MVME147 Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | RAM_START   0x00005000 |
#define  | RAM_END   0x00400000 |
#define  | pcc   ((volatile struct pcc_map * const) 0xfffe1000) |
#define  | z8530   0xfffe3001 |
#define  | PCC_BASE_VECTOR   0x40 /* First user int */ |
#define  | SCC_VECTOR   PCC_BASE_VECTOR+3 |
#define  | TIMER_1_VECTOR   PCC_BASE_VECTOR+8 |
#define  | TIMER_2_VECTOR   PCC_BASE_VECTOR+9 |
#define  | SOFT_1_VECTOR   PCC_BASE_VECTOR+10 |
#define  | SOFT_2_VECTOR   PCC_BASE_VECTOR+11 |
#define  | USE_CHANNEL_A   1                /* 1 = use channel A for console */ |
#define  | USE_CHANNEL_B   0                /* 1 = use channel B for console */ |
#define  | CONSOLE_CONTROL   0xfffe3002 |
#define  | CONSOLE_DATA   0xfffe3003 |
rtems_isr_entry  | M68Kvec [] |
◆ set_vector()
Install an interrupt handler.
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
