC_IDR_DRQFT (0x1u << 20) |
| | (GMAC_IDR) PTP Delay Request Frame Transmitted
#define | GMAC_IDR_SFT (0x1u << 21) |
| | (GMAC_IDR) PTP Sync Frame Transmitted
#define | GMAC_IDR_PDRQFR (0x1u << 22) |
| | (GMAC_IDR) PDelay Request Frame Received
#define | GMAC_IDR_PDRSFR (0x1u << 23) |
| | (GMAC_IDR) PDelay Response Frame Received
#define | GMAC_IDR_PDRQFT (0x1u << 24) |
| | (GMAC_IDR) PDelay Request Frame Transmitted
#define | GMAC_IDR_PDRSFT (0x1u << 25) |
| | (GMAC_IDR) PDelay Response Frame Transmitted
#define | GMAC_IDR_SRI (0x1u << 26) |
| | (GMAC_IDR) TSU Seconds Register Increment
#define | GMAC_IDR_WOL (0x1u << 28) |
| | (GMAC_IDR) Wake On LAN
#define | GMAC_IMR_MFS (0x1u << 0) |
| | (GMAC_IMR) Management Frame Sent
#define | GMAC_IMR_RCOMP (0x1u << 1) |
| | (GMAC_IMR) Receive Complete
#define | GMAC_IMR_RXUBR (0x1u << 2) |
| | (GMAC_IMR) RX Used Bit Read
#define | GMAC_IMR_TXUBR (0x1u << 3) |
| | (GMAC_IMR) TX Used Bit Read
#define | GMAC_IMR_TUR (0x1u << 4) |
| | (GMAC_IMR) Transmit Underrun
#define | GMAC_IMR_RLEX (0x1u << 5) |
| | (GMAC_IMR) Retry Limit Exceeded
#define | GMAC_IMR_TFC (0x1u << 6) |
| | (GMAC_IMR) Transmit Frame Corruption Due to AHB Error
#define | GMAC_IMR_TCOMP (0x1u << 7) |
| | (GMAC_IMR) Transmit Complete
#define | GMAC_IMR_ROVR (0x1u << 10) |
| | (GMAC_IMR) Receive Overrun
#define | GMAC_IMR_HRESP (0x1u << 11) |
| | (GMAC_IMR) HRESP Not OK
#define | GMAC_IMR_PFNZ (0x1u << 12) |
| | (GMAC_IMR) Pause Frame with Non-zero Pause Quantum Received
#define | GMAC_IMR_PTZ (0x1u << 13) |
| | (GMAC_IMR) Pause Time Zero
#define | GMAC_IMR_PFTR (0x1u << 14) |
| | (GMAC_IMR) Pause Frame Transmitted
#define | GMAC_IMR_EXINT (0x1u << 15) |
| | (GMAC_IMR) External Interrupt
#define | GMAC_IMR_DRQFR (0x1u << 18) |
| | (GMAC_IMR) PTP Delay Request Frame Received
#define | GMAC_IMR_SFR (0x1u << 19) |
| | (GMAC_IMR) PTP Sync Frame Received
#define | GMAC_IMR_DRQFT (0x1u << 20) |
| | (GMAC_IMR) PTP Delay Request Frame Transmitted
#define | GMAC_IMR_SFT (0x1u << 21) |
| | (GMAC_IMR) PTP Sync Frame Transmitted
#define | GMAC_IMR_PDRQFR (0x1u << 22) |
| | (GMAC_IMR) PDelay Request Frame Received
#define | GMAC_IMR_PDRSFR (0x1u << 23) |
| | (GMAC_IMR) PDelay Response Frame Received
#define | GMAC_IMR_PDRQFT (0x1u << 24) |
| | (GMAC_IMR) PDelay Request Frame Transmitted
#define | GMAC_IMR_PDRSFT (0x1u << 25) |
| | (GMAC_IMR) PDelay Response Frame Transmitted
#define | GMAC_MAN_DATA_Pos 0 |
#define | GMAC_MAN_DATA_Msk (0xffffu << GMAC_MAN_DATA_Pos) |
| | (GMAC_MAN) PHY Data
#define | GMAC_MAN_DATA(value) ((GMAC_MAN_DATA_Msk & ((value) << GMAC_MAN_DATA_Pos))) |
#define | GMAC_MAN_WTN_Pos 16 |
#define | GMAC_MAN_WTN_Msk (0x3u << GMAC_MAN_WTN_Pos) |
| | (GMAC_MAN) Write Ten
#define | GMAC_MAN_WTN(value) ((GMAC_MAN_WTN_Msk & ((value) << GMAC_MAN_WTN_Pos))) |
#define | GMAC_MAN_REGA_Pos 18 |
#define | GMAC_MAN_REGA_Msk (0x1fu << GMAC_MAN_REGA_Pos) |
| | (GMAC_MAN) Register Address
#define | GMAC_MAN_REGA(value) ((GMAC_MAN_REGA_Msk & ((value) << GMAC_MAN_REGA_Pos))) |
#define | GMAC_MAN_PHYA_Pos 23 |
#define | GMAC_MAN_PHYA_Msk (0x1fu << GMAC_MAN_PHYA_Pos) |
| | (GMAC_MAN) PHY Address
#define | GMAC_MAN_PHYA(value) ((GMAC_MAN_PHYA_Msk & ((value) << GMAC_MAN_PHYA_Pos))) |
#define | GMAC_MAN_OP_Pos 28 |
#define | GMAC_MAN_OP_Msk (0x3u << GMAC_MAN_OP_Pos) |
| | (GMAC_MAN) Operation
#define | GMAC_MAN_OP(value) ((GMAC_MAN_OP_Msk & ((value) << GMAC_MAN_OP_Pos))) |
#define | GMAC_MAN_CLTTO (0x1u << 30) |
| | (GMAC_MAN) Clause 22 Operation
#define | GMAC_MAN_WZO (0x1u << 31) |
| | (GMAC_MAN) Write ZERO
#define | GMAC_RPQ_RPQ_Pos 0 |
#define | GMAC_RPQ_RPQ_Msk (0xffffu << GMAC_RPQ_RPQ_Pos) |
| | (GMAC_RPQ) Received Pause Quantum
#define | GMAC_TPQ_TPQ_Pos 0 |
#define | GMAC_TPQ_TPQ_Msk (0xffffu << GMAC_TPQ_TPQ_Pos) |
| | (GMAC_TPQ) Transmit Pause Quantum
#define | GMAC_TPQ_TPQ(value) ((GMAC_TPQ_TPQ_Msk & ((value) << GMAC_TPQ_TPQ_Pos))) |
#define | GMAC_TPSF_TPB1ADR_Pos 0 |
#define | GMAC_TPSF_TPB1ADR_Msk (0xfffu << GMAC_TPSF_TPB1ADR_Pos) |
| | (GMAC_TPSF) Transmit Partial Store and Forward Address
#define | GMAC_TPSF_TPB1ADR(value) ((GMAC_TPSF_TPB1ADR_Msk & ((value) << GMAC_TPSF_TPB1ADR_Pos))) |
#define | GMAC_TPSF_ENTXP (0x1u << 31) |
| | (GMAC_TPSF) Enable TX Partial Store and Forward Operation
#define | GMAC_RPSF_RPB1ADR_Pos 0 |
#define | GMAC_RPSF_RPB1ADR_Msk (0xfffu << GMAC_RPSF_RPB1ADR_Pos) |
| | (GMAC_RPSF) Receive Partial Store and Forward Address
#define | GMAC_RPSF_RPB1ADR(value) ((GMAC_RPSF_RPB1ADR_Msk & ((value) << GMAC_RPSF_RPB1ADR_Pos))) |
#define | GMAC_RPSF_ENRXP (0x1u << 31) |
| | (GMAC_RPSF) Enable RX Partial Store and Forward Operation
#define | GMAC_RJFML_FML_Pos 0 |
#define | GMAC_RJFML_FML_Msk (0x3fffu << GMAC_RJFML_FML_Pos) |
| | (GMAC_RJFML) Frame Max Length
#define | GMAC_RJFML_FML(value) ((GMAC_RJFML_FML_Msk & ((value) << GMAC_RJFML_FML_Pos))) |
#define | GMAC_HRB_ADDR_Pos 0 |
#define | GMAC_HRB_ADDR_Msk (0xffffffffu << GMAC_HRB_ADDR_Pos) |
| | (GMAC_HRB) Hash Address
#define | GMAC_HRB_ADDR(value) ((GMAC_HRB_ADDR_Msk & ((value) << GMAC_HRB_ADDR_Pos))) |
#define | GMAC_HRT_ADDR_Pos 0 |
#define | GMAC_HRT_ADDR_Msk (0xffffffffu << GMAC_HRT_ADDR_Pos) |
| | (GMAC_HRT) Hash Address
#define | GMAC_HRT_ADDR(value) ((GMAC_HRT_ADDR_Msk & ((value) << GMAC_HRT_ADDR_Pos))) |
#define | GMAC_SAB_ADDR_Pos 0 |
#define | GMAC_SAB_ADDR_Msk (0xffffffffu << GMAC_SAB_ADDR_Pos) |
| | (GMAC_SAB) Specific Address 1
#define | GMAC_SAB_ADDR(value) ((GMAC_SAB_ADDR_Msk & ((value) << GMAC_SAB_ADDR_Pos))) |
#define | GMAC_SAT_ADDR_Pos 0 |
#define | GMAC_SAT_ADDR_Msk (0xffffu << GMAC_SAT_ADDR_Pos) |
| | (GMAC_SAT) Specific Address 1
#define | GMAC_SAT_ADDR(value) ((GMAC_SAT_ADDR_Msk & ((value) << GMAC_SAT_ADDR_Pos))) |
#define | GMAC_TIDM1_TID_Pos 0 |
#define | GMAC_TIDM1_TID_Msk (0xffffu << GMAC_TIDM1_TID_Pos) |
| | (GMAC_TIDM1) Type ID Match 1
#define | GMAC_TIDM1_TID(value) ((GMAC_TIDM1_TID_Msk & ((value) << GMAC_TIDM1_TID_Pos))) |
#define | GMAC_TIDM1_ENID1 (0x1u << 31) |
| | (GMAC_TIDM1) Enable Copying of TID Matched Frames
#define | GMAC_TIDM2_TID_Pos 0 |
#define | GMAC_TIDM2_TID_Msk (0xffffu << GMAC_TIDM2_TID_Pos) |
| | (GMAC_TIDM2) Type ID Match 2
#define | GMAC_TIDM2_TID(value) ((GMAC_TIDM2_TID_Msk & ((value) << GMAC_TIDM2_TID_Pos))) |
#define | GMAC_TIDM2_ENID2 (0x1u << 31) |
| | (GMAC_TIDM2) Enable Copying of TID Matched Frames
#define | GMAC_TIDM3_TID_Pos 0 |
#define | GMAC_TIDM3_TID_Msk (0xffffu << GMAC_TIDM3_TID_Pos) |
| | (GMAC_TIDM3) Type ID Match 3
#define | GMAC_TIDM3_TID(value) ((GMAC_TIDM3_TID_Msk & ((value) << GMAC_TIDM3_TID_Pos))) |
#define | GMAC_TIDM3_ENID3 (0x1u << 31) |
| | (GMAC_TIDM3) Enable Copying of TID Matched Frames
#define | GMAC_TIDM4_TID_Pos 0 |
#define | GMAC_TIDM4_TID_Msk (0xffffu << GMAC_TIDM4_TID_Pos) |
| | (GMAC_TIDM4) Type ID Match 4
#define | GMAC_TIDM4_TID(value) ((GMAC_TIDM4_TID_Msk & ((value) << GMAC_TIDM4_TID_Pos))) |
#define | GMAC_TIDM4_ENID4 (0x1u << 31) |
| | (GMAC_TIDM4) Enable Copying of TID Matched Frames
#define | GMAC_WOL_IP_Pos 0 |
#define | GMAC_WOL_IP_Msk (0xffffu << GMAC_WOL_IP_Pos) |
| | (GMAC_WOL) ARP Request IP Address
#define | GMAC_WOL_IP(value) ((GMAC_WOL_IP_Msk & ((value) << GMAC_WOL_IP_Pos))) |
#define | GMAC_WOL_MAG (0x1u << 16) |
| | (GMAC_WOL) Magic Packet Event Enable
#define | GMAC_WOL_ARP (0x1u << 17) |
#define | GMAC_WOL_SA1 (0x1u << 18) |
| | (GMAC_WOL) Specific Address Register 1 Event Enable
#define | GMAC_WOL_MTI (0x1u << 19) |
| | (GMAC_WOL) Multicast Hash Event Enable
#define | GMAC_IPGS_FL_Pos 0 |
#define | GMAC_IPGS_FL_Msk (0xffffu << GMAC_IPGS_FL_Pos) |
| | (GMAC_IPGS) Frame Length
#define | GMAC_IPGS_FL(value) ((GMAC_IPGS_FL_Msk & ((value) << GMAC_IPGS_FL_Pos))) |
#define | GMAC_SVLAN_VLAN_TYPE_Pos 0 |
#define | GMAC_SVLAN_VLAN_TYPE_Msk (0xffffu << GMAC_SVLAN_VLAN_TYPE_Pos) |
| | (GMAC_SVLAN) User Defined VLAN_TYPE Field
#define | GMAC_SVLAN_VLAN_TYPE(value) ((GMAC_SVLAN_VLAN_TYPE_Msk & ((value) << GMAC_SVLAN_VLAN_TYPE_Pos))) |
#define | GMAC_SVLAN_ESVLAN (0x1u << 31) |
| | (GMAC_SVLAN) Enable Stacked VLAN Processing Mode
#define | GMAC_TPFCP_PEV_Pos 0 |
#define | GMAC_TPFCP_PEV_Msk (0xffu << GMAC_TPFCP_PEV_Pos) |
