RTEMS
5.1
| struct | Uart |
| Uart hardware registers. More... | |
| #define | UART_CR_RSTRX (0x1u << 2) |
| (UART_CR) Reset Receiver | |
| #define | UART_CR_RSTTX (0x1u << 3) |
| (UART_CR) Reset Transmitter | |
| #define | UART_CR_RXEN (0x1u << 4) |
| (UART_CR) Receiver Enable | |
| #define | UART_CR_RXDIS (0x1u << 5) |
| (UART_CR) Receiver Disable | |
| #define | UART_CR_TXEN (0x1u << 6) |
| (UART_CR) Transmitter Enable | |
| #define | UART_CR_TXDIS (0x1u << 7) |
| (UART_CR) Transmitter Disable | |
| #define | UART_CR_RSTSTA (0x1u << 8) |
| (UART_CR) Reset Status | |
| #define | UART_CR_REQCLR (0x1u << 12) |
| (UART_CR) Request Clear | |
| #define | UART_MR_FILTER (0x1u << 4) |
| (UART_MR) Receiver Digital Filter | |
| #define | UART_MR_FILTER_DISABLED (0x0u << 4) |
| (UART_MR) UART does not filter the receive line. | |
| #define | UART_MR_FILTER_ENABLED (0x1u << 4) |
| (UART_MR) UART filters the receive line using a three-sample filter (16x-bit clock) (2 over 3 majority). | |
| #define | UART_MR_PAR_Pos 9 |
| #define | UART_MR_PAR_Msk (0x7u << UART_MR_PAR_Pos) |
| (UART_MR) Parity Type | |
| #define | UART_MR_PAR(value) ((UART_MR_PAR_Msk & ((value) << UART_MR_PAR_Pos))) |
| #define | UART_MR_PAR_EVEN (0x0u << 9) |
| (UART_MR) Even Parity | |
| #define | UART_MR_PAR_ODD (0x1u << 9) |
| (UART_MR) Odd Parity | |
| #define | UART_MR_PAR_SPACE (0x2u << 9) |
| (UART_MR) Space: parity forced to 0 | |
| #define | UART_MR_PAR_MARK (0x3u << 9) |
| (UART_MR) Mark: parity forced to 1 | |
| #define | UART_MR_PAR_NO (0x4u << 9) |
| (UART_MR) No parity | |
| #define | UART_MR_BRSRCCK (0x1u << 12) |
| (UART_MR) Baud Rate Source Clock | |
| #define | UART_MR_BRSRCCK_PERIPH_CLK (0x0u << 12) |
| (UART_MR) The baud rate is driven by the peripheral clock | |
| #define | UART_MR_BRSRCCK_PMC_PCK (0x1u << 12) |
| (UART_MR) The baud rate is driven by a PMC programmable clock PCK (see section Power Management Controller (PMC)). | |
| #define | UART_MR_CHMODE_Pos 14 |
| #define | UART_MR_CHMODE_Msk (0x3u << UART_MR_CHMODE_Pos) |
| (UART_MR) Channel Mode | |
| #define | UART_MR_CHMODE(value) ((UART_MR_CHMODE_Msk & ((value) << UART_MR_CHMODE_Pos))) |
| #define | UART_MR_CHMODE_NORMAL (0x0u << 14) |
| (UART_MR) Normal mode | |
| #define | UART_MR_CHMODE_AUTOMATIC (0x1u << 14) |
| (UART_MR) Automatic echo | |
| #define | UART_MR_CHMODE_LOCAL_LOOPBACK (0x2u << 14) |
| (UART_MR) Local loopback | |
| #define | UART_MR_CHMODE_REMOTE_LOOPBACK (0x3u << 14) |
| (UART_MR) Remote loopback | |
| #define | UART_IER_RXRDY (0x1u << 0) |
| (UART_IER) Enable RXRDY Interrupt | |
| #define | UART_IER_TXRDY (0x1u << 1) |
| (UART_IER) Enable TXRDY Interrupt | |
| #define | UART_IER_OVRE (0x1u << 5) |
| (UART_IER) Enable Overrun Error Interrupt | |
| #define | UART_IER_FRAME (0x1u << 6) |
| (UART_IER) Enable Framing Error Interrupt | |
| #define | UART_IER_PARE (0x1u << 7) |
| (UART_IER) Enable Parity Error Interrupt | |
| #define | UART_IER_TXEMPTY (0x1u << 9) |
| (UART_IER) Enable TXEMPTY Interrupt | |
| #define | UART_IER_CMP (0x1u << 15) |
| (UART_IER) Enable Comparison Interrupt | |
| #define | UART_IDR_RXRDY (0x1u << 0) |
| (UART_IDR) Disable RXRDY Interrupt | |
| #define | UART_IDR_TXRDY (0x1u << 1) |
| (UART_IDR) Disable TXRDY Interrupt | |
| #define | UART_IDR_OVRE (0x1u << 5) |
| (UART_IDR) Disable Overrun Error Interrupt | |
| #define | UART_IDR_FRAME (0x1u << 6) |
| (UART_IDR) Disable Framing Error Interrupt | |
