MCF5206eLite Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
#define  | BSP_MEM_ADDR_FLASH   (0xFFE00000) |
#define  | BSP_MEM_SIZE_FLASH   (1*1024*1024) |
#define  | BSP_MEM_MASK_FLASH   (MCF5206E_CSMR_MASK_1M) |
#define  | BSP_MEM_ADDR_ESRAM   (0x30000000) |
#define  | BSP_MEM_SIZE_ESRAM   (1*1024*1024) |
#define  | BSP_MEM_MASK_ESRAM   (MCF5206E_CSMR_MASK_1M) |
#define  | BSP_MEM_ADDR_GPIO   (0x40000000) |
#define  | BSP_MEM_SIZE_GPIO   (64*1024) |
#define  | BSP_MEM_MASK_GPIO   (MCF5206E_CSMR_MASK_64K) |
#define  | BSP_MEM_ADDR_DRAM   (0x00000000) |
#define  | BSP_MEM_SIZE_DRAM   (16*1024*1024) |
#define  | BSP_MEM_MASK_DRAM   (MCF5206E_DCMR_MASK_16M) |
#define  | BSP_MEM_ADDR_SRAM   (0x20000000) |
#define  | BSP_MEM_SIZE_SRAM   (8*1024) |
#define  | BSP_MEM_ADDR_IMM   (0x10000000) |
#define  | BSP_MEM_SIZE_IMM   (1*1024) |
#define  | MBAR   BSP_MEM_ADDR_IMM |
#define  | BSP_INTVEC_AVEC1   (25) |
#define  | BSP_INTLVL_AVEC1   (1) |
#define  | BSP_INTPRIO_AVEC1   (3) |
#define  | BSP_INTVEC_AVEC2   (26) |
#define  | BSP_INTLVL_AVEC2   (2) |
#define  | BSP_INTPRIO_AVEC2   (3) |
#define  | BSP_INTVEC_AVEC3   (27) |
#define  | BSP_INTLVL_AVEC3   (3) |
#define  | BSP_INTPRIO_AVEC3   (3) |
#define  | BSP_INTVEC_AVEC4   (28) |
#define  | BSP_INTLVL_AVEC4   (4) |
#define  | BSP_INTPRIO_AVEC4   (3) |
#define  | BSP_INTVEC_AVEC5   (29) |
#define  | BSP_INTLVL_AVEC5   (5) |
#define  | BSP_INTPRIO_AVEC5   (3) |
#define  | BSP_INTVEC_AVEC6   (30) |
#define  | BSP_INTLVL_AVEC6   (6) |
#define  | BSP_INTPRIO_AVEC6   (3) |
#define  | BSP_INTVEC_AVEC7   (31) |
#define  | BSP_INTLVL_AVEC7   (7) |
#define  | BSP_INTPRIO_AVEC7   (3) |
#define  | BSP_INTVEC_TIMER1   (BSP_INTVEC_AVEC5) |
#define  | BSP_INTLVL_TIMER1   (BSP_INTLVL_AVEC5) |
#define  | BSP_INTPRIO_TIMER1   (2) |
#define  | BSP_INTVEC_TIMER2   (BSP_INTVEC_AVEC6) |
#define  | BSP_INTLVL_TIMER2   (BSP_INTLVL_AVEC6) |
#define  | BSP_INTPRIO_TIMER2   (2) |
#define  | BSP_INTVEC_MBUS   (BSP_INTVEC_AVEC4) |
#define  | BSP_INTLVL_MBUS   (BSP_INTLVL_AVEC4) |
#define  | BSP_INTPRIO_MBUS   (2) |
#define  | BSP_INTVEC_UART1   (64) |
#define  | BSP_INTLVL_UART1   (4) |
#define  | BSP_INTPRIO_UART1   (0) |
#define  | BSP_INTVEC_UART2   (65) |
#define  | BSP_INTLVL_UART2   (4) |
#define  | BSP_INTPRIO_UART2   (1) |
#define  | BSP_INTVEC_DMA0   (66) |
#define  | BSP_INTLVL_DMA0   (3) |
#define  | BSP_INTPRIO_DMA0   (1) |
#define  | BSP_INTVEC_DMA1   (67) |
#define  | BSP_INTLVL_DMA1   (3) |
#define  | BSP_INTPRIO_DMA1   (2) |
#define  | DS1307_I2C_BUS_NUMBER   (0) |
#define  | BSP_SYSTEM_FREQUENCY   ((unsigned int)&_SYS_CLOCK_FREQUENCY) |
#define  | BSP_MBUS_FREQUENCY   (16000) |
#define  | I2C_NUMBER_OF_BUSES   (1) |
#define  | I2C_SELECT_BUS(bus) |
| #define  | rtems_bsp_delay(microseconds) |
◆ rtems_bsp_delay
          | #define rtems_bsp_delay |
          microseconds | ) |
Value:{ register uint32_t         _delay=(microseconds); \
    register uint32_t         _tmp=123; \
    __asm__ volatile( "0: \                     nbcd      %0 ; \                     nbcd      %0 ; \                     dbf       %1,0b" \
                  : "=d" (_tmp), "=d" (_delay) \
                  : "0"  (_tmp), "1"  (_delay) ); \
◆ set_vector()
Install an interrupt handler.
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