| | (GMAC_TPFCP) Priority Enable Vector
#define | GMAC_TPFCP_PEV(value) ((GMAC_TPFCP_PEV_Msk & ((value) << GMAC_TPFCP_PEV_Pos))) |
#define | GMAC_TPFCP_PQ_Pos 8 |
#define | GMAC_TPFCP_PQ_Msk (0xffu << GMAC_TPFCP_PQ_Pos) |
| | (GMAC_TPFCP) Pause Quantum
#define | GMAC_TPFCP_PQ(value) ((GMAC_TPFCP_PQ_Msk & ((value) << GMAC_TPFCP_PQ_Pos))) |
#define | GMAC_SAMB1_ADDR_Pos 0 |
#define | GMAC_SAMB1_ADDR_Msk (0xffffffffu << GMAC_SAMB1_ADDR_Pos) |
| | (GMAC_SAMB1) Specific Address 1 Mask
#define | GMAC_SAMB1_ADDR(value) ((GMAC_SAMB1_ADDR_Msk & ((value) << GMAC_SAMB1_ADDR_Pos))) |
#define | GMAC_SAMT1_ADDR_Pos 0 |
#define | GMAC_SAMT1_ADDR_Msk (0xffffu << GMAC_SAMT1_ADDR_Pos) |
| | (GMAC_SAMT1) Specific Address 1 Mask
#define | GMAC_SAMT1_ADDR(value) ((GMAC_SAMT1_ADDR_Msk & ((value) << GMAC_SAMT1_ADDR_Pos))) |
#define | GMAC_NSC_NANOSEC_Pos 0 |
#define | GMAC_NSC_NANOSEC_Msk (0x3fffffu << GMAC_NSC_NANOSEC_Pos) |
| | (GMAC_NSC) 1588 Timer Nanosecond Comparison Value
#define | GMAC_NSC_NANOSEC(value) ((GMAC_NSC_NANOSEC_Msk & ((value) << GMAC_NSC_NANOSEC_Pos))) |
#define | GMAC_SCL_SEC_Pos 0 |
#define | GMAC_SCL_SEC_Msk (0xffffffffu << GMAC_SCL_SEC_Pos) |
| | (GMAC_SCL) 1588 Timer Second Comparison Value
#define | GMAC_SCL_SEC(value) ((GMAC_SCL_SEC_Msk & ((value) << GMAC_SCL_SEC_Pos))) |
#define | GMAC_SCH_SEC_Pos 0 |
#define | GMAC_SCH_SEC_Msk (0xffffu << GMAC_SCH_SEC_Pos) |
| | (GMAC_SCH) 1588 Timer Second Comparison Value
#define | GMAC_SCH_SEC(value) ((GMAC_SCH_SEC_Msk & ((value) << GMAC_SCH_SEC_Pos))) |
#define | GMAC_EFTSH_RUD_Pos 0 |
#define | GMAC_EFTSH_RUD_Msk (0xffffu << GMAC_EFTSH_RUD_Pos) |
| | (GMAC_EFTSH) Register Update
#define | GMAC_EFRSH_RUD_Pos 0 |
#define | GMAC_EFRSH_RUD_Msk (0xffffu << GMAC_EFRSH_RUD_Pos) |
| | (GMAC_EFRSH) Register Update
#define | GMAC_PEFTSH_RUD_Pos 0 |
#define | GMAC_PEFTSH_RUD_Msk (0xffffu << GMAC_PEFTSH_RUD_Pos) |
| | (GMAC_PEFTSH) Register Update
#define | GMAC_PEFRSH_RUD_Pos 0 |
#define | GMAC_PEFRSH_RUD_Msk (0xffffu << GMAC_PEFRSH_RUD_Pos) |
| | (GMAC_PEFRSH) Register Update
#define | GMAC_MID_MREV_Pos 0 |
#define | GMAC_MID_MREV_Msk (0xffffu << GMAC_MID_MREV_Pos) |
| | (GMAC_MID) Module Revision
#define | GMAC_MID_MID_Pos 16 |
#define | GMAC_MID_MID_Msk (0xffffu << GMAC_MID_MID_Pos) |
| | (GMAC_MID) Module Identification Number
#define | GMAC_OTLO_TXO_Pos 0 |
#define | GMAC_OTLO_TXO_Msk (0xffffffffu << GMAC_OTLO_TXO_Pos) |
| | (GMAC_OTLO) Transmitted Octets
#define | GMAC_OTHI_TXO_Pos 0 |
#define | GMAC_OTHI_TXO_Msk (0xffffu << GMAC_OTHI_TXO_Pos) |
| | (GMAC_OTHI) Transmitted Octets
#define | GMAC_FT_FTX_Pos 0 |
#define | GMAC_FT_FTX_Msk (0xffffffffu << GMAC_FT_FTX_Pos) |
| | (GMAC_FT) Frames Transmitted without Error
#define | GMAC_BCFT_BFTX_Pos 0 |
#define | GMAC_BCFT_BFTX_Msk (0xffffffffu << GMAC_BCFT_BFTX_Pos) |
| | (GMAC_BCFT) Broadcast Frames Transmitted without Error
#define | GMAC_MFT_MFTX_Pos 0 |
#define | GMAC_MFT_MFTX_Msk (0xffffffffu << GMAC_MFT_MFTX_Pos) |
| | (GMAC_MFT) Multicast Frames Transmitted without Error
#define | GMAC_PFT_PFTX_Pos 0 |
#define | GMAC_PFT_PFTX_Msk (0xffffu << GMAC_PFT_PFTX_Pos) |
| | (GMAC_PFT) Pause Frames Transmitted Register
#define | GMAC_BFT64_NFTX_Pos 0 |
#define | GMAC_BFT64_NFTX_Msk (0xffffffffu << GMAC_BFT64_NFTX_Pos) |
| | (GMAC_BFT64) 64 Byte Frames Transmitted without Error
#define | GMAC_TBFT127_NFTX_Pos 0 |
#define | GMAC_TBFT127_NFTX_Msk (0xffffffffu << GMAC_TBFT127_NFTX_Pos) |
| | (GMAC_TBFT127) 65 to 127 Byte Frames Transmitted without Error
#define | GMAC_TBFT255_NFTX_Pos 0 |
#define | GMAC_TBFT255_NFTX_Msk (0xffffffffu << GMAC_TBFT255_NFTX_Pos) |
| | (GMAC_TBFT255) 128 to 255 Byte Frames Transmitted without Error
#define | GMAC_TBFT511_NFTX_Pos 0 |
#define | GMAC_TBFT511_NFTX_Msk (0xffffffffu << GMAC_TBFT511_NFTX_Pos) |
| | (GMAC_TBFT511) 256 to 511 Byte Frames Transmitted without Error
#define | GMAC_TBFT1023_NFTX_Pos 0 |
#define | GMAC_TBFT1023_NFTX_Msk (0xffffffffu << GMAC_TBFT1023_NFTX_Pos) |
| | (GMAC_TBFT1023) 512 to 1023 Byte Frames Transmitted without Error
#define | GMAC_TBFT1518_NFTX_Pos 0 |
#define | GMAC_TBFT1518_NFTX_Msk (0xffffffffu << GMAC_TBFT1518_NFTX_Pos) |
| | (GMAC_TBFT1518) 1024 to 1518 Byte Frames Transmitted without Error
#define | GMAC_GTBFT1518_NFTX_Pos 0 |
#define | GMAC_GTBFT1518_NFTX_Msk (0xffffffffu << GMAC_GTBFT1518_NFTX_Pos) |
| | (GMAC_GTBFT1518) Greater than 1518 Byte Frames Transmitted without Error
#define | GMAC_TUR_TXUNR_Pos 0 |
#define | GMAC_TUR_TXUNR_Msk (0x3ffu << GMAC_TUR_TXUNR_Pos) |
| | (GMAC_TUR) Transmit Underruns
#define | GMAC_SCF_SCOL_Pos 0 |
#define | GMAC_SCF_SCOL_Msk (0x3ffffu << GMAC_SCF_SCOL_Pos) |
| | (GMAC_SCF) Single Collision
#define | GMAC_MCF_MCOL_Pos 0 |
#define | GMAC_MCF_MCOL_Msk (0x3ffffu << GMAC_MCF_MCOL_Pos) |
| | (GMAC_MCF) Multiple Collision
#define | GMAC_EC_XCOL_Pos 0 |
#define | GMAC_EC_XCOL_Msk (0x3ffu << GMAC_EC_XCOL_Pos) |
| | (GMAC_EC) Excessive Collisions
#define | GMAC_LC_LCOL_Pos 0 |
#define | GMAC_LC_LCOL_Msk (0x3ffu << GMAC_LC_LCOL_Pos) |
| | (GMAC_LC) Late Collisions
#define | GMAC_DTF_DEFT_Pos 0 |
#define | GMAC_DTF_DEFT_Msk (0x3ffffu << GMAC_DTF_DEFT_Pos) |
| | (GMAC_DTF) Deferred Transmission
#define | GMAC_CSE_CSR_Pos 0 |
#define | GMAC_CSE_CSR_Msk (0x3ffu << GMAC_CSE_CSR_Pos) |
| | (GMAC_CSE) Carrier Sense Error
#define | GMAC_ORLO_RXO_Pos 0 |
#define | GMAC_ORLO_RXO_Msk (0xffffffffu << GMAC_ORLO_RXO_Pos) |
| | (GMAC_ORLO) Received Octets
#define | GMAC_ORHI_RXO_Pos 0 |
#define | GMAC_ORHI_RXO_Msk (0xffffu << GMAC_ORHI_RXO_Pos) |
| | (GMAC_ORHI) Received Octets
#define | GMAC_FR_FRX_Pos 0 |
#define | GMAC_FR_FRX_Msk (0xffffffffu << GMAC_FR_FRX_Pos) |
| | (GMAC_FR) Frames Received without Error
#define | GMAC_BCFR_BFRX_Pos 0 |
#define | GMAC_BCFR_BFRX_Msk (0xffffffffu << GMAC_BCFR_BFRX_Pos) |
| | (GMAC_BCFR) Broadcast Frames Received without Error
#define | GMAC_MFR_MFRX_Pos 0 |
#define | GMAC_MFR_MFRX_Msk (0xffffffffu << GMAC_MFR_MFRX_Pos) |
| | (GMAC_MFR) Multicast Frames Received without Error
#define | GMAC_PFR_PFRX_Pos 0 |
#define | GMAC_PFR_PFRX_Msk (0xffffu << GMAC_PFR_PFRX_Pos) |
| | (GMAC_PFR) Pause Frames Received Register
#define | GMAC_BFR64_NFRX_Pos 0 |
#define | GMAC_BFR64_NFRX_Msk (0xffffffffu << GMAC_BFR64_NFRX_Pos) |
| | (GMAC_BFR64) 64 Byte Frames Received without Error
#define | GMAC_TBFR127_NFRX_Pos 0 |
#define | GMAC_TBFR127_NFRX_Msk (0xffffffffu << GMAC_TBFR127_NFRX_Pos) |
| | (GMAC_TBFR127) 65 to 127 Byte Frames Received without Error
#define | GMAC_TBFR255_NFRX_Pos 0 |
#define | GMAC_TBFR255_NFRX_Msk (0xffffffffu << GMAC_TBFR255_NFRX_Pos) |
| | (GMAC_TBFR255) 128 to 255 Byte Frames Received without Error
#define | GMAC_TBFR511_NFRX_Pos 0 |
#define | GMAC_TBFR511_NFRX_Msk (0xffffffffu << GMAC_TBFR511_NFRX_Pos) |
| | (GMAC_TBFR511) 256 to 511 Byte Frames Received without Error
#define | GMAC_TBFR1023_NFRX_Pos 0 |
#define | GMAC_TBFR1023_NFRX_Msk (0xffffffffu << GMAC_TBFR1023_NFRX_Pos) |
| | (GMAC_TBFR1023) 512 to 1023 Byte Frames Received without Error
#define | GMAC_TBFR1518_NFRX_Pos 0 |
#define | GMAC_TBFR1518_NFRX_Msk (0xffffffffu << GMAC_TBFR1518_NFRX_Pos) |
| | (GMAC_TBFR1518) 1024 to 1518 Byte Frames Received without Error
#define | GMAC_TMXBFR_NFRX_Pos 0 |
#define | GMAC_TMXBFR_NFRX_Msk (0xffffffffu << GMAC_TMXBFR_NFRX_Pos) |
| | (GMAC_TMXBFR) 1519 to Maximum Byte Frames Received without Error
#define | GMAC_UFR_UFRX_Pos 0 |
#define | GMAC_UFR_UFRX_Msk (0x3ffu << GMAC_UFR_UFRX_Pos) |
| | (GMAC_UFR) Undersize Frames Received
#define | GMAC_OFR_OFRX_Pos 0 |
#define | GMAC_OFR_OFRX_Msk (0x3ffu << GMAC_OFR_OFRX_Pos) |
| | (GMAC_OFR) Oversized Frames Received
#define | GMAC_JR_JRX_Pos 0 |
#define | GMAC_JR_JRX_Msk (0x3ffu << GMAC_JR_JRX_Pos) |
| | (GMAC_JR) Jabbers Received
#define | GMAC_FCSE_FCKR_Pos 0 |
#define | GMAC_FCSE_FCKR_Msk (0x3ffu << GMAC_FCSE_FCKR_Pos) |
| | (GMAC_FCSE) Frame Check Sequence Errors
#define | GMAC_LFFE_LFER_Pos 0 |
#define | GMAC_LFFE_LFER_Msk (0x3ffu << GMAC_LFFE_LFER_Pos) |
| | (GMAC_LFFE) Length Field Frame Errors
#define | GMAC_RSE_RXSE_Pos 0 |
#define | GMAC_RSE_RXSE_Msk (0x3ffu << GMAC_RSE_RXSE_Pos) |
| | (GMAC_RSE) Receive Symbol Errors
