#define | QSPI_CR_QSPIEN (0x1u << 0) |
| | (QSPI_CR) QSPI Enable
#define | QSPI_CR_QSPIDIS (0x1u << 1) |
| | (QSPI_CR) QSPI Disable
#define | QSPI_CR_SWRST (0x1u << 7) |
| | (QSPI_CR) QSPI Software Reset
#define | QSPI_CR_LASTXFER (0x1u << 24) |
| | (QSPI_CR) Last Transfer
#define | QSPI_MR_SMM (0x1u << 0) |
| | (QSPI_MR) Serial Memory Mode
#define | QSPI_MR_SMM_SPI (0x0u << 0) |
| | (QSPI_MR) The QSPI is in SPI mode.
#define | QSPI_MR_SMM_MEMORY (0x1u << 0) |
| | (QSPI_MR) The QSPI is in Serial Memory mode.
#define | QSPI_MR_LLB (0x1u << 1) |
| | (QSPI_MR) Local Loopback Enable
#define | QSPI_MR_LLB_DISABLED (0x0u << 1) |
| | (QSPI_MR) Local loopback path disabled.
#define | QSPI_MR_LLB_ENABLED (0x1u << 1) |
| | (QSPI_MR) Local loopback path enabled.
#define | QSPI_MR_WDRBT (0x1u << 2) |
| | (QSPI_MR) Wait Data Read Before Transfer
#define | QSPI_MR_WDRBT_DISABLED (0x0u << 2) |
| | (QSPI_MR) No effect. In SPI mode, a transfer can be initiated whatever the state of the QSPI_RDR is.
#define | QSPI_MR_WDRBT_ENABLED (0x1u << 2) |
| | (QSPI_MR) In SPI mode, a transfer can start only if the QSPI_RDR is empty, i.e., does not contain any unread data. This mode prevents overrun error in reception.
#define | QSPI_MR_CSMODE_Pos 4 |
#define | QSPI_MR_CSMODE_Msk (0x3u << QSPI_MR_CSMODE_Pos) |
| | (QSPI_MR) Chip Select Mode
#define | QSPI_MR_CSMODE(value) ((QSPI_MR_CSMODE_Msk & ((value) << QSPI_MR_CSMODE_Pos))) |
#define | QSPI_MR_CSMODE_NOT_RELOADED (0x0u << 4) |
| | (QSPI_MR) The chip select is deasserted if QSPI_TDR.TD has not been reloaded before the end of the current transfer.
#define | QSPI_MR_CSMODE_LASTXFER (0x1u << 4) |
| | (QSPI_MR) The chip select is deasserted when the bit LASTXFER is written at 1 and the character written in QSPI_TDR.TD has been transferred.
#define | QSPI_MR_CSMODE_SYSTEMATICALLY (0x2u << 4) |
| | (QSPI_MR) The chip select is deasserted systematically after each transfer.
#define | QSPI_MR_NBBITS_Pos 8 |
#define | QSPI_MR_NBBITS_Msk (0xfu << QSPI_MR_NBBITS_Pos) |
| | (QSPI_MR) Number Of Bits Per Transfer
#define | QSPI_MR_NBBITS(value) ((QSPI_MR_NBBITS_Msk & ((value) << QSPI_MR_NBBITS_Pos))) |
#define | QSPI_MR_NBBITS_8_BIT (0x0u << 8) |
| | (QSPI_MR) 8 bits for transfer
#define | QSPI_MR_NBBITS_16_BIT (0x8u << 8) |
| | (QSPI_MR) 16 bits for transfer
#define | QSPI_MR_DLYBCT_Pos 16 |
#define | QSPI_MR_DLYBCT_Msk (0xffu << QSPI_MR_DLYBCT_Pos) |
| | (QSPI_MR) Delay Between Consecutive Transfers
#define | QSPI_MR_DLYBCT(value) ((QSPI_MR_DLYBCT_Msk & ((value) << QSPI_MR_DLYBCT_Pos))) |
#define | QSPI_MR_DLYCS_Pos 24 |
#define | QSPI_MR_DLYCS_Msk (0xffu << QSPI_MR_DLYCS_Pos) |
| | (QSPI_MR) Minimum Inactive QCS Delay
#define | QSPI_MR_DLYCS(value) ((QSPI_MR_DLYCS_Msk & ((value) << QSPI_MR_DLYCS_Pos))) |
#define | QSPI_RDR_RD_Pos 0 |
#define | QSPI_RDR_RD_Msk (0xffffu << QSPI_RDR_RD_Pos) |
| | (QSPI_RDR) Receive Data
#define | QSPI_TDR_TD_Pos 0 |
#define | QSPI_TDR_TD_Msk (0xffffu << QSPI_TDR_TD_Pos) |
