MCF548X Board Support Package.
More...
| file   | bsp.h |
|   | Global BSP definitions.
| file   | tm27.h |
|   | Time Test 27 routines.
| #define  | CONSOLE_PORT   0 |
#define  | RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_mcf548x_fec_driver_attach_detach |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME   "fec1" |
#define  | RTEMS_BSP_NETWORK_DRIVER_NAME2   "fec2" |
uint32_t  | get_CPU_clock_speed (void) |
| rtems_isr_entry  | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
|   | Install an interrupt handler.  More...
int  | rtems_mcf548x_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
void  | bsp_cacr_set_flags (uint32_t flags) |
void  | bsp_cacr_set_self_clear_flags (uint32_t flags) |
void  | bsp_cacr_clear_flags (uint32_t flags) |
const uint8_t  | mcf548x_intc_icr_init_values [64] |
◆ CONSOLE_PORT
Hardware data structure headers User Definable configuration
◆ set_vector()
This method installs an interrupt handle.
- Parameters
    | [in] | handler | is the isr routine  |
    | [in] | vector | is the vector number  |
    | [in] | type | indicates whether RTEMS or RAW intr |
- Returns
 - returns old vector
