#define | SSC_CR_RXEN (0x1u << 0) |
| | (SSC_CR) Receive Enable
#define | SSC_CR_RXDIS (0x1u << 1) |
| | (SSC_CR) Receive Disable
#define | SSC_CR_TXEN (0x1u << 8) |
| | (SSC_CR) Transmit Enable
#define | SSC_CR_TXDIS (0x1u << 9) |
| | (SSC_CR) Transmit Disable
#define | SSC_CR_SWRST (0x1u << 15) |
| | (SSC_CR) Software Reset
#define | SSC_CMR_DIV_Pos 0 |
#define | SSC_CMR_DIV_Msk (0xfffu << SSC_CMR_DIV_Pos) |
| | (SSC_CMR) Clock Divider
#define | SSC_CMR_DIV(value) ((SSC_CMR_DIV_Msk & ((value) << SSC_CMR_DIV_Pos))) |
#define | SSC_RCMR_CKS_Pos 0 |
#define | SSC_RCMR_CKS_Msk (0x3u << SSC_RCMR_CKS_Pos) |
| | (SSC_RCMR) Receive Clock Selection
#define | SSC_RCMR_CKS(value) ((SSC_RCMR_CKS_Msk & ((value) << SSC_RCMR_CKS_Pos))) |
#define | SSC_RCMR_CKS_MCK (0x0u << 0) |
| | (SSC_RCMR) Divided Clock
#define | SSC_RCMR_CKS_TK (0x1u << 0) |
| | (SSC_RCMR) TK Clock signal
#define | SSC_RCMR_CKS_RK (0x2u << 0) |
| | (SSC_RCMR) RK pin
#define | SSC_RCMR_CKO_Pos 2 |
#define | SSC_RCMR_CKO_Msk (0x7u << SSC_RCMR_CKO_Pos) |
| | (SSC_RCMR) Receive Clock Output Mode Selection
#define | SSC_RCMR_CKO(value) ((SSC_RCMR_CKO_Msk & ((value) << SSC_RCMR_CKO_Pos))) |
#define | SSC_RCMR_CKO_NONE (0x0u << 2) |
| | (SSC_RCMR) None, RK pin is an input
#define | SSC_RCMR_CKO_CONTINUOUS (0x1u << 2) |
| | (SSC_RCMR) Continuous Receive Clock, RK pin is an output
#define | SSC_RCMR_CKO_TRANSFER (0x2u << 2) |
| | (SSC_RCMR) Receive Clock only during data transfers, RK pin is an output
#define | SSC_RCMR_CKI (0x1u << 5) |
| | (SSC_RCMR) Receive Clock Inversion
#define | SSC_RCMR_CKG_Pos 6 |
#define | SSC_RCMR_CKG_Msk (0x3u << SSC_RCMR_CKG_Pos) |
| | (SSC_RCMR) Receive Clock Gating Selection
#define | SSC_RCMR_CKG(value) ((SSC_RCMR_CKG_Msk & ((value) << SSC_RCMR_CKG_Pos))) |
#define | SSC_RCMR_CKG_CONTINUOUS (0x0u << 6) |
| | (SSC_RCMR) None
#define | SSC_RCMR_CKG_EN_RF_LOW (0x1u << 6) |
| | (SSC_RCMR) Receive Clock enabled only if RF Low
#define | SSC_RCMR_CKG_EN_RF_HIGH (0x2u << 6) |
| | (SSC_RCMR) Receive Clock enabled only if RF High
#define | SSC_RCMR_START_Pos 8 |
#define | SSC_RCMR_START_Msk (0xfu << SSC_RCMR_START_Pos) |
| | (SSC_RCMR) Receive Start Selection
#define | SSC_RCMR_START(value) ((SSC_RCMR_START_Msk & ((value) << SSC_RCMR_START_Pos))) |
#define | SSC_RCMR_START_CONTINUOUS (0x0u << 8) |
| | (SSC_RCMR) Continuous, as soon as the receiver is enabled, and immediately after the end of transfer of the previous data.