| | (QSPI_TDR) Transmit Data
#define | QSPI_TDR_TD(value) ((QSPI_TDR_TD_Msk & ((value) << QSPI_TDR_TD_Pos))) |
#define | QSPI_SR_RDRF (0x1u << 0) |
| | (QSPI_SR) Receive Data Register Full
#define | QSPI_SR_TDRE (0x1u << 1) |
| | (QSPI_SR) Transmit Data Register Empty
#define | QSPI_SR_TXEMPTY (0x1u << 2) |
| | (QSPI_SR) Transmission Registers Empty
#define | QSPI_SR_OVRES (0x1u << 3) |
| | (QSPI_SR) Overrun Error Status
#define | QSPI_SR_CSR (0x1u << 8) |
| | (QSPI_SR) Chip Select Rise
#define | QSPI_SR_CSS (0x1u << 9) |
| | (QSPI_SR) Chip Select Status
#define | QSPI_SR_INSTRE (0x1u << 10) |
| | (QSPI_SR) Instruction End Status
#define | QSPI_SR_QSPIENS (0x1u << 24) |
| | (QSPI_SR) QSPI Enable Status
#define | QSPI_IER_RDRF (0x1u << 0) |
| | (QSPI_IER) Receive Data Register Full Interrupt Enable
#define | QSPI_IER_TDRE (0x1u << 1) |
| | (QSPI_IER) Transmit Data Register Empty Interrupt Enable
#define | QSPI_IER_TXEMPTY (0x1u << 2) |
| | (QSPI_IER) Transmission Registers Empty Enable
#define | QSPI_IER_OVRES (0x1u << 3) |
| | (QSPI_IER) Overrun Error Interrupt Enable
#define | QSPI_IER_CSR (0x1u << 8) |
| | (QSPI_IER) Chip Select Rise Interrupt Enable
#define | QSPI_IER_CSS (0x1u << 9) |
| | (QSPI_IER) Chip Select Status Interrupt Enable
#define | QSPI_IER_INSTRE (0x1u << 10) |
| | (QSPI_IER) Instruction End Interrupt Enable
#define | QSPI_IDR_RDRF (0x1u << 0) |
| | (QSPI_IDR) Receive Data Register Full Interrupt Disable
#define | QSPI_IDR_TDRE (0x1u << 1) |
| | (QSPI_IDR) Transmit Data Register Empty Interrupt Disable
#define | QSPI_IDR_TXEMPTY (0x1u << 2) |
| | (QSPI_IDR) Transmission Registers Empty Disable
#define | QSPI_IDR_OVRES (0x1u << 3) |
| | (QSPI_IDR) Overrun Error Interrupt Disable
#define | QSPI_IDR_CSR (0x1u << 8) |
| | (QSPI_IDR) Chip Select Rise Interrupt Disable
#define | QSPI_IDR_CSS (0x1u << 9) |
| | (QSPI_IDR) Chip Select Status Interrupt Disable
#define | QSPI_IDR_INSTRE (0x1u << 10) |
| | (QSPI_IDR) Instruction End Interrupt Disable
#define | QSPI_IMR_RDRF (0x1u << 0) |
| | (QSPI_IMR) Receive Data Register Full Interrupt Mask
#define | QSPI_IMR_TDRE (0x1u << 1) |
| | (QSPI_IMR) Transmit Data Register Empty Interrupt Mask
#define | QSPI_IMR_TXEMPTY (0x1u << 2) |
| | (QSPI_IMR) Transmission Registers Empty Mask
#define | QSPI_IMR_OVRES (0x1u << 3) |
| | (QSPI_IMR) Overrun Error Interrupt Mask
#define | QSPI_IMR_CSR (0x1u << 8) |
| | (QSPI_IMR) Chip Select Rise Interrupt Mask
#define | QSPI_IMR_CSS (0x1u << 9) |
| | (QSPI_IMR) Chip Select Status Interrupt Mask
#define | QSPI_IMR_INSTRE (0x1u << 10) |
| | (QSPI_IMR) Instruction End Interrupt Mask
#define | QSPI_SCR_CPOL (0x1u << 0) |
| | (QSPI_SCR) Clock Polarity
#define | QSPI_SCR_CPHA (0x1u << 1) |
| | (QSPI_SCR) Clock Phase
#define | QSPI_SCR_SCBR_Pos 8 |
#define | QSPI_SCR_SCBR_Msk (0xffu << QSPI_SCR_SCBR_Pos) |
| | (QSPI_SCR) Serial Clock Baud Rate
#define | QSPI_SCR_SCBR(value) ((QSPI_SCR_SCBR_Msk & ((value) << QSPI_SCR_SCBR_Pos))) |
