#define | SDRAMC_MR_MODE_Pos 0 |
#define | SDRAMC_MR_MODE_Msk (0x7u << SDRAMC_MR_MODE_Pos) |
| | (SDRAMC_MR) SDRAMC Command Mode
#define | SDRAMC_MR_MODE(value) ((SDRAMC_MR_MODE_Msk & ((value) << SDRAMC_MR_MODE_Pos))) |
#define | SDRAMC_MR_MODE_NORMAL (0x0u << 0) |
| | (SDRAMC_MR) Normal mode. Any access to the SDRAM is decoded normally. To activate this mode, command must be followed by a write to the SDRAM.
#define | SDRAMC_MR_MODE_NOP (0x1u << 0) |
| | (SDRAMC_MR) The SDRAMC issues a NOP command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define | SDRAMC_MR_MODE_ALLBANKS_PRECHARGE (0x2u << 0) |
| | (SDRAMC_MR) The SDRAMC issues an "All Banks Precharge" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define | SDRAMC_MR_MODE_LOAD_MODEREG (0x3u << 0) |
| | (SDRAMC_MR) The SDRAMC issues a "Load Mode Register" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, command must be followed by a write to the SDRAM.
#define | SDRAMC_MR_MODE_AUTO_REFRESH (0x4u << 0) |
| | (SDRAMC_MR) The SDRAMC issues an "Auto-Refresh" Command when the SDRAM device is accessed regardless of the cycle. Previously, an "All Banks Precharge" command must be issued. To activate this mode, command must be followed by a write to the SDRAM.
#define | SDRAMC_MR_MODE_EXT_LOAD_MODEREG (0x5u << 0) |
| | (SDRAMC_MR) The SDRAMC issues an "Extended Load Mode Register" command when the SDRAM device is accessed regardless of the cycle. To activate this mode, the "Extended Load Mode Register" command must be followed by a write to the SDRAM. The write in the SDRAM must be done in the appropriate bank; most low-power SDRAM devices use the bank 1.
#define | SDRAMC_MR_MODE_DEEP_POWERDOWN (0x6u << 0) |
| | (SDRAMC_MR) Deep power-down mode. Enters deep power-down mode.
#define | SDRAMC_TR_COUNT_Pos 0 |
#define | SDRAMC_TR_COUNT_Msk (0xfffu << SDRAMC_TR_COUNT_Pos) |
| | (SDRAMC_TR) SDRAMC Refresh Timer Count
#define | SDRAMC_TR_COUNT(value) ((SDRAMC_TR_COUNT_Msk & ((value) << SDRAMC_TR_COUNT_Pos))) |
#define | SDRAMC_CR_NC_Pos 0 |
#define | SDRAMC_CR_NC_Msk (0x3u << SDRAMC_CR_NC_Pos) |
| | (SDRAMC_CR) Number of Column Bits
#define | SDRAMC_CR_NC(value) ((SDRAMC_CR_NC_Msk & ((value) << SDRAMC_CR_NC_Pos))) |
#define | SDRAMC_CR_NC_COL8 (0x0u << 0) |
| | (SDRAMC_CR) 8 column bits
#define | SDRAMC_CR_NC_COL9 (0x1u << 0) |
| | (SDRAMC_CR) 9 column bits
#define | SDRAMC_CR_NC_COL10 (0x2u << 0) |
| | (SDRAMC_CR) 10 column bits
#define | SDRAMC_CR_NC_COL11 (0x3u << 0) |
| | (SDRAMC_CR) 11 column bits
#define | SDRAMC_CR_NR_Pos 2 |
#define | SDRAMC_CR_NR_Msk (0x3u << SDRAMC_CR_NR_Pos) |
| | (SDRAMC_CR) Number of Row Bits
#define | SDRAMC_CR_NR(value) ((SDRAMC_CR_NR_Msk & ((value) << SDRAMC_CR_NR_Pos))) |