#define | SSC_RCMR_START_TRANSMIT (0x1u << 8) |
| | (SSC_RCMR) Transmit start
#define | SSC_RCMR_START_RF_LOW (0x2u << 8) |
| | (SSC_RCMR) Detection of a low level on RF signal
#define | SSC_RCMR_START_RF_HIGH (0x3u << 8) |
| | (SSC_RCMR) Detection of a high level on RF signal
#define | SSC_RCMR_START_RF_FALLING (0x4u << 8) |
| | (SSC_RCMR) Detection of a falling edge on RF signal
#define | SSC_RCMR_START_RF_RISING (0x5u << 8) |
| | (SSC_RCMR) Detection of a rising edge on RF signal
#define | SSC_RCMR_START_RF_LEVEL (0x6u << 8) |
| | (SSC_RCMR) Detection of any level change on RF signal
#define | SSC_RCMR_START_RF_EDGE (0x7u << 8) |
| | (SSC_RCMR) Detection of any edge on RF signal
#define | SSC_RCMR_START_CMP_0 (0x8u << 8) |
| | (SSC_RCMR) Compare 0
#define | SSC_RCMR_STOP (0x1u << 12) |
| | (SSC_RCMR) Receive Stop Selection
#define | SSC_RCMR_STTDLY_Pos 16 |
#define | SSC_RCMR_STTDLY_Msk (0xffu << SSC_RCMR_STTDLY_Pos) |
| | (SSC_RCMR) Receive Start Delay
#define | SSC_RCMR_STTDLY(value) ((SSC_RCMR_STTDLY_Msk & ((value) << SSC_RCMR_STTDLY_Pos))) |
#define | SSC_RCMR_PERIOD_Pos 24 |
#define | SSC_RCMR_PERIOD_Msk (0xffu << SSC_RCMR_PERIOD_Pos) |
| | (SSC_RCMR) Receive Period Divider Selection
#define | SSC_RCMR_PERIOD(value) ((SSC_RCMR_PERIOD_Msk & ((value) << SSC_RCMR_PERIOD_Pos))) |
#define | SSC_RFMR_DATLEN_Pos 0 |
#define | SSC_RFMR_DATLEN_Msk (0x1fu << SSC_RFMR_DATLEN_Pos) |
| | (SSC_RFMR) Data Length
#define | SSC_RFMR_DATLEN(value) ((SSC_RFMR_DATLEN_Msk & ((value) << SSC_RFMR_DATLEN_Pos))) |
#define | SSC_RFMR_LOOP (0x1u << 5) |
| | (SSC_RFMR) Loop Mode
#define | SSC_RFMR_MSBF (0x1u << 7) |
| | (SSC_RFMR) Most Significant Bit First
#define | SSC_RFMR_DATNB_Pos 8 |
#define | SSC_RFMR_DATNB_Msk (0xfu << SSC_RFMR_DATNB_Pos) |
| | (SSC_RFMR) Data Number per Frame
#define | SSC_RFMR_DATNB(value) ((SSC_RFMR_DATNB_Msk & ((value) << SSC_RFMR_DATNB_Pos))) |
#define | SSC_RFMR_FSLEN_Pos 16 |
#define | SSC_RFMR_FSLEN_Msk (0xfu << SSC_RFMR_FSLEN_Pos) |
| | (SSC_RFMR) Receive Frame Sync Length
#define | SSC_RFMR_FSLEN(value) ((SSC_RFMR_FSLEN_Msk & ((value) << SSC_RFMR_FSLEN_Pos))) |
#define | SSC_RFMR_FSOS_Pos 20 |
#define | SSC_RFMR_FSOS_Msk (0x7u << SSC_RFMR_FSOS_Pos) |
| | (SSC_RFMR) Receive Frame Sync Output Selection
#define | SSC_RFMR_FSOS(value) ((SSC_RFMR_FSOS_Msk & ((value) << SSC_RFMR_FSOS_Pos))) |
#define | SSC_RFMR_FSOS_NONE (0x0u << 20) |
| | (SSC_RFMR) None, RF pin is an input
#define | SSC_RFMR_FSOS_NEGATIVE (0x1u << 20) |
| | (SSC_RFMR) Negative Pulse, RF pin is an output
#define | SSC_RFMR_FSOS_POSITIVE (0x2u << 20) |
| | (SSC_RFMR) Positive Pulse, RF pin is an output
