#define | ICM_CFG_WBDIS (0x1u << 0) |
| | (ICM_CFG) Write Back Disable
#define | ICM_CFG_EOMDIS (0x1u << 1) |
| | (ICM_CFG) End of Monitoring Disable
#define | ICM_CFG_SLBDIS (0x1u << 2) |
| | (ICM_CFG) Secondary List Branching Disable
#define | ICM_CFG_BBC_Pos 4 |
#define | ICM_CFG_BBC_Msk (0xfu << ICM_CFG_BBC_Pos) |
| | (ICM_CFG) Bus Burden Control
#define | ICM_CFG_BBC(value) ((ICM_CFG_BBC_Msk & ((value) << ICM_CFG_BBC_Pos))) |
#define | ICM_CFG_ASCD (0x1u << 8) |
| | (ICM_CFG) Automatic Switch To Compare Digest
#define | ICM_CFG_DUALBUFF (0x1u << 9) |
| | (ICM_CFG) Dual Input Buffer
#define | ICM_CFG_UIHASH (0x1u << 12) |
| | (ICM_CFG) User Initial Hash Value
#define | ICM_CFG_UALGO_Pos 13 |
#define | ICM_CFG_UALGO_Msk (0x7u << ICM_CFG_UALGO_Pos) |
| | (ICM_CFG) User SHA Algorithm
#define | ICM_CFG_UALGO(value) ((ICM_CFG_UALGO_Msk & ((value) << ICM_CFG_UALGO_Pos))) |
#define | ICM_CFG_UALGO_SHA1 (0x0u << 13) |
| | (ICM_CFG) SHA1 algorithm processed
#define | ICM_CFG_UALGO_SHA256 (0x1u << 13) |
| | (ICM_CFG) SHA256 algorithm processed
#define | ICM_CFG_UALGO_SHA224 (0x4u << 13) |
| | (ICM_CFG) SHA224 algorithm processed
#define | ICM_CFG_HAPROT_Pos 16 |
#define | ICM_CFG_HAPROT_Msk (0x3fu << ICM_CFG_HAPROT_Pos) |
| | (ICM_CFG) Region Hash Area Protection
#define | ICM_CFG_HAPROT(value) ((ICM_CFG_HAPROT_Msk & ((value) << ICM_CFG_HAPROT_Pos))) |
#define | ICM_CFG_DAPROT_Pos 24 |
#define | ICM_CFG_DAPROT_Msk (0x3fu << ICM_CFG_DAPROT_Pos) |
| | (ICM_CFG) Region Descriptor Area Protection
#define | ICM_CFG_DAPROT(value) ((ICM_CFG_DAPROT_Msk & ((value) << ICM_CFG_DAPROT_Pos))) |
#define | ICM_CTRL_ENABLE (0x1u << 0) |
| | (ICM_CTRL) ICM Enable
#define | ICM_CTRL_DISABLE (0x1u << 1) |
| | (ICM_CTRL) ICM Disable Register
#define | ICM_CTRL_SWRST (0x1u << 2) |
| | (ICM_CTRL) Software Reset
#define | ICM_CTRL_REHASH_Pos 4 |
#define | ICM_CTRL_REHASH_Msk (0xfu << ICM_CTRL_REHASH_Pos) |
| | (ICM_CTRL) Recompute Internal Hash
#define | ICM_CTRL_REHASH(value) ((ICM_CTRL_REHASH_Msk & ((value) << ICM_CTRL_REHASH_Pos))) |
#define | ICM_CTRL_RMDIS_Pos 8 |
#define | ICM_CTRL_RMDIS_Msk (0xfu << ICM_CTRL_RMDIS_Pos) |
| | (ICM_CTRL) Region Monitoring Disable
#define | ICM_CTRL_RMDIS(value) ((ICM_CTRL_RMDIS_Msk & ((value) << ICM_CTRL_RMDIS_Pos))) |
#define | ICM_CTRL_RMEN_Pos 12 |
#define | ICM_CTRL_RMEN_Msk (0xfu << ICM_CTRL_RMEN_Pos) |
| | (ICM_CTRL) Region Monitoring Enable
#define | ICM_CTRL_RMEN(value) ((ICM_CTRL_RMEN_Msk & ((value) << ICM_CTRL_RMEN_Pos))) |
#define | ICM_SR_ENABLE (0x1u << 0) |
| | (ICM_SR) ICM Controller Enable Register
#define | ICM_SR_RAWRMDIS_Pos 8 |
#define | ICM_SR_RAWRMDIS_Msk (0xfu << ICM_SR_RAWRMDIS_Pos) |
| | (ICM_SR) Region Monitoring Disabled Raw Status
#define | ICM_SR_RAWRMDIS(value) ((ICM_SR_RAWRMDIS_Msk & ((value) << ICM_SR_RAWRMDIS_Pos))) |
#define | ICM_SR_RMDIS_Pos 12 |
#define | ICM_SR_RMDIS_Msk (0xfu << ICM_SR_RMDIS_Pos) |
| | (ICM_SR) Region Monitoring Disabled Status
#define | ICM_SR_RMDIS(value) ((ICM_SR_RMDIS_Msk & ((value) << ICM_SR_RMDIS_Pos))) |