| #define | UART_IDR_PARE (0x1u << 7) |
| (UART_IDR) Disable Parity Error Interrupt | |
| #define | UART_IDR_TXEMPTY (0x1u << 9) |
| (UART_IDR) Disable TXEMPTY Interrupt | |
| #define | UART_IDR_CMP (0x1u << 15) |
| (UART_IDR) Disable Comparison Interrupt | |
| #define | UART_IMR_RXRDY (0x1u << 0) |
| (UART_IMR) Mask RXRDY Interrupt | |
| #define | UART_IMR_TXRDY (0x1u << 1) |
| (UART_IMR) Disable TXRDY Interrupt | |
| #define | UART_IMR_OVRE (0x1u << 5) |
| (UART_IMR) Mask Overrun Error Interrupt | |
| #define | UART_IMR_FRAME (0x1u << 6) |
| (UART_IMR) Mask Framing Error Interrupt | |
| #define | UART_IMR_PARE (0x1u << 7) |
| (UART_IMR) Mask Parity Error Interrupt | |
| #define | UART_IMR_TXEMPTY (0x1u << 9) |
| (UART_IMR) Mask TXEMPTY Interrupt | |
| #define | UART_IMR_CMP (0x1u << 15) |
| (UART_IMR) Mask Comparison Interrupt | |
| #define | UART_SR_RXRDY (0x1u << 0) |
| (UART_SR) Receiver Ready | |
| #define | UART_SR_TXRDY (0x1u << 1) |
| (UART_SR) Transmitter Ready | |
| #define | UART_SR_OVRE (0x1u << 5) |
| (UART_SR) Overrun Error | |
| #define | UART_SR_FRAME (0x1u << 6) |
| (UART_SR) Framing Error | |
| #define | UART_SR_PARE (0x1u << 7) |
| (UART_SR) Parity Error | |
| #define | UART_SR_TXEMPTY (0x1u << 9) |
| (UART_SR) Transmitter Empty | |
| #define | UART_SR_CMP (0x1u << 15) |
| (UART_SR) Comparison Match | |
| #define | UART_RHR_RXCHR_Pos 0 |
| #define | UART_RHR_RXCHR_Msk (0xffu << UART_RHR_RXCHR_Pos) |
| (UART_RHR) Received Character | |
| #define | UART_THR_TXCHR_Pos 0 |
| #define | UART_THR_TXCHR_Msk (0xffu << UART_THR_TXCHR_Pos) |
| (UART_THR) Character to be Transmitted | |
| #define | UART_THR_TXCHR(value) ((UART_THR_TXCHR_Msk & ((value) << UART_THR_TXCHR_Pos))) |
| #define | UART_BRGR_CD_Pos 0 |
| #define | UART_BRGR_CD_Msk (0xffffu << UART_BRGR_CD_Pos) |
| (UART_BRGR) Clock Divisor | |
| #define | UART_BRGR_CD(value) ((UART_BRGR_CD_Msk & ((value) << UART_BRGR_CD_Pos))) |
| #define | UART_CMPR_VAL1_Pos 0 |
| #define | UART_CMPR_VAL1_Msk (0xffu << UART_CMPR_VAL1_Pos) |
| (UART_CMPR) First Comparison Value for Received Character | |
| #define | UART_CMPR_VAL1(value) ((UART_CMPR_VAL1_Msk & ((value) << UART_CMPR_VAL1_Pos))) |
| #define | UART_CMPR_CMPMODE (0x1u << 12) |
| (UART_CMPR) Comparison Mode | |
| #define | UART_CMPR_CMPMODE_FLAG_ONLY (0x0u << 12) |
| (UART_CMPR) Any character is received and comparison function drives CMP flag. | |
| #define | UART_CMPR_CMPMODE_START_CONDITION (0x1u << 12) |
| (UART_CMPR) Comparison condition must be met to start reception. | |
| #define | UART_CMPR_CMPPAR (0x1u << 14) |
| (UART_CMPR) Compare Parity | |
| #define | UART_CMPR_VAL2_Pos 16 |
| #define | UART_CMPR_VAL2_Msk (0xffu << UART_CMPR_VAL2_Pos) |
| (UART_CMPR) Second Comparison Value for Received Character | |
| #define | UART_CMPR_VAL2(value) ((UART_CMPR_VAL2_Msk & ((value) << UART_CMPR_VAL2_Pos))) |
| #define | UART_WPMR_WPEN (0x1u << 0) |
| (UART_WPMR) Write Protection Enable | |
| #define | UART_WPMR_WPKEY_Pos 8 |
| #define | UART_WPMR_WPKEY_Msk (0xffffffu << UART_WPMR_WPKEY_Pos) |
| (UART_WPMR) Write Protection Key | |
| #define | UART_WPMR_WPKEY(value) ((UART_WPMR_WPKEY_Msk & ((value) << UART_WPMR_WPKEY_Pos))) |
| #define | UART_WPMR_WPKEY_PASSWD (0x554152u << 8) |
| (UART_WPMR) Writing any other value in this field aborts the write operation.Always reads as 0. | |
SOFTWARE API DEFINITION FOR Universal Asynchronous Receiver Transmitter
1.8.15
