    RTEMS
    5.1
Xilinx Virtex-5 Board Support Package. More...
Modules | |
| Virtex 5 - MMU Support | |
| MMU support.  | |
| int | BSP_disconnect_clock_handler (void) |
| int | BSP_connect_clock_handler (void) |
| Clock Tick Device Driver.  More... | |
| void | zero_bss (void) |
| void | BSP_ask_for_reset (void) |
| unsigned int | BSP_bus_frequency |
| unsigned int | BSP_processor_frequency |
| unsigned int | BSP_time_base_divisor |
| int BSP_connect_clock_handler | ( | void | ) |
This routine utilizes the Decrementer Register common to the PPC family.
The tick frequency is directly programmed to the configured number of microseconds per tick.
 1.8.15