#define | ICM_IER_RHC_Pos 0 |
#define | ICM_IER_RHC_Msk (0xfu << ICM_IER_RHC_Pos) |
| | (ICM_IER) Region Hash Completed Interrupt Enable
#define | ICM_IER_RHC(value) ((ICM_IER_RHC_Msk & ((value) << ICM_IER_RHC_Pos))) |
#define | ICM_IER_RDM_Pos 4 |
#define | ICM_IER_RDM_Msk (0xfu << ICM_IER_RDM_Pos) |
| | (ICM_IER) Region Digest Mismatch Interrupt Enable
#define | ICM_IER_RDM(value) ((ICM_IER_RDM_Msk & ((value) << ICM_IER_RDM_Pos))) |
#define | ICM_IER_RBE_Pos 8 |
#define | ICM_IER_RBE_Msk (0xfu << ICM_IER_RBE_Pos) |
| | (ICM_IER) Region Bus Error Interrupt Enable
#define | ICM_IER_RBE(value) ((ICM_IER_RBE_Msk & ((value) << ICM_IER_RBE_Pos))) |
#define | ICM_IER_RWC_Pos 12 |
#define | ICM_IER_RWC_Msk (0xfu << ICM_IER_RWC_Pos) |
| | (ICM_IER) Region Wrap Condition detected Interrupt Enable
#define | ICM_IER_RWC(value) ((ICM_IER_RWC_Msk & ((value) << ICM_IER_RWC_Pos))) |
#define | ICM_IER_REC_Pos 16 |
#define | ICM_IER_REC_Msk (0xfu << ICM_IER_REC_Pos) |
| | (ICM_IER) Region End bit Condition Detected Interrupt Enable
#define | ICM_IER_REC(value) ((ICM_IER_REC_Msk & ((value) << ICM_IER_REC_Pos))) |
#define | ICM_IER_RSU_Pos 20 |
#define | ICM_IER_RSU_Msk (0xfu << ICM_IER_RSU_Pos) |
| | (ICM_IER) Region Status Updated Interrupt Disable
#define | ICM_IER_RSU(value) ((ICM_IER_RSU_Msk & ((value) << ICM_IER_RSU_Pos))) |
#define | ICM_IER_URAD (0x1u << 24) |
| | (ICM_IER) Undefined Register Access Detection Interrupt Enable
#define | ICM_IDR_RHC_Pos 0 |
#define | ICM_IDR_RHC_Msk (0xfu << ICM_IDR_RHC_Pos) |
| | (ICM_IDR) Region Hash Completed Interrupt Disable
#define | ICM_IDR_RHC(value) ((ICM_IDR_RHC_Msk & ((value) << ICM_IDR_RHC_Pos))) |
#define | ICM_IDR_RDM_Pos 4 |
#define | ICM_IDR_RDM_Msk (0xfu << ICM_IDR_RDM_Pos) |
| | (ICM_IDR) Region Digest Mismatch Interrupt Disable
#define | ICM_IDR_RDM(value) ((ICM_IDR_RDM_Msk & ((value) << ICM_IDR_RDM_Pos))) |
#define | ICM_IDR_RBE_Pos 8 |
#define | ICM_IDR_RBE_Msk (0xfu << ICM_IDR_RBE_Pos) |
| | (ICM_IDR) Region Bus Error Interrupt Disable
#define | ICM_IDR_RBE(value) ((ICM_IDR_RBE_Msk & ((value) << ICM_IDR_RBE_Pos))) |
#define | ICM_IDR_RWC_Pos 12 |
#define | ICM_IDR_RWC_Msk (0xfu << ICM_IDR_RWC_Pos) |
| | (ICM_IDR) Region Wrap Condition Detected Interrupt Disable
#define | ICM_IDR_RWC(value) ((ICM_IDR_RWC_Msk & ((value) << ICM_IDR_RWC_Pos))) |
#define | ICM_IDR_REC_Pos 16 |
#define | ICM_IDR_REC_Msk (0xfu << ICM_IDR_REC_Pos) |
| | (ICM_IDR) Region End bit Condition detected Interrupt Disable
#define | ICM_IDR_REC(value) ((ICM_IDR_REC_Msk & ((value) << ICM_IDR_REC_Pos))) |
#define | ICM_IDR_RSU_Pos 20 |
#define | ICM_IDR_RSU_Msk (0xfu << ICM_IDR_RSU_Pos) |
| | (ICM_IDR) Region Status Updated Interrupt Disable
#define | ICM_IDR_RSU(value) ((ICM_IDR_RSU_Msk & ((value) << ICM_IDR_RSU_Pos))) |
#define | ICM_IDR_URAD (0x1u << 24) |
| | (ICM_IDR) Undefined Register Access Detection Interrupt Disable
#define | ICM_IMR_RHC_Pos 0 |
#define | ICM_IMR_RHC_Msk (0xfu << ICM_IMR_RHC_Pos) |
| | (ICM_IMR) Region Hash Completed Interrupt Mask
#define | ICM_IMR_RDM_Pos 4 |
