RTEMS
5.1
LatticeMicro32 (lm32) Assembler Support. More...
| #define | __USER_LABEL_PREFIX__ _ |
| #define | __REGISTER_PREFIX__ |
| #define | SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x) |
| #define | REG(x) CONCAT1 (__REGISTER_PREFIX__, x) |
| #define | BEGIN_CODE_DCL .text |
| #define | END_CODE_DCL |
| #define | BEGIN_DATA_DCL .data |
| #define | END_DATA_DCL |
| #define | BEGIN_CODE .text |
| #define | END_CODE |
| #define | BEGIN_DATA |
| #define | END_DATA |
| #define | BEGIN_BSS |
| #define | END_BSS |
| #define | END |
| #define | PUBLIC(sym) .globl SYM (sym) |
| #define | EXTERN(sym) .globl SYM (sym) |
| #define __REGISTER_PREFIX__ |
Recent versions of GNU cpp define variables which indicate the need for underscores and percents. If not using GNU cpp or the version does not support this, then you will obviously have to define these as appropriate.
| #define __USER_LABEL_PREFIX__ _ |
| #define BEGIN_BSS |
This macro is used to denote the beginning of the unitialized data section.
| #define BEGIN_CODE .text |
| #define BEGIN_CODE_DCL .text |
| #define BEGIN_DATA |
| #define BEGIN_DATA_DCL .data |
| #define END |
| #define END_BSS |
| #define END_CODE |
| #define END_CODE_DCL |
| #define END_DATA |
| #define END_DATA_DCL |
| #define EXTERN | ( | sym | ) | .globl SYM (sym) |
NOTE: This must be tailored for a particular flavor of the C compiler. They may need to put underscores in front of the symbols.
| #define PUBLIC | ( | sym | ) | .globl SYM (sym) |
| #define REG | ( | x | ) | CONCAT1 (__REGISTER_PREFIX__, x) |
| #define SYM | ( | x | ) | CONCAT1 (__USER_LABEL_PREFIX__, x) |
1.8.15