#define | SSC_RFMR_FSOS_LOW (0x3u << 20) |
| | (SSC_RFMR) Driven Low during data transfer, RF pin is an output
#define | SSC_RFMR_FSOS_HIGH (0x4u << 20) |
| | (SSC_RFMR) Driven High during data transfer, RF pin is an output
#define | SSC_RFMR_FSOS_TOGGLING (0x5u << 20) |
| | (SSC_RFMR) Toggling at each start of data transfer, RF pin is an output
#define | SSC_RFMR_FSEDGE (0x1u << 24) |
| | (SSC_RFMR) Frame Sync Edge Detection
#define | SSC_RFMR_FSEDGE_POSITIVE (0x0u << 24) |
| | (SSC_RFMR) Positive Edge Detection
#define | SSC_RFMR_FSEDGE_NEGATIVE (0x1u << 24) |
| | (SSC_RFMR) Negative Edge Detection
#define | SSC_RFMR_FSLEN_EXT_Pos 28 |
#define | SSC_RFMR_FSLEN_EXT_Msk (0xfu << SSC_RFMR_FSLEN_EXT_Pos) |
| | (SSC_RFMR) FSLEN Field Extension
#define | SSC_RFMR_FSLEN_EXT(value) ((SSC_RFMR_FSLEN_EXT_Msk & ((value) << SSC_RFMR_FSLEN_EXT_Pos))) |
#define | SSC_TCMR_CKS_Pos 0 |
#define | SSC_TCMR_CKS_Msk (0x3u << SSC_TCMR_CKS_Pos) |
| | (SSC_TCMR) Transmit Clock Selection
#define | SSC_TCMR_CKS(value) ((SSC_TCMR_CKS_Msk & ((value) << SSC_TCMR_CKS_Pos))) |
#define | SSC_TCMR_CKS_MCK (0x0u << 0) |
| | (SSC_TCMR) Divided Clock
#define | SSC_TCMR_CKS_RK (0x1u << 0) |
| | (SSC_TCMR) RK Clock signal
#define | SSC_TCMR_CKS_TK (0x2u << 0) |
| | (SSC_TCMR) TK pin
#define | SSC_TCMR_CKO_Pos 2 |
#define | SSC_TCMR_CKO_Msk (0x7u << SSC_TCMR_CKO_Pos) |
| | (SSC_TCMR) Transmit Clock Output Mode Selection
#define | SSC_TCMR_CKO(value) ((SSC_TCMR_CKO_Msk & ((value) << SSC_TCMR_CKO_Pos))) |
#define | SSC_TCMR_CKO_NONE (0x0u << 2) |
| | (SSC_TCMR) None, TK pin is an input
#define | SSC_TCMR_CKO_CONTINUOUS (0x1u << 2) |
| | (SSC_TCMR) Continuous Transmit Clock, TK pin is an output
#define | SSC_TCMR_CKO_TRANSFER (0x2u << 2) |
| | (SSC_TCMR) Transmit Clock only during data transfers, TK pin is an output
#define | SSC_TCMR_CKI (0x1u << 5) |
| | (SSC_TCMR) Transmit Clock Inversion
#define | SSC_TCMR_CKG_Pos 6 |
#define | SSC_TCMR_CKG_Msk (0x3u << SSC_TCMR_CKG_Pos) |
| | (SSC_TCMR) Transmit Clock Gating Selection
#define | SSC_TCMR_CKG(value) ((SSC_TCMR_CKG_Msk & ((value) << SSC_TCMR_CKG_Pos))) |
#define | SSC_TCMR_CKG_CONTINUOUS (0x0u << 6) |
| | (SSC_TCMR) None
#define | SSC_TCMR_CKG_EN_TF_LOW (0x1u << 6) |
| | (SSC_TCMR) Transmit Clock enabled only if TF Low
#define | SSC_TCMR_CKG_EN_TF_HIGH (0x2u << 6) |
| | (SSC_TCMR) Transmit Clock enabled only if TF High
#define | SSC_TCMR_START_Pos 8 |
#define | SSC_TCMR_START_Msk (0xfu << SSC_TCMR_START_Pos) |
| | (SSC_TCMR) Transmit Start Selection
#define | SSC_TCMR_START(value) ((SSC_TCMR_START_Msk & ((value) << SSC_TCMR_START_Pos))) |
#define | SSC_TCMR_START_CONTINUOUS (0x0u << 8) |