#define | SDRAMC_CR_NR_ROW11 (0x0u << 2) |
| | (SDRAMC_CR) 11 row bits
#define | SDRAMC_CR_NR_ROW12 (0x1u << 2) |
| | (SDRAMC_CR) 12 row bits
#define | SDRAMC_CR_NR_ROW13 (0x2u << 2) |
| | (SDRAMC_CR) 13 row bits
#define | SDRAMC_CR_NB (0x1u << 4) |
| | (SDRAMC_CR) Number of Banks
#define | SDRAMC_CR_NB_BANK2 (0x0u << 4) |
| | (SDRAMC_CR) 2 banks
#define | SDRAMC_CR_NB_BANK4 (0x1u << 4) |
| | (SDRAMC_CR) 4 banks
#define | SDRAMC_CR_CAS_Pos 5 |
#define | SDRAMC_CR_CAS_Msk (0x3u << SDRAMC_CR_CAS_Pos) |
| | (SDRAMC_CR) CAS Latency
#define | SDRAMC_CR_CAS(value) ((SDRAMC_CR_CAS_Msk & ((value) << SDRAMC_CR_CAS_Pos))) |
#define | SDRAMC_CR_CAS_LATENCY1 (0x0u << 5) |
| | (SDRAMC_CR) 1 cycle CAS latency
#define | SDRAMC_CR_CAS_LATENCY2 (0x1u << 5) |
| | (SDRAMC_CR) 2 cycle CAS latency
#define | SDRAMC_CR_CAS_LATENCY3 (0x2u << 5) |
| | (SDRAMC_CR) 3 cycle CAS latency
#define | SDRAMC_CR_DBW (0x1u << 7) |
| | (SDRAMC_CR) Data Bus Width
#define | SDRAMC_CR_TWR_Pos 8 |
#define | SDRAMC_CR_TWR_Msk (0xfu << SDRAMC_CR_TWR_Pos) |
| | (SDRAMC_CR) Write Recovery Delay
#define | SDRAMC_CR_TWR(value) ((SDRAMC_CR_TWR_Msk & ((value) << SDRAMC_CR_TWR_Pos))) |
#define | SDRAMC_CR_TRC_TRFC_Pos 12 |
#define | SDRAMC_CR_TRC_TRFC_Msk (0xfu << SDRAMC_CR_TRC_TRFC_Pos) |
| | (SDRAMC_CR) Row Cycle Delay and Row Refresh Cycle
#define | SDRAMC_CR_TRC_TRFC(value) ((SDRAMC_CR_TRC_TRFC_Msk & ((value) << SDRAMC_CR_TRC_TRFC_Pos))) |
#define | SDRAMC_CR_TRP_Pos 16 |
#define | SDRAMC_CR_TRP_Msk (0xfu << SDRAMC_CR_TRP_Pos) |
| | (SDRAMC_CR) Row Precharge Delay
#define | SDRAMC_CR_TRP(value) ((SDRAMC_CR_TRP_Msk & ((value) << SDRAMC_CR_TRP_Pos))) |
#define | SDRAMC_CR_TRCD_Pos 20 |
#define | SDRAMC_CR_TRCD_Msk (0xfu << SDRAMC_CR_TRCD_Pos) |
| | (SDRAMC_CR) Row to Column Delay
#define | SDRAMC_CR_TRCD(value) ((SDRAMC_CR_TRCD_Msk & ((value) << SDRAMC_CR_TRCD_Pos))) |
#define | SDRAMC_CR_TRAS_Pos 24 |
#define | SDRAMC_CR_TRAS_Msk (0xfu << SDRAMC_CR_TRAS_Pos) |
| | (SDRAMC_CR) Active to Precharge Delay
#define | SDRAMC_CR_TRAS(value) ((SDRAMC_CR_TRAS_Msk & ((value) << SDRAMC_CR_TRAS_Pos))) |
#define | SDRAMC_CR_TXSR_Pos 28 |
#define | SDRAMC_CR_TXSR_Msk (0xfu << SDRAMC_CR_TXSR_Pos) |
| | (SDRAMC_CR) Exit Self Refresh to Active Delay
#define | SDRAMC_CR_TXSR(value) ((SDRAMC_CR_TXSR_Msk & ((value) << SDRAMC_CR_TXSR_Pos))) |
#define | SDRAMC_LPR_LPCB_Pos 0 |
#define | SDRAMC_LPR_LPCB_Msk (0x3u << SDRAMC_LPR_LPCB_Pos) |
| | (SDRAMC_LPR) Low-power Configuration Bits
#define | SDRAMC_LPR_LPCB(value) ((SDRAMC_LPR_LPCB_Msk & ((value) << SDRAMC_LPR_LPCB_Pos))) |
#define | SDRAMC_LPR_LPCB_DISABLED (0x0u << 0) |
| | (SDRAMC_LPR) Low Power Feature is inhibited: no Power-down, Self-refresh or Deep Power-down command is issued to the SDRAM device.