#define | GMAC_AE_AER_Pos 0 |
#define | GMAC_AE_AER_Msk (0x3ffu << GMAC_AE_AER_Pos) |
| | (GMAC_AE) Alignment Errors
#define | GMAC_RRE_RXRER_Pos 0 |
#define | GMAC_RRE_RXRER_Msk (0x3ffffu << GMAC_RRE_RXRER_Pos) |
| | (GMAC_RRE) Receive Resource Errors
#define | GMAC_ROE_RXOVR_Pos 0 |
#define | GMAC_ROE_RXOVR_Msk (0x3ffu << GMAC_ROE_RXOVR_Pos) |
| | (GMAC_ROE) Receive Overruns
#define | GMAC_IHCE_HCKER_Pos 0 |
#define | GMAC_IHCE_HCKER_Msk (0xffu << GMAC_IHCE_HCKER_Pos) |
| | (GMAC_IHCE) IP Header Checksum Errors
#define | GMAC_TCE_TCKER_Pos 0 |
#define | GMAC_TCE_TCKER_Msk (0xffu << GMAC_TCE_TCKER_Pos) |
| | (GMAC_TCE) TCP Checksum Errors
#define | GMAC_UCE_UCKER_Pos 0 |
#define | GMAC_UCE_UCKER_Msk (0xffu << GMAC_UCE_UCKER_Pos) |
| | (GMAC_UCE) UDP Checksum Errors
#define | GMAC_TISUBN_LSBTIR_Pos 0 |
#define | GMAC_TISUBN_LSBTIR_Msk (0xffffu << GMAC_TISUBN_LSBTIR_Pos) |
| | (GMAC_TISUBN) Lower Significant Bits of Timer Increment Register
#define | GMAC_TISUBN_LSBTIR(value) ((GMAC_TISUBN_LSBTIR_Msk & ((value) << GMAC_TISUBN_LSBTIR_Pos))) |
#define | GMAC_TSH_TCS_Pos 0 |
#define | GMAC_TSH_TCS_Msk (0xffffu << GMAC_TSH_TCS_Pos) |
| | (GMAC_TSH) Timer Count in Seconds
#define | GMAC_TSH_TCS(value) ((GMAC_TSH_TCS_Msk & ((value) << GMAC_TSH_TCS_Pos))) |
#define | GMAC_TSL_TCS_Pos 0 |
#define | GMAC_TSL_TCS_Msk (0xffffffffu << GMAC_TSL_TCS_Pos) |
| | (GMAC_TSL) Timer Count in Seconds
#define | GMAC_TSL_TCS(value) ((GMAC_TSL_TCS_Msk & ((value) << GMAC_TSL_TCS_Pos))) |
#define | GMAC_TN_TNS_Pos 0 |
#define | GMAC_TN_TNS_Msk (0x3fffffffu << GMAC_TN_TNS_Pos) |
| | (GMAC_TN) Timer Count in Nanoseconds
#define | GMAC_TN_TNS(value) ((GMAC_TN_TNS_Msk & ((value) << GMAC_TN_TNS_Pos))) |
#define | GMAC_TA_ITDT_Pos 0 |
#define | GMAC_TA_ITDT_Msk (0x3fffffffu << GMAC_TA_ITDT_Pos) |
| | (GMAC_TA) Increment/Decrement
#define | GMAC_TA_ITDT(value) ((GMAC_TA_ITDT_Msk & ((value) << GMAC_TA_ITDT_Pos))) |
#define | GMAC_TA_ADJ (0x1u << 31) |
| | (GMAC_TA) Adjust 1588 Timer
#define | GMAC_TI_CNS_Pos 0 |
#define | GMAC_TI_CNS_Msk (0xffu << GMAC_TI_CNS_Pos) |
| | (GMAC_TI) Count Nanoseconds
#define | GMAC_TI_CNS(value) ((GMAC_TI_CNS_Msk & ((value) << GMAC_TI_CNS_Pos))) |
#define | GMAC_TI_ACNS_Pos 8 |
#define | GMAC_TI_ACNS_Msk (0xffu << GMAC_TI_ACNS_Pos) |
| | (GMAC_TI) Alternative Count Nanoseconds
#define | GMAC_TI_ACNS(value) ((GMAC_TI_ACNS_Msk & ((value) << GMAC_TI_ACNS_Pos))) |
#define | GMAC_TI_NIT_Pos 16 |
#define | GMAC_TI_NIT_Msk (0xffu << GMAC_TI_NIT_Pos) |
| | (GMAC_TI) Number of Increments
#define | GMAC_TI_NIT(value) ((GMAC_TI_NIT_Msk & ((value) << GMAC_TI_NIT_Pos))) |
#define | GMAC_EFTSL_RUD_Pos 0 |
#define | GMAC_EFTSL_RUD_Msk (0xffffffffu << GMAC_EFTSL_RUD_Pos) |
| | (GMAC_EFTSL) Register Update
#define | GMAC_EFTN_RUD_Pos 0 |
#define | GMAC_EFTN_RUD_Msk (0x3fffffffu << GMAC_EFTN_RUD_Pos) |
| | (GMAC_EFTN) Register Update
#define | GMAC_EFRSL_RUD_Pos 0 |
#define | GMAC_EFRSL_RUD_Msk (0xffffffffu << GMAC_EFRSL_RUD_Pos) |
| | (GMAC_EFRSL) Register Update
#define | GMAC_EFRN_RUD_Pos 0 |
#define | GMAC_EFRN_RUD_Msk (0x3fffffffu << GMAC_EFRN_RUD_Pos) |
| | (GMAC_EFRN) Register Update
#define | GMAC_PEFTSL_RUD_Pos 0 |
#define | GMAC_PEFTSL_RUD_Msk (0xffffffffu << GMAC_PEFTSL_RUD_Pos) |
| | (GMAC_PEFTSL) Register Update
#define | GMAC_PEFTN_RUD_Pos 0 |
#define | GMAC_PEFTN_RUD_Msk (0x3fffffffu << GMAC_PEFTN_RUD_Pos) |
| | (GMAC_PEFTN) Register Update
#define | GMAC_PEFRSL_RUD_Pos 0 |
#define | GMAC_PEFRSL_RUD_Msk (0xffffffffu << GMAC_PEFRSL_RUD_Pos) |
| | (GMAC_PEFRSL) Register Update
#define | GMAC_PEFRN_RUD_Pos 0 |
#define | GMAC_PEFRN_RUD_Msk (0x3fffffffu << GMAC_PEFRN_RUD_Pos) |
| | (GMAC_PEFRN) Register Update
#define | GMAC_ISRPQ_RCOMP (0x1u << 1) |
| | (GMAC_ISRPQ[2]) Receive Complete
#define | GMAC_ISRPQ_RXUBR (0x1u << 2) |
| | (GMAC_ISRPQ[2]) RX Used Bit Read
#define | GMAC_ISRPQ_RLEX (0x1u << 5) |
| | (GMAC_ISRPQ[2]) Retry Limit Exceeded or Late Collision
#define | GMAC_ISRPQ_TFC (0x1u << 6) |
| | (GMAC_ISRPQ[2]) Transmit Frame Corruption Due to AHB Error
#define | GMAC_ISRPQ_TCOMP (0x1u << 7) |
| | (GMAC_ISRPQ[2]) Transmit Complete
#define | GMAC_ISRPQ_ROVR (0x1u << 10) |
| | (GMAC_ISRPQ[2]) Receive Overrun
#define | GMAC_ISRPQ_HRESP (0x1u << 11) |
| | (GMAC_ISRPQ[2]) HRESP Not OK
#define | GMAC_TBQBAPQ_TXBQBA_Pos 2 |
#define | GMAC_TBQBAPQ_TXBQBA_Msk (0x3fffffffu << GMAC_TBQBAPQ_TXBQBA_Pos) |
| | (GMAC_TBQBAPQ[2]) Transmit Buffer Queue Base Address
#define | GMAC_TBQBAPQ_TXBQBA(value) ((GMAC_TBQBAPQ_TXBQBA_Msk & ((value) << GMAC_TBQBAPQ_TXBQBA_Pos))) |
#define | GMAC_RBQBAPQ_RXBQBA_Pos 2 |
#define | GMAC_RBQBAPQ_RXBQBA_Msk (0x3fffffffu << GMAC_RBQBAPQ_RXBQBA_Pos) |
| | (GMAC_RBQBAPQ[2]) Receive Buffer Queue Base Address
#define | GMAC_RBQBAPQ_RXBQBA(value) ((GMAC_RBQBAPQ_RXBQBA_Msk & ((value) << GMAC_RBQBAPQ_RXBQBA_Pos))) |
#define | GMAC_RBSRPQ_RBS_Pos 0 |
#define | GMAC_RBSRPQ_RBS_Msk (0xffffu << GMAC_RBSRPQ_RBS_Pos) |
| | (GMAC_RBSRPQ[2]) Receive Buffer Size
#define | GMAC_RBSRPQ_RBS(value) ((GMAC_RBSRPQ_RBS_Msk & ((value) << GMAC_RBSRPQ_RBS_Pos))) |
#define | GMAC_CBSCR_QBE (0x1u << 0) |
| | (GMAC_CBSCR) Queue B CBS Enable
#define | GMAC_CBSCR_QAE (0x1u << 1) |
| | (GMAC_CBSCR) Queue A CBS Enable
#define | GMAC_CBSISQA_IS_Pos 0 |
#define | GMAC_CBSISQA_IS_Msk (0xffffffffu << GMAC_CBSISQA_IS_Pos) |
| | (GMAC_CBSISQA) IdleSlope
#define | GMAC_CBSISQA_IS(value) ((GMAC_CBSISQA_IS_Msk & ((value) << GMAC_CBSISQA_IS_Pos))) |
#define | GMAC_CBSISQB_IS_Pos 0 |
#define | GMAC_CBSISQB_IS_Msk (0xffffffffu << GMAC_CBSISQB_IS_Pos) |
| | (GMAC_CBSISQB) IdleSlope
#define | GMAC_CBSISQB_IS(value) ((GMAC_CBSISQB_IS_Msk & ((value) << GMAC_CBSISQB_IS_Pos))) |
#define | GMAC_ST1RPQ_QNB_Pos 0 |
#define | GMAC_ST1RPQ_QNB_Msk (0x7u << GMAC_ST1RPQ_QNB_Pos) |
| | (GMAC_ST1RPQ[4]) Queue Number (0-2)
#define | GMAC_ST1RPQ_QNB(value) ((GMAC_ST1RPQ_QNB_Msk & ((value) << GMAC_ST1RPQ_QNB_Pos))) |
#define | GMAC_ST1RPQ_DSTCM_Pos 4 |
#define | GMAC_ST1RPQ_DSTCM_Msk (0xffu << GMAC_ST1RPQ_DSTCM_Pos) |
| | (GMAC_ST1RPQ[4]) Differentiated Services or Traffic Class Match
#define | GMAC_ST1RPQ_DSTCM(value) ((GMAC_ST1RPQ_DSTCM_Msk & ((value) << GMAC_ST1RPQ_DSTCM_Pos))) |
#define | GMAC_ST1RPQ_UDPM_Pos 12 |
#define | GMAC_ST1RPQ_UDPM_Msk (0xffffu << GMAC_ST1RPQ_UDPM_Pos) |
| | (GMAC_ST1RPQ[4]) UDP Port Match
#define | GMAC_ST1RPQ_UDPM(value) ((GMAC_ST1RPQ_UDPM_Msk & ((value) << GMAC_ST1RPQ_UDPM_Pos))) |
#define | GMAC_ST1RPQ_DSTCE (0x1u << 28) |
| | (GMAC_ST1RPQ[4]) Differentiated Services or Traffic Class Match Enable
#define | GMAC_ST1RPQ_UDPE (0x1u << 29) |
| | (GMAC_ST1RPQ[4]) UDP Port Match Enable
#define | GMAC_ST2RPQ_QNB_Pos 0 |
#define | GMAC_ST2RPQ_QNB_Msk (0x7u << GMAC_ST2RPQ_QNB_Pos) |
| | (GMAC_ST2RPQ[8]) Queue Number (0-2)
#define | GMAC_ST2RPQ_QNB(value) ((GMAC_ST2RPQ_QNB_Msk & ((value) << GMAC_ST2RPQ_QNB_Pos))) |
#define | GMAC_ST2RPQ_VLANP_Pos 4 |
#define | GMAC_ST2RPQ_VLANP_Msk (0x7u << GMAC_ST2RPQ_VLANP_Pos) |
| | (GMAC_ST2RPQ[8]) VLAN Priority
#define | GMAC_ST2RPQ_VLANP(value) ((GMAC_ST2RPQ_VLANP_Msk & ((value) << GMAC_ST2RPQ_VLANP_Pos))) |
#define | GMAC_ST2RPQ_VLANE (0x1u << 8) |
| | (GMAC_ST2RPQ[8]) VLAN Enable
#define | GMAC_ST2RPQ_I2ETH_Pos 9 |
#define | GMAC_ST2RPQ_I2ETH_Msk (0x7u << GMAC_ST2RPQ_I2ETH_Pos) |
| | (GMAC_ST2RPQ[8]) Index of Screening Type 2 EtherType register x
#define | GMAC_ST2RPQ_I2ETH(value) ((GMAC_ST2RPQ_I2ETH_Msk & ((value) << GMAC_ST2RPQ_I2ETH_Pos))) |
#define | GMAC_ST2RPQ_ETHE (0x1u << 12) |
| | (GMAC_ST2RPQ[8]) EtherType Enable
#define | GMAC_ST2RPQ_COMPA_Pos 13 |
#define | GMAC_ST2RPQ_COMPA_Msk (0x1fu << GMAC_ST2RPQ_COMPA_Pos) |
| | (GMAC_ST2RPQ[8]) Index of Screening Type 2 Compare Word 0/Word 1 register x
#define | GMAC_ST2RPQ_COMPA(value) ((GMAC_ST2RPQ_COMPA_Msk & ((value) << GMAC_ST2RPQ_COMPA_Pos))) |
#define | GMAC_ST2RPQ_COMPAE (0x1u << 18) |
| | (GMAC_ST2RPQ[8]) Compare A Enable
#define | GMAC_ST2RPQ_COMPB_Pos 19 |
#define | GMAC_ST2RPQ_COMPB_Msk (0x1fu << GMAC_ST2RPQ_COMPB_Pos) |
#define | GMAC_ST2RPQ_COMPB(value) ((GMAC_ST2RPQ_COMPB_Msk & ((value) << GMAC_ST2RPQ_COMPB_Pos))) |
#define | GMAC_ST2RPQ_COMPBE (0x1u << 24) |
| | (GMAC_ST2RPQ[8]) Compare B Enable
