#define  | ID_SUPC   ( 0) |
|   | Supply Controller (SUPC)
#define  | ID_RSTC   ( 1) |
|   | Reset Controller (RSTC)
#define  | ID_RTC   ( 2) |
|   | Real Time Clock (RTC)
#define  | ID_RTT   ( 3) |
|   | Real Time Timer (RTT)
#define  | ID_WDT   ( 4) |
|   | Watchdog Timer (WDT)
#define  | ID_PMC   ( 5) |
|   | Power Management Controller (PMC)
#define  | ID_EFC   ( 6) |
|   | Enhanced Embedded Flash Controller (EFC)
#define  | ID_UART0   ( 7) |
|   | UART 0 (UART0)
#define  | ID_UART1   ( 8) |
|   | UART 1 (UART1)
#define  | ID_SMC   ( 9) |
|   | Static Memory Controller (SMC)
#define  | ID_PIOA   (10) |
|   | Parallel I/O Controller A (PIOA)
#define  | ID_PIOB   (11) |
|   | Parallel I/O Controller B (PIOB)
#define  | ID_PIOC   (12) |
|   | Parallel I/O Controller C (PIOC)
#define  | ID_USART0   (13) |
|   | USART 0 (USART0)
#define  | ID_USART1   (14) |
|   | USART 1 (USART1)
#define  | ID_USART2   (15) |
|   | USART 2 (USART2)
#define  | ID_PIOD   (16) |
|   | Parallel I/O Controller D (PIOD)
#define  | ID_PIOE   (17) |
|   | Parallel I/O Controller E (PIOE)
#define  | ID_HSMCI   (18) |
|   | Multimedia Card Interface (HSMCI)
#define  | ID_TWIHS0   (19) |
|   | Two Wire Interface 0 HS (TWIHS0)
#define  | ID_TWIHS1   (20) |
|   | Two Wire Interface 1 HS (TWIHS1)
#define  | ID_SPI0   (21) |
|   | Serial Peripheral Interface 0 (SPI0)
#define  | ID_SSC   (22) |
|   | Synchronous Serial Controller (SSC)
#define  | ID_TC0   (23) |
|   | Timer/Counter 0 (TC0)
#define  | ID_TC1   (24) |
|   | Timer/Counter 1 (TC1)
#define  | ID_TC2   (25) |
|   | Timer/Counter 2 (TC2)
#define  | ID_TC3   (26) |
|   | Timer/Counter 3 (TC3)
#define  | ID_TC4   (27) |
|   | Timer/Counter 4 (TC4)
#define  | ID_TC5   (28) |
|   | Timer/Counter 5 (TC5)
#define  | ID_AFEC0   (29) |
|   | Analog Front End 0 (AFEC0)
#define  | ID_DACC   (30) |
|   | Digital To Analog Converter (DACC)
#define  | ID_PWM0   (31) |
|   | Pulse Width Modulation 0 (PWM0)
#define  | ID_ICM   (32) |
|   | Integrity Check Monitor (ICM)
#define  | ID_ACC   (33) |
|   | Analog Comparator (ACC)
#define  | ID_USBHS   (34) |
|   | USB Host / Device Controller (USBHS)
#define  | ID_MCAN0   (35) |
|   | MCAN Controller 0 (MCAN0)
#define  | ID_MCAN1   (37) |
|   | MCAN Controller 1 (MCAN1)
#define  | ID_GMAC   (39) |
|   | Ethernet MAC (GMAC)
#define  | ID_AFEC1   (40) |
|   | Analog Front End 1 (AFEC1)
#define  | ID_TWIHS2   (41) |
|   | Two Wire Interface 2 HS (TWIHS2)
#define  | ID_SPI1   (42) |
|   | Serial Peripheral Interface 1 (SPI1)
#define  | ID_QSPI   (43) |
|   | Quad I/O Serial Peripheral Interface (QSPI)
#define  | ID_UART2   (44) |
|   | UART 2 (UART2)
#define  | ID_UART3   (45) |
|   | UART 3 (UART3)
#define  | ID_UART4   (46) |
|   | UART 4 (UART4)
#define  | ID_TC6   (47) |
|   | Timer/Counter 6 (TC6)
#define  | ID_TC7   (48) |
|   | Timer/Counter 7 (TC7)
#define  | ID_TC8   (49) |
|   | Timer/Counter 8 (TC8)
#define  | ID_TC9   (50) |
|   | Timer/Counter 9 (TC9)
#define  | ID_TC10   (51) |
|   | Timer/Counter 10 (TC10)
#define  | ID_TC11   (52) |
|   | Timer/Counter 11 (TC11)
#define  | ID_MLB   (53) |
|   | MediaLB (MLB)
#define  | ID_AES   (56) |
|   | AES (AES)
#define  | ID_TRNG   (57) |
|   | True Random Generator (TRNG)
#define  | ID_XDMAC   (58) |
|   | DMA (XDMAC)
#define  | ID_ISI   (59) |
|   | Camera Interface (ISI)
#define  | ID_PWM1   (60) |
|   | Pulse Width Modulation 1 (PWM1)
#define  | ID_SDRAMC   (62) |
|   | SDRAM Controller (SDRAMC)
#define  | ID_RSWDT   (63) |
|   | Reinforced Secure Watchdog Timer (RSWDT)
#define  | ID_PERIPH_COUNT   (64) |
|   | Number of peripheral IDs.