#define | SDRAMC_LPR_LPCB_SELF_REFRESH (0x1u << 0) |
| | (SDRAMC_LPR) The SDRAMC issues a Self-refresh command to the SDRAM device, the SDCK clock is deactivated and the SDCKE signal is set low. The SDRAM device leaves the Self Refresh Mode when accessed and enters it after the access.
#define | SDRAMC_LPR_LPCB_POWER_DOWN (0x2u << 0) |
| | (SDRAMC_LPR) The SDRAMC issues a Power-down Command to the SDRAM device after each access, the SDCKE signal is set to low. The SDRAM device leaves the Power-down Mode when accessed and enters it after the access.
#define | SDRAMC_LPR_LPCB_DEEP_POWER_DOWN (0x3u << 0) |
| | (SDRAMC_LPR) The SDRAMC issues a Deep Power-down command to the SDRAM device. This mode is unique to low-power SDRAM.
#define | SDRAMC_LPR_PASR_Pos 4 |
#define | SDRAMC_LPR_PASR_Msk (0x7u << SDRAMC_LPR_PASR_Pos) |
| | (SDRAMC_LPR) Partial Array Self-refresh (only for low-power SDRAM)
#define | SDRAMC_LPR_PASR(value) ((SDRAMC_LPR_PASR_Msk & ((value) << SDRAMC_LPR_PASR_Pos))) |
#define | SDRAMC_LPR_TCSR_Pos 8 |
#define | SDRAMC_LPR_TCSR_Msk (0x3u << SDRAMC_LPR_TCSR_Pos) |
| | (SDRAMC_LPR) Temperature Compensated Self-Refresh (only for low-power SDRAM)
#define | SDRAMC_LPR_TCSR(value) ((SDRAMC_LPR_TCSR_Msk & ((value) << SDRAMC_LPR_TCSR_Pos))) |
#define | SDRAMC_LPR_DS_Pos 10 |
#define | SDRAMC_LPR_DS_Msk (0x3u << SDRAMC_LPR_DS_Pos) |
| | (SDRAMC_LPR) Drive Strength (only for low-power SDRAM)
#define | SDRAMC_LPR_DS(value) ((SDRAMC_LPR_DS_Msk & ((value) << SDRAMC_LPR_DS_Pos))) |
#define | SDRAMC_LPR_TIMEOUT_Pos 12 |
#define | SDRAMC_LPR_TIMEOUT_Msk (0x3u << SDRAMC_LPR_TIMEOUT_Pos) |
| | (SDRAMC_LPR) Time to Define When Low-power Mode Is Enabled
#define | SDRAMC_LPR_TIMEOUT(value) ((SDRAMC_LPR_TIMEOUT_Msk & ((value) << SDRAMC_LPR_TIMEOUT_Pos))) |
#define | SDRAMC_LPR_TIMEOUT_LP_LAST_XFER (0x0u << 12) |
| | (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode immediately after the end of the last transfer.