#define | GMAC_ST2RPQ_COMPC_Pos 25 |
#define | GMAC_ST2RPQ_COMPC_Msk (0x1fu << GMAC_ST2RPQ_COMPC_Pos) |
#define | GMAC_ST2RPQ_COMPC(value) ((GMAC_ST2RPQ_COMPC_Msk & ((value) << GMAC_ST2RPQ_COMPC_Pos))) |
#define | GMAC_ST2RPQ_COMPCE (0x1u << 30) |
| | (GMAC_ST2RPQ[8]) Compare C Enable
#define | GMAC_IERPQ_RCOMP (0x1u << 1) |
| | (GMAC_IERPQ[2]) Receive Complete
#define | GMAC_IERPQ_RXUBR (0x1u << 2) |
| | (GMAC_IERPQ[2]) RX Used Bit Read
#define | GMAC_IERPQ_RLEX (0x1u << 5) |
| | (GMAC_IERPQ[2]) Retry Limit Exceeded or Late Collision
#define | GMAC_IERPQ_TFC (0x1u << 6) |
| | (GMAC_IERPQ[2]) Transmit Frame Corruption Due to AHB Error
#define | GMAC_IERPQ_TCOMP (0x1u << 7) |
| | (GMAC_IERPQ[2]) Transmit Complete
#define | GMAC_IERPQ_ROVR (0x1u << 10) |
| | (GMAC_IERPQ[2]) Receive Overrun
#define | GMAC_IERPQ_HRESP (0x1u << 11) |
| | (GMAC_IERPQ[2]) HRESP Not OK
#define | GMAC_IDRPQ_RCOMP (0x1u << 1) |
| | (GMAC_IDRPQ[2]) Receive Complete
#define | GMAC_IDRPQ_RXUBR (0x1u << 2) |
| | (GMAC_IDRPQ[2]) RX Used Bit Read
#define | GMAC_IDRPQ_RLEX (0x1u << 5) |
| | (GMAC_IDRPQ[2]) Retry Limit Exceeded or Late Collision
#define | GMAC_IDRPQ_TFC (0x1u << 6) |
| | (GMAC_IDRPQ[2]) Transmit Frame Corruption Due to AHB Error
#define | GMAC_IDRPQ_TCOMP (0x1u << 7) |
| | (GMAC_IDRPQ[2]) Transmit Complete
#define | GMAC_IDRPQ_ROVR (0x1u << 10) |
| | (GMAC_IDRPQ[2]) Receive Overrun
#define | GMAC_IDRPQ_HRESP (0x1u << 11) |
| | (GMAC_IDRPQ[2]) HRESP Not OK
#define | GMAC_IMRPQ_RCOMP (0x1u << 1) |
| | (GMAC_IMRPQ[2]) Receive Complete
#define | GMAC_IMRPQ_RXUBR (0x1u << 2) |
| | (GMAC_IMRPQ[2]) RX Used Bit Read
#define | GMAC_IMRPQ_RLEX (0x1u << 5) |
| | (GMAC_IMRPQ[2]) Retry Limit Exceeded or Late Collision
#define | GMAC_IMRPQ_AHB (0x1u << 6) |
| | (GMAC_IMRPQ[2]) AHB Error
#define | GMAC_IMRPQ_TCOMP (0x1u << 7) |
| | (GMAC_IMRPQ[2]) Transmit Complete
#define | GMAC_IMRPQ_ROVR (0x1u << 10) |
| | (GMAC_IMRPQ[2]) Receive Overrun
#define | GMAC_IMRPQ_HRESP (0x1u << 11) |
| | (GMAC_IMRPQ[2]) HRESP Not OK
#define | GMAC_ST2ER_COMPVAL_Pos 0 |
#define | GMAC_ST2ER_COMPVAL_Msk (0xffffu << GMAC_ST2ER_COMPVAL_Pos) |
| | (GMAC_ST2ER[4]) Ethertype Compare Value
#define | GMAC_ST2ER_COMPVAL(value) ((GMAC_ST2ER_COMPVAL_Msk & ((value) << GMAC_ST2ER_COMPVAL_Pos))) |
#define | GMAC_ST2CW00_MASKVAL_Pos 0 |
#define | GMAC_ST2CW00_MASKVAL_Msk (0xffffu << GMAC_ST2CW00_MASKVAL_Pos) |
| | (GMAC_ST2CW00) Mask Value
#define | GMAC_ST2CW00_MASKVAL(value) ((GMAC_ST2CW00_MASKVAL_Msk & ((value) << GMAC_ST2CW00_MASKVAL_Pos))) |
#define | GMAC_ST2CW00_COMPVAL_Pos 16 |
#define | GMAC_ST2CW00_COMPVAL_Msk (0xffffu << GMAC_ST2CW00_COMPVAL_Pos) |
| | (GMAC_ST2CW00) Compare Value
#define | GMAC_ST2CW00_COMPVAL(value) ((GMAC_ST2CW00_COMPVAL_Msk & ((value) << GMAC_ST2CW00_COMPVAL_Pos))) |
#define | GMAC_ST2CW10_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW10_OFFSVAL_Msk (0x7fu << GMAC_ST2CW10_OFFSVAL_Pos) |
| | (GMAC_ST2CW10) Offset Value in Bytes
#define | GMAC_ST2CW10_OFFSVAL(value) ((GMAC_ST2CW10_OFFSVAL_Msk & ((value) << GMAC_ST2CW10_OFFSVAL_Pos))) |
#define | GMAC_ST2CW10_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW10_OFFSSTRT_Msk (0x3u << GMAC_ST2CW10_OFFSSTRT_Pos) |
| | (GMAC_ST2CW10) Ethernet Frame Offset Start
#define | GMAC_ST2CW10_OFFSSTRT(value) ((GMAC_ST2CW10_OFFSSTRT_Msk & ((value) << GMAC_ST2CW10_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW10_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW10) Offset from the start of the frame
#define | GMAC_ST2CW10_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW10) Offset from the byte after the EtherType field
#define | GMAC_ST2CW10_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW10) Offset from the byte after the IP header field
#define | GMAC_ST2CW10_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW10) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW01_MASKVAL_Pos 0 |
#define | GMAC_ST2CW01_MASKVAL_Msk (0xffffu << GMAC_ST2CW01_MASKVAL_Pos) |
| | (GMAC_ST2CW01) Mask Value
#define | GMAC_ST2CW01_MASKVAL(value) ((GMAC_ST2CW01_MASKVAL_Msk & ((value) << GMAC_ST2CW01_MASKVAL_Pos))) |
#define | GMAC_ST2CW01_COMPVAL_Pos 16 |
#define | GMAC_ST2CW01_COMPVAL_Msk (0xffffu << GMAC_ST2CW01_COMPVAL_Pos) |
| | (GMAC_ST2CW01) Compare Value
#define | GMAC_ST2CW01_COMPVAL(value) ((GMAC_ST2CW01_COMPVAL_Msk & ((value) << GMAC_ST2CW01_COMPVAL_Pos))) |
#define | GMAC_ST2CW11_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW11_OFFSVAL_Msk (0x7fu << GMAC_ST2CW11_OFFSVAL_Pos) |
| | (GMAC_ST2CW11) Offset Value in Bytes
#define | GMAC_ST2CW11_OFFSVAL(value) ((GMAC_ST2CW11_OFFSVAL_Msk & ((value) << GMAC_ST2CW11_OFFSVAL_Pos))) |
#define | GMAC_ST2CW11_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW11_OFFSSTRT_Msk (0x3u << GMAC_ST2CW11_OFFSSTRT_Pos) |
| | (GMAC_ST2CW11) Ethernet Frame Offset Start
#define | GMAC_ST2CW11_OFFSSTRT(value) ((GMAC_ST2CW11_OFFSSTRT_Msk & ((value) << GMAC_ST2CW11_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW11_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW11) Offset from the start of the frame
#define | GMAC_ST2CW11_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW11) Offset from the byte after the EtherType field
#define | GMAC_ST2CW11_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW11) Offset from the byte after the IP header field
#define | GMAC_ST2CW11_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW11) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW02_MASKVAL_Pos 0 |
#define | GMAC_ST2CW02_MASKVAL_Msk (0xffffu << GMAC_ST2CW02_MASKVAL_Pos) |
| | (GMAC_ST2CW02) Mask Value
#define | GMAC_ST2CW02_MASKVAL(value) ((GMAC_ST2CW02_MASKVAL_Msk & ((value) << GMAC_ST2CW02_MASKVAL_Pos))) |
#define | GMAC_ST2CW02_COMPVAL_Pos 16 |
#define | GMAC_ST2CW02_COMPVAL_Msk (0xffffu << GMAC_ST2CW02_COMPVAL_Pos) |
| | (GMAC_ST2CW02) Compare Value
#define | GMAC_ST2CW02_COMPVAL(value) ((GMAC_ST2CW02_COMPVAL_Msk & ((value) << GMAC_ST2CW02_COMPVAL_Pos))) |
#define | GMAC_ST2CW12_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW12_OFFSVAL_Msk (0x7fu << GMAC_ST2CW12_OFFSVAL_Pos) |
| | (GMAC_ST2CW12) Offset Value in Bytes
#define | GMAC_ST2CW12_OFFSVAL(value) ((GMAC_ST2CW12_OFFSVAL_Msk & ((value) << GMAC_ST2CW12_OFFSVAL_Pos))) |
#define | GMAC_ST2CW12_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW12_OFFSSTRT_Msk (0x3u << GMAC_ST2CW12_OFFSSTRT_Pos) |
| | (GMAC_ST2CW12) Ethernet Frame Offset Start
#define | GMAC_ST2CW12_OFFSSTRT(value) ((GMAC_ST2CW12_OFFSSTRT_Msk & ((value) << GMAC_ST2CW12_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW12_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW12) Offset from the start of the frame
#define | GMAC_ST2CW12_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW12) Offset from the byte after the EtherType field
#define | GMAC_ST2CW12_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW12) Offset from the byte after the IP header field
#define | GMAC_ST2CW12_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW12) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW03_MASKVAL_Pos 0 |
#define | GMAC_ST2CW03_MASKVAL_Msk (0xffffu << GMAC_ST2CW03_MASKVAL_Pos) |
| | (GMAC_ST2CW03) Mask Value
#define | GMAC_ST2CW03_MASKVAL(value) ((GMAC_ST2CW03_MASKVAL_Msk & ((value) << GMAC_ST2CW03_MASKVAL_Pos))) |
#define | GMAC_ST2CW03_COMPVAL_Pos 16 |
#define | GMAC_ST2CW03_COMPVAL_Msk (0xffffu << GMAC_ST2CW03_COMPVAL_Pos) |
| | (GMAC_ST2CW03) Compare Value
#define | GMAC_ST2CW03_COMPVAL(value) ((GMAC_ST2CW03_COMPVAL_Msk & ((value) << GMAC_ST2CW03_COMPVAL_Pos))) |
#define | GMAC_ST2CW13_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW13_OFFSVAL_Msk (0x7fu << GMAC_ST2CW13_OFFSVAL_Pos) |
| | (GMAC_ST2CW13) Offset Value in Bytes
#define | GMAC_ST2CW13_OFFSVAL(value) ((GMAC_ST2CW13_OFFSVAL_Msk & ((value) << GMAC_ST2CW13_OFFSVAL_Pos))) |
#define | GMAC_ST2CW13_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW13_OFFSSTRT_Msk (0x3u << GMAC_ST2CW13_OFFSSTRT_Pos) |
| | (GMAC_ST2CW13) Ethernet Frame Offset Start
#define | GMAC_ST2CW13_OFFSSTRT(value) ((GMAC_ST2CW13_OFFSSTRT_Msk & ((value) << GMAC_ST2CW13_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW13_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW13) Offset from the start of the frame