| | (SSC_TCMR) Continuous, as soon as a word is written in the SSC_THR (if Transmit is enabled), and immediately after the end of transfer of the previous data
#define | SSC_TCMR_START_RECEIVE (0x1u << 8) |
| | (SSC_TCMR) Receive start
#define | SSC_TCMR_START_TF_LOW (0x2u << 8) |
| | (SSC_TCMR) Detection of a low level on TF signal
#define | SSC_TCMR_START_TF_HIGH (0x3u << 8) |
| | (SSC_TCMR) Detection of a high level on TF signal
#define | SSC_TCMR_START_TF_FALLING (0x4u << 8) |
| | (SSC_TCMR) Detection of a falling edge on TF signal
#define | SSC_TCMR_START_TF_RISING (0x5u << 8) |
| | (SSC_TCMR) Detection of a rising edge on TF signal
#define | SSC_TCMR_START_TF_LEVEL (0x6u << 8) |
| | (SSC_TCMR) Detection of any level change on TF signal
#define | SSC_TCMR_START_TF_EDGE (0x7u << 8) |
| | (SSC_TCMR) Detection of any edge on TF signal
#define | SSC_TCMR_STTDLY_Pos 16 |
#define | SSC_TCMR_STTDLY_Msk (0xffu << SSC_TCMR_STTDLY_Pos) |
| | (SSC_TCMR) Transmit Start Delay
#define | SSC_TCMR_STTDLY(value) ((SSC_TCMR_STTDLY_Msk & ((value) << SSC_TCMR_STTDLY_Pos))) |
#define | SSC_TCMR_PERIOD_Pos 24 |
#define | SSC_TCMR_PERIOD_Msk (0xffu << SSC_TCMR_PERIOD_Pos) |
| | (SSC_TCMR) Transmit Period Divider Selection
#define | SSC_TCMR_PERIOD(value) ((SSC_TCMR_PERIOD_Msk & ((value) << SSC_TCMR_PERIOD_Pos))) |
#define | SSC_TFMR_DATLEN_Pos 0 |
#define | SSC_TFMR_DATLEN_Msk (0x1fu << SSC_TFMR_DATLEN_Pos) |
| | (SSC_TFMR) Data Length
#define | SSC_TFMR_DATLEN(value) ((SSC_TFMR_DATLEN_Msk & ((value) << SSC_TFMR_DATLEN_Pos))) |
#define | SSC_TFMR_DATDEF (0x1u << 5) |
| | (SSC_TFMR) Data Default Value
#define | SSC_TFMR_MSBF (0x1u << 7) |
| | (SSC_TFMR) Most Significant Bit First
#define | SSC_TFMR_DATNB_Pos 8 |
#define | SSC_TFMR_DATNB_Msk (0xfu << SSC_TFMR_DATNB_Pos) |
| | (SSC_TFMR) Data Number per Frame
#define | SSC_TFMR_DATNB(value) ((SSC_TFMR_DATNB_Msk & ((value) << SSC_TFMR_DATNB_Pos))) |
#define | SSC_TFMR_FSLEN_Pos 16 |
#define | SSC_TFMR_FSLEN_Msk (0xfu << SSC_TFMR_FSLEN_Pos) |
| | (SSC_TFMR) Transmit Frame Sync Length
#define | SSC_TFMR_FSLEN(value) ((SSC_TFMR_FSLEN_Msk & ((value) << SSC_TFMR_FSLEN_Pos))) |
#define | SSC_TFMR_FSOS_Pos 20 |
#define | SSC_TFMR_FSOS_Msk (0x7u << SSC_TFMR_FSOS_Pos) |
| | (SSC_TFMR) Transmit Frame Sync Output Selection
#define | SSC_TFMR_FSOS(value) ((SSC_TFMR_FSOS_Msk & ((value) << SSC_TFMR_FSOS_Pos))) |
#define | SSC_TFMR_FSOS_NONE (0x0u << 20) |
| | (SSC_TFMR) None, TF pin is an input
#define | SSC_TFMR_FSOS_NEGATIVE (0x1u << 20) |
| | (SSC_TFMR) Negative Pulse, TF pin is an output
#define | SSC_TFMR_FSOS_POSITIVE (0x2u << 20) |
