RTEMS  5.1
Files | Functions
Profiling Support
Profiling support. More...
file  profiling.h
 Profiling Support API.
void _Profiling_Outer_most_interrupt_entry_and_exit (Per_CPU_Control *cpu, CPU_Counter_ticks interrupt_entry_instant, CPU_Counter_ticks interrupt_exit_instant)
 Updates the interrupt profiling statistics. More...
Profiling support.
◆ _Profiling_Outer_most_interrupt_entry_and_exit()
void _Profiling_Outer_most_interrupt_entry_and_exit ( Per_CPU_Control *  cpu,
Must be called with the interrupt stack and before the thread dispatch disable level is decremented.
Parameters
cpuThe cpu control.
interrupt_entry_instantThe instant that the interrupt occured.
interrupt_exit_instantThe instant in which the interrupt was exited.