#define | QSPI_SCR_DLYBS_Pos 16 |
#define | QSPI_SCR_DLYBS_Msk (0xffu << QSPI_SCR_DLYBS_Pos) |
| | (QSPI_SCR) Delay Before QSCK
#define | QSPI_SCR_DLYBS(value) ((QSPI_SCR_DLYBS_Msk & ((value) << QSPI_SCR_DLYBS_Pos))) |
#define | QSPI_IAR_ADDR_Pos 0 |
#define | QSPI_IAR_ADDR_Msk (0xffffffffu << QSPI_IAR_ADDR_Pos) |
| | (QSPI_IAR) Address
#define | QSPI_IAR_ADDR(value) ((QSPI_IAR_ADDR_Msk & ((value) << QSPI_IAR_ADDR_Pos))) |
#define | QSPI_ICR_INST_Pos 0 |
#define | QSPI_ICR_INST_Msk (0xffu << QSPI_ICR_INST_Pos) |
| | (QSPI_ICR) Instruction Code
#define | QSPI_ICR_INST(value) ((QSPI_ICR_INST_Msk & ((value) << QSPI_ICR_INST_Pos))) |
#define | QSPI_ICR_OPT_Pos 16 |
#define | QSPI_ICR_OPT_Msk (0xffu << QSPI_ICR_OPT_Pos) |
| | (QSPI_ICR) Option Code
#define | QSPI_ICR_OPT(value) ((QSPI_ICR_OPT_Msk & ((value) << QSPI_ICR_OPT_Pos))) |
#define | QSPI_IFR_WIDTH_Pos 0 |
#define | QSPI_IFR_WIDTH_Msk (0x7u << QSPI_IFR_WIDTH_Pos) |
| | (QSPI_IFR) Width of Instruction Code, Address, Option Code and Data
#define | QSPI_IFR_WIDTH(value) ((QSPI_IFR_WIDTH_Msk & ((value) << QSPI_IFR_WIDTH_Pos))) |
#define | QSPI_IFR_WIDTH_SINGLE_BIT_SPI (0x0u << 0) |
| | (QSPI_IFR) Instruction: Single-bit SPI / Address-Option: Single-bit SPI / Data: Single-bit SPI
#define | QSPI_IFR_WIDTH_DUAL_OUTPUT (0x1u << 0) |
| | (QSPI_IFR) Instruction: Single-bit SPI / Address-Option: Single-bit SPI / Data: Dual SPI
#define | QSPI_IFR_WIDTH_QUAD_OUTPUT (0x2u << 0) |
| | (QSPI_IFR) Instruction: Single-bit SPI / Address-Option: Single-bit SPI / Data: Quad SPI
#define | QSPI_IFR_WIDTH_DUAL_IO (0x3u << 0) |
| | (QSPI_IFR) Instruction: Single-bit SPI / Address-Option: Dual SPI / Data: Dual SPI
#define | QSPI_IFR_WIDTH_QUAD_IO (0x4u << 0) |
| | (QSPI_IFR) Instruction: Single-bit SPI / Address-Option: Quad SPI / Data: Quad SPI
#define | QSPI_IFR_WIDTH_DUAL_CMD (0x5u << 0) |
| | (QSPI_IFR) Instruction: Dual SPI / Address-Option: Dual SPI / Data: Dual SPI
#define | QSPI_IFR_WIDTH_QUAD_CMD (0x6u << 0) |
| | (QSPI_IFR) Instruction: Quad SPI / Address-Option: Quad SPI / Data: Quad SPI
#define | QSPI_IFR_INSTEN (0x1u << 4) |
| | (QSPI_IFR) Instruction Enable
#define | QSPI_IFR_ADDREN (0x1u << 5) |
| | (QSPI_IFR) Address Enable
#define | QSPI_IFR_OPTEN (0x1u << 6) |
| | (QSPI_IFR) Option Enable
#define | QSPI_IFR_DATAEN (0x1u << 7) |
| | (QSPI_IFR) Data Enable
#define | QSPI_IFR_OPTL_Pos 8 |
#define | QSPI_IFR_OPTL_Msk (0x3u << QSPI_IFR_OPTL_Pos) |
| | (QSPI_IFR) Option Code Length
#define | QSPI_IFR_OPTL(value) ((QSPI_IFR_OPTL_Msk & ((value) << QSPI_IFR_OPTL_Pos))) |
#define | QSPI_IFR_OPTL_OPTION_1BIT (0x0u << 8) |
| | (QSPI_IFR) The option code is 1 bit long.
#define | QSPI_IFR_OPTL_OPTION_2BIT (0x1u << 8) |
| | (QSPI_IFR) The option code is 2 bits long.
#define | QSPI_IFR_OPTL_OPTION_4BIT (0x2u << 8) |
| | (QSPI_IFR) The option code is 4 bits long.
#define | QSPI_IFR_OPTL_OPTION_8BIT (0x3u << 8) |
| | (QSPI_IFR) The option code is 8 bits long.
