RTEMS  5.1
Files | Data Structures | Macros | Functions | Variables
Memory Handler
Low level handler to provide memory areas for higher level memory handlers such as the Workspace Handler. More...
file  memory.h
 Memory Handler API.
struct  Memory_Area
 The memory area description. More...
struct  Memory_Information
 The memory information. More...
#define MEMORY_INFORMATION_INITIALIZER(areas)   { RTEMS_ARRAY_SIZE( areas ), ( areas ) }
 Statically initialize a memory information. More...
#define MEMORY_INITIALIZER(begin, end)   { ( begin ), ( begin ), ( end ) }
 Statically initialize a memory area. More...
RTEMS_INLINE_ROUTINE size_t _Memory_Get_count (const Memory_Information *information)
 Get the memory area count. More...
RTEMS_INLINE_ROUTINE Memory_Area * _Memory_Get_area (const Memory_Information *information, size_t index)
 Get a memory area by index. More...
RTEMS_INLINE_ROUTINE void _Memory_Initialize (Memory_Area *area, void *begin, void *end)
 Initialize the memory area. More...
RTEMS_INLINE_ROUTINE void _Memory_Initialize_by_size (Memory_Area *area, void *begin, uintptr_t size)
 Initialize the memory area by size. More...
RTEMS_INLINE_ROUTINE const void * _Memory_Get_begin (const Memory_Area *area)
 Get the memory area begin. More...
RTEMS_INLINE_ROUTINE void _Memory_Set_begin (Memory_Area *area, const void *begin)
 Set the memory area begin. More...
RTEMS_INLINE_ROUTINE const void * _Memory_Get_end (const Memory_Area *area)
 Get the memory area end. More...
RTEMS_INLINE_ROUTINE void _Memory_Set_end (Memory_Area *area, const void *end)
 Set the memory area end. More...
RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_size (const Memory_Area *area)
 Get the memory area size. More...
RTEMS_INLINE_ROUTINE void * _Memory_Get_free_begin (const Memory_Area *area)
 Get the begin of the free area of the memory area. More...
RTEMS_INLINE_ROUTINE void _Memory_Set_free_begin (Memory_Area *area, void *begin)
 Set the begin of the free area of the memory area. More...
RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_free_size (const Memory_Area *area)
 Get the size of the free memory area of the memory area. More...
RTEMS_INLINE_ROUTINE void _Memory_Consume (Memory_Area *area, uintptr_t consume)
 Consume the specified size from the free memory area of the memory area. More...
const Memory_Information * _Memory_Get (void)
 Return the memory information of this platform. More...
void * _Memory_Allocate (const Memory_Information *information, uintptr_t size, uintptr_t alignment)
 Allocate a memory area from the memory information. More...
void _Memory_Fill (const Memory_Information *information, int c)
 Fill all free memory areas of the memory information with a constant byte. More...
void _Memory_Zero_free_areas (void)
 Zeros all free memory areas of the system.
void _Memory_Dirty_free_areas (void)
 Dirty all free memory areas of the system.
const bool _Memory_Zero_before_use
 Indicates if the memory is zeroed during system initialization. More...
◆ MEMORY_INFORMATION_INITIALIZER
#define MEMORY_INFORMATION_INITIALIZER (   areas)    { RTEMS_ARRAY_SIZE( areas ), ( areas ) }
Parameters
areasThe designator of an array of the memory areas.
◆ MEMORY_INITIALIZER
#define MEMORY_INITIALIZER (   begin,
  end
Parameters
beginThe begin of the memory area.
endThe end of the memory area.
◆ _Memory_Allocate()
void* _Memory_Allocate ( const Memory_Information *  information,
uintptr_t  size,
uintptr_t  alignment
It is not possible to free the memory area allocated by this function.
Parameters
informationThe memory information.
sizeThe size in bytes of the memory area to allocate.
alignmentThe alignment in bytes of the memory area to allocate. It must be a power of two.
Return values
NULLNo such memory area available.
beginThe begin of the allocated memory area.
◆ _Memory_Consume()
RTEMS_INLINE_ROUTINE void _Memory_Consume ( Memory_Area *  area,
uintptr_t  consume
Parameters
areaThe memory area.
consumeThe bytes to consume from the free memory area of the memory area.
◆ _Memory_Fill()
void _Memory_Fill ( const Memory_Information *  information,
int  c
Parameters
cThe constant byte to fill the free memory areas.
◆ _Memory_Get()
const Memory_Information* _Memory_Get ( void  )
This function is provided by the Board Support Package (BSP). Using a function gives the BSPs a bit more freedom with respect to the implementation. Calling this function shall not have side-effects. Initialization steps to set up the memory information shall be done in a system initialization handler (RTEMS_SYSINIT_MEMORY).
Returns
◆ _Memory_Get_area()
RTEMS_INLINE_ROUTINE Memory_Area* _Memory_Get_area ( const Memory_Information *  information,
size_t  index
Parameters
indexThe index of the memory area to return.
Returns
The memory area of the specified index.
◆ _Memory_Get_begin()
RTEMS_INLINE_ROUTINE const void* _Memory_Get_begin ( const Memory_Area *  area)
Parameters
Returns
The memory area begin.
◆ _Memory_Get_count()
RTEMS_INLINE_ROUTINE size_t _Memory_Get_count ( const Memory_Information *  information)
Parameters
Returns
The memory area count.
◆ _Memory_Get_end()
RTEMS_INLINE_ROUTINE const void* _Memory_Get_end ( const Memory_Area *  area)
Parameters
Returns
The memory area end.
◆ _Memory_Get_free_begin()
RTEMS_INLINE_ROUTINE void* _Memory_Get_free_begin ( const Memory_Area *  area)
Parameters
Returns
The free memory area begin the memory area.
◆ _Memory_Get_free_size()
RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_free_size ( const Memory_Area *  area)
Parameters
Returns
The free memory area size in bytes of the memory area.
◆ _Memory_Get_size()
RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_size ( const Memory_Area *  area)
Parameters
Returns
The memory area size in bytes.
◆ _Memory_Initialize()
RTEMS_INLINE_ROUTINE void _Memory_Initialize ( Memory_Area *  area,
void *  begin,
void *  end
Parameters
◆ _Memory_Initialize_by_size()
RTEMS_INLINE_ROUTINE void _Memory_Initialize_by_size ( Memory_Area *  area,
void *  begin,
uintptr_t  size
Parameters
sizeThe size of the memory area in bytes.
◆ _Memory_Set_begin()
RTEMS_INLINE_ROUTINE void _Memory_Set_begin ( Memory_Area *  area,
const void *  begin
Parameters
beginThe memory area begin.
◆ _Memory_Set_end()
RTEMS_INLINE_ROUTINE void _Memory_Set_end ( Memory_Area *  area,
const void *  end
Parameters
endThe memory area end.
◆ _Memory_Set_free_begin()
RTEMS_INLINE_ROUTINE void _Memory_Set_free_begin ( Memory_Area *  area,
void *  begin
Parameters
beginThe free memory area begin the memory area.
Variable Documentation
◆ _Memory_Zero_before_use
This value is provided via <rtems/confdefs.h> in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is defined.