| | (SSC_TFMR) Positive Pulse, TF pin is an output
#define | SSC_TFMR_FSOS_LOW (0x3u << 20) |
| | (SSC_TFMR) Driven Low during data transfer
#define | SSC_TFMR_FSOS_HIGH (0x4u << 20) |
| | (SSC_TFMR) Driven High during data transfer
#define | SSC_TFMR_FSOS_TOGGLING (0x5u << 20) |
| | (SSC_TFMR) Toggling at each start of data transfer
#define | SSC_TFMR_FSDEN (0x1u << 23) |
| | (SSC_TFMR) Frame Sync Data Enable
#define | SSC_TFMR_FSEDGE (0x1u << 24) |
| | (SSC_TFMR) Frame Sync Edge Detection
#define | SSC_TFMR_FSEDGE_POSITIVE (0x0u << 24) |
| | (SSC_TFMR) Positive Edge Detection
#define | SSC_TFMR_FSEDGE_NEGATIVE (0x1u << 24) |
| | (SSC_TFMR) Negative Edge Detection
#define | SSC_TFMR_FSLEN_EXT_Pos 28 |
#define | SSC_TFMR_FSLEN_EXT_Msk (0xfu << SSC_TFMR_FSLEN_EXT_Pos) |
| | (SSC_TFMR) FSLEN Field Extension
#define | SSC_TFMR_FSLEN_EXT(value) ((SSC_TFMR_FSLEN_EXT_Msk & ((value) << SSC_TFMR_FSLEN_EXT_Pos))) |
#define | SSC_RHR_RDAT_Pos 0 |
#define | SSC_RHR_RDAT_Msk (0xffffffffu << SSC_RHR_RDAT_Pos) |
| | (SSC_RHR) Receive Data
#define | SSC_THR_TDAT_Pos 0 |
#define | SSC_THR_TDAT_Msk (0xffffffffu << SSC_THR_TDAT_Pos) |
| | (SSC_THR) Transmit Data
#define | SSC_THR_TDAT(value) ((SSC_THR_TDAT_Msk & ((value) << SSC_THR_TDAT_Pos))) |
#define | SSC_RSHR_RSDAT_Pos 0 |
#define | SSC_RSHR_RSDAT_Msk (0xffffu << SSC_RSHR_RSDAT_Pos) |
| | (SSC_RSHR) Receive Synchronization Data
#define | SSC_TSHR_TSDAT_Pos 0 |
#define | SSC_TSHR_TSDAT_Msk (0xffffu << SSC_TSHR_TSDAT_Pos) |
| | (SSC_TSHR) Transmit Synchronization Data
#define | SSC_TSHR_TSDAT(value) ((SSC_TSHR_TSDAT_Msk & ((value) << SSC_TSHR_TSDAT_Pos))) |
#define | SSC_RC0R_CP0_Pos 0 |
#define | SSC_RC0R_CP0_Msk (0xffffu << SSC_RC0R_CP0_Pos) |
| | (SSC_RC0R) Receive Compare Data 0
#define | SSC_RC0R_CP0(value) ((SSC_RC0R_CP0_Msk & ((value) << SSC_RC0R_CP0_Pos))) |
#define | SSC_RC1R_CP1_Pos 0 |
#define | SSC_RC1R_CP1_Msk (0xffffu << SSC_RC1R_CP1_Pos) |
| | (SSC_RC1R) Receive Compare Data 1
#define | SSC_RC1R_CP1(value) ((SSC_RC1R_CP1_Msk & ((value) << SSC_RC1R_CP1_Pos))) |
#define | SSC_SR_TXRDY (0x1u << 0) |
| | (SSC_SR) Transmit Ready
#define | SSC_SR_TXEMPTY (0x1u << 1) |
| | (SSC_SR) Transmit Empty
#define | SSC_SR_RXRDY (0x1u << 4) |
| | (SSC_SR) Receive Ready
#define | SSC_SR_OVRUN (0x1u << 5) |
| | (SSC_SR) Receive Overrun
#define | SSC_SR_CP0 (0x1u << 8) |
| | (SSC_SR) Compare 0
#define | SSC_SR_CP1 (0x1u << 9) |
| | (SSC_SR) Compare 1
#define | SSC_SR_TXSYN (0x1u << 10) |
| | (SSC_SR) Transmit Sync
#define | SSC_SR_RXSYN (0x1u << 11) |
| | (SSC_SR) Receive Sync
#define | SSC_SR_TXEN (0x1u << 16) |
| | (SSC_SR) Transmit Enable
#define | SSC_SR_RXEN (0x1u << 17) |