#define | GMAC_ST2CW13_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW13) Offset from the byte after the EtherType field
#define | GMAC_ST2CW13_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW13) Offset from the byte after the IP header field
#define | GMAC_ST2CW13_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW13) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW04_MASKVAL_Pos 0 |
#define | GMAC_ST2CW04_MASKVAL_Msk (0xffffu << GMAC_ST2CW04_MASKVAL_Pos) |
| | (GMAC_ST2CW04) Mask Value
#define | GMAC_ST2CW04_MASKVAL(value) ((GMAC_ST2CW04_MASKVAL_Msk & ((value) << GMAC_ST2CW04_MASKVAL_Pos))) |
#define | GMAC_ST2CW04_COMPVAL_Pos 16 |
#define | GMAC_ST2CW04_COMPVAL_Msk (0xffffu << GMAC_ST2CW04_COMPVAL_Pos) |
| | (GMAC_ST2CW04) Compare Value
#define | GMAC_ST2CW04_COMPVAL(value) ((GMAC_ST2CW04_COMPVAL_Msk & ((value) << GMAC_ST2CW04_COMPVAL_Pos))) |
#define | GMAC_ST2CW14_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW14_OFFSVAL_Msk (0x7fu << GMAC_ST2CW14_OFFSVAL_Pos) |
| | (GMAC_ST2CW14) Offset Value in Bytes
#define | GMAC_ST2CW14_OFFSVAL(value) ((GMAC_ST2CW14_OFFSVAL_Msk & ((value) << GMAC_ST2CW14_OFFSVAL_Pos))) |
#define | GMAC_ST2CW14_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW14_OFFSSTRT_Msk (0x3u << GMAC_ST2CW14_OFFSSTRT_Pos) |
| | (GMAC_ST2CW14) Ethernet Frame Offset Start
#define | GMAC_ST2CW14_OFFSSTRT(value) ((GMAC_ST2CW14_OFFSSTRT_Msk & ((value) << GMAC_ST2CW14_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW14_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW14) Offset from the start of the frame
#define | GMAC_ST2CW14_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW14) Offset from the byte after the EtherType field
#define | GMAC_ST2CW14_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW14) Offset from the byte after the IP header field
#define | GMAC_ST2CW14_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW14) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW05_MASKVAL_Pos 0 |
#define | GMAC_ST2CW05_MASKVAL_Msk (0xffffu << GMAC_ST2CW05_MASKVAL_Pos) |
| | (GMAC_ST2CW05) Mask Value
#define | GMAC_ST2CW05_MASKVAL(value) ((GMAC_ST2CW05_MASKVAL_Msk & ((value) << GMAC_ST2CW05_MASKVAL_Pos))) |
#define | GMAC_ST2CW05_COMPVAL_Pos 16 |
#define | GMAC_ST2CW05_COMPVAL_Msk (0xffffu << GMAC_ST2CW05_COMPVAL_Pos) |
| | (GMAC_ST2CW05) Compare Value
#define | GMAC_ST2CW05_COMPVAL(value) ((GMAC_ST2CW05_COMPVAL_Msk & ((value) << GMAC_ST2CW05_COMPVAL_Pos))) |
#define | GMAC_ST2CW15_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW15_OFFSVAL_Msk (0x7fu << GMAC_ST2CW15_OFFSVAL_Pos) |
| | (GMAC_ST2CW15) Offset Value in Bytes
#define | GMAC_ST2CW15_OFFSVAL(value) ((GMAC_ST2CW15_OFFSVAL_Msk & ((value) << GMAC_ST2CW15_OFFSVAL_Pos))) |
#define | GMAC_ST2CW15_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW15_OFFSSTRT_Msk (0x3u << GMAC_ST2CW15_OFFSSTRT_Pos) |
| | (GMAC_ST2CW15) Ethernet Frame Offset Start
#define | GMAC_ST2CW15_OFFSSTRT(value) ((GMAC_ST2CW15_OFFSSTRT_Msk & ((value) << GMAC_ST2CW15_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW15_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW15) Offset from the start of the frame
#define | GMAC_ST2CW15_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW15) Offset from the byte after the EtherType field
#define | GMAC_ST2CW15_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW15) Offset from the byte after the IP header field
#define | GMAC_ST2CW15_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW15) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW06_MASKVAL_Pos 0 |
#define | GMAC_ST2CW06_MASKVAL_Msk (0xffffu << GMAC_ST2CW06_MASKVAL_Pos) |
| | (GMAC_ST2CW06) Mask Value
#define | GMAC_ST2CW06_MASKVAL(value) ((GMAC_ST2CW06_MASKVAL_Msk & ((value) << GMAC_ST2CW06_MASKVAL_Pos))) |
#define | GMAC_ST2CW06_COMPVAL_Pos 16 |
#define | GMAC_ST2CW06_COMPVAL_Msk (0xffffu << GMAC_ST2CW06_COMPVAL_Pos) |
| | (GMAC_ST2CW06) Compare Value
#define | GMAC_ST2CW06_COMPVAL(value) ((GMAC_ST2CW06_COMPVAL_Msk & ((value) << GMAC_ST2CW06_COMPVAL_Pos))) |
#define | GMAC_ST2CW16_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW16_OFFSVAL_Msk (0x7fu << GMAC_ST2CW16_OFFSVAL_Pos) |
| | (GMAC_ST2CW16) Offset Value in Bytes
#define | GMAC_ST2CW16_OFFSVAL(value) ((GMAC_ST2CW16_OFFSVAL_Msk & ((value) << GMAC_ST2CW16_OFFSVAL_Pos))) |
#define | GMAC_ST2CW16_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW16_OFFSSTRT_Msk (0x3u << GMAC_ST2CW16_OFFSSTRT_Pos) |
| | (GMAC_ST2CW16) Ethernet Frame Offset Start
#define | GMAC_ST2CW16_OFFSSTRT(value) ((GMAC_ST2CW16_OFFSSTRT_Msk & ((value) << GMAC_ST2CW16_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW16_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW16) Offset from the start of the frame
#define | GMAC_ST2CW16_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW16) Offset from the byte after the EtherType field
#define | GMAC_ST2CW16_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW16) Offset from the byte after the IP header field
#define | GMAC_ST2CW16_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW16) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW07_MASKVAL_Pos 0 |
#define | GMAC_ST2CW07_MASKVAL_Msk (0xffffu << GMAC_ST2CW07_MASKVAL_Pos) |
| | (GMAC_ST2CW07) Mask Value
#define | GMAC_ST2CW07_MASKVAL(value) ((GMAC_ST2CW07_MASKVAL_Msk & ((value) << GMAC_ST2CW07_MASKVAL_Pos))) |
#define | GMAC_ST2CW07_COMPVAL_Pos 16 |
#define | GMAC_ST2CW07_COMPVAL_Msk (0xffffu << GMAC_ST2CW07_COMPVAL_Pos) |
| | (GMAC_ST2CW07) Compare Value
#define | GMAC_ST2CW07_COMPVAL(value) ((GMAC_ST2CW07_COMPVAL_Msk & ((value) << GMAC_ST2CW07_COMPVAL_Pos))) |
#define | GMAC_ST2CW17_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW17_OFFSVAL_Msk (0x7fu << GMAC_ST2CW17_OFFSVAL_Pos) |
| | (GMAC_ST2CW17) Offset Value in Bytes
#define | GMAC_ST2CW17_OFFSVAL(value) ((GMAC_ST2CW17_OFFSVAL_Msk & ((value) << GMAC_ST2CW17_OFFSVAL_Pos))) |
#define | GMAC_ST2CW17_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW17_OFFSSTRT_Msk (0x3u << GMAC_ST2CW17_OFFSSTRT_Pos) |
| | (GMAC_ST2CW17) Ethernet Frame Offset Start
#define | GMAC_ST2CW17_OFFSSTRT(value) ((GMAC_ST2CW17_OFFSSTRT_Msk & ((value) << GMAC_ST2CW17_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW17_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW17) Offset from the start of the frame
#define | GMAC_ST2CW17_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW17) Offset from the byte after the EtherType field
#define | GMAC_ST2CW17_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW17) Offset from the byte after the IP header field
#define | GMAC_ST2CW17_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW17) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW08_MASKVAL_Pos 0 |
#define | GMAC_ST2CW08_MASKVAL_Msk (0xffffu << GMAC_ST2CW08_MASKVAL_Pos) |
| | (GMAC_ST2CW08) Mask Value
#define | GMAC_ST2CW08_MASKVAL(value) ((GMAC_ST2CW08_MASKVAL_Msk & ((value) << GMAC_ST2CW08_MASKVAL_Pos))) |
#define | GMAC_ST2CW08_COMPVAL_Pos 16 |
#define | GMAC_ST2CW08_COMPVAL_Msk (0xffffu << GMAC_ST2CW08_COMPVAL_Pos) |
| | (GMAC_ST2CW08) Compare Value
#define | GMAC_ST2CW08_COMPVAL(value) ((GMAC_ST2CW08_COMPVAL_Msk & ((value) << GMAC_ST2CW08_COMPVAL_Pos))) |
#define | GMAC_ST2CW18_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW18_OFFSVAL_Msk (0x7fu << GMAC_ST2CW18_OFFSVAL_Pos) |
| | (GMAC_ST2CW18) Offset Value in Bytes
#define | GMAC_ST2CW18_OFFSVAL(value) ((GMAC_ST2CW18_OFFSVAL_Msk & ((value) << GMAC_ST2CW18_OFFSVAL_Pos))) |
#define | GMAC_ST2CW18_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW18_OFFSSTRT_Msk (0x3u << GMAC_ST2CW18_OFFSSTRT_Pos) |
| | (GMAC_ST2CW18) Ethernet Frame Offset Start
#define | GMAC_ST2CW18_OFFSSTRT(value) ((GMAC_ST2CW18_OFFSSTRT_Msk & ((value) << GMAC_ST2CW18_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW18_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW18) Offset from the start of the frame
#define | GMAC_ST2CW18_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW18) Offset from the byte after the EtherType field