#define | SDRAMC_LPR_TIMEOUT_LP_LAST_XFER_64 (0x1u << 12) |
| | (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode 64 clock cycles after the end of the last transfer.
#define | SDRAMC_LPR_TIMEOUT_LP_LAST_XFER_128 (0x2u << 12) |
| | (SDRAMC_LPR) The SDRAMC activates the SDRAM low-power mode 128 clock cycles after the end of the last transfer.
#define | SDRAMC_IER_RES (0x1u << 0) |
| | (SDRAMC_IER) Refresh Error Status
#define | SDRAMC_IDR_RES (0x1u << 0) |
| | (SDRAMC_IDR) Refresh Error Status
#define | SDRAMC_IMR_RES (0x1u << 0) |
| | (SDRAMC_IMR) Refresh Error Status
#define | SDRAMC_ISR_RES (0x1u << 0) |
| | (SDRAMC_ISR) Refresh Error Status (cleared on read)
#define | SDRAMC_MDR_MD_Pos 0 |
#define | SDRAMC_MDR_MD_Msk (0x3u << SDRAMC_MDR_MD_Pos) |
| | (SDRAMC_MDR) Memory Device Type
#define | SDRAMC_MDR_MD(value) ((SDRAMC_MDR_MD_Msk & ((value) << SDRAMC_MDR_MD_Pos))) |
#define | SDRAMC_MDR_MD_SDRAM (0x0u << 0) |
| | (SDRAMC_MDR) SDRAM
#define | SDRAMC_MDR_MD_LPSDRAM (0x1u << 0) |
| | (SDRAMC_MDR) Low-power SDRAM
#define | SDRAMC_CFR1_TMRD_Pos 0 |
#define | SDRAMC_CFR1_TMRD_Msk (0xfu << SDRAMC_CFR1_TMRD_Pos) |
| | (SDRAMC_CFR1) Load Mode Register Command to Active or Refresh Command
#define | SDRAMC_CFR1_TMRD(value) ((SDRAMC_CFR1_TMRD_Msk & ((value) << SDRAMC_CFR1_TMRD_Pos))) |
#define | SDRAMC_CFR1_UNAL (0x1u << 8) |
| | (SDRAMC_CFR1) Support Unaligned Access
#define | SDRAMC_CFR1_UNAL_UNSUPPORTED (0x0u << 8) |
| | (SDRAMC_CFR1) Unaligned access is not supported.
#define | SDRAMC_CFR1_UNAL_SUPPORTED (0x1u << 8) |
| | (SDRAMC_CFR1) Unaligned access is supported.
#define | SDRAMC_OCMS_SDR_SE (0x1u << 0) |
| | (SDRAMC_OCMS) SDRAM Memory Controller Scrambling Enable
#define | SDRAMC_OCMS_KEY1_KEY1_Pos 0 |
#define | SDRAMC_OCMS_KEY1_KEY1_Msk (0xffffffffu << SDRAMC_OCMS_KEY1_KEY1_Pos) |
| | (SDRAMC_OCMS_KEY1) Off-chip Memory Scrambling (OCMS) Key Part 1
#define | SDRAMC_OCMS_KEY1_KEY1(value) ((SDRAMC_OCMS_KEY1_KEY1_Msk & ((value) << SDRAMC_OCMS_KEY1_KEY1_Pos))) |
#define | SDRAMC_OCMS_KEY2_KEY2_Pos 0 |
#define | SDRAMC_OCMS_KEY2_KEY2_Msk (0xffffffffu << SDRAMC_OCMS_KEY2_KEY2_Pos) |
| | (SDRAMC_OCMS_KEY2) Off-chip Memory Scrambling (OCMS) Key Part 2
#define | SDRAMC_OCMS_KEY2_KEY2(value) ((SDRAMC_OCMS_KEY2_KEY2_Msk & ((value) << SDRAMC_OCMS_KEY2_KEY2_Pos))) |
