RTEMS  5.1
Modules | Files | Data Structures | Macros | Functions
API Mutex Handler
Provides routines to ensure mutual exclusion on API level. More...
 RTEMS Allocator Mutex
 Protection for all memory allocations and deallocations in RTEMS.
file  apimutex.h
 API Mutex Handler API.
file  muteximpl.h
 Structures for the implementation of mutexes.
file  apimutexisowner.c
file  apimutexlock.c
 Acquires the specified API mutex.
file  apimutexunlock.c
 Releases the Specified API Mutex.
struct  API_Mutex_Control
 Control block used to manage each API mutex. More...
struct  Mutex_Control
struct  Mutex_recursive_Control
#define API_MUTEX_INITIALIZER(name)   { _MUTEX_RECURSIVE_NAMED_INITIALIZER( name ), 0 }
 Statically initialize an API mutex.
void _API_Mutex_Lock (API_Mutex_Control *mutex)
 Acquires the specified API mutex. More...
void _API_Mutex_Unlock (API_Mutex_Control *mutex)
 Releases the specified API mutex. More...
bool _API_Mutex_Is_owner (const API_Mutex_Control *mutex)
 Checks if the specified API mutex is owned by the executing thread. More...
◆ _API_Mutex_Is_owner()
bool _API_Mutex_Is_owner ( const API_Mutex_Control *  mutex)
Parameters
[in]mutexThe API mutex to check the owner from.
◆ _API_Mutex_Lock()
void _API_Mutex_Lock ( API_Mutex_Control *  mutex)
Parameters
[in,out]mutexThe API mutex to acquire.
◆ _API_Mutex_Unlock()
void _API_Mutex_Unlock ( API_Mutex_Control *  mutex)
Parameters
[in,out]mutexThe API mutex to release.