#define | GMAC_ST2CW18_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW18) Offset from the byte after the IP header field
#define | GMAC_ST2CW18_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW18) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW09_MASKVAL_Pos 0 |
#define | GMAC_ST2CW09_MASKVAL_Msk (0xffffu << GMAC_ST2CW09_MASKVAL_Pos) |
| | (GMAC_ST2CW09) Mask Value
#define | GMAC_ST2CW09_MASKVAL(value) ((GMAC_ST2CW09_MASKVAL_Msk & ((value) << GMAC_ST2CW09_MASKVAL_Pos))) |
#define | GMAC_ST2CW09_COMPVAL_Pos 16 |
#define | GMAC_ST2CW09_COMPVAL_Msk (0xffffu << GMAC_ST2CW09_COMPVAL_Pos) |
| | (GMAC_ST2CW09) Compare Value
#define | GMAC_ST2CW09_COMPVAL(value) ((GMAC_ST2CW09_COMPVAL_Msk & ((value) << GMAC_ST2CW09_COMPVAL_Pos))) |
#define | GMAC_ST2CW19_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW19_OFFSVAL_Msk (0x7fu << GMAC_ST2CW19_OFFSVAL_Pos) |
| | (GMAC_ST2CW19) Offset Value in Bytes
#define | GMAC_ST2CW19_OFFSVAL(value) ((GMAC_ST2CW19_OFFSVAL_Msk & ((value) << GMAC_ST2CW19_OFFSVAL_Pos))) |
#define | GMAC_ST2CW19_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW19_OFFSSTRT_Msk (0x3u << GMAC_ST2CW19_OFFSSTRT_Pos) |
| | (GMAC_ST2CW19) Ethernet Frame Offset Start
#define | GMAC_ST2CW19_OFFSSTRT(value) ((GMAC_ST2CW19_OFFSSTRT_Msk & ((value) << GMAC_ST2CW19_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW19_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW19) Offset from the start of the frame
#define | GMAC_ST2CW19_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW19) Offset from the byte after the EtherType field
#define | GMAC_ST2CW19_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW19) Offset from the byte after the IP header field
#define | GMAC_ST2CW19_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW19) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW010_MASKVAL_Pos 0 |
#define | GMAC_ST2CW010_MASKVAL_Msk (0xffffu << GMAC_ST2CW010_MASKVAL_Pos) |
| | (GMAC_ST2CW010) Mask Value
#define | GMAC_ST2CW010_MASKVAL(value) ((GMAC_ST2CW010_MASKVAL_Msk & ((value) << GMAC_ST2CW010_MASKVAL_Pos))) |
#define | GMAC_ST2CW010_COMPVAL_Pos 16 |
#define | GMAC_ST2CW010_COMPVAL_Msk (0xffffu << GMAC_ST2CW010_COMPVAL_Pos) |
| | (GMAC_ST2CW010) Compare Value
#define | GMAC_ST2CW010_COMPVAL(value) ((GMAC_ST2CW010_COMPVAL_Msk & ((value) << GMAC_ST2CW010_COMPVAL_Pos))) |
#define | GMAC_ST2CW110_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW110_OFFSVAL_Msk (0x7fu << GMAC_ST2CW110_OFFSVAL_Pos) |
| | (GMAC_ST2CW110) Offset Value in Bytes
#define | GMAC_ST2CW110_OFFSVAL(value) ((GMAC_ST2CW110_OFFSVAL_Msk & ((value) << GMAC_ST2CW110_OFFSVAL_Pos))) |
#define | GMAC_ST2CW110_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW110_OFFSSTRT_Msk (0x3u << GMAC_ST2CW110_OFFSSTRT_Pos) |
| | (GMAC_ST2CW110) Ethernet Frame Offset Start
#define | GMAC_ST2CW110_OFFSSTRT(value) ((GMAC_ST2CW110_OFFSSTRT_Msk & ((value) << GMAC_ST2CW110_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW110_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW110) Offset from the start of the frame
#define | GMAC_ST2CW110_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW110) Offset from the byte after the EtherType field
#define | GMAC_ST2CW110_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW110) Offset from the byte after the IP header field
#define | GMAC_ST2CW110_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW110) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW011_MASKVAL_Pos 0 |
#define | GMAC_ST2CW011_MASKVAL_Msk (0xffffu << GMAC_ST2CW011_MASKVAL_Pos) |
| | (GMAC_ST2CW011) Mask Value
#define | GMAC_ST2CW011_MASKVAL(value) ((GMAC_ST2CW011_MASKVAL_Msk & ((value) << GMAC_ST2CW011_MASKVAL_Pos))) |
#define | GMAC_ST2CW011_COMPVAL_Pos 16 |
#define | GMAC_ST2CW011_COMPVAL_Msk (0xffffu << GMAC_ST2CW011_COMPVAL_Pos) |
| | (GMAC_ST2CW011) Compare Value
#define | GMAC_ST2CW011_COMPVAL(value) ((GMAC_ST2CW011_COMPVAL_Msk & ((value) << GMAC_ST2CW011_COMPVAL_Pos))) |
#define | GMAC_ST2CW111_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW111_OFFSVAL_Msk (0x7fu << GMAC_ST2CW111_OFFSVAL_Pos) |
| | (GMAC_ST2CW111) Offset Value in Bytes
#define | GMAC_ST2CW111_OFFSVAL(value) ((GMAC_ST2CW111_OFFSVAL_Msk & ((value) << GMAC_ST2CW111_OFFSVAL_Pos))) |
#define | GMAC_ST2CW111_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW111_OFFSSTRT_Msk (0x3u << GMAC_ST2CW111_OFFSSTRT_Pos) |
| | (GMAC_ST2CW111) Ethernet Frame Offset Start
#define | GMAC_ST2CW111_OFFSSTRT(value) ((GMAC_ST2CW111_OFFSSTRT_Msk & ((value) << GMAC_ST2CW111_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW111_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW111) Offset from the start of the frame
#define | GMAC_ST2CW111_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW111) Offset from the byte after the EtherType field
#define | GMAC_ST2CW111_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW111) Offset from the byte after the IP header field
#define | GMAC_ST2CW111_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW111) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW012_MASKVAL_Pos 0 |
#define | GMAC_ST2CW012_MASKVAL_Msk (0xffffu << GMAC_ST2CW012_MASKVAL_Pos) |
| | (GMAC_ST2CW012) Mask Value
#define | GMAC_ST2CW012_MASKVAL(value) ((GMAC_ST2CW012_MASKVAL_Msk & ((value) << GMAC_ST2CW012_MASKVAL_Pos))) |
#define | GMAC_ST2CW012_COMPVAL_Pos 16 |
#define | GMAC_ST2CW012_COMPVAL_Msk (0xffffu << GMAC_ST2CW012_COMPVAL_Pos) |
| | (GMAC_ST2CW012) Compare Value
#define | GMAC_ST2CW012_COMPVAL(value) ((GMAC_ST2CW012_COMPVAL_Msk & ((value) << GMAC_ST2CW012_COMPVAL_Pos))) |
#define | GMAC_ST2CW112_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW112_OFFSVAL_Msk (0x7fu << GMAC_ST2CW112_OFFSVAL_Pos) |
| | (GMAC_ST2CW112) Offset Value in Bytes
#define | GMAC_ST2CW112_OFFSVAL(value) ((GMAC_ST2CW112_OFFSVAL_Msk & ((value) << GMAC_ST2CW112_OFFSVAL_Pos))) |
#define | GMAC_ST2CW112_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW112_OFFSSTRT_Msk (0x3u << GMAC_ST2CW112_OFFSSTRT_Pos) |
| | (GMAC_ST2CW112) Ethernet Frame Offset Start
#define | GMAC_ST2CW112_OFFSSTRT(value) ((GMAC_ST2CW112_OFFSSTRT_Msk & ((value) << GMAC_ST2CW112_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW112_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW112) Offset from the start of the frame
#define | GMAC_ST2CW112_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW112) Offset from the byte after the EtherType field
#define | GMAC_ST2CW112_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW112) Offset from the byte after the IP header field
#define | GMAC_ST2CW112_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW112) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW013_MASKVAL_Pos 0 |
#define | GMAC_ST2CW013_MASKVAL_Msk (0xffffu << GMAC_ST2CW013_MASKVAL_Pos) |
| | (GMAC_ST2CW013) Mask Value
#define | GMAC_ST2CW013_MASKVAL(value) ((GMAC_ST2CW013_MASKVAL_Msk & ((value) << GMAC_ST2CW013_MASKVAL_Pos))) |
#define | GMAC_ST2CW013_COMPVAL_Pos 16 |
#define | GMAC_ST2CW013_COMPVAL_Msk (0xffffu << GMAC_ST2CW013_COMPVAL_Pos) |
| | (GMAC_ST2CW013) Compare Value
#define | GMAC_ST2CW013_COMPVAL(value) ((GMAC_ST2CW013_COMPVAL_Msk & ((value) << GMAC_ST2CW013_COMPVAL_Pos))) |
#define | GMAC_ST2CW113_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW113_OFFSVAL_Msk (0x7fu << GMAC_ST2CW113_OFFSVAL_Pos) |
| | (GMAC_ST2CW113) Offset Value in Bytes
#define | GMAC_ST2CW113_OFFSVAL(value) ((GMAC_ST2CW113_OFFSVAL_Msk & ((value) << GMAC_ST2CW113_OFFSVAL_Pos))) |
#define | GMAC_ST2CW113_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW113_OFFSSTRT_Msk (0x3u << GMAC_ST2CW113_OFFSSTRT_Pos) |
| | (GMAC_ST2CW113) Ethernet Frame Offset Start
#define | GMAC_ST2CW113_OFFSSTRT(value) ((GMAC_ST2CW113_OFFSSTRT_Msk & ((value) << GMAC_ST2CW113_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW113_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW113) Offset from the start of the frame
#define | GMAC_ST2CW113_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW113) Offset from the byte after the EtherType field
#define | GMAC_ST2CW113_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW113) Offset from the byte after the IP header field