#define | QSPI_IFR_ADDRL (0x1u << 10) |
| | (QSPI_IFR) Address Length
#define | QSPI_IFR_ADDRL_24_BIT (0x0u << 10) |
| | (QSPI_IFR) The address is 24 bits long.
#define | QSPI_IFR_ADDRL_32_BIT (0x1u << 10) |
| | (QSPI_IFR) The address is 32 bits long.
#define | QSPI_IFR_TFRTYP_Pos 12 |
#define | QSPI_IFR_TFRTYP_Msk (0x3u << QSPI_IFR_TFRTYP_Pos) |
| | (QSPI_IFR) Data Transfer Type
#define | QSPI_IFR_TFRTYP(value) ((QSPI_IFR_TFRTYP_Msk & ((value) << QSPI_IFR_TFRTYP_Pos))) |
#define | QSPI_IFR_TFRTYP_TRSFR_READ (0x0u << 12) |
| | (QSPI_IFR) Read transfer from the serial memory.Scrambling is not performed.Read at random location (fetch) in the serial Flash memory is not possible.
#define | QSPI_IFR_TFRTYP_TRSFR_READ_MEMORY (0x1u << 12) |
| | (QSPI_IFR) Read data transfer from the serial memory.If enabled, scrambling is performed.Read at random location (fetch) in the serial Flash memory is possible.
#define | QSPI_IFR_TFRTYP_TRSFR_WRITE (0x2u << 12) |
| | (QSPI_IFR) Write transfer into the serial memory.Scrambling is not performed.
#define | QSPI_IFR_TFRTYP_TRSFR_WRITE_MEMORY (0x3u << 12) |
| | (QSPI_IFR) Write data transfer into the serial memory.If enabled, scrambling is performed.
#define | QSPI_IFR_CRM (0x1u << 14) |
| | (QSPI_IFR) Continuous Read Mode
#define | QSPI_IFR_CRM_DISABLED (0x0u << 14) |
| | (QSPI_IFR) The Continuous Read mode is disabled.
#define | QSPI_IFR_CRM_ENABLED (0x1u << 14) |
| | (QSPI_IFR) The Continuous Read mode is enabled.
#define | QSPI_IFR_NBDUM_Pos 16 |
#define | QSPI_IFR_NBDUM_Msk (0x1fu << QSPI_IFR_NBDUM_Pos) |
| | (QSPI_IFR) Number Of Dummy Cycles
#define | QSPI_IFR_NBDUM(value) ((QSPI_IFR_NBDUM_Msk & ((value) << QSPI_IFR_NBDUM_Pos))) |
#define | QSPI_SMR_SCREN (0x1u << 0) |
| | (QSPI_SMR) Scrambling/Unscrambling Enable
#define | QSPI_SMR_SCREN_DISABLED (0x0u << 0) |
| | (QSPI_SMR) The scrambling/unscrambling is disabled.
#define | QSPI_SMR_SCREN_ENABLED (0x1u << 0) |
| | (QSPI_SMR) The scrambling/unscrambling is enabled.
#define | QSPI_SMR_RVDIS (0x1u << 1) |
| | (QSPI_SMR) Scrambling/Unscrambling Random Value Disable
#define | QSPI_SKR_USRK_Pos 0 |
#define | QSPI_SKR_USRK_Msk (0xffffffffu << QSPI_SKR_USRK_Pos) |
| | (QSPI_SKR) Scrambling User Key
#define | QSPI_SKR_USRK(value) ((QSPI_SKR_USRK_Msk & ((value) << QSPI_SKR_USRK_Pos))) |
#define | QSPI_WPMR_WPEN (0x1u << 0) |
| | (QSPI_WPMR) Write Protection Enable
#define | QSPI_WPMR_WPKEY_Pos 8 |
#define | QSPI_WPMR_WPKEY_Msk (0xffffffu << QSPI_WPMR_WPKEY_Pos) |
| | (QSPI_WPMR) Write Protection Key
#define | QSPI_WPMR_WPKEY(value) ((QSPI_WPMR_WPKEY_Msk & ((value) << QSPI_WPMR_WPKEY_Pos))) |
#define | QSPI_WPMR_WPKEY_PASSWD (0x515350u << 8) |
| | (QSPI_WPMR) Writing any other value in this field aborts the write operation of the WPEN bit. Always reads as 0.
#define | QSPI_WPSR_WPVS (0x1u << 0) |
| | (QSPI_WPSR) Write Protection Violation Status
#define | QSPI_WPSR_WPVSRC_Pos 8 |
#define | QSPI_WPSR_WPVSRC_Msk (0xffu << QSPI_WPSR_WPVSRC_Pos) |
| | (QSPI_WPSR) Write Protection Violation Source