#define | ICM_IMR_RDM_Msk (0xfu << ICM_IMR_RDM_Pos) |
| | (ICM_IMR) Region Digest Mismatch Interrupt Mask
#define | ICM_IMR_RBE_Pos 8 |
#define | ICM_IMR_RBE_Msk (0xfu << ICM_IMR_RBE_Pos) |
| | (ICM_IMR) Region Bus Error Interrupt Mask
#define | ICM_IMR_RWC_Pos 12 |
#define | ICM_IMR_RWC_Msk (0xfu << ICM_IMR_RWC_Pos) |
| | (ICM_IMR) Region Wrap Condition Detected Interrupt Mask
#define | ICM_IMR_REC_Pos 16 |
#define | ICM_IMR_REC_Msk (0xfu << ICM_IMR_REC_Pos) |
| | (ICM_IMR) Region End bit Condition Detected Interrupt Mask
#define | ICM_IMR_RSU_Pos 20 |
#define | ICM_IMR_RSU_Msk (0xfu << ICM_IMR_RSU_Pos) |
| | (ICM_IMR) Region Status Updated Interrupt Mask
#define | ICM_IMR_URAD (0x1u << 24) |
| | (ICM_IMR) Undefined Register Access Detection Interrupt Mask
#define | ICM_ISR_RHC_Pos 0 |
#define | ICM_ISR_RHC_Msk (0xfu << ICM_ISR_RHC_Pos) |
| | (ICM_ISR) Region Hash Completed
#define | ICM_ISR_RDM_Pos 4 |
#define | ICM_ISR_RDM_Msk (0xfu << ICM_ISR_RDM_Pos) |
| | (ICM_ISR) Region Digest Mismatch
#define | ICM_ISR_RBE_Pos 8 |
#define | ICM_ISR_RBE_Msk (0xfu << ICM_ISR_RBE_Pos) |
| | (ICM_ISR) Region Bus Error
#define | ICM_ISR_RWC_Pos 12 |
#define | ICM_ISR_RWC_Msk (0xfu << ICM_ISR_RWC_Pos) |
| | (ICM_ISR) Region Wrap Condition Detected
#define | ICM_ISR_REC_Pos 16 |
#define | ICM_ISR_REC_Msk (0xfu << ICM_ISR_REC_Pos) |
| | (ICM_ISR) Region End bit Condition Detected
#define | ICM_ISR_RSU_Pos 20 |
#define | ICM_ISR_RSU_Msk (0xfu << ICM_ISR_RSU_Pos) |
| | (ICM_ISR) Region Status Updated Detected
#define | ICM_ISR_URAD (0x1u << 24) |
| | (ICM_ISR) Undefined Register Access Detection Status
#define | ICM_UASR_URAT_Pos 0 |
#define | ICM_UASR_URAT_Msk (0x7u << ICM_UASR_URAT_Pos) |
| | (ICM_UASR) Undefined Register Access Trace
#define | ICM_UASR_URAT_UNSPEC_STRUCT_MEMBER (0x0u << 0) |
| | (ICM_UASR) Unspecified structure member set to one detected when the descriptor is loaded.
#define | ICM_UASR_URAT_ICM_CFG_MODIFIED (0x1u << 0) |
| | (ICM_UASR) ICM_CFG modified during active monitoring.
#define | ICM_UASR_URAT_ICM_DSCR_MODIFIED (0x2u << 0) |
| | (ICM_UASR) ICM_DSCR modified during active monitoring.
#define | ICM_UASR_URAT_ICM_HASH_MODIFIED (0x3u << 0) |
| | (ICM_UASR) ICM_HASH modified during active monitoring
#define | ICM_UASR_URAT_READ_ACCESS (0x4u << 0) |
| | (ICM_UASR) Write-only register read access
#define | ICM_DSCR_DASA_Pos 6 |
#define | ICM_DSCR_DASA_Msk (0x3ffffffu << ICM_DSCR_DASA_Pos) |
| | (ICM_DSCR) Descriptor Area Start Address
#define | ICM_DSCR_DASA(value) ((ICM_DSCR_DASA_Msk & ((value) << ICM_DSCR_DASA_Pos))) |
#define | ICM_HASH_HASA_Pos 7 |
#define | ICM_HASH_HASA_Msk (0x1ffffffu << ICM_HASH_HASA_Pos) |
| | (ICM_HASH) Hash Area Start Address
#define | ICM_HASH_HASA(value) ((ICM_HASH_HASA_Msk & ((value) << ICM_HASH_HASA_Pos))) |
#define | ICM_UIHVAL_VAL_Pos 0 |
#define | ICM_UIHVAL_VAL_Msk (0xffffffffu << ICM_UIHVAL_VAL_Pos) |
| | (ICM_UIHVAL[8]) Initial Hash Value
#define | ICM_UIHVAL_VAL(value) ((ICM_UIHVAL_VAL_Msk & ((value) << ICM_UIHVAL_VAL_Pos))) |