#define | GMAC_ST2CW113_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW113) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW014_MASKVAL_Pos 0 |
#define | GMAC_ST2CW014_MASKVAL_Msk (0xffffu << GMAC_ST2CW014_MASKVAL_Pos) |
| | (GMAC_ST2CW014) Mask Value
#define | GMAC_ST2CW014_MASKVAL(value) ((GMAC_ST2CW014_MASKVAL_Msk & ((value) << GMAC_ST2CW014_MASKVAL_Pos))) |
#define | GMAC_ST2CW014_COMPVAL_Pos 16 |
#define | GMAC_ST2CW014_COMPVAL_Msk (0xffffu << GMAC_ST2CW014_COMPVAL_Pos) |
| | (GMAC_ST2CW014) Compare Value
#define | GMAC_ST2CW014_COMPVAL(value) ((GMAC_ST2CW014_COMPVAL_Msk & ((value) << GMAC_ST2CW014_COMPVAL_Pos))) |
#define | GMAC_ST2CW114_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW114_OFFSVAL_Msk (0x7fu << GMAC_ST2CW114_OFFSVAL_Pos) |
| | (GMAC_ST2CW114) Offset Value in Bytes
#define | GMAC_ST2CW114_OFFSVAL(value) ((GMAC_ST2CW114_OFFSVAL_Msk & ((value) << GMAC_ST2CW114_OFFSVAL_Pos))) |
#define | GMAC_ST2CW114_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW114_OFFSSTRT_Msk (0x3u << GMAC_ST2CW114_OFFSSTRT_Pos) |
| | (GMAC_ST2CW114) Ethernet Frame Offset Start
#define | GMAC_ST2CW114_OFFSSTRT(value) ((GMAC_ST2CW114_OFFSSTRT_Msk & ((value) << GMAC_ST2CW114_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW114_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW114) Offset from the start of the frame
#define | GMAC_ST2CW114_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW114) Offset from the byte after the EtherType field
#define | GMAC_ST2CW114_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW114) Offset from the byte after the IP header field
#define | GMAC_ST2CW114_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW114) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW015_MASKVAL_Pos 0 |
#define | GMAC_ST2CW015_MASKVAL_Msk (0xffffu << GMAC_ST2CW015_MASKVAL_Pos) |
| | (GMAC_ST2CW015) Mask Value
#define | GMAC_ST2CW015_MASKVAL(value) ((GMAC_ST2CW015_MASKVAL_Msk & ((value) << GMAC_ST2CW015_MASKVAL_Pos))) |
#define | GMAC_ST2CW015_COMPVAL_Pos 16 |
#define | GMAC_ST2CW015_COMPVAL_Msk (0xffffu << GMAC_ST2CW015_COMPVAL_Pos) |
| | (GMAC_ST2CW015) Compare Value
#define | GMAC_ST2CW015_COMPVAL(value) ((GMAC_ST2CW015_COMPVAL_Msk & ((value) << GMAC_ST2CW015_COMPVAL_Pos))) |
#define | GMAC_ST2CW115_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW115_OFFSVAL_Msk (0x7fu << GMAC_ST2CW115_OFFSVAL_Pos) |
| | (GMAC_ST2CW115) Offset Value in Bytes
#define | GMAC_ST2CW115_OFFSVAL(value) ((GMAC_ST2CW115_OFFSVAL_Msk & ((value) << GMAC_ST2CW115_OFFSVAL_Pos))) |
#define | GMAC_ST2CW115_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW115_OFFSSTRT_Msk (0x3u << GMAC_ST2CW115_OFFSSTRT_Pos) |
| | (GMAC_ST2CW115) Ethernet Frame Offset Start
#define | GMAC_ST2CW115_OFFSSTRT(value) ((GMAC_ST2CW115_OFFSSTRT_Msk & ((value) << GMAC_ST2CW115_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW115_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW115) Offset from the start of the frame
#define | GMAC_ST2CW115_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW115) Offset from the byte after the EtherType field
#define | GMAC_ST2CW115_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW115) Offset from the byte after the IP header field
#define | GMAC_ST2CW115_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW115) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW016_MASKVAL_Pos 0 |
#define | GMAC_ST2CW016_MASKVAL_Msk (0xffffu << GMAC_ST2CW016_MASKVAL_Pos) |
| | (GMAC_ST2CW016) Mask Value
#define | GMAC_ST2CW016_MASKVAL(value) ((GMAC_ST2CW016_MASKVAL_Msk & ((value) << GMAC_ST2CW016_MASKVAL_Pos))) |
#define | GMAC_ST2CW016_COMPVAL_Pos 16 |
#define | GMAC_ST2CW016_COMPVAL_Msk (0xffffu << GMAC_ST2CW016_COMPVAL_Pos) |
| | (GMAC_ST2CW016) Compare Value
#define | GMAC_ST2CW016_COMPVAL(value) ((GMAC_ST2CW016_COMPVAL_Msk & ((value) << GMAC_ST2CW016_COMPVAL_Pos))) |
#define | GMAC_ST2CW116_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW116_OFFSVAL_Msk (0x7fu << GMAC_ST2CW116_OFFSVAL_Pos) |
| | (GMAC_ST2CW116) Offset Value in Bytes
#define | GMAC_ST2CW116_OFFSVAL(value) ((GMAC_ST2CW116_OFFSVAL_Msk & ((value) << GMAC_ST2CW116_OFFSVAL_Pos))) |
#define | GMAC_ST2CW116_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW116_OFFSSTRT_Msk (0x3u << GMAC_ST2CW116_OFFSSTRT_Pos) |
| | (GMAC_ST2CW116) Ethernet Frame Offset Start
#define | GMAC_ST2CW116_OFFSSTRT(value) ((GMAC_ST2CW116_OFFSSTRT_Msk & ((value) << GMAC_ST2CW116_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW116_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW116) Offset from the start of the frame
#define | GMAC_ST2CW116_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW116) Offset from the byte after the EtherType field
#define | GMAC_ST2CW116_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW116) Offset from the byte after the IP header field
#define | GMAC_ST2CW116_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW116) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW017_MASKVAL_Pos 0 |
#define | GMAC_ST2CW017_MASKVAL_Msk (0xffffu << GMAC_ST2CW017_MASKVAL_Pos) |
| | (GMAC_ST2CW017) Mask Value
#define | GMAC_ST2CW017_MASKVAL(value) ((GMAC_ST2CW017_MASKVAL_Msk & ((value) << GMAC_ST2CW017_MASKVAL_Pos))) |
#define | GMAC_ST2CW017_COMPVAL_Pos 16 |
#define | GMAC_ST2CW017_COMPVAL_Msk (0xffffu << GMAC_ST2CW017_COMPVAL_Pos) |
| | (GMAC_ST2CW017) Compare Value
#define | GMAC_ST2CW017_COMPVAL(value) ((GMAC_ST2CW017_COMPVAL_Msk & ((value) << GMAC_ST2CW017_COMPVAL_Pos))) |
#define | GMAC_ST2CW117_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW117_OFFSVAL_Msk (0x7fu << GMAC_ST2CW117_OFFSVAL_Pos) |
| | (GMAC_ST2CW117) Offset Value in Bytes
#define | GMAC_ST2CW117_OFFSVAL(value) ((GMAC_ST2CW117_OFFSVAL_Msk & ((value) << GMAC_ST2CW117_OFFSVAL_Pos))) |
#define | GMAC_ST2CW117_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW117_OFFSSTRT_Msk (0x3u << GMAC_ST2CW117_OFFSSTRT_Pos) |
| | (GMAC_ST2CW117) Ethernet Frame Offset Start
#define | GMAC_ST2CW117_OFFSSTRT(value) ((GMAC_ST2CW117_OFFSSTRT_Msk & ((value) << GMAC_ST2CW117_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW117_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW117) Offset from the start of the frame
#define | GMAC_ST2CW117_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW117) Offset from the byte after the EtherType field
#define | GMAC_ST2CW117_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW117) Offset from the byte after the IP header field
#define | GMAC_ST2CW117_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW117) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW018_MASKVAL_Pos 0 |
#define | GMAC_ST2CW018_MASKVAL_Msk (0xffffu << GMAC_ST2CW018_MASKVAL_Pos) |
| | (GMAC_ST2CW018) Mask Value
#define | GMAC_ST2CW018_MASKVAL(value) ((GMAC_ST2CW018_MASKVAL_Msk & ((value) << GMAC_ST2CW018_MASKVAL_Pos))) |
#define | GMAC_ST2CW018_COMPVAL_Pos 16 |
#define | GMAC_ST2CW018_COMPVAL_Msk (0xffffu << GMAC_ST2CW018_COMPVAL_Pos) |
| | (GMAC_ST2CW018) Compare Value
#define | GMAC_ST2CW018_COMPVAL(value) ((GMAC_ST2CW018_COMPVAL_Msk & ((value) << GMAC_ST2CW018_COMPVAL_Pos))) |
#define | GMAC_ST2CW118_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW118_OFFSVAL_Msk (0x7fu << GMAC_ST2CW118_OFFSVAL_Pos) |
| | (GMAC_ST2CW118) Offset Value in Bytes
#define | GMAC_ST2CW118_OFFSVAL(value) ((GMAC_ST2CW118_OFFSVAL_Msk & ((value) << GMAC_ST2CW118_OFFSVAL_Pos))) |
#define | GMAC_ST2CW118_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW118_OFFSSTRT_Msk (0x3u << GMAC_ST2CW118_OFFSSTRT_Pos) |
| | (GMAC_ST2CW118) Ethernet Frame Offset Start
#define | GMAC_ST2CW118_OFFSSTRT(value) ((GMAC_ST2CW118_OFFSSTRT_Msk & ((value) << GMAC_ST2CW118_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW118_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW118) Offset from the start of the frame
#define | GMAC_ST2CW118_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW118) Offset from the byte after the EtherType field
#define | GMAC_ST2CW118_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW118) Offset from the byte after the IP header field