| | (SSC_SR) Receive Enable
#define | SSC_IER_TXRDY (0x1u << 0) |
| | (SSC_IER) Transmit Ready Interrupt Enable
#define | SSC_IER_TXEMPTY (0x1u << 1) |
| | (SSC_IER) Transmit Empty Interrupt Enable
#define | SSC_IER_RXRDY (0x1u << 4) |
| | (SSC_IER) Receive Ready Interrupt Enable
#define | SSC_IER_OVRUN (0x1u << 5) |
| | (SSC_IER) Receive Overrun Interrupt Enable
#define | SSC_IER_CP0 (0x1u << 8) |
| | (SSC_IER) Compare 0 Interrupt Enable
#define | SSC_IER_CP1 (0x1u << 9) |
| | (SSC_IER) Compare 1 Interrupt Enable
#define | SSC_IER_TXSYN (0x1u << 10) |
| | (SSC_IER) Tx Sync Interrupt Enable
#define | SSC_IER_RXSYN (0x1u << 11) |
| | (SSC_IER) Rx Sync Interrupt Enable
#define | SSC_IDR_TXRDY (0x1u << 0) |
| | (SSC_IDR) Transmit Ready Interrupt Disable
#define | SSC_IDR_TXEMPTY (0x1u << 1) |
| | (SSC_IDR) Transmit Empty Interrupt Disable
#define | SSC_IDR_RXRDY (0x1u << 4) |
| | (SSC_IDR) Receive Ready Interrupt Disable
#define | SSC_IDR_OVRUN (0x1u << 5) |
| | (SSC_IDR) Receive Overrun Interrupt Disable
#define | SSC_IDR_CP0 (0x1u << 8) |
| | (SSC_IDR) Compare 0 Interrupt Disable
#define | SSC_IDR_CP1 (0x1u << 9) |
| | (SSC_IDR) Compare 1 Interrupt Disable
#define | SSC_IDR_TXSYN (0x1u << 10) |
| | (SSC_IDR) Tx Sync Interrupt Enable
#define | SSC_IDR_RXSYN (0x1u << 11) |
| | (SSC_IDR) Rx Sync Interrupt Enable
#define | SSC_IMR_TXRDY (0x1u << 0) |
| | (SSC_IMR) Transmit Ready Interrupt Mask
#define | SSC_IMR_TXEMPTY (0x1u << 1) |
| | (SSC_IMR) Transmit Empty Interrupt Mask
#define | SSC_IMR_RXRDY (0x1u << 4) |
| | (SSC_IMR) Receive Ready Interrupt Mask
#define | SSC_IMR_OVRUN (0x1u << 5) |
| | (SSC_IMR) Receive Overrun Interrupt Mask
#define | SSC_IMR_CP0 (0x1u << 8) |
| | (SSC_IMR) Compare 0 Interrupt Mask
#define | SSC_IMR_CP1 (0x1u << 9) |
| | (SSC_IMR) Compare 1 Interrupt Mask
#define | SSC_IMR_TXSYN (0x1u << 10) |
| | (SSC_IMR) Tx Sync Interrupt Mask
#define | SSC_IMR_RXSYN (0x1u << 11) |
| | (SSC_IMR) Rx Sync Interrupt Mask
#define | SSC_WPMR_WPEN (0x1u << 0) |
| | (SSC_WPMR) Write Protection Enable
#define | SSC_WPMR_WPKEY_Pos 8 |
#define | SSC_WPMR_WPKEY_Msk (0xffffffu << SSC_WPMR_WPKEY_Pos) |
| | (SSC_WPMR) Write Protection Key
#define | SSC_WPMR_WPKEY(value) ((SSC_WPMR_WPKEY_Msk & ((value) << SSC_WPMR_WPKEY_Pos))) |
#define | SSC_WPMR_WPKEY_PASSWD (0x535343u << 8) |
| | (SSC_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit.Always reads as 0.
#define | SSC_WPSR_WPVS (0x1u << 0) |
| | (SSC_WPSR) Write Protection Violation Status
#define | SSC_WPSR_WPVSRC_Pos 8 |
#define | SSC_WPSR_WPVSRC_Msk (0xffffu << SSC_WPSR_WPVSRC_Pos) |
| | (SSC_WPSR) Write Protect Violation Source