#define | GMAC_ST2CW118_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW118) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW019_MASKVAL_Pos 0 |
#define | GMAC_ST2CW019_MASKVAL_Msk (0xffffu << GMAC_ST2CW019_MASKVAL_Pos) |
| | (GMAC_ST2CW019) Mask Value
#define | GMAC_ST2CW019_MASKVAL(value) ((GMAC_ST2CW019_MASKVAL_Msk & ((value) << GMAC_ST2CW019_MASKVAL_Pos))) |
#define | GMAC_ST2CW019_COMPVAL_Pos 16 |
#define | GMAC_ST2CW019_COMPVAL_Msk (0xffffu << GMAC_ST2CW019_COMPVAL_Pos) |
| | (GMAC_ST2CW019) Compare Value
#define | GMAC_ST2CW019_COMPVAL(value) ((GMAC_ST2CW019_COMPVAL_Msk & ((value) << GMAC_ST2CW019_COMPVAL_Pos))) |
#define | GMAC_ST2CW119_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW119_OFFSVAL_Msk (0x7fu << GMAC_ST2CW119_OFFSVAL_Pos) |
| | (GMAC_ST2CW119) Offset Value in Bytes
#define | GMAC_ST2CW119_OFFSVAL(value) ((GMAC_ST2CW119_OFFSVAL_Msk & ((value) << GMAC_ST2CW119_OFFSVAL_Pos))) |
#define | GMAC_ST2CW119_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW119_OFFSSTRT_Msk (0x3u << GMAC_ST2CW119_OFFSSTRT_Pos) |
| | (GMAC_ST2CW119) Ethernet Frame Offset Start
#define | GMAC_ST2CW119_OFFSSTRT(value) ((GMAC_ST2CW119_OFFSSTRT_Msk & ((value) << GMAC_ST2CW119_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW119_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW119) Offset from the start of the frame
#define | GMAC_ST2CW119_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW119) Offset from the byte after the EtherType field
#define | GMAC_ST2CW119_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW119) Offset from the byte after the IP header field
#define | GMAC_ST2CW119_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW119) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW020_MASKVAL_Pos 0 |
#define | GMAC_ST2CW020_MASKVAL_Msk (0xffffu << GMAC_ST2CW020_MASKVAL_Pos) |
| | (GMAC_ST2CW020) Mask Value
#define | GMAC_ST2CW020_MASKVAL(value) ((GMAC_ST2CW020_MASKVAL_Msk & ((value) << GMAC_ST2CW020_MASKVAL_Pos))) |
#define | GMAC_ST2CW020_COMPVAL_Pos 16 |
#define | GMAC_ST2CW020_COMPVAL_Msk (0xffffu << GMAC_ST2CW020_COMPVAL_Pos) |
| | (GMAC_ST2CW020) Compare Value
#define | GMAC_ST2CW020_COMPVAL(value) ((GMAC_ST2CW020_COMPVAL_Msk & ((value) << GMAC_ST2CW020_COMPVAL_Pos))) |
#define | GMAC_ST2CW120_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW120_OFFSVAL_Msk (0x7fu << GMAC_ST2CW120_OFFSVAL_Pos) |
| | (GMAC_ST2CW120) Offset Value in Bytes
#define | GMAC_ST2CW120_OFFSVAL(value) ((GMAC_ST2CW120_OFFSVAL_Msk & ((value) << GMAC_ST2CW120_OFFSVAL_Pos))) |
#define | GMAC_ST2CW120_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW120_OFFSSTRT_Msk (0x3u << GMAC_ST2CW120_OFFSSTRT_Pos) |
| | (GMAC_ST2CW120) Ethernet Frame Offset Start
#define | GMAC_ST2CW120_OFFSSTRT(value) ((GMAC_ST2CW120_OFFSSTRT_Msk & ((value) << GMAC_ST2CW120_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW120_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW120) Offset from the start of the frame
#define | GMAC_ST2CW120_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW120) Offset from the byte after the EtherType field
#define | GMAC_ST2CW120_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW120) Offset from the byte after the IP header field
#define | GMAC_ST2CW120_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW120) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW021_MASKVAL_Pos 0 |
#define | GMAC_ST2CW021_MASKVAL_Msk (0xffffu << GMAC_ST2CW021_MASKVAL_Pos) |
| | (GMAC_ST2CW021) Mask Value
#define | GMAC_ST2CW021_MASKVAL(value) ((GMAC_ST2CW021_MASKVAL_Msk & ((value) << GMAC_ST2CW021_MASKVAL_Pos))) |
#define | GMAC_ST2CW021_COMPVAL_Pos 16 |
#define | GMAC_ST2CW021_COMPVAL_Msk (0xffffu << GMAC_ST2CW021_COMPVAL_Pos) |
| | (GMAC_ST2CW021) Compare Value
#define | GMAC_ST2CW021_COMPVAL(value) ((GMAC_ST2CW021_COMPVAL_Msk & ((value) << GMAC_ST2CW021_COMPVAL_Pos))) |
#define | GMAC_ST2CW121_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW121_OFFSVAL_Msk (0x7fu << GMAC_ST2CW121_OFFSVAL_Pos) |
| | (GMAC_ST2CW121) Offset Value in Bytes
#define | GMAC_ST2CW121_OFFSVAL(value) ((GMAC_ST2CW121_OFFSVAL_Msk & ((value) << GMAC_ST2CW121_OFFSVAL_Pos))) |
#define | GMAC_ST2CW121_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW121_OFFSSTRT_Msk (0x3u << GMAC_ST2CW121_OFFSSTRT_Pos) |
| | (GMAC_ST2CW121) Ethernet Frame Offset Start
#define | GMAC_ST2CW121_OFFSSTRT(value) ((GMAC_ST2CW121_OFFSSTRT_Msk & ((value) << GMAC_ST2CW121_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW121_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW121) Offset from the start of the frame
#define | GMAC_ST2CW121_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW121) Offset from the byte after the EtherType field
#define | GMAC_ST2CW121_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW121) Offset from the byte after the IP header field
#define | GMAC_ST2CW121_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW121) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW022_MASKVAL_Pos 0 |
#define | GMAC_ST2CW022_MASKVAL_Msk (0xffffu << GMAC_ST2CW022_MASKVAL_Pos) |
| | (GMAC_ST2CW022) Mask Value
#define | GMAC_ST2CW022_MASKVAL(value) ((GMAC_ST2CW022_MASKVAL_Msk & ((value) << GMAC_ST2CW022_MASKVAL_Pos))) |
#define | GMAC_ST2CW022_COMPVAL_Pos 16 |
#define | GMAC_ST2CW022_COMPVAL_Msk (0xffffu << GMAC_ST2CW022_COMPVAL_Pos) |
| | (GMAC_ST2CW022) Compare Value
#define | GMAC_ST2CW022_COMPVAL(value) ((GMAC_ST2CW022_COMPVAL_Msk & ((value) << GMAC_ST2CW022_COMPVAL_Pos))) |
#define | GMAC_ST2CW122_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW122_OFFSVAL_Msk (0x7fu << GMAC_ST2CW122_OFFSVAL_Pos) |
| | (GMAC_ST2CW122) Offset Value in Bytes
#define | GMAC_ST2CW122_OFFSVAL(value) ((GMAC_ST2CW122_OFFSVAL_Msk & ((value) << GMAC_ST2CW122_OFFSVAL_Pos))) |
#define | GMAC_ST2CW122_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW122_OFFSSTRT_Msk (0x3u << GMAC_ST2CW122_OFFSSTRT_Pos) |
| | (GMAC_ST2CW122) Ethernet Frame Offset Start
#define | GMAC_ST2CW122_OFFSSTRT(value) ((GMAC_ST2CW122_OFFSSTRT_Msk & ((value) << GMAC_ST2CW122_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW122_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW122) Offset from the start of the frame
#define | GMAC_ST2CW122_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW122) Offset from the byte after the EtherType field
#define | GMAC_ST2CW122_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW122) Offset from the byte after the IP header field
#define | GMAC_ST2CW122_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW122) Offset from the byte after the TCP/UDP header field
#define | GMAC_ST2CW023_MASKVAL_Pos 0 |
#define | GMAC_ST2CW023_MASKVAL_Msk (0xffffu << GMAC_ST2CW023_MASKVAL_Pos) |
| | (GMAC_ST2CW023) Mask Value
#define | GMAC_ST2CW023_MASKVAL(value) ((GMAC_ST2CW023_MASKVAL_Msk & ((value) << GMAC_ST2CW023_MASKVAL_Pos))) |
#define | GMAC_ST2CW023_COMPVAL_Pos 16 |
#define | GMAC_ST2CW023_COMPVAL_Msk (0xffffu << GMAC_ST2CW023_COMPVAL_Pos) |
| | (GMAC_ST2CW023) Compare Value
#define | GMAC_ST2CW023_COMPVAL(value) ((GMAC_ST2CW023_COMPVAL_Msk & ((value) << GMAC_ST2CW023_COMPVAL_Pos))) |
#define | GMAC_ST2CW123_OFFSVAL_Pos 0 |
#define | GMAC_ST2CW123_OFFSVAL_Msk (0x7fu << GMAC_ST2CW123_OFFSVAL_Pos) |
| | (GMAC_ST2CW123) Offset Value in Bytes
#define | GMAC_ST2CW123_OFFSVAL(value) ((GMAC_ST2CW123_OFFSVAL_Msk & ((value) << GMAC_ST2CW123_OFFSVAL_Pos))) |
#define | GMAC_ST2CW123_OFFSSTRT_Pos 7 |
#define | GMAC_ST2CW123_OFFSSTRT_Msk (0x3u << GMAC_ST2CW123_OFFSSTRT_Pos) |
| | (GMAC_ST2CW123) Ethernet Frame Offset Start
#define | GMAC_ST2CW123_OFFSSTRT(value) ((GMAC_ST2CW123_OFFSSTRT_Msk & ((value) << GMAC_ST2CW123_OFFSSTRT_Pos))) |
#define | GMAC_ST2CW123_OFFSSTRT_FRAMESTART (0x0u << 7) |
| | (GMAC_ST2CW123) Offset from the start of the frame
#define | GMAC_ST2CW123_OFFSSTRT_ETHERTYPE (0x1u << 7) |
| | (GMAC_ST2CW123) Offset from the byte after the EtherType field
#define | GMAC_ST2CW123_OFFSSTRT_IP (0x2u << 7) |
| | (GMAC_ST2CW123) Offset from the byte after the IP header field
#define | GMAC_ST2CW123_OFFSSTRT_TCP_UDP (0x3u << 7) |
| | (GMAC_ST2CW123) Offset from the byte after the TCP/UDP header field
